  4. ioBroker friert ein: "Request actual repository...".....
81 Beiträge 10 Kommentatoren 13.5k Aufrufe 9 Beobachtet
  • L Lollo_C
    @djmarc75 Sorry, dann habe ich die falsche Darstellung gewählt. Natürlich ist es ein Blockly:
      <variables>
        <variable id="0sMP]4h8G%L;e+hd;:J|">numberInstanzConnected</variable>
        <variable id="pAwkt}:^4Pi7YPKXTGH4">listWert</variable>
        <variable type="timeout" id="timeout2">timeout2</variable>
        <variable type="timeout" id="timeout">timeout</variable>
      </variables>
      <block type="comment" id="Jx6`69;o(.30WFP3kXmt" x="162" y="-413">
        <field name="COMMENT">ermittelt Anzahl der verbundenen Instanzen und schreibt Wert in DP</field>
        <next>
          <block type="on_ext" id="}VB0XElJb.2BM9QxK8/}">
            <value name="OID0">
              <shadow type="field_oid" id="zJi=!?Kwz{CViZIAfYft">
              </shadow>
              <block type="selector" id="_01=ovj:|:~HnLoS_Gkb">
                <field name="TEXT">state[id=system.*.*.*.*connected]</field>
              </block>
            </value>
            <statement name="STATEMENT">
              <block type="procedures_callnoreturn" id="vr$6N*G;}`^9.kPJx@pl">
                <mutation name="countInstanzConnected"></mutation>
              </block>
            </statement>
          </block>
        </next>
      </block>
      <block type="procedures_defnoreturn" id="KmT1LtI;Aa.OJU2ybgEh" x="163" y="-237">
        <field name="NAME">countInstanzConnected</field>
        <statement name="STACK">
          <block type="variables_set" id=",pNpcw)A5twc?hn(y4E(">
            <field name="VAR" id="0sMP]4h8G%L;e+hd;:J|">numberInstanzConnected</field>
            <value name="VALUE">
              <block type="math_number" id="5#BQ@[!(GNJ!_6ach$Z7">
                <field name="NUM">0</field>
              </block>
            </value>
            <next>
              <block type="controls_forEach" id="Ymgblw7x]]Nr0?.H4icU">
                <field name="VAR" id="pAwkt}:^4Pi7YPKXTGH4">listWert</field>
                <value name="LIST">
                  <block type="selector" id="(IlvbxQm+0Ugx);HgzM|">
                  </block>
                </value>
                <statement name="DO">
                  <block type="controls_if" id="=!L7$NG+lw7Q%/fRb-+A">
                    <value name="IF0">
                      <block type="logic_compare" id="db`Sv[U#v5@wN(uleUX/">
                        <field name="OP">EQ</field>
                        <value name="A">
                          <block type="get_value_var" id="$Bet4#W(`qj8i@1eE3:P">
                            <value name="OID">
                              <shadow type="text" id="d@gto=uVA*(8uxSZG:Vx">
                                <field name="TEXT"></field>
                              </shadow>
                              <block type="variables_get" id="]@(Ij`EmXA1gDaD%!Vg]">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="17dG-?_n1ca/EoUjSn[X">
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO0">
                      <block type="math_change" id="dou[/X!2XtHyuTU9ZN+Z">
                        <value name="DELTA">
                          <shadow type="math_number" id="m;o}zSNkreAqg:6na_Oa">
                            <field name="NUM">1</field>
                          </shadow>
                          <block type="math_number" id="!AcJDEEf{_?y,vcKAff*">
                          </block>
                        </value>
                        <next>
                          <block type="debug" id="qp*,#O:t}8@|/-s3zZXz" disabled="true">
                            <field name="Severity">warn</field>
                            <value name="TEXT">
                              <shadow type="text" id="VQnvxoop92S/5o_P=wh_">
                              </shadow>
                              <block type="get_value_var" id="*876w*rQNhI4FIsa[H}(">
                                <value name="OID">
                                  <shadow type="text" id="[A*g]~HTz5MW:.W[SzQO">
                                  </shadow>
                                  <block type="variables_get" id="EziRkFa!;%xydss*2^6q">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="update" id="(IkXj-95AM0d|u/Rj(3:">
                                <field name="OID">0_userdata.0.System.AnzahlInstanzenConnected</field>
                                  <block type="variables_get" id="O(;Ow0bAF!9|SJ+~)*``">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="comment" id="BY)7aa*12^m)L:zfqN1^" x="216" y="76">
        <field name="COMMENT">prüft, ob eine Instanz nicht erreichbar ist</field>
        <next>
          <block type="comment" id="6)_C7[s{+BZ`j(O_$uL*">
            <field name="COMMENT">Vorlage: https://www.machs-smart.de/iobroker-status-alive-connected-instanz-adapter-push-email/</field>
            <next>
              <block type="on_ext" id="?Q#4ffqYw~}cy,|wI|PF">
