  4. Iobroker startet nicht mehr nach Restore
59 Beiträge 5 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • B Bill S. Preston
    So, update ist fertig. Auch nach nem reboot des Systems ist der Broker still.
    @bill-s-preston
    iob diag
    sagt?
    B 1 Antwort Letzte Antwort
      @bill-s-preston
      iob diag
      sagt?
      Bill S. Preston
      @thomas-braun said in Iobroker startet nicht mehr nach Restore:
      @bill-s-preston
      iob diag
      sagt?
      Skript v.2024-04-21
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.28+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       14:34:15 up 4 min,  2 users,  load average: 0.83, 0.74, 0.33
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-05-06 14:34:15 CEST
                 Universal time: Mon 2024-05-06 12:34:15 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      herke
      HOME=/home/herke
      GROUPS=herke adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
      Try `pgrep -f' option to match against the complete command line.
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        641M        2.7G        1.2M        669M        3.3G
      Swap:           104M          0B        104M
      Total:          4.1G        641M        2.8G
      Active iob-Instances:   3
               3792 M total memory
                612 M used memory
                871 M active memory
                200 M inactive memory
               2613 M free memory
                 64 M buffer memory
                573 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 14:34:16 up 4 min,  2 users,  load average: 0.83, 0.74, 0.33
      Tasks: 186 total,   2 running, 184 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,   2612.8 free,    613.1 used,    638.6 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3178.9 avail Mem
      *** FAILED SERVICES ***
        UNIT              LOAD   ACTIVE SUB    DESCRIPTION
      * motioneye.service loaded failed failed motionEye Server
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4      117G  8.1G  103G   8% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Mon May  6 14:30:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:96:C0:F6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=03edf4a5-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Mon May  6 14:30:09 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Mon May  6 14:30:11 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2408
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671304k,nr_inodes=417826,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.9G    /var/
      1.3G    /var/lib
      1.1G    /var/lib/influxdb/data
      1015M   /var/lib/influxdb/data/iobroker/autogen
      Archived and active journals take up 175.7M in the file system.
      /opt/iobroker/backups:
      522M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      286M    /opt/iobroker/iobroker-data/
      210M    /opt/iobroker/iobroker-data/files
      60M     /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      8.2M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      nodejs modules from github:     1
      +-- iobroker.sourceanalytix@0.4.8-alpha.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#eacbbdeadf4c4bd44636743bc6f52dd21c6f0766)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
        system.adapter.email.0                  : email                 : raspberrypi                              - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
        system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 0
        system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              - disabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
        system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
      + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
        system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1882, bind: 192.168.178.23
        system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 0.0.0.0
        system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
        system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
        system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
        system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
        system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1883
        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
        system.adapter.zigbee.1                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "onvif"        : 1.1.3    , installed 1.1.3
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "shelly"       : 6.9.0    , installed 6.9.0
      Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        11125
      States:         9533
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        2951       752/influxd
      tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      108        5759       678/motion
      tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      108        5758       678/motion
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1685       682/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5871       833/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5864       833/iobroker.js-con
      tcp6       0      0 :::3000                 :::*                    LISTEN      107        1857       832/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1687       682/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      106        5841       752/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5931       876/io.admin.0
      udp        0      0 0.0.0.0:56049           0.0.0.0:*                           104        5664       534/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5662       534/avahi-daemon: r
      udp6       0      0 :::55982                :::*                                104        5665       534/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        5663       534/avahi-daemon: r
