  4. ioBroker friert ein: "Request actual repository...".....
81 Beiträge 10 Kommentatoren 13.5k Aufrufe 9 Beobachtet
  • L Lollo_C
    @djmarc75 sagte in ioBroker friert ein: "Request actual repository...".....:
    @lollo_c hast Du in Deiner Aufzählung auch Adapter die Scheduled sind ? z.B. Wetter oder so ?
    Ja, hier die aktuelle iob diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Static hostname: RasPi4
          Icon name: computer
             Kernel: Linux 6.1.0-rpi8-rpi-v8
       Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
    15:43:06 up  1:25,  2 users,  load average: 0.58, 0.61, 0.61
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                  Local time: Mon 2024-03-11 15:43:06 CET
              Universal time: Mon 2024-03-11 14:43:06 UTC
                    RTC time: n/a
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        2.6G        125M        1.2M        1.2G        1.3G
    Swap:           104M          0B        104M
    Total:          4.1G        2.6G        230M
            3792 M total memory
            2518 M used memory
            3119 M active memory
             411 M inactive memory
             119 M free memory
              94 M buffer memory
            1027 M swap cache
              99 M total swap
               0 M used swap
              99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/sda2      ext4      110G  9.3G   96G   9% /
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Mar 11 14:17:46 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A6:44:D3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a45a8ca6-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Mar 11 14:17:49 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Mar 11 14:17:50 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.0G    /var/
    4.0G    /var/log/journal/e4b3faf7370f4262b1b9aded77288404
    4.0G    /var/log
    538M    /var/cache
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    75M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    444M    /opt/iobroker/iobroker-data/
    315M    /opt/iobroker/iobroker-data/files
    92M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
     Installed: 18.19.1-1nodesource1
     Candidate: 18.19.1-1nodesource1
     Version table:
    *** 18.19.1-1nodesource1 1001
           500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           100 /var/lib/dpkg/status
        18.19.0+dfsg-6~deb12u1 500
        18.19.0-1nodesource1 1001
        18.18.2-1nodesource1 1001
        18.18.1-1nodesource1 1001
        18.18.0-1nodesource1 1001
        18.17.1-1nodesource1 1001
        18.17.0-1nodesource1 1001
        18.16.1-1nodesource1 1001
        18.16.0-1nodesource1 1001
        18.15.0-1nodesource1 1001
        18.14.2-1nodesource1 1001
        18.14.1-1nodesource1 1001
        18.14.0-1nodesource1 1001
        18.13.0+dfsg1-1 500
        18.13.0-1nodesource1 1001
        18.12.0-1nodesource1 1001
        18.11.0-1nodesource1 1001
        18.10.0-1nodesource1 1001
        18.9.1-1nodesource1 1001
        18.9.0-1nodesource1 1001
        18.8.0-1nodesource1 1001
        18.7.0-1nodesource1 1001
        18.6.0-1nodesource1 1001
        18.5.0-1nodesource1 1001
        18.4.0-1nodesource1 1001
        18.3.0-1nodesource1 1001
        18.2.0-1nodesource1 1001
        18.1.0-1nodesource1 1001
        18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : RasPi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RasPi4                                   -  enabled
     system.adapter.cloud.0                  : cloud                 : RasPi4                                   - disabled
     system.adapter.devices.0                : devices               : RasPi4                                   - disabled
    + system.adapter.discovery.0              : discovery             : RasPi4                                   -  enabled
     system.adapter.dwd.0                    : dwd                   : RasPi3                                   -  enabled
     system.adapter.flot.0                   : flot                  : RasPi4                                   - disabled
    + system.adapter.hm-rega.1                : hm-rega               : RasPi4                                   -  enabled
    + system.adapter.hm-rpc.2                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
    + system.adapter.hmip.0                   : hmip                  : RasPi4                                   -  enabled
     system.adapter.ical.0                   : ical                  : RasPi3                                   -  enabled
     system.adapter.icons-material-png.0     : icons-material-png    : RasPi4                                   - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPi4                                   - disabled