                <field name="CONDITION">lt</field>
                <value name="OID0">
                  <shadow type="field_oid" id="bSHTPdM,I)zz.I0i5;t)">
                  </shadow>
                  <block type="selector" id="^%WM-:8-TuX)Nbr{.W(h">
                  </block>
                </value>
                  <block type="timeouts_cleartimeout" id="Q#/@H4)RVPQ`Xc@tgkNA">
                    <next>
                      <block type="timeouts_settimeout_variable" id="=6@BuLMG8-u^.^izs5en">
                        <value name="DELAY_MS">
                          <shadow type="math_number" id="11C.yn(?7EHNW5N@Wj*e">
                            <field name="NUM">20000</field>
                          </shadow>
                        </value>
                          <block type="controls_if" id="5c8k:m!aO}vw9Q4c_y@^">
                            <value name="IF0">
                              <block type="logic_negate" id="g@LEx?}=Ci-.;i9jro)*">
                                <value name="BOOL">
                                  <block type="get_value_var" id="Ib$/aY5OL7l|71Z7cnDl">
                                    <value name="OID">
                                      <shadow type="text" id="U9A4!hC||;*rz)ydl-+p">
                                      </shadow>
                                      <block type="on_source" id=")8QNTcx%n]%YQ2h?%99*">
                                        <field name="ATTR">id</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="update" id=",%x{]kt1R7HolH.+Kp#m">
                                <field name="OID">0_userdata.0.System.StatusInstanzen</field>
                                  <block type="logic_boolean" id="ZdHVphkb)lP63n6BD#Zn">
                                  </block>
                                </value>
                                <next>
                                  <block type="telegram" id="!S!xfj,7!B?)hVp-64%:">
                                    <field name="LOG"></field>
                                    <field name="ESCAPING">FALSE</field>
                                    <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                                    <value name="MESSAGE">
                                      <shadow type="text" id="R];dOkU.y[2cGe0rWb8q">
                                        <field name="TEXT">Passat Wohnzimmer 24Grad</field>
                                      </shadow>
                                      <block type="text_join" id="1ugKNeEU-3K9qrT@ZCv=">
                                        <value name="ADD0">
                                          <block type="text" id="]tD=(Z]2O;i~o00,N}Wt">
                                            <field name="TEXT">ioBroker Instanz: </field>
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="on_source" id="o^=s,]$0(?FU%03Y?Z.2">
                                            <field name="ATTR">channelName</field>
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="text" id="AlHL~VBS,U)D!^MG2{)o">
                                            <field name="TEXT"> ist nicht erreichbar.</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="comment" id="[t=WW0lb4BP~dh2u6%LE" x="247" y="724">
        <field name="COMMENT">Setzt Datenpunkt, wenn alle Instanzen wieder erreichbar sind</field>
        <next>
          <block type="on_ext" id="hdWeRo_R%rr9DU84ozg0">
            <field name="CONDITION">gt</field>
            <value name="OID0">
              <shadow type="field_oid" id="2*lWyY-q6x3B+TaiFGb!">
              </shadow>
              <block type="selector" id="qI(L*MFb]#(uF7*BTFn:">
              </block>
            </value>
              <block type="timeouts_cleartimeout" id="`_RfunuRgSx,QX@$_e!z">
                <next>
                  <block type="timeouts_settimeout_variable" id="X]m7::y_-/TJ=0?,~h5o">
                    <field name="NAME">timeout2</field>
                      <shadow type="math_number" id="YI~c8[!dE4u]V|HG%qE%">
                      </shadow>
                    </value>
                      <block type="controls_if" id="kj4q4niol+3XN)mraxf_">
                        <value name="IF0">
                          <block type="get_value_var" id="L8ye$@4fB1-9Bz?.zbkN">
                            <value name="OID">
                              <shadow type="text" id="FmJ/0XpCs]z-)U..+|-W">
                              </shadow>
                              <block type="on_source" id="5g/Lcb3M)]D(PjpN1}R,">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="update" id="hW$27Y3?;N5:S-,d*6+/">
                              <block type="logic_boolean" id="8+J`^||kE6))e4UidYYl">
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @lollo_c sagte in ioBroker friert ein: "Request actual repository...".....:
    Man würde das gerne sehen ! XML ist wenig nützlich (am Handy und auch so) ;)
    Bitte einen Screenshot zeigen.
