  4. Hilfe beim Zigbee Controller mit Sonoff Zigbee 3.0
31 Beiträge 4 Kommentatoren 4.0k Aufrufe 3 Beobachtet
  • Jan LangeJ Jan Lange
    als COM Id habe ich hinterlegt "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124092219-if00"
    total 0
    drwxr-xr-x 2 root root 60 May 31 13:08 .
    drwxr-xr-x 4 root root 80 May 31 13:08 ..
    lrwxrwxrwx 1 root root 13 May 31 13:08 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124092219-if00 -> ../../ttyACM0
    Hier der Log aus der Console
    2024-05-31 14:36:03.302  - info: host.raspberry4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-05-31 14:36:03.340  - info: admin.0 (2912) <== Disconnect system.user.admin from ::ffff:192.168.0.23
    2024-05-31 14:36:02.563  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-05-31 14:36:02.571  - info: zigbee.0 (3717) Got terminate signal TERMINATE_YOURSELF
    2024-05-31 14:36:02.602  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 send kill signal
    2024-05-31 14:36:02.575  - info: zigbee.0 (3717) cleaned everything up...
    2024-05-31 14:36:02.582  - info: zigbee.0 (3717) Zigbee: disabling joining new devices.
    2024-05-31 14:36:02.634  - warn: zigbee.0 (3717) Failed to stop zigbee during startup
    2024-05-31 14:36:02.635  - info: zigbee.0 (3717) terminating
    2024-05-31 14:36:02.636  - info: zigbee.0 (3717) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-05-31 14:36:03.076  - info: zigbee.0 (3717) terminating
    2024-05-31 14:36:05.672  - info: host.raspberry4 instance system.adapter.zigbee.0 started with pid 3768
    2024-05-31 14:36:10.832  - info: zigbee.0 (3768) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
    2024-05-31 14:36:10.939  - info: zigbee.0 (3768) delete old Backup files. keep only last 10
    2024-05-31 14:36:10.942  - info: zigbee.0 (3768) Starting Zigbee  npm ...
    2024-05-31 14:36:11.303  - info: zigbee.0 (3768) Installed Version: iobroker.zigbee@1.10.3
    2024-05-31 14:36:15.301  - error: zigbee.0 (3768) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2024-05-31 14:36:15.302  - error: zigbee.0 (3768) Failed to start Zigbee
    2024-05-31 14:36:15.303  - error: zigbee.0 (3768) Error herdsman start
    @jan-lange sagte in Hilfe beim Zigbee Controller mit Sonoff Zigbee 3.0:
    Da ist die PanID, die extended PanID oder der Transportschlüssel falsch. Früher standen die Abweichungen mal im Log. Ist wohl irgendwann unter den Tisch gefallen.
    Jan LangeJ 2 Antworten Letzte Antwort
      Jan LangeJ Offline
      Jan LangeJ Offline
      Jan Lange
      Hier noch mal der Log mit debug Info:
      2024-05-31 14:39:51.043  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-05-31 14:39:51.056  - info: zigbee.0 (3869) Got terminate signal TERMINATE_YOURSELF
      2024-05-31 14:39:51.061  - info: zigbee.0 (3869) cleaned everything up...
      2024-05-31 14:39:51.079  - info: zigbee.0 (3869) Zigbee: disabling joining new devices.
