  4. Adapter lassen sich nicht mehr aktualisieren
23 Beiträge 6 Kommentatoren 3.1k Aufrufe 6 Beobachtet
    t1m0
    Grüße,
    seit ein paar Tagen bin ich nicht in der Lage irgendwelche updates durchzuführen. Ich habe, zumindest nicht wissentlich, irgendetwas geändert.
    Ich bekomme immer, egal welchen Adapter ich Updaten will, folgende Fehlermeldung:
    $ iobroker upgrade hm-rpc@1.17.0 --debug
    Update hm-rpc from @1.16.0 to @1.17.0
    NPM version: 10.5.0
    Installing iobroker.hm-rpc@1.17.0... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm ERR! code 127
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.npm WARN deprecated har-validator@5.1.5: this library is no longer supportednpm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.loghost.iobroker Cannot install iobroker.hm-rpc@1.17.0: 127
    ERROR: Process exited with code 25
    Mein System:
    pi@iobroker:~$ uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    /usr/bin/corepack
    v18.20.2
    v18.20.2
    10.5.0
    10.5.0
    0.25.2
    5.0.19
    pi
    pi cdrom floppy sudo audio dip video plugdev netdev iobroker
    tty
    /home/pi
    OK:1 http://security.debian.org/debian-security buster/updates InRelease
    OK:2 http://deb.debian.org/debian buster InRelease
    OK:3 http://deb.debian.org/debian buster-updates InRelease
    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Aktualisierung für 7 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
      Installiert:           18.20.2-1nodesource1
      Installationskandidat: 18.20.2-1nodesource1
      Versionstabelle:
     *** 18.20.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.20.1-1nodesource1 500
         18.20.0-1nodesource1 500
         18.19.1-1nodesource1 500
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         10.24.0~dfsg-1~deb10u4 500
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
    Über eure Hilfe wäre ich sehr Dankbar!
    DJMarc75D Thomas BraunT T 4 Antworten Letzte Antwort
    • T t1m0
      Grüße,
      NPM version: 10.5.0
      npm ERR! code 127
      Mein System:
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      /usr/bin/corepack
      v18.20.2
      v18.20.2
      10.5.0
      10.5.0
      0.25.2
      5.0.19
      pi
      tty
      /home/pi
      nodejs:
        Versionstabelle:
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @t1m0 BUSTER ist auch schon sehr, sehr lange tot ;)
      Wir sind mittlerweile bei BOOKWORM.
      Bring das auf Stand.
      Lehrling seit 1975 !!!
      • amg_666A Offline
        amg_666A Offline
        amg_666
        @t1m0 sagte in Adapter lassen sich nicht mehr aktualisieren:
        Kannst du diesen Log mal posten? und ich würde auch mal iobroker fix über das System laufen lassen.
        • T t1m0
          Grüße,
          NPM version: 10.5.0
          npm ERR! code 127
          Mein System:
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          /usr/bin/corepack
          v18.20.2
          v18.20.2
          10.5.0
          10.5.0
          0.25.2
          5.0.19
          pi
          tty
          /home/pi
          nodejs:
            Versionstabelle:
          Joh, aber dein Betriebssystem hättest du ganz wissentlich aktualisieren dürfen. Buster ist seit September 2022 abgekündigt. Höchste Zeit von dem toten Gaul herunterzusteigen.