      2024-05-06 14:32:13.828  - error: host.raspberrypi iobroker npm-install: npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_04_539Z-debug-0.log
      2024-05-06 14:32:13.829  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@4.0.0: 127
      2024-05-06 14:32:14.856  - info: host.raspberrypi iobroker npm-install: exit 25
      2024-05-06 14:32:15.856  - warn: host.raspberrypi startInstance cannot find adapter "sayit@1.12.3". Try to install it... 3 attempt
      2024-05-06 14:32:15.857  - info: host.raspberrypi iobroker install sayit@1.12.3 using installedVersion
      2024-05-06 14:32:19.039  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0
      2024-05-06 14:32:19.042  - info: host.raspberrypi iobroker npm-install: Installing iobroker.sayit@1.12.3... (System call)
      2024-05-06 14:32:35.524  - error: host.raspberrypi iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.sayitnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! node:internal/modules/cjs/loader:1143npm ERR!   throw err;npm ERR!   ^npm ERR! npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'npm ERR! Require stack:npm ERR! - /opt/iobroker/node_modules/iobroker.sayit/main.jsnpm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)npm ERR!     at Module._load (node:internal/modules/cjs/loader:981:27)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1231:19)npm ERR!     at require (node:internal/modules/helpers:177:18)npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sayit/main.js:17:61)npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1364:14)npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)npm ERR!     at Module.load (node:internal/modules/cjs/loader:1203:32)npm ERR!     at Module._load (node:internal/modules/cjs/loader:1019:12)npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {npm ERR!   code: 'MODULE_NOT_FOUND',npm ERR!   requireStack: [ '/opt/iobroker/node_modules/iobroker.sayit/main.js' ]npm ERR! }npm ERR! npm ERR! Node.js v18.20.2npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_19_779Z-debug-0.log
      2024-05-06 14:32:35.525  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.sayit@1.12.3: 1
      2024-05-06 14:32:36.555  - info: host.raspberrypi iobroker npm-install: exit 25
      2024-05-06 14:32:37.556  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@4.0.0". Try to install it... 4 attempt
      2024-05-06 14:32:37.557  - info: host.raspberrypi iobroker install mihome-vacuum@4.0.0 using installedVersion
      2024-05-06 14:32:40.645  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0
      2024-05-06 14:32:40.647  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@4.0.0... (System call)
      2024-05-06 14:32:50.493  - error: host.raspberrypi iobroker npm-install: npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_41_399Z-debug-0.loghost.raspberrypi Cannot install iobroker.mihome-vacuum@4.0.0: 127
      2024-05-06 14:32:51.518  - info: host.raspberrypi iobroker npm-install: exit 25
      2024-05-06 14:32:52.519  - warn: host.raspberrypi startInstance cannot find adapter "sayit@1.12.3". Try to install it... 4 attempt
      2024-05-06 14:32:52.519  - info: host.raspberrypi iobroker install sayit@1.12.3 using installedVersion
      2024-05-06 14:32:55.668  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0
      2024-05-06 14:32:55.671  - info: host.raspberrypi iobroker npm-install: Installing iobroker.sayit@1.12.3... (System call)
      2024-05-06 14:33:11.937  - error: host.raspberrypi iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.sayitnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! node:internal/modules/cjs/loader:1143npm ERR!   throw err;npm ERR!   ^npm ERR! npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'npm ERR! Require stack:npm ERR! - /opt/iobroker/node_modules/iobroker.sayit/main.jsnpm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)npm ERR!     at Module._load (node:internal/modules/cjs/loader:981:27)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1231:19)npm ERR!     at require (node:internal/modules/helpers:177:18)npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sayit/main.js:17:61)npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1364:14)npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)npm ERR!     at Module.load (node:internal/modules/cjs/loader:1203:32)npm ERR!     at Module._load (node:internal/modules/cjs/loader:1019:12)npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {npm ERR!   code: 'MODULE_NOT_FOUND',npm ERR!   requireStack: [ '/opt/iobroker/node_modules/iobroker.sayit/main.js' ]npm ERR! }npm ERR! npm ERR! Node.js v18.20.2npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_56_377Z-debug-0.log
      2024-05-06 14:33:11.938  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.sayit@1.12.3: 1
      2024-05-06 14:33:12.966  - info: host.raspberrypi iobroker npm-install: exit 25
      2024-05-06 14:33:13.966  - error: host.raspberrypi Cannot download and install adapter "mihome-vacuum@4.0.0". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      2024-05-06 14:33:14.467  - error: host.raspberrypi Cannot download and install adapter "sayit@1.12.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      • B Bill S. Preston
        @bill-s-preston
        iob diag
        sagt?
        Skript v.2024-04-21
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        herke
        HOME=/home/herke
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           104M          0B        104M
                 3792 M total memory
                  612 M used memory
                  871 M active memory
                 2613 M free memory
                   64 M buffer memory
                  573 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        1.9G    /var/
        1.3G    /var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11125
        States:         9533
        Pending Updates: 0
        @bill-s-preston
        iob start web
        • B Bill S. Preston
          @bill-s-preston
          iob diag
          sagt?