    + system.adapter.influxdb.0               : influxdb              : RasPi4                                   -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : RasPi4                                   -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : RasPi4                                   -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : RasPi4                                   -  enabled
     system.adapter.luftdaten.0              : luftdaten             : RasPi3                                   -  enabled
     system.adapter.luftdaten.1              : luftdaten             : RasPi3                                   -  enabled
     system.adapter.luftdaten.2              : luftdaten             : RasPi3                                   -  enabled
     system.adapter.mobile.0                 : mobile                : RasPi4                                   - disabled
    + system.adapter.modbus.0                 : modbus                : RasPi4                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : RasPi4                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : RasPi4                                   -  enabled
     system.adapter.openweathermap.0         : openweathermap        : RasPi3                                   -  enabled
    + system.adapter.owfs.0                   : owfs                  : RasPi3                                   -  enabled, port: 4304
    + system.adapter.ping.0                   : ping                  : RasPi4                                   -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : RasPi3                                   -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : RasPi4                                   -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : RasPi3                                   -  enabled
    + system.adapter.scenes.0                 : scenes                : RasPi4                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : RasPi4                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : RasPi4                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : RasPi3                                   -  enabled
    + system.adapter.socketio.0               : socketio              : RasPi4                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonos.0                  : sonos                 : RasPi4                                   -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : RasPi4                                   -  enabled
    + system.adapter.telegram.0               : telegram              : RasPi4                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : RasPi4                                   -  enabled
     system.adapter.vis-colorpicker.0        : vis-colorpicker       : RasPi4                                   - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : RasPi4                                   -  enabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPi4                                   - disabled
     system.adapter.vis-material-webfont.0   : vis-material-webfont  : RasPi4                                   - disabled
     system.adapter.vis-material.0           : vis-material          : RasPi4                                   - disabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi4                                   - disabled
     system.adapter.vis-metro.0              : vis-metro             : RasPi4                                   -  enabled
     system.adapter.vis-players.0            : vis-players           : RasPi4                                   - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : RasPi4                                   - disabled
     system.adapter.vis-weather.0            : vis-weather           : RasPi4                                   - disabled
     system.adapter.vis.0                    : vis                   : RasPi4                                   -  enabled
    + system.adapter.web.0                    : web                   : RasPi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
     system.adapter.ws.0                     : ws                    : RasPi4                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : RasPi4                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hmip"         : 1.22.0   , installed 1.22.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        11579
    States:         9829
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        14165      701/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21083      1266/io.shelly.0
    tcp        0      0 192.168.2.210:42010     0.0.0.0:*               LISTEN      1001       17373      1102/io.hm-rpc.2
    tcp        0      0 192.168.2.210:42001     0.0.0.0:*               LISTEN      1001       17404      1113/io.hm-rpc.3
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14264      866/iobroker.js-con
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15660      781/influxd
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      106        14181      683/redis-server 0.