          • amg_666A amg_666
            t1m0
            @amg_666 said in Adapter lassen sich nicht mehr aktualisieren:
            schon probiert, bringt nix :/
            pi@iobroker:~$ nano /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
              GNU nano 3.2        /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@10.5.0
            2 info using node@v18.20.2
            3 timing npm:load:whichnode Completed in 2ms
            4 timing config:load:defaults Completed in 2ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
            6 timing config:load:builtin Completed in 0ms
            7 timing config:load:cli Completed in 3ms
            8 timing config:load:env Completed in 0ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
            10 timing config:load:project Completed in 7ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
            12 timing config:load:user Completed in 0ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 0ms
            15 timing config:load:setEnvs Completed in 1ms
            16 timing config:load Completed in 13ms
            17 timing npm:load:configload Completed in 13ms
            18 timing config:load:flatten Completed in 2ms
            19 timing npm:load:mkdirpcache Completed in 0ms
            20 timing npm:load:mkdirplogs Completed in 0ms
            21 verbose title npm install iobroker.hm-rpc@1.17.0
            22 verbose argv "install" "--save-exact" "iobroker.hm-rpc@1.17.0"
            23 timing npm:load:setTitle Completed in 0ms
            24 timing npm:load:display Completed in 1ms
            25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-
            26 verbose logfile /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
            27 timing npm:load:logFile Completed in 6ms
            28 timing npm:load:timers Completed in 0ms
            29 timing npm:load:configScope Completed in 0ms
            30 timing npm:load Completed in 34ms
            31 timing arborist:ctor Completed in 0ms
            32 silly logfile start cleaning logs, removing 3 files
            33 timing idealTree:init Completed in 7ms
            34 timing idealTree:userRequests Completed in 3ms
            35 silly idealTree buildDeps
            36 silly fetch manifest colors@^1.3.2
            37 silly logfile done cleaning log files
            38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            39 http fetch GET 200 https://registry.npmjs.org/colors 575ms (cache revalidated)
            40 silly fetch manifest fs-extra@^7.0.0
            41 http fetch GET 200 https://registry.npmjs.org/fs-extra 160ms (cache revalidated)
            42 silly fetch manifest iobroker.acme@0.1.2
            43 http fetch GET 200 https://registry.npmjs.org/iobroker.acme 567ms (cache revalidated)
            44 silly fetch manifest iobroker.admin@6.13.16
            45 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 592ms (cache revalidated)
            46 silly fetch manifest iobroker.alexa2@3.26.4
            47 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 591ms (cache revalidated)
            48 silly fetch manifest iobroker.alias-manager@1.2.6
            49 http fetch GET 200 https://registry.npmjs.org/iobroker.alias-manager 561ms (cache revalidated)
            50 silly fetch manifest iobroker.amazon-dash@1.2.0
            51 http fetch GET 200 https://registry.npmjs.org/iobroker.amazon-dash 581ms (cache revalidated)
            52 silly fetch manifest iobroker.backitup@2.9.8
            53 http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 568ms (cache revalidated)
            54 silly fetch manifest iobroker.ble@0.13.4
            55 http fetch GET 200 https://registry.npmjs.org/iobroker.ble 225ms (cache revalidated)
            56 silly fetch manifest iobroker.broadlink2@2.1.5
            57 http fetch GET 200 https://registry.npmjs.org/iobroker.broadlink2 591ms (cache revalidated)
              t1m0
              @thomas-braun okay, danke! War da nie dran. Werde das dann mal probieren 😵
              • DJMarc75D DJMarc75
                t1m0
                @djmarc75 ich werde es mal versuchen und berichten
                • T t1m0
                  War da nie dran.
                  Das sieht man...
                  Das Log ist nicht vollständig.
                  • T t1m0
                    Meister MopperM Online
                    Meister Mopper
                    Ja, da gibt es hier im Forum gefühlt zehntausend Beiträge für Systemupgrades. Einfach suchen und das Problem selbst lösen.
                    Proxmox und HA ...
                    • T t1m0
                      Grüße,
                      NPM version: 10.5.0
                      npm ERR! code 127
                      Mein System:
                      x86_64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      /usr/bin/corepack
                      v18.20.2
                      v18.20.2
                      10.5.0
                      10.5.0
                      0.25.2
                      5.0.19
                      pi
                      tty
                      /home/pi
                      nodejs:
                        Versionstabelle:
                      t1m0
                      schrieb am zuletzt editiert von t1m0
                      So ich habe nun alles auf den neuesten Stand gebracht (hoffe ich zumindest).
                      Trotzdem bekomme ich weiterhin diese Fehlermeldung...
