  5. Script mit "request" umbauen
7 Beiträge 3 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • Merlin123M Offline
    Merlin123M Offline
    Merlin123
    Ein ähnliches Problem gab es hier schon, aber ich kann mit der Lösung dort nichts anfangen :( Kann kein JS (bis jetzt)
    Hab folgendes Script
    const printerName = 'K1'; // Replace with your actual printer name
    const printerBaseUrl = 'http://192.168.0.252:7125'; // Replace with your actual moonraker ip
    const updateInterval = 20000; // 20 seconds
    // Function to make an HTTP request and return a promise
    function getPrinterStatus(url) {
        return new Promise((resolve, reject) => {
            const request = require('request');
            request(url, { json: true }, (err, res, body) => {
                if (err) {
                    reject(err);
                } else {
                    resolve(body);
    // Function to get metadata for the given filename
    function getFileMetadata(filename) {
        const metadataUrl = printerBaseUrl + `/server/files/metadata?filename=${encodeURIComponent(filename)}`;
        return getPrinterStatus(metadataUrl); // Reusing the HTTP request function
    // Function to convert seconds to HH:MM:SS
    function toHHMMSS(seconds) {
        const hours = Math.floor(seconds / 3600);
        const minutes = Math.floor((seconds % 3600) / 60);
        const sec = Math.floor(seconds % 60);
        return [hours, minutes, sec]
            .map(v => v < 10 ? "0" + v : v)
            .join(":");
    // Function to update the online status of the printer
    function updatePrinterOnlineStatus(isOnline) {
        const onlineStateName = `${printerName}.onlineStatus`;
        createOrUpdateState(onlineStateName, isOnline);
    // Function to create or update ioBroker states
    function createOrUpdateState(fullStateName, value, key='') {
        // Check if the key contains 'duration' and format it if it does
        if (key.includes('duration')) {
            value = toHHMMSS(value);
        // Check if the key contains 'progress' and multiply by 100 and round it if it does
        if (key.includes('progress')) {
            value = Math.round(value * 100); // Converts to percentage and rounds to the nearest integer
        if (!existsState(fullStateName)) {
            createState(fullStateName, {
                type: typeof value,
                read: true,
                write: false,
                desc: 'Printer status value'
                setState(fullStateName, value, true);
        } else {
    // Function to process the printer status and update the ioBroker states
    function processPrinterStatus(printerData, parentKey = '') {
        Object.keys(printerData).forEach(key => {
            const value = printerData[key];
            let fullStateName = `${printerName}`;
            if (parentKey) {
                fullStateName += `.${parentKey}`;
            fullStateName += `.${key}`;
            if (value !== null && typeof value === 'object' && !(value instanceof Array)) {
                // It's a nested object, so we need to recurse
                processPrinterStatus(value, key);
            } else {
                // It's a value, so we create or update the state
                createOrUpdateState(fullStateName, value, key);
    // Function to nullify file metadata states in ioBroker
    function nullifyFileMetadataStates() {
        var states = $(`*.${printerName}.file_metadata.*`/*Printer file metadata*/);
        states.each(function(id, i){
            setState(id, {val: null, ack: true});
    // Polling function
    function startPolling() {
        setInterval(() => {
            if (getState('sonoff.0.DVES_C38B13.POWER').val == true) getPrinterStatus(printerBaseUrl + '/printer/objects/query?display_status&print_stats&extruder&heater_bed&system_stats')
                .then(response => {
                    if (response && response.result) {
                        const printStats = response.result.status.print_stats || {};
                        const filename = printStats.filename;
                        // Update printer status
                        processPrinterStatus(response.result);
                        // If there is a filename, get and process the file metadata
                        if (filename) {
                            getFileMetadata(filename).then(metadataResponse => {
                                if (metadataResponse && metadataResponse.result) {
                                    processPrinterStatus(metadataResponse.result, 'file_metadata');
                            }).catch(error => {
                                console.error('Error fetching file metadata:', error);
                        } else {
                            // If filename is empty, nullify all file_metadata states
                            nullifyFileMetadataStates();
                        updatePrinterOnlineStatus(true); // Printer is online
                .catch(error => {
                    console.log('Error fetching printer status... setting Printer offline');
                    updatePrinterOnlineStatus(false); // Printer is offline
        }, updateInterval);
    // Start the polling process
    startPolling();
    Da soll das request raus.
    Hatte mit ChatGPT mein Glück versucht und den request block so ersetzt:
    const axios = require('axios');
        return axios.get(url)
            .then(response => response.data)
            .catch(error => {
                throw error;
    Reicht aber anscheinend nicht...
    Was muss ich da noch umbauen?