    Lehrling seit 1975 !!!
    • L Lollo_C
      @djmarc75 sagte in [ioBroker friert ein: "Request actual repository...".....]
      könnte man das mal sehen ?
      var numberInstanzConnected, listWert, timeout2, timeout;
      // Beschreibe diese Funktion …
      async function countInstanzConnected() {
        numberInstanzConnected = 0;
        var listWert_list = Array.prototype.slice.apply($('state[id=system.*.*.*.*connected]'));
        for (var listWert_index in listWert_list) {
          listWert = listWert_list[listWert_index];
          if (getState(listWert).val == true) {
            numberInstanzConnected = (typeof numberInstanzConnected === 'number' ? numberInstanzConnected : 0) + 1;
            setState('0_userdata.0.System.AnzahlInstanzenConnected' /* AnzahlInstanzenConnected */, numberInstanzConnected, true);
      // ermittelt Anzahl der verbundenen Instanzen und schreibt Wert in DP
      on({ id: [].concat(Array.prototype.slice.apply($('state[id=system.*.*.*.*connected]'))), change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        let oldValue = obj.oldState.val;
        await countInstanzConnected();
      // prüft, ob eine Instanz nicht erreichbar ist
      // Vorlage: https://www.machs-smart.de/iobroker-status-alive-connected-instanz-adapter-push-email/
      on({ id: [].concat(Array.prototype.slice.apply($('state[id=system.*.*.*.*connected]'))), change: 'lt' }, async (obj) => {
        (() => { if (timeout) { clearTimeout(timeout); timeout = null; }})();
        timeout = setTimeout(async () => {
          timeout = null;
          if (!getState(obj.id).val) {
            setState('0_userdata.0.System.StatusInstanzen' /* StatusInstanzen */, false, true);
            sendTo("telegram", "send", {
                text: (['ioBroker Instanz: ',obj.channelName,' ist nicht erreichbar.'].join(''))
        }, parseInt(20000));
      // Setzt Datenpunkt, wenn alle Instanzen wieder erreichbar sind
      on({ id: [].concat(Array.prototype.slice.apply($('state[id=system.*.*.*.*connected]'))), change: 'gt' }, async (obj) => {
        timeout2 = setTimeout(async () => {
          timeout2 = null;
          if (getState(obj.id).val) {
            setState('0_userdata.0.System.StatusInstanzen' /* StatusInstanzen */, true, true);
      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
      CodierknechtC Offline
      Codierknecht
      @lollo_c
      Warum 3 Trigger auf die gleichen States?
      Das kann man alles in nur einem einzigen Trigger behandeln.
      Edit
      ... wobei das in JS tatsächlich einfacher und eleganter wäre ;-)
      Prinzip:
      const ids = Array.prototype.slice.apply($('state[id=system.*.*.*.connected]'));
      on({id: ids, change: 'ne'}, async function(obj) {
          let active = 0;
          let inactive = 0;
          for (let id of ids) {
              if (getState(id).val) {
                  active++
              } else {
                  inactive++;
          log(`Aktive Instanzen: ${active}`);
          log(`Inaktive Instanzen: ${inactive}`);
          await setStateAsync('0_userdata.0.System.StatusInstanzen' , !inactive, true);
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        @lollo_c
        Edit
        Prinzip:
            let active = 0;
            let inactive = 0;
                    active++
                } else {
                    inactive++;
        @codierknecht
        @DJMarc75
        leider kein Bild 😢
        könnt ihr was sehen, was durch das einlesen des Repos zu Problemen führt?
        DJMarc75D CodierknechtC L 3 Antworten Letzte Antwort
          @codierknecht
          @DJMarc75
          leider kein Bild 😢
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @homoran sagte in ioBroker friert ein: "Request actual repository...".....:
          nö, in dem Skript nicht - ist aber ein ziemlich (naja) Triggerlasstiges Skript.
          Da wird 3 mal auf den gleichen DP getriggert und zusätzlich noch in einer Funktion.
          Ich versuch das grad mal irgendwie zu verstehn und umzubauen 😰
            @codierknecht
            @DJMarc75
            leider kein Bild 😢
            Codierknecht
            Krieg's nicht sauber importiert ... hab' kein Telegram.