                      $ iobroker upgrade alexa2@3.26.5
                      Update alexa2 from @3.26.4 to @3.26.5
                      NPM version: 10.5.0Installing iobroker.alexa2@3.26.5... (System call)
                      npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T20_53_59_908Z-debug-0.loghost.iobroker Cannot install iobroker.alexa2@3.26.5: 127
                      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      pi@iobroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      x86_64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v18.20.2
                      v18.20.2
                      10.5.0
                      5.0.19
                      pi
                      /home/pi
                      OK:1 http://deb.debian.org/debian bookworm InRelease
                      OK:2 http://security.debian.org/debian-security bookworm-security InRelease
                      OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                      Alle Pakete sind aktuell.
                      nodejs:
                        Versionstabelle:
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      pi@iobroker:~$
                      • T t1m0
                        x86_64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v18.20.2
                        v18.20.2
                        10.5.0
                        5.0.19
                        pi
                        /home/pi
                        nodejs:
                          Versionstabelle:
                             18.13.0+dfsg1-1 500
                        pi@iobroker:~$
                        @t1m0
                        Gib mal die Langfassung von
                        iob diag
                        bekannt.
                        • T t1m0
                          x86_64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v18.20.2
                          v18.20.2
                          10.5.0
                          5.0.19
                          pi
                          /home/pi
                          nodejs:
                            Versionstabelle:
                               18.13.0+dfsg1-1 500
                          pi@iobroker:~$
                          node-waf
                          Das Ding macht seit einiger Zeit Trouble. Siehe auch hier:
                          https://forum.iobroker.net/topic/73800/iobroker-exit-25-bei-adapter-update
                            @t1m0
                            iob diag
                            bekannt.
                            t1m0
                            Skript v.2024-04-21
                            *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer-vm
                                     Chassis: vm 🖴
                              Virtualization: kvm
                                      Kernel: Linux 6.1.0-21-amd64
                                Architecture: x86-64
                             Hardware Vendor: QEMU
                              Hardware Model: Standard PC _i440FX + PIIX, 1996_
                            Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                            model name      : Common KVM processor
                            Docker          : false
                            Virtualization  : kvm
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             23:42:01 up 10 min,  2 users,  load average: 0.15, 0.30, 0.20
                            CPU threads: 4
                            *** Time and Time Zones ***
                                           Local time: Thu 2024-05-16 23:42:01 CEST
                                       Universal time: Thu 2024-05-16 21:42:01 UTC
                                             RTC time: Thu 2024-05-16 21:42:01
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            pi
                            HOME=/home/pi
                            GROUPS=pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev bluetooth
                            *** Display-Server-Setup ***
                            pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                            Try `pgrep -f' option to match against the complete command line.
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            6.2G        2.6G        2.7G        544K        1.1G        3.6G
                            Swap:           5.4G          0B        5.4G
                            Total:           11G        2.6G        8.1G
                            Active iob-Instances:   31
                                     5925 M total memory
                                     2523 M used memory
                                      374 M active memory
                                     2621 M inactive memory
                                     2583 M free memory
                                      156 M buffer memory
                                      938 M swap cache
                                     5117 M total swap
                                        0 M used swap
                                     5117 M free swap
                            top - 23:42:01 up 10 min,  2 users,  load average: 0.15, 0.30, 0.20
                            Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   5925.2 total,   2583.4 free,   2523.1 used,   1094.5 buff/cache
                            MiB Swap:   5118.0 total,   5118.0 free,      0.0 used.   3402.1 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            udev           devtmpfs  2.9G     0  2.9G   0% /dev
                            tmpfs          tmpfs     593M  536K  592M   1% /run
                            /dev/vda1      ext4       27G   19G  6.6G  74% /
                            tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
                            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                            tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
                            [Thu May 16 23:31:21 2024] EXT4-fs (vda1): mounted filesystem with ordered data mode. Quota mode: none.
                            [Thu May 16 23:31:22 2024] EXT4-fs (vda1): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET                                                  SOURCE      FSTYPE      OPTIONS
                            /                                                       /dev/vda1   ext4        rw,relatime,errors=remount-ro
                            |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                            | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                            | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                            |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                            | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13012
                            |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                            |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3014624k,nr_inodes=753656,mode=755,inode64
                            | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                            | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                            | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                            `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=606744k,mode=755,inode64
                              |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                              |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                              `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=606740k,nr_inodes=151685,mode=700,uid=1000,gid=1000,inode64
                            /var:
                            1.3G    /var/
                            1020M   /var/cache
                            1011M   /var/cache/apt
                            935M    /var/cache/apt/archives
                            179M    /var/lib
                            Archived and active journals take up 15.3M in the file system.