      2024-05-31 14:39:51.134  - warn: zigbee.0 (3869) Failed to stop zigbee during startup
      2024-05-31 14:39:51.134  - info: zigbee.0 (3869) terminating
      2024-05-31 14:39:51.136  - debug: zigbee.0 (3869) Plugin sentry destroyed
      2024-05-31 14:39:51.136  - info: zigbee.0 (3869) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-05-31 14:39:51.160  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 send kill signal
      2024-05-31 14:39:51.563  - info: zigbee.0 (3869) terminating
      2024-05-31 14:39:51.736  - info: host.raspberry4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-05-31 14:39:54.222  - info: host.raspberry4 instance system.adapter.zigbee.0 started with pid 3897
      2024-05-31 14:39:58.744  - debug: zigbee.0 (3897) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-05-31 14:39:58.800  - debug: zigbee.0 (3897) Objects client ready ... initialize now
      2024-05-31 14:39:58.804  - debug: zigbee.0 (3897) Objects create System PubSub Client
      2024-05-31 14:39:58.806  - debug: zigbee.0 (3897) Objects create User PubSub Client
      2024-05-31 14:39:58.887  - debug: zigbee.0 (3897) Objects client initialize lua scripts
      2024-05-31 14:39:58.900  - debug: zigbee.0 (3897) Objects connected to redis: 127.0.0.1:9001
      2024-05-31 14:39:58.949  - debug: zigbee.0 (3897) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-05-31 14:39:58.972  - debug: zigbee.0 (3897) States create System PubSub Client
      2024-05-31 14:39:58.974  - debug: zigbee.0 (3897) States create User PubSub Client
      2024-05-31 14:39:59.056  - debug: zigbee.0 (3897) States connected to redis: 127.0.0.1:9000
      2024-05-31 14:39:59.107  - debug: zigbee.0 (3897) Plugin sentry Initialize Plugin (enabled=true)
      2024-05-31 14:39:59.625  - info: zigbee.0 (3897) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
      2024-05-31 14:39:59.659  - debug: zigbee.0 (3897) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[208,221,220,221,221,210,222,173]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124092219-if00","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      2024-05-31 14:39:59.722  - info: zigbee.0 (3897) delete old Backup files. keep only last 10
      2024-05-31 14:39:59.724  - info: zigbee.0 (3897) Starting Zigbee  npm ...
      2024-05-31 14:39:59.778  - debug: zigbee.0 (3897) Starting zigbee-herdsman...
      2024-05-31 14:40:00.089  - info: zigbee.0 (3897) Installed Version: iobroker.zigbee@1.10.3
      2024-05-31 14:40:00.488  - debug: zigbee.0 (3897) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_05_31-14_39_59.tar.gz success
      2024-05-31 14:40:04.040  - error: zigbee.0 (3897) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      2024-05-31 14:40:04.042  - error: zigbee.0 (3897) Failed to start Zigbee
      2024-05-31 14:40:04.043  - error: zigbee.0 (3897) Error herdsman start
        Jan LangeJ Offline
        Jan LangeJ Offline
        Jan Lange
        das hatte ich ja auch vermutet. Nur wie finde ich raus welche die Richtigen sind?
          Keine Ahnung. Wie gesagt, früher stands mal im Log drin.
            total 0
            crunchipC Offline
            crunchipC Offline
            fehlt da nicht der Port?
              @crunchip
              Nein.
                @crunchip
                Nein.
                crunchipC Offline
                crunchipC Offline
                @thomas-braun ok, dann wäre vllt noch möglich
                Es ist zu achten dass am Ende kein leer Zeichen mitgenommen wird
                  @crunchip
                  Ja. Hier ist aber vermutlich das nvram/backup zu löschen.
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    @thomas-braun jep, hatte ich auch im parallel Thread geschrieben
                    Jan LangeJ 1 Antwort Letzte Antwort
                      Jan LangeJ Offline
                      Jan LangeJ Offline
                      Jan Lange
                      @crunchip
                      Also ich habe mal die Backup gelöscht wie der User in parallel Thread: Allerdings bringt das bei mir nichts.
                      rm: cannot remove '/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json': No such file or directory
                      In dem Ordner zigbee_0 liegt jedoch eine andere Backup Datei macht es Sinn diese mal zu löschen?
                      dir /opt/iobroker/iobroker-data/zigbee_0/
                      backup_2024_06_03-11_08_00.tar.gz  shepherd.db
                      Habe auch mal versucht die Default Werte zu nutzen. Bringt leider auch nichts.
                        @crunchip
                        Jan LangeJ Offline
                        Jan LangeJ Offline
                        Jan Lange
                        schrieb am zuletzt editiert von Jan Lange
                        Habs jetzt noch mal versucht und wenn ich den Typ ebenfalls auf den init Wert stehen lass, dann bekommt er die Verbindung aufgebaut. Aber auch wirklich nur dann und wie in dem anderen Post nur mit dem Standard Werten.
                        Habe inzwischen auch mal ein Conbee testen können. Da klappt alles problemlos.