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13023      716/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23226      1402/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14322      919/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25058      1413/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15692      781/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22921      1342/io.socketio.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      107        14166      701/mosquitto
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21134      1281/io.sonos.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      108        13141      865/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13034      716/sshd: /usr/sbin
    udp        0      0 0.0.0.0:50295           0.0.0.0:*                           104        15467      571/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15465      571/avahi-daemon: r
    udp6       0      0 fe80::5635:5d6e:3e1:546 :::*                                0          16488      633/NetworkManager
    udp6       0      0 :::41856                :::*                                104        15468      571/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        15466      571/avahi-daemon: r
    2024-03-11 15:29:01.020  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1710167341011,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167341011}
    2024-03-11 15:29:01.023  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1710167341011,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167341011}
    2024-03-11 15:29:01.045  - warn: javascript.0 (993) script.js.EIGENE_SCRIPTE.Lautsprecher.TP_favorites_set_Setzen_v2: Test_coordinatorSetzen oder favorites_setSetzen
    2024-03-11 15:29:20.606  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_45.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167360602,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167360602}
    2024-03-11 15:29:20.647  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_45.state with {"val":"play","ack":false,"ts":1710167360602,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167360602}
    2024-03-11 15:29:20.650  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_45.state_simple with {"val":true,"ack":false,"ts":1710167360602,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167360602}
    2024-03-11 15:29:25.205  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167365200,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167365200}
    2024-03-11 15:29:25.702  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state with {"val":"play","ack":false,"ts":1710167365699,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167365699}
    2024-03-11 15:29:25.708  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state_simple with {"val":true,"ack":false,"ts":1710167365700,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167365700}
    2024-03-11 15:34:39.853  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167679833,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167009005}
    2024-03-11 15:34:40.837  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"stop","ack":false,"ts":1710167680834,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167680834}
    2024-03-11 15:34:40.839  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":false,"ack":false,"ts":1710167680834,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167680834}
    2024-03-11 15:35:31.046  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167731042,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167009005}
    2024-03-11 15:35:31.087  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1710167731042,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167731042}
    2024-03-11 15:35:31.146  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1710167731142,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167731142}
    2024-03-11 15:36:19.839  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.coordinator with {"val":"192_168_2_41","ack":false,"ts":1710167779836,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167779836}
    2024-03-11 15:36:20.839  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state with {"val":"stop","ack":false,"ts":1710167780836,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167780836}
    2024-03-11 15:36:20.843  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state_simple with {"val":false,"ack":false,"ts":1710167780836,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167780836}
    2024-03-11 15:41:50.824  - info: admin.0 (919) <== Disconnect system.user.admin from ::ffff:192.168.2.74 javascript
    2024-03-11 15:41:59.163  - warn: admin.0 (919) dwd has an invalid jsonConfig: [{"instancePath":"/items/land/options/1","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/22/then/properties/options/items/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"noTranslation"},"message":"must NOT have additional properties"}]
    2024-03-11 15:44:08.937  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710168248931,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167009005}
    2024-03-11 15:44:09.761  - warn: javascript.0 (993) script.js.EIGENE_SCRIPTE.Lautsprecher.TP_favorites_set_Setzen_v2: Test_coordinatorSetzen oder favorites_setSetzen
    2024-03-11 15:44:10.105  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"stop","ack":false,"ts":1710168249930,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710168249701}
    2024-03-11 15:44:10.111  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":false,"ack":false,"ts":1710168249932,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710168249699}
    2024-03-11 15:44:24.608  - warn: host.RasPi4 too delayed answer for system.host.RasPi3
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @lollo_c sagte in ioBroker friert ein: "Request actual repository...".....:
    Ja
    Sehr gut dass du iob diag zeigst, aber wenn Du Scheduled-Adapter in Deiner Aufzählung hast dann kippt Dir Dein Skript um da diese Datenpunkte auf (null) gehen wenn der jeweilige Adapter sich wieder deaktiviert.
    Lehrling seit 1975 !!!
    L 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      Ja
      Lollo_C
      ... aber wenn Du Scheduled-Adapter in Deiner Aufzählung hast dann kippt Dir Dein Skript um da diese Datenpunkte auf (null) gehen wenn der jeweilige Adapter sich wieder deaktiviert.
      So ganz verstehe ich das nicht, da die zeitgesteuerten Adapter den Datenpunkt "connection" nicht haben und deshalb von dem Script auch nicht angesprochen werden.
      Wie dem auch sei, ich lasse das Script erst einmal deaktiviert und warte ab, was passiert.
      Mit freundlichen Grüßen und Glückauf
      Wilfried
      DJMarc75D L 2 Antworten Letzte Antwort
      • L Lollo_C
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        Aber klar hat jeder installierte Adapter den Datenpunkt "connected" - bis auf die VIS-Adapter, also Widgets-Adapter.
        Ich bau da heut noch was zusammen.