                            /opt/iobroker/backups:
                            7.2G    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            2.0G    /opt/iobroker/iobroker-data/
                            1.4G    /opt/iobroker/iobroker-data/sonosCache
                            289M    /opt/iobroker/iobroker-data/files
                            159M    /opt/iobroker/iobroker-data/backup-objects
                            57M     /opt/iobroker/iobroker-data/files/javascript.admin
                            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                            20M     /opt/iobroker/iobroker-data/objects.jsonl
                            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                            16M     /opt/iobroker/iobroker-data/objects.json.migrated
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            HINT:
                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f6cab8486cd9eb11a420178e6fe9f4d9-if00-port0
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.20.2
                            /usr/bin/node           v18.20.2
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            /usr/bin/corepack       0.25.2
                            nodejs:
                              Installed: 18.20.2-1nodesource1
                              Candidate: 18.20.2-1nodesource1
                              Version table:
                                 18.13.0+dfsg1-1 500
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  5.0.19
                            admin:          6.13.16
                            javascript:     7.8.0
                            nodejs modules from github:     1
                            |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                            + system.adapter.amazon-dash.0            : amazon-dash           : iobroker                                 -  enabled
                              system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                              system.adapter.ble.0                    : ble                   : iobroker                                 - disabled
                              system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
                              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                              system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                              system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                            + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                            + system.adapter.history.0                : history               : iobroker                                 -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12002
                            + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                            + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 443
                              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                              system.adapter.info.0                   : info                  : iobroker                                 - disabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                            + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
                            + system.adapter.milight-smart-light.1    : milight-smart-light   : iobroker                                 -  enabled
                              system.adapter.milight.0                : milight               : iobroker                                 - disabled, port: 5987
                              system.adapter.milight.1                : milight               : iobroker                                 - disabled, port: 5987
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                              system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                              system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 - disabled
                              system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1337, bind: 10.0.0.9
                            + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                              system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                              system.adapter.tankerkoenig.1           : tankerkoenig          : iobroker                                 - disabled
                            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                              system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                            + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : iobroker                                 -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                              system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
                              system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                              system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
                              system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f6cab8486cd9eb11a420178e6fe9f4d9-if00-port0
                            + instance is alive
                            ioBroker-Repositories
                            Stable (default): http://download.iobroker.net/sources-dist.json
                            Installed ioBroker-Instances
                            Adapter    "acme"         : 0.1.2    , installed 0.1.2
                            Adapter    "admin"        : 6.13.16  , installed 6.13.16
                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                            Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                            Adapter    "backitup"     : 2.11.0   , installed 2.9.8  [Updatable]
                            Adapter    "ble"          : 0.14.0   , installed 0.13.4 [Updatable]
                            Adapter    "broadlink2"   : 2.2.0    , installed 2.1.5  [Updatable]
                            Adapter    "daswetter"    : 3.1.13   , installed 3.1.10 [Updatable]
                            Adapter    "devices"      : 1.1.5    , installed 1.1.5
                            Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                            Adapter    "doorbird"     : 1.5.0    , installed 1.3.1  [Updatable]
                            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                            Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
                            Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                            Adapter    "hue"          : 3.11.0   , installed 3.10.2 [Updatable]
                            Adapter    "ical"         : 1.14.3   , installed 1.13.3 [Updatable]
                            Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                            Controller "js-controller": 5.0.19   , installed 5.0.19
                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.0  [Updatable]
                            Adapter    "milight"      : 0.4.0    , installed 0.4.0
                            Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "nut"          : 1.6.0    , installed 1.6.0
                            Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