          Skript v.2024-04-21
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          herke
          HOME=/home/herke
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           104M          0B        104M
                   3792 M total memory
                    612 M used memory
                    871 M active memory
                   2613 M free memory
                     64 M buffer memory
                    573 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          1.9G    /var/
          1.3G    /var/lib
          USB-Devices by-id:
          HINT:
          /dev/ttyACM0
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.13.16
          javascript:     7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11125
          States:         9533
          Pending Updates: 0
          crunchipC Offline
          crunchipC Offline
          @bill-s-preston sagte in Iobroker startet nicht mehr nach Restore:
          So viel ich weiß, müssen ggf Ports angepasst werden um Motioneye und iobroker zusammen auf einen Rechner laufen zu lassen
          Unabhängig davon, reichen 4GB RAM da eh nicht aus
          B crunchipC 2 Antworten Letzte Antwort
            @bill-s-preston
            iob start web
            Bill S. Preston
            @bill-s-preston
            iob start web
            Gemacht. Startet noch immer nicht.
              Bill S. Preston
              schrieb am zuletzt editiert von Bill S. Preston
              @crunchip said in Iobroker startet nicht mehr nach Restore:
              MoitonEye und Iobroker laufen seit zwei Jahren ohne Probleme zusammen auf einem 4GB Pi.
              Aber ich habe jetzt bei dem Neuen System versucht MotionEye zu öffnen. Leider ebenfalls Still.
              MotionEye lläuft aber auf Port 8765. Und wie gesagt, bis gestern vor dem Restore auch ohne Probleme.
              • B Bill S. Preston
                @bill-s-preston
                iob start web
                was genau?
                wie genau?
                was passiert?
                  was genau?
                  wie genau?
                  was passiert?
                  Bill S. Preston
                  @homoran said in Iobroker startet nicht mehr nach Restore:
                  was genau?
                  wie genau?
                  was passiert?
                  Iobroker über den Browser aufrufen (192.168.178.68:8081)
                  Firefox kann keine Verbindung zu dem Server unter 192.168.178.68:8081 aufbauen.
                  Bei MotionEye das gleiche.
                  • B Bill S. Preston
                    was genau?
                    wie genau?
                    was passiert?
                    welcher Browser?
                    und was exakt steht in der Adresszeile?
                    • Thomas BraunT Online
                      Der Service 'failed' ja auch.
                      Die Adapter 'ws' und 'socketio' bitte auch updaten.
                      War der 'socketio' nicht ohnehin obsolet?
                        welcher Browser?
                        Bill S. Preston
                        welcher Browser?
                        Unter Firefox und Chrome 192.168.178.68:8081 eingegeben.
                          Bill S. Preston
                          Kann es sein, dass sich das Backup vom alten System mit dem neuen beißt?
                          Hier
                          iob start web
                          vom alten noch laufenden System.
                          Skript v.2024-04-21
                          *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer
                            Operating System: Raspbian GNU/Linux 10 (buster)
                                      Kernel: Linux 5.10.103-v7l+
                                Architecture: arm
                          Model		: Raspberry Pi 4 Model B Rev 1.1
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : 32 bit
                           11:23:56 up 11:39,  2 users,  load average: 1.59, 1.08, 0.89
                          CPU threads: 4
                          Current issues:
                                         Local time: Mon 2024-05-06 11:23:56 CEST
                                     Universal time: Mon 2024-05-06 09:23:56 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          XDG_CONFIG_HOME=/home/pi/.config
                          HOME=/home/pi
                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker myftp
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video bluetooth gpio i2c myftp
                          Display-Server: true
                          Desktop: 	LXDE-pi
                          Terminal: 	x11
                          Boot Target: 	graphical.target
                          *** MEMORY ***
                          Mem:           3.8G        2.0G        260M         92M        1.6G        1.8G
                          Swap:           99M         42M         57M
                          Total:         3.9G        2.0G        317M
                          Active iob-Instances: 	34
                                   3838 M total memory
                                   1980 M used memory
                                    788 M active memory
                                   2619 M inactive memory
                                    259 M free memory
                                    272 M buffer memory
                                   1325 M swap cache
                                     99 M total swap
                                     42 M used swap
                                     57 M free swap
                          top - 11:23:57 up 11:39,  2 users,  load average: 1.59, 1.08, 0.89
                          Tasks: 209 total,   1 running, 207 sleeping,   0 stopped,   1 zombie
                          %Cpu(s):  7.2 us,  5.8 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3838.7 total,    259.5 free,   1980.4 used,   1598.8 buff/cache
                          MiB Swap:    100.0 total,     57.7 free,     42.2 used.   1826.4 avail Mem
                          * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
                          1 loaded units listed. Pass --all to see loaded but inactive units, too.