          CodierknechtC Offline
          Codierknecht
          Als JS wäre es einfach:
          const ids = Array.prototype.slice.apply($('state[id=system.*.*.*.connected]'));
          on({id: ids, change: 'ne'}, async function(obj) {
              let active = 0;
              let inactive = 0;
              for (let id of ids) {
                  const instanceObject = await getObjectAsync(id.replace('.connected', ''));
                  const scheduled = getAttr(instanceObject, 'common.schedule');
                  if (!scheduled) {
                      if (getState(id).val) {
                          active++
                      } else {
                          inactive++;
              log(`Aktive Instanzen: ${active}`);
              log(`Inaktive Instanzen: ${inactive}`);
              await setStateAsync('0_userdata.0.System.StatusInstanzen' , !inactive, true);
          Für Blockly fehlt mir gerade die Muße ;-)
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
                let active = 0;
                let inactive = 0;
                    if (!scheduled) {
                            active++
                        } else {
                            inactive++;
            haus-automatisierungH Offline
            schrieb am zuletzt editiert von haus-automatisierung
            Das Problem an diesem Script ist aber generell, dass man es regelmäßig neustarten muss damit alle Instanzen berücksichtigt werden. Und es könnte Probleme geben, wenn eine Instanz gelöscht wird (weil der State dann nicht mehr da ist, aber noch in der Liste steht).
            @codierknecht sagte in ioBroker friert ein: "Request actual repository...".....:
            Da würde ich eher auf den common.mode gehen und nur daemon berücksichtigen. Gibt ja neben Schedule auch noch einige andere.
            📚 Meine Dokumentation
              Codierknecht
              @haus-automatisierung
              Wie gesagt:
              Prinzip:
              Da führen - wie so oft - viele Wege nach Rom.
              @haus-automatisierung sagte in ioBroker friert ein: "Request actual repository...".....:
              Das ließe sich vermutlich auch noch irgendwie automatisieren.
              Ein bisschen Gehirnschmalz darf der TE da natürlich noch investieren 😁
              • L Lollo_C
                Lollo_C
                schrieb am zuletzt editiert von Lollo_C
                @lollo_c Hallo Zusammen,
                also an dem Script lag es offensichtlich nicht,. Obwohl es deaktiviert war hat der Raspi heute wieder seinen Dienst eingestellt: Symptome wie gehabt;
                • iobroker und Vis nicht erreichbar
                • Raspi rote LED an, grüne blinkt,
                • Ping antwortet sofort
                • mit Putty nicht erreichbar.
                Ich habe ihm eine Stunde Zeit gegeben und dann den Stecker gezogen. Nach dem Neustart ins Protokoll geschaut. Die letzten Einträge vor dem Crash waren wieder:
                2024-03-12 15:44:10.246 - info: admin.0 (919) Request actual repository...
                2024-03-12 15:44:12.765 - info: host.RasPi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                Jemand eine Idee, wie ich weitersuchen kann?
                Wilfried
                • L Lollo_C
                  Schau dir deine Lautsprecher-Skripte an. Nicht das du mit denen das System strangulierst.
                    Lollo_C
                    @thomas-braun sagte in ioBroker friert ein: "Request actual repository...".....:
                    Okay, ich habe die Scripte erst einmal alle deaktiviert. Mal sehen, was morgen passiert ;-)
                    Wilfried
                    • L Lollo_C
                      Lollo_C
                      Gestern lief der ioBroker durch. Aber heute kam es wieder zum Absturz. Im Log waren um 16:51 Uhr wieder die letzten Meldungen zu lesen:
                      2024-03-14 16:51:44.443 - info: admin.0 (900) Adapter rating updated
                      2024-03-14 16:52:07.331 - info: admin.0 (900) Request actual repository...