                            Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
                            Adapter    "parser"       : 2.1.0    , installed 2.1.0
                            Adapter    "proxmox"      : 2.3.0    , installed 2.2.1  [Updatable]
                            Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
                            Adapter    "scenes"       : 2.3.9    , installed 2.3.9
                            Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
                            Adapter    "telegram"     : 3.2.1    , installed 3.0.1  [Updatable]
                            Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
                            Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                            Adapter    "unifi"        : 0.7.0    , installed 0.6.6  [Updatable]
                            Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
                            Adapter    "vis"          : 1.5.4    , installed 1.5.4
                            Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                            Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                            Adapter    "vis-justgage" : 2.1.7    , installed 2.0.2  [Updatable]
                            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                            Adapter    "vis-map"      : 1.0.5    , installed 1.0.4  [Updatable]
                            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                            Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                            Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                            Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
                            Objects and States
                            Objects:        23842
                            States:         20725
                            Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15559      471/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1864       1/init
                            tcp        0      0 0.0.0.0:42629           0.0.0.0:*               LISTEN      1001       19144      1127/io.yahka.1
                            tcp        0      0 10.0.0.9:12002          0.0.0.0:*               LISTEN      1001       17198      758/io.hm-rpc.1
                            tcp        0      0 10.0.0.9:12001          0.0.0.0:*               LISTEN      1001       16893      671/io.hm-rpc.0
                            tcp        0      0 10.0.0.9:8100           0.0.0.0:*               LISTEN      1001       18938      1021/io.doorbird.0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15608      448/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15601      448/iobroker.js-con
                            tcp        0      0 10.0.0.9:1337           0.0.0.0:*               LISTEN      1001       17663      824/io.sonoff.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          15561      471/sshd: /usr/sbin
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          1866       1/init
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15679      497/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18589      898/io.web.0
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18105      985/io.simple-api.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14120      411/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1865       1/init
                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16278      741/io.mihome-vacuu
                            udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       17893      882/io.mihome-vacuu
                            udp        0      0 0.0.0.0:57980           0.0.0.0:*                           1001       19514      1178/io.milight-sma
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15520      432/avahi-daemon: r
                            udp        0      0 0.0.0.0:38379           0.0.0.0:*                           106        15522      432/avahi-daemon: r
                            udp        0      0 0.0.0.0:1905            0.0.0.0:*                           1001       32778      706/io.sonos.0
                            udp        0      0 0.0.0.0:38880           0.0.0.0:*                           1001       19228      1161/io.milight-sma
                            udp6       0      0 :::111                  :::*                                0          1867       1/init
                            udp6       0      0 :::5353                 :::*                                106        15521      432/avahi-daemon: r
                            udp6       0      0 :::59121                :::*                                106        15523      432/avahi-daemon: r
                            2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) Got terminate signal TERMINATE_YOURSELF
                            2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) cleaned everything up...
                            2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) terminating
                            2024-05-16 23:34:01.581  - info: panasonic-comfort-cloud.0 (1145) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-05-16 23:34:01.623  - info: host.iobroker stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal
                            2024-05-16 23:34:02.081  - info: panasonic-comfort-cloud.0 (1145) terminating
                            2024-05-16 23:34:02.135  - info: host.iobroker instance system.adapter.panasonic-comfort-cloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-05-16 23:34:37.708  - info: sonoff.0 (824) Client [zwischensteckernous2] connected with secret 1715895277708_8747
                            2024-05-16 23:34:38.721  - info: sonoff.0 (824) Client [zwischensteckernous5] connected with secret 1715895278721_6036
                            2024-05-16 23:34:59.544  - info: mihome-vacuum.0 (741) create state for carpet_mode
                            2024-05-16 23:35:00.010  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1332
                            2024-05-16 23:35:00.820  - info: dwd.0 (1332) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                            2024-05-16 23:35:01.346  - info: dwd.0 (1332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-05-16 23:35:01.857  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-05-16 23:35:19.650  - info: mihome-vacuum.0 (741) change states from State control.fan_power
                            2024-05-16 23:35:19.650  - info: mihome-vacuum.0 (741) create states for water box
                            2024-05-16 23:36:01.350  - info: host.iobroker iobroker upgrade doorbird@1.5.0
                            2024-05-16 23:36:02.157  - info: host.iobroker iobroker Update doorbird from @1.3.1 to @1.5.0
                            2024-05-16 23:36:02.448  - info: host.iobroker iobroker NPM version: 10.5.0Installing iobroker.doorbird@1.5.0... (System call)
                            2024-05-16 23:39:32.894  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-16T21_36_02_664Z-debug-0.loghost.iobroker Cannot install iobroker.doorbird@1.5.0: 127