                          To show all installed unit files use 'systemctl list-unit-files'.
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G   22G   34G  40% /
                          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                          tmpfs          tmpfs     1.9G  864K  1.9G   1% /dev/shm
                          tmpfs          tmpfs     1.9G   57M  1.9G   3% /run
                          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                          /dev/sda1      ext4       57G   33G   21G  61% /backup
                          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                          tmpfs          tmpfs     384M  4.0K  384M   1% /run/user/1000
                          [Sun May  5 23:44:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1024x768M@60D smsc95xx.macaddr=DC:A6:32:30:EB:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5cd8a1b8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                          [Sun May  5 23:44:19 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                          [Sun May  5 23:44:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Sun May  5 23:44:22 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                          [Sun May  5 23:44:25 2024] EXT4-fs (sda1): recovery complete
                          [Sun May  5 23:44:25 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                          |-/dev                                devtmpfs       devtmpfs        rw,relatime,size=1800568k,nr_inodes=84157,mode=755
                          | `-/dev/mqueue                       mqueue         mqueue          rw,relatime
                          | |-/sys/fs/cgroup                    tmpfs          tmpfs           ro,nosuid,nodev,noexec,mode=755
                          | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate
                          | | |-/sys/fs/cgroup/systemd          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                          | | |-/sys/fs/cgroup/blkio            cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,blkio
                          | | |-/sys/fs/cgroup/pids             cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,pids
                          | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                          | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                          | | |-/sys/fs/cgroup/freezer          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,freezer
                          | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,perf_event
                          | | |-/sys/fs/cgroup/devices          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,devices
                          | | `-/sys/fs/cgroup/cpuset           cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpuset
                          | |-/sys/fs/bpf                       none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                          | |-/sys/kernel/debug                 debugfs        debugfs         rw,relatime
                          | |-/sys/kernel/config                configfs       configfs        rw,relatime
                          | `-/sys/fs/fuse/connections          fusectl        fusectl         rw,relatime
                          | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs          rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                          |-/run                                tmpfs          tmpfs           rw,nosuid,nodev,mode=755
                          | `-/run/user/1000                    tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
                          |   `-/run/user/1000/gvfs             gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                          |-/backup                             /dev/sda1      ext4            rw,relatime
                          `-/boot                               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          2.9G	/var/
                          1.4G	/var/lib
                          1.2G	/var/lib/influxdb/data
                          1.1G	/var/lib/influxdb/data/iobroker
                          Archived and active journals take up 55.9M in the file system.
                          6.3G	/opt/iobroker/backups/
                          414M	/opt/iobroker/iobroker-data/
                          195M	/opt/iobroker/iobroker-data/files
                          132M	/opt/iobroker/iobroker-data/backup-objects
                          51M	/opt/iobroker/iobroker-data/files/javascript.admin
                          33M	/opt/iobroker/iobroker-data/files/web.admin/static
                          22M	/opt/iobroker/iobroker-data/objects.jsonl
                          18M	/opt/iobroker/iobroker-data/states.jsonl
                          9.7M	/opt/iobroker/iobroker-data/objects.json.migrated
                          9.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100FNC-if03
                          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100FNC-if00
                          HINT:
                          /dev/ttyACM0
                          /usr/bin/npm 		10.5.0
                          /usr/bin/npx 		10.5.0
                          nodejs:
                            Version table:
                           *** 18.20.2-1nodesource1 600
                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                               18.20.1-1nodesource1 600
                               18.20.0-1nodesource1 600
                               18.19.1-1nodesource1 600
                               18.19.0-1nodesource1 600
                               18.18.2-1nodesource1 600
                               18.18.1-1nodesource1 600
                               18.18.0-1nodesource1 600
                               18.17.1-1nodesource1 600
                               18.17.0-1nodesource1 600
                               18.16.1-1nodesource1 600
                               18.16.0-1nodesource1 600
                               18.15.0-1nodesource1 600
                               18.14.2-1nodesource1 600
                               18.14.1-1nodesource1 600