    Beta-Tester
    Merlin123M crunchipC haus-automatisierungH 3 Antworten Letzte Antwort
    • Merlin123M Merlin123
                  if (err) {
                      reject(err);
                  } else {
                      resolve(body);
              .join(":");
                  type: typeof value,
                  read: true,
                  write: false,
          } else {
              if (parentKey) {
              } else {
      // Polling function
          setInterval(() => {
                  .then(response => {
                          if (filename) {
                              }).catch(error => {
                          } else {
                  .catch(error => {
          }, updateInterval);
      startPolling();
              .catch(error => {
                  throw error;
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      @merlin123 Hab es jetzt mal anders umbauen lassen:
      const http = require('http');
              const req = http.get(url, (res) => {
                  let data = '';
                  // A chunk of data has been received
                  res.on('data', (chunk) => {
                      data += chunk;
                  // The whole response has been received
                  res.on('end', () => {
                      try {
                          const parsedData = JSON.parse(data);
                          resolve(parsedData);
                      } catch (error) {
                          reject(error);
              // Error handling for the request
              req.on('error', (error) => {
                  reject(error);
      Wirft zumindest nicht gleich nen Fehler. Mal testen, wenn ich das nächste Mal was drucke
      Beta-Tester
      Merlin123M 1 Antwort Letzte Antwort
                    let data = '';
                        data += chunk;
                        try {
                        } catch (error) {
                            reject(error);
                    reject(error);
        Merlin123M Offline
        Merlin123M Offline
        Merlin123
        War leider nix.... Wirft keinen Fehler, aber es geht leider nicht mehr :(
        Beta-Tester
                      if (err) {
                          reject(err);
                      } else {
                          resolve(body);
                  .join(":");
                      type: typeof value,
                      read: true,
                      write: false,
              } else {
                  if (parentKey) {
                  } else {
          // Polling function
              setInterval(() => {
                      .then(response => {
                              if (filename) {
                                  }).catch(error => {
                              } else {
                      .catch(error => {
              }, updateInterval);
          startPolling();
                  .catch(error => {
                      throw error;
          crunchipC Offline
          crunchipC Offline
          @merlin123 sagte in Script mit "request" umbauen:
          Kann kein JS
          ich auch nicht, aber denke das sollte so in etwas passen
          https://forum.iobroker.net/post/1159470
                        if (err) {
                            reject(err);
                        } else {
                            resolve(body);
                    .join(":");
                        type: typeof value,
                        read: true,
                        write: false,
                } else {
                    if (parentKey) {
                    } else {
            // Polling function
                setInterval(() => {
                        .then(response => {
                                if (filename) {
                                    }).catch(error => {
                                } else {
                        .catch(error => {
                }, updateInterval);
            startPolling();
                    .catch(error => {
                        throw error;
            haus-automatisierungH Offline
            @merlin123 Ungetestet, aber das wäre die Grundlage. Ginge auch mit httpGetAsync.
            async function getPrinterStatus(url) {
                    httpGet(url, { timeout: 2000 }, (err, response) => {
                        if (err) {
                            reject(err);
                        } else {
                            resolve(JSON.parse(response.data));
            async function getFileMetadata(filename) {
                return getPrinterStatus(`${printerBaseUrl}/server/files/metadata?filename=${encodeURIComponent(filename)}`); // Reusing the HTTP request function
                    .map(v => v < 10 ? '0' + v : v)
                    .join(':');
                createOrUpdateState(`${printerName}.onlineStatus`, isOnline);
                        type: typeof value,
                        read: true,
                        write: false,
                } else {
                    if (parentKey) {
                    } else {
                const states = $(`*.${printerName}.file_metadata.*`);
                states.each((id, i) => {
                    setState(id, { val: null, ack: true });
            // Polling function
                setInterval(() => {
                    if (getState('sonoff.0.DVES_C38B13.POWER').val) {
                        getPrinterStatus(`${printerBaseUrl}/printer/objects/query?display_status&print_stats&extruder&heater_bed&system_stats`)
                            .then(data => {
                                const printStats = data.status.print_stats || {};
                                processPrinterStatus(data);
                                if (filename) {
                                        .then(data => {
                                            processPrinterStatus(data, 'file_metadata');
                                        }).catch(error => {
                                } else {
                            .catch(error => {
                }, updateInterval);
            startPolling();
            📚 Meine Dokumentation
            Merlin123M 2 Antworten Letzte Antwort
                          if (err) {
                              reject(err);
                          } else {
                      .join(':');
                          type: typeof value,
                          read: true,
                          write: false,
                  } else {
                      if (parentKey) {
                      } else {
              // Polling function
                  setInterval(() => {
                              .then(data => {
                                  if (filename) {
                                          .then(data => {
                                          }).catch(error => {
                                  } else {
                              .catch(error => {
                  }, updateInterval);
              startPolling();
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              @haus-automatisierung Dank Dir! Werde es testen :)
              Beta-Tester
                            if (err) {
                                reject(err);
                            } else {
                        .join(':');
                            type: typeof value,
                            read: true,
                            write: false,
                    } else {
                        if (parentKey) {
                        } else {
                // Polling function
                    setInterval(() => {
                                .then(data => {
                                    if (filename) {
                                            .then(data => {
                                            }).catch(error => {
                                    } else {
                                .catch(error => {
                    }, updateInterval);
                startPolling();
                Merlin123M Offline
                Merlin123M Offline
                Merlin123
                @haus-automatisierung Auf den ersten Blick sieht es gut aus. Riesigen Dank! Ich schau mir das mal in Ruhe an und versuche es zu verstehen :)
                Beta-Tester