                      2024-03-14 16:52:10.859 - info: host.RasPi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      Danach wieder wie gehabt: ping i.O. ; mit Putty kein Zugriff. Um 17:41 habe ich dann den Stecker gezogen und der RasPi lief neu hoch. Beim betrachten der Logs fiel mir danach auf, dass der RasPi in der Zwischenzeit wohl doch was ins log geschrieben hat. Folgende Einträge sind von 17:31 Uhr:
                      2024-03-14 17:31:25.715 - info: host.RasPi4 iobroker.js-controller version 5.0.19 js-controller starting
                      2024-03-14 17:31:25.722 - info: host.RasPi4 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2024-03-14 17:31:25.723 - info: host.RasPi4 hostname: RasPi4, node: v18.19.1
                      2024-03-14 17:31:25.724 - info: host.RasPi4 ip addresses: 192.168.2.210 2003:e0:9712:9a00:a47e:4086:36a5:a208 fe80::5635:5d6e:3e15:cb7e
                      2024-03-14 17:31:27.258 - info: host.RasPi4 connected to Objects and States
                      2024-03-14 17:31:27.288 - info: host.RasPi4 added notifications configuration of host
                      2024-03-14 17:31:28.283 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.nodeCurrent"
                      2024-03-14 17:31:28.287 - info: host.RasPi4 55 instances found
                      2024-03-14 17:31:28.368 - info: host.RasPi4 starting 28 instances
                      2024-03-14 17:31:28.381 - warn: host.RasPi4 startInstance cannot find adapter "vis-material-webfont@0.0.3". Try to install it... 1 attempt
                      2024-03-14 17:31:28.383 - info: host.RasPi4 iobroker install vis-material-webfont@0.0.3 using installedFrom
                      2024-03-14 17:31:28.572 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.nodeNewest"
                      2024-03-14 17:31:28.591 - info: host.RasPi4 instance system.adapter.admin.0 started with pid 898
                      2024-03-14 17:31:28.623 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.nodeNewestNext"
                      2024-03-14 17:31:28.633 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.npmCurrent"
                      2024-03-14 17:31:28.641 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.npmNewest"
                      2024-03-14 17:31:28.650 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.npmNewestNext"
                      2024-03-14 17:31:28.658 - info: host.RasPi4 Some obsolete host states deleted.
                      2024-03-14 17:31:31.746 - error: host.RasPi4 iobroker npm-install: host.RasPi4 Unknown packetName vis-material-webfont. Please install packages from outside the repository using npm!
                      2024-03-14 17:31:32.513 - info: host.RasPi4 instance system.adapter.influxdb.0 started with pid 909
                      2024-03-14 17:31:32.803 - info: host.RasPi4 iobroker npm-install: exit 12
                      2024-03-14 17:31:32.957 - info: admin.0 (898) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
                      2024-03-14 17:31:33.009 - info: admin.0 (898) requesting all objects
                      2024-03-14 17:31:36.174 - info: admin.0 (898) received all objects
                      2024-03-14 17:31:36.561 - info: host.RasPi4 instance system.adapter.influxdb.1 started with pid 932
                      2024-03-14 17:31:36.754 - info: admin.0 (898) Request actual repository...
                      2024-03-14 17:31:36.826 - info: admin.0 (898) socket.io server listening on port 8081
                      2024-03-14 17:31:36.843 - info: admin.0 (898) http server listening on port 8081
                      2024-03-14 17:31:36.844 - info: admin.0 (898) Use link "http://127.0.0.1:8081" to configure.
                      2024-03-14 17:31:39.474 - info: influxdb.0 (909) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v18.19.1, js-controller: 5.0.19
                      2024-03-14 17:31:39.518 - info: influxdb.0 (909) No stored data from last exit found
                      2024-03-14 17:31:39.522 - info: influxdb.0 (909) Connecting http://localhost:8086/ ...
                      2024-03-14 17:31:39.523 - info: influxdb.0 (909) Influx DB Version used: 1.x
                      Dann folgt eine ganze Auflistung bei der alle geloggten Datenpunkte der influxdb aufgelistet sind. Gefolgt von eine Auflistung aller Scripte im javascript-Adapter und dann den Homematic usw. Adapter.