                               18.14.0-1nodesource1 600
                               18.13.0-1nodesource1 600
                               18.12.0-1nodesource1 600
                               18.11.0-1nodesource1 600
                               18.10.0-1nodesource1 600
                               18.9.1-1nodesource1 600
                               18.9.0-1nodesource1 600
                               18.8.0-1nodesource1 600
                               18.7.0-1nodesource1 600
                               18.6.0-1nodesource1 600
                               18.5.0-1nodesource1 600
                               18.4.0-1nodesource1 600
                               18.3.0-1nodesource1 600
                               18.2.0-1nodesource1 600
                               18.1.0-1nodesource1 600
                               18.0.0-1nodesource1 600
                               10.24.0~dfsg-1~deb10u3 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          js-controller: 	4.0.24
                          admin: 		6.13.16
                          javascript: 	6.1.4
                          nodejs modules from github: 	0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                          + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.23
                          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                          + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
                          + system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                          + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883
                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                          + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                          + instance is alive
                          Adapter    "cloud"        : 5.0.1    , installed 4.1.0  [Updatable]
                          Adapter    "discovery"    : 4.4.0    , installed 2.6.1  [Updatable]
                          Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
                          Adapter    "email"        : 1.2.2    , installed 1.0.9  [Updatable]
                          Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                          Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
                          Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
                          Adapter    "heatingcontrol": 2.12.5  , installed 2.3.2  [Updatable]
                          Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.16 [Updatable]
                          Adapter    "ical"         : 1.14.3   , installed 1.7.4  [Updatable]
                          Adapter    "icons-mfd-svg": 1.2.0    , installed 1.0.2  [Updatable]
                          Adapter    "javascript"   : 7.8.0    , installed 6.1.4  [Updatable]
                          Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
                          Adapter    "lgtv"         : 2.2.0    , installed 2.1.1  [Updatable]
                          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                          Adapter    "mihome-vacuum": 4.2.0    , installed 4.0.0  [Updatable]
                          Adapter    "mqtt"         : 5.2.0    , installed 2.4.0  [Updatable]
                          Adapter    "onvif"        : 1.1.3    , installed 0.4.4  [Updatable]
                          Adapter    "openweathermap": 1.0.4   , installed 0.3.3  [Updatable]
                          Adapter    "paw"          : 0.3.2    , installed 0.3.2
                          Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
                          Adapter    "shelly"       : 6.9.0    , installed 6.3.1  [Updatable]
                          Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                          Adapter    "telegram"     : 3.2.1    , installed 1.8.1  [Updatable]
                          Adapter    "text2command" : 3.0.3    , installed 2.3.0  [Updatable]
                          Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                          Adapter    "vis-icontwo"  : 1.5.0    , installed 0.93.0 [Updatable]
                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                          Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
                          Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                          Adapter    "yr"           : 5.3.0    , installed 5.3.0
                          Objects and States
                          Objects: 	11713
                          States: 	10121
                          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Some index files failed to download. They have been ignored, or old ones used instead.
                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Get:2 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
                          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Err:2 https://repos.influxdata.com/debian buster InRelease
                          Fetched 12.9 kB in 2s (8498 B/s)
                          Pending Updates: 0
                          tcp        0      0 192.168.178.23:2001     0.0.0.0:*               LISTEN      1001       536573     3566/io.hm-rpc.3
                          tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      117        19738      705/proftpd: (accep
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18287      559/sshd
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          41534      3077/cupsd
                          tcp        0      0 0.0.0.0:5656            0.0.0.0:*               LISTEN      0          18860      779/motion
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19649      517/influxd
                          tcp        0      0 192.168.178.23:2010     0.0.0.0:*               LISTEN      1001       539134     3448/io.hm-rpc.1
                          tcp        0      0 192.168.178.23:1882     0.0.0.0:*               LISTEN      1001       539067     3394/io.mqtt.0
                          tcp        0      0 0.0.0.0:9595            0.0.0.0:*               LISTEN      0          18861      779/motion