              @codierknecht
              @DJMarc75
              leider kein Bild 😢
              Lollo_C
              schrieb am zuletzt editiert von Lollo_C
              leider kein Bild 😢
              Sorry, ich musste das Bild erst zusammensetzen:
              Ich hatte das Script so von machs-smart übernommen. Es hatte aber vor dem Neuaufsetzen und updaten des RasPi keine Probleme bereitet.
              Mit freundlichen Grüßen und Glückauf
              Wilfried
              • L Lollo_C
                leider kein Bild 😢
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @lollo_c hast Du in Deiner Aufzählung auch Adapter die Scheduled sind ? z.B. Wetter oder so ?
                L 1 Antwort Letzte Antwort
                • DJMarc75D DJMarc75
                  Lollo_C
                  @djmarc75 sagte in ioBroker friert ein: "Request actual repository...".....:
                  Ja, hier die aktuelle iob diag:
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                  Static hostname: RasPi4
                        Icon name: computer
                           Kernel: Linux 6.1.0-rpi8-rpi-v8
                     Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                  15:43:06 up  1:25,  2 users,  load average: 0.58, 0.61, 0.61
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                Local time: Mon 2024-03-11 15:43:06 CET
                            Universal time: Mon 2024-03-11 14:43:06 UTC
                                  RTC time: n/a
                               NTP service: active
                           RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            4.0G        2.6G        125M        1.2M        1.2G        1.3G
                  Swap:           104M          0B        104M
                  Total:          4.1G        2.6G        230M
                          3792 M total memory
                          2518 M used memory
                          3119 M active memory
                           411 M inactive memory
                           119 M free memory
                            94 M buffer memory
                          1027 M swap cache
                            99 M total swap
                             0 M used swap
                            99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                  /dev/sda2      ext4      110G  9.3G   96G   9% /
                  tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                  /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Mon Mar 11 14:17:46 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A6:44:D3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a45a8ca6-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Mon Mar 11 14:17:49 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Mon Mar 11 14:17:50 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  TARGET           SOURCE    FSTYPE OPTIONS
                  /                /dev/sda2 ext4   rw,noatime
                  `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  5.0G    /var/
                  4.0G    /var/log/journal/e4b3faf7370f4262b1b9aded77288404
                  4.0G    /var/log
                  538M    /var/cache
                  Archived and active journals take up 3.9G in the file system.
                  /opt/iobroker/backups:
                  75M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  444M    /opt/iobroker/iobroker-data/
                  315M    /opt/iobroker/iobroker-data/files
                  92M     /opt/iobroker/iobroker-data/backup-objects
                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                  45M     /opt/iobroker/iobroker-data/files/devices.admin/static
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  31M     /opt/iobroker/iobroker-data/objects.jsonl
                  22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                  8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.19.1
                  /usr/bin/node           v18.19.1
                  /usr/bin/npm            10.2.4
                  /usr/bin/npx            10.2.4
                  /usr/bin/corepack       0.22.0
                  nodejs:
                   Installed: 18.19.1-1nodesource1
                   Candidate: 18.19.1-1nodesource1
                   Version table:
                  *** 18.19.1-1nodesource1 1001
                         500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                      18.19.0+dfsg-6~deb12u1 500
                         500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                      18.19.0-1nodesource1 1001
                      18.18.2-1nodesource1 1001
                      18.18.1-1nodesource1 1001
                      18.18.0-1nodesource1 1001
                      18.17.1-1nodesource1 1001
                      18.17.0-1nodesource1 1001
                      18.16.1-1nodesource1 1001
                      18.16.0-1nodesource1 1001
                      18.15.0-1nodesource1 1001
                      18.14.2-1nodesource1 1001
                      18.14.1-1nodesource1 1001
                      18.14.0-1nodesource1 1001
                      18.13.0+dfsg1-1 500
                         500 http://deb.debian.org/debian bookworm/main arm64 Packages
                      18.13.0-1nodesource1 1001
                      18.12.0-1nodesource1 1001
                      18.11.0-1nodesource1 1001
                      18.10.0-1nodesource1 1001
                      18.9.1-1nodesource1 1001
                      18.9.0-1nodesource1 1001
                      18.8.0-1nodesource1 1001
                      18.7.0-1nodesource1 1001
                      18.6.0-1nodesource1 1001
                      18.5.0-1nodesource1 1001
                      18.4.0-1nodesource1 1001
                      18.3.0-1nodesource1 1001
                      18.2.0-1nodesource1 1001
                      18.1.0-1nodesource1 1001
                      18.0.0-1nodesource1 1001
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: redis
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapters from github:   1
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : RasPi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : RasPi4                                   -  enabled
                   system.adapter.cloud.0                  : cloud                 : RasPi4                                   - disabled
                   system.adapter.devices.0                : devices               : RasPi4                                   - disabled
                  + system.adapter.discovery.0              : discovery             : RasPi4                                   -  enabled
                   system.adapter.dwd.0                    : dwd                   : RasPi3                                   -  enabled
                   system.adapter.flot.0                   : flot                  : RasPi4                                   - disabled