                            2024-05-16 23:39:33.904  - info: host.iobroker iobroker exit 25
                            2024-05-16 23:40:00.012  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2663
                            2024-05-16 23:40:00.853  - info: dwd.0 (2663) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                            2024-05-16 23:40:01.511  - info: dwd.0 (2663) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-05-16 23:40:02.022  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                                    v.2024-04-21
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            Installation:           kvm
                            Kernel:                 x86_64
                            Userland:               64 bit
                            Timezone:               Europe/Berlin (CEST, +0200)
                            User-ID:                1000
                            Pending OS-Updates:     0
                            Pending iob updates:    26
                            Nodejs-Installation:
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            Recommended versions are nodejs 18.20.2 and npm 10.5.0
                            MEMORY:
                            Mem:            6.2G        2.7G        2.7G        548K        1.1G        3.6G
                            Swap:           5.4G          0B        5.4G
                            Total:           11G        2.7G        8.1G
                            ioBroker Core:          js-controller           5.0.19
                                                    admin                   6.13.16
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                23842
                            States:                 20725
                            Size of iob-Database:
                            16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            6.4M    /opt/iobroker/iobroker-data/states.jsonl
                            4.6M    /opt/iobroker/iobroker-data/states.json.migrated
                            4.6M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            0       /opt/iobroker/iobroker-data/states.json.broken
                            • T t1m0
                              Skript v.2024-04-21
                              *** BASE SYSTEM ***
                                       Chassis: vm 🖴
                                Virtualization: kvm
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           5.4G          0B        5.4G
                                       5925 M total memory
                                       2523 M used memory
                                        374 M active memory
                                       2583 M free memory
                                        156 M buffer memory
                                        938 M swap cache
                                       5117 M total swap
                                          0 M used swap
                                       5117 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.3G    /var/
                              1020M   /var/cache
                              179M    /var/lib
                              USB-Devices by-id:
                              HINT:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        23842
                              States:         20725
                              Pending Updates: 0
                                                      v.2024-04-21
                                       Chassis: vm 🖴
                                Virtualization: kvm
                              Installation:           kvm
                              Kernel:                 x86_64
                              Userland:               64 bit
                              User-ID:                1000
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              MEMORY:
                              Swap:           5.4G          0B        5.4G
                                                      admin                   6.13.16
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                23842
                              States:                 20725
                              @t1m0
                              Da klemmt es:
                              Installier den homematic-Adapter nochmal.
                                @t1m0
                                Da klemmt es:
                                t1m0
                                Wie soll ich denn etwas neu installieren? Kann ich doch nicht. Oder meinst du es ändert sich, wenn ich die Adapter vorher lösche?
                                Habe 3Stk
                                • T t1m0
                                  Habe 3Stk
                                  @t1m0
                                  Versuch es mal über die Kommandozeile
                                  iobroker upgrade ADAPTERNAME@VERSIONSNUMMER
                                  €dit: Falschen Fehler korrigiert.
                                  HomoranH T 2 Antworten Letzte Antwort
                                    @t1m0
                                    @thomas-braun sagte in Adapter lassen sich nicht mehr aktualisieren:
                                    @t1m0
                                    iobroker update ADAPTERNAME@VERSIONSNUMMER
                                    @t1m0 am besten mit `--debug`` hinten dran. Und dann die Ausgabe posten
                                      @t1m0
                                      t1m0
                                      oder meinst du "upgrade"?
                                      pi@iobroker:~$ iobroker update zigbee@1.10.3 --debug
                                      Used repository: zigbee@1.10.3
                                      Error: unknown repository is active - "zigbee@1.10.3". Known: Stable (default)
                                      pi@iobroker:~$
                                      • T t1m0
                                        pi@iobroker:~$
                                        @t1m0
                                        Ja, sorry, hab aus dem Gedächtnis geschrieben.
                                        upgrade muss das heißen.
                                        Ich würde auch die homematic-Adapter ins Auge fassen, nicht den zigbee.
                                          @t1m0
                                          t1m0
                                          pi@iobroker:~$ iobroker upgrade hm-rpc@1.17.0 --debug
                                          This upgrade of "hm-rpc" will introduce the following changes:
                                          -> 1.17.0:
                                          Fixed encrypted configuration
                                          -> 1.16.1:
                                          Improved the configuration layout
                                          Would you like to upgrade hm-rpc from @1.16.0 to @1.17.0 now? [(y)es, (n)o]: y
                                          NPM version: 10.5.0
                                          npm ERR! code 127
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-17T09_55_38_815Z-debug-0.log
                                          npm ERR! code 127
                                          pi@iobroker:~$