                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       539216     3521/io.sonoff.0
                          tcp        0      0 192.168.178.23:8701     0.0.0.0:*               LISTEN      1001       539127     3441/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          18979      428/python2
                          tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14225      526/anydesk
                          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          18862      779/motion
                          tcp        0      0 0.0.0.0:38149           0.0.0.0:*               LISTEN      0          525839     526/anydesk
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       536192     3307/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       536185     3307/iobroker.js-co
                          tcp        0      0 192.168.178.23:9292     0.0.0.0:*               LISTEN      1001       541006     3463/io.hm-rpc.2
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       541910     3710/io.web.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        22642      517/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          18289      559/sshd
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          41533      3077/cupsd
                          tcp6       0      0 :::3000                 :::*                    LISTEN      110        20755      513/grafana-server
                          tcp6       0      0 :::7777                 :::*                    LISTEN      1001       538566     3325/io.admin.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       540354     3502/io.shelly.0
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19750      445/dhcpcd
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          41552      3079/cups-browsed
                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       541081     3536/io.mihome-vacu
                          udp        0      0 192.168.178.23:5353     0.0.0.0:*                           1001       539137     3420/io.tr-064.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17531      374/avahi-daemon: r
                          udp        0      0 0.0.0.0:47875           0.0.0.0:*                           108        17533      374/avahi-daemon: r
                          udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          22556      526/anydesk
                          udp6       0      0 :::5353                 :::*                                108        17532      374/avahi-daemon: r
                          udp6       0      0 :::33120                :::*                                108        17534      374/avahi-daemon: r
                          2024-05-06 11:24:16.473  - warn: javascript.0 (3382)     at processImmediate (node:internal/timers:476:21)
                          2024-05-06 11:24:16.473  - warn: javascript.0 (3382) State "javascript.0.Stromverbrauch.Stromkosten_vorheriger_Tag" not found
                          2024-05-06 11:24:16.475  - warn: javascript.0 (3382)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                          2024-05-06 11:24:16.475  - warn: javascript.0 (3382)     at Object.<anonymous> (script.js.Verbräuche.Stromverbrauch_gestern:5:3)
                          2024-05-06 11:24:16.477  - warn: javascript.0 (3382)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                          2024-05-06 11:24:16.477  - warn: javascript.0 (3382)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                          2024-05-06 11:24:16.478  - warn: javascript.0 (3382)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                          2024-05-06 11:24:16.478  - warn: javascript.0 (3382)     at processImmediate (node:internal/timers:476:21)
                          2024-05-06 11:24:21.813  - info: meross.0 (3483) Can not get Data for Device 1909127883156625186348e1e9034905: Error: Timeout
                          2024-05-06 11:24:21.814  - warn: meross.0 (3483) Can not get Data for Device 1909127883156625186348e1e9034905: undefined
                          2024-05-06 11:24:21.835  - info: meross.0 (3483) Can not get Data for Device 1801301547342725131134298f115e90: Error: Timeout
                          2024-05-06 11:24:21.836  - warn: meross.0 (3483) Can not get Data for Device 1801301547342725131134298f115e90: undefined
                          2024-05-06 11:24:21.864  - info: meross.0 (3483) Can not get Data for Device 1801306356734125131134298f115f59: Error: Timeout
                          2024-05-06 11:24:21.865  - warn: meross.0 (3483) Can not get Data for Device 1801306356734125131134298f115f59: undefined
                          2024-05-06 11:24:21.899  - info: meross.0 (3483) Can not get Data for Device 1801300540186725131134298f115ef4: Error: Timeout
                          2024-05-06 11:24:21.900  - warn: meross.0 (3483) Can not get Data for Device 1801300540186725131134298f115ef4: undefined
                          2024-05-06 11:24:40.484  - debug: onvif.0 (3778) startCameras
                          2024-05-06 11:24:40.521  - debug: onvif.0 (3778) getDevices: [{"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
                          2024-05-06 11:24:40.522  - debug: onvif.0 (3778) setCameras: [{"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
                          2024-05-06 11:24:40.523  - debug: onvif.0 (3778) classCam: item = {"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                          2024-05-06 11:24:43.681  - error: onvif.0 (3778) classCam. Camera/NVT: "192.168.178.47:8899" Error: connect EHOSTUNREACH 192.168.178.47:8899
                          2024-05-06 11:24:43.682  - debug: onvif.0 (3778) startCameras. cameras: {}
                          2024-05-06 11:24:43.682  - warn: onvif.0 (3778) startCameras: Cameras/NVT unavailables
                          2024-05-06 11:24:52.570  - warn: mqtt.0 (3394) Client [shelly1-E8DB84D496EE] has invalid password(h65cgi) or username(iobroker)
                          2024-05-06 11:25:08.865  - warn: telegram.0 (3790) 1 of 1 recipients are unknown!
                          Hier läuft noch der js-controller: 4.0.24. Im neuen ist der 5.0.19.