                      Würde mich über den nächsten Tipp zur Fehlersuche sehr freuen.
                      Wilfried
                      • L Lollo_C
                        nicht unbedingt!
                        der Raspi hat keine Batteriegepufferte Echtzeituhr.
                        es kann also eine falsche Uhrzeit sein, bevorcder Pi sich per ntp wieder die richtige Zeit verschaffen konnte.
                          nicht unbedingt!
                          Lollo_C
                          @homoran sagte in ioBroker friert ein: "Request actual repository...".....:
                          nicht unbedingt!
                          Schade. Ich hatte schon die Hoffnung, dass ich nur nicht lange genug gewartet hätte. Kann ich denn sonst noch irgendwo sehen, waren der ioBroker eingefroren ist?
                          Wilfried
                          • L Lollo_C
                            nicht unbedingt!
                            @lollo_c hattest du das log aus den Dateien geholt?
                            (/opt/iobroker/logs)
                              Lollo_C
                              @homoran Ja, es ist aber mit dem aus dem ioBroker identisch.
                              Wilfried
                              • L Lollo_C
                                da sind aber mehrere
                                  Lollo_C
                                  @homoran Da sind die gz-Dateien der letzten Tage, die iobroker.2024-03-14.log, eine iobroker-audit.json und ein Ordner iobroker.current.log, den ich mit FileZilla nicht öffnen kann. Heruntergeladen ergibt er eine Text-Datei mit bekanntem Inhalt.
                                  Wo müsste ich suchen?
                                  Wilfried
                                  • L Lollo_C
                                    im log des gestrigen Tages, nicht im current.log
                                      Lollo_C
                                      @homoran Ich war jetzt etwas irritiert, da Du geschrieben hattest, es müsste noch andere Log-Dateien geben. Ich habe tatsächlich nur die selben log-Dateien, die auch im ioBroker angezeigt werden.FileZilla_logs_2024-03-15.jpg
                                      Ich schreibe auch einige Werte aus dem rpi-Adapter mit. Außer einer erhöhten CPU-Load nach dem Neustart und während des nächtlichen Backup kann ich da nichts erkennen. Schon gar nicht in dem Zeitraum 16:51 Uhr (vor dem einfrieren).
                                      Wo müsste ich jetzt weitersuchen?
                                      Wilfried
                                      • L Lollo_C
                                        Nach "Stecker raus" fängt der Log im iob üblicherweise erst mit dem Neustart an.
                                        Intetessant wäre das, was zuletzt davor kam.
                                        Ich hatte die Hoffnung dass in den Dateien etwas zu sehen sei.
                                        Ansonsten gäbe es noch ein Linux log, da kenne ich mich aber nicht mit aus.
                                          Lollo_C
                                          Ja, das betrifft aber nur die Protokolle im Admin des ioBroker. Wenn man die Log herunterläd bekommt man den kompletten Tag ab 0:00 Uhr.
                                          Interessant wäre das, was zuletzt davor kam.
                                          Das ist es ja: Jedesmal kamen, bevor der ioBroker einfror, folgende Meldungen:
                                          Für mich sieht das so aus, als wenn der Adapter ein aktuelles Repository anfordert und dann etwas in eine externe Datei ("http://download.iobroker.net/sources-dist.json") speichern will und dabei einfriert.
                                          Wie im Eingangspost erwähnt, habe ich das System erst am vergangenen Wochenende neu aufgesetzt. Dabei wurden auch alle Adapter usw. auf den neusten Stand gebracht. Mit den alten Versionen hatte ich das Problem nicht.
                                          Mir wäre nur wichtig, das Problem zu lösen, da ich demnächst in den Urlaub fahren möchte und aus der Ferne kann ich zwar per VPN in den ioBroker reingucken, aber ich kann keinen Stecker ziehen.
                                          Wilfried