                          Wie update ich den ?
                          • B Bill S. Preston
                            Hier
                            iob start web
                            Skript v.2024-04-21
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : 32 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            iobroker
                            HOME=/home/iobroker
                            Desktop: 	LXDE-pi
                            Terminal: 	x11
                            *** MEMORY ***
                            Swap:           99M         42M         57M
                                     3838 M total memory
                                     1980 M used memory
                                      788 M active memory
                                      259 M free memory
                                      272 M buffer memory
                                     1325 M swap cache
                                       99 M total swap
                                       42 M used swap
                                       57 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.9G	/var/
                            1.4G	/var/lib
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyACM0
                            /usr/bin/npm 		10.5.0
                            /usr/bin/npx 		10.5.0
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.13.16
                            javascript: 	6.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	11713
                            States: 	10121
                            Pending Updates: 0
                            Das kann schon sein. Das Alt-System verdient sich diesen Namen ja ganz besonders...
                            Bring das zuerst mal auf Stand und dann ziehst du mit einem aktuellen Backup um.
                              Bill S. Preston
                              Wieso aktualisiert sich der js-controller mit
                              obroker stop
                              iobroker update
                              iobroker upgrade self
                              iobroker start
                              nicht?
                              • B Bill S. Preston
                                obroker stop
                                iobroker update
                                iobroker start
                                nicht?
                                @bill-s-preston
                                Ohne Meldungen kann dir das keiner sagen.
                                • B Bill S. Preston
                                  crunchipC Offline
                                  crunchipC Offline
                                  korrekt, die Benutzeroberfläche, die cams selbst aber dann 8081, 8082, 8083 usw
                                  daher auch auf deinem Alt System
                                    Bill S. Preston
                                    @crunchip
                                    cd /opt/iobroker
                                    sudo iobroker set admin.0 --port 7777
                                    hat geholfen. Iobroker kann wieder erreicht werden. 👍
                                    Nun fehlt noch MotionEye .
                                    Hier bekomme ich folgende meldung
                                    herke@raspberrypi:~ $ sudo systemctl status motioneye
                                    × motioneye.service - motionEye Server
                                         Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: en>
                                         Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s>
                                       Duration: 1.494s
                                        Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioney>
                                       Main PID: 1403 (code=exited, status=255/EXCEPTION)
                                            CPU: 1.493s
                                    May 07 07:55:22 raspberrypi systemd[1]: Started motioneye.service - motionEye S>
                                    May 07 07:55:23 raspberrypi meyectl[1403]: configure_logging cmd motioneye: Fal>
                                    May 07 07:55:23 raspberrypi meyectl[1403]: configure logging to file: None
                                    May 07 07:55:23 raspberrypi meyectl[1403]:     INFO: hello! this is motionEye s>
                                    May 07 07:55:23 raspberrypi meyectl[1403]: CRITICAL: pid directory "/var/run" d>
                                    May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Main process exited,>
                                    May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Failed with result '>
                                    May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Consumed 1.493s CPU >
                                    lines 1-16/16 (END)
                                         Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: enabled)
                                         Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s ago
                                       Duration: 1.494s
                                        Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioneye/moti>
                                            CPU: 1.493s
                                    Thomas BraunT crunchipC 3 Antworten Letzte Antwort
                                    • B Bill S. Preston
                                      @crunchip
                                      cd /opt/iobroker
                                         Duration: 1.494s
                                              CPU: 1.493s
                                      lines 1-16/16 (END)
                                         Duration: 1.494s
                                              CPU: 1.493s
                                      @bill-s-preston
                                      Bitte NIE, NIE, NIE das iobroker-Kommando per sudo anpacken.
                                      iob stop
                                      iob fix
                                      iob start
                                      • B Bill S. Preston
                                        @crunchip
                                        cd /opt/iobroker
                                           Duration: 1.494s
                                                CPU: 1.493s
                                        lines 1-16/16 (END)
                                           Duration: 1.494s
                                                CPU: 1.493s
                                        @bill-s-preston
                                        Und mach das Fenster von deinem Terminal groß. In der Ausgabe fehlen die Zeilenenden.
                                          @bill-s-preston
                                          iob stop
                                          iob fix
                                          iob start
                                          Bill S. Preston
                                          @bill-s-preston
                                          iob stop
                                          iob fix
                                          iob start
                                          Alles klar. Was kann passieren wenn sudo benutzt wird?