                  + system.adapter.hm-rega.1                : hm-rega               : RasPi4                                   -  enabled
                  + system.adapter.hm-rpc.2                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
                  + system.adapter.hm-rpc.3                 : hm-rpc                : RasPi4                                   -  enabled, port: 0
                  + system.adapter.hmip.0                   : hmip                  : RasPi4                                   -  enabled
                   system.adapter.ical.0                   : ical                  : RasPi3                                   -  enabled
                   system.adapter.icons-material-png.0     : icons-material-png    : RasPi4                                   - disabled
                   system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPi4                                   - disabled
                  + system.adapter.influxdb.0               : influxdb              : RasPi4                                   -  enabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : RasPi4                                   -  enabled, port: 8086
                  + system.adapter.influxdb.2               : influxdb              : RasPi4                                   -  enabled, port: 8086
                  + system.adapter.javascript.0             : javascript            : RasPi4                                   -  enabled
                   system.adapter.luftdaten.0              : luftdaten             : RasPi3                                   -  enabled
                   system.adapter.luftdaten.1              : luftdaten             : RasPi3                                   -  enabled
                   system.adapter.luftdaten.2              : luftdaten             : RasPi3                                   -  enabled
                   system.adapter.mobile.0                 : mobile                : RasPi4                                   - disabled
                  + system.adapter.modbus.0                 : modbus                : RasPi4                                   -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : RasPi4                                   -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.nut.0                    : nut                   : RasPi4                                   -  enabled
                   system.adapter.openweathermap.0         : openweathermap        : RasPi3                                   -  enabled
                  + system.adapter.owfs.0                   : owfs                  : RasPi3                                   -  enabled, port: 4304
                  + system.adapter.ping.0                   : ping                  : RasPi4                                   -  enabled
                  + system.adapter.pvforecast.0             : pvforecast            : RasPi3                                   -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : RasPi4                                   -  enabled
                  + system.adapter.rpi2.1                   : rpi2                  : RasPi3                                   -  enabled
                  + system.adapter.scenes.0                 : scenes                : RasPi4                                   -  enabled
                  + system.adapter.shelly.0                 : shelly                : RasPi4                                   -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : RasPi4                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smartmeter.0             : smartmeter            : RasPi3                                   -  enabled
                  + system.adapter.socketio.0               : socketio              : RasPi4                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonos.0                  : sonos                 : RasPi4                                   -  enabled
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : RasPi4                                   -  enabled
                  + system.adapter.telegram.0               : telegram              : RasPi4                                   -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : RasPi4                                   -  enabled
                   system.adapter.vis-colorpicker.0        : vis-colorpicker       : RasPi4                                   - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : RasPi4                                   -  enabled
                   system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPi4                                   - disabled
                   system.adapter.vis-material-webfont.0   : vis-material-webfont  : RasPi4                                   - disabled
                   system.adapter.vis-material.0           : vis-material          : RasPi4                                   - disabled
                   system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi4                                   - disabled
                   system.adapter.vis-metro.0              : vis-metro             : RasPi4                                   -  enabled
                   system.adapter.vis-players.0            : vis-players           : RasPi4                                   - disabled
                   system.adapter.vis-timeandweather.0     : vis-timeandweather    : RasPi4                                   - disabled
                   system.adapter.vis-weather.0            : vis-weather           : RasPi4                                   - disabled
                   system.adapter.vis.0                    : vis                   : RasPi4                                   -  enabled
                  + system.adapter.web.0                    : web                   : RasPi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                   system.adapter.ws.0                     : ws                    : RasPi4                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : RasPi4                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                  Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                  Adapter    "devices"      : 1.1.5    , installed 1.1.5
                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                  Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                  Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Controller "js-controller": 5.0.19   , installed 5.0.19
                  Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                  Adapter    "owfs"         : 0.7.0    , installed 0.7.0
                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                  Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                  Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                  Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                  Adapter    "vis"          : 1.5.4    , installed 1.5.4
                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                  Objects and States
                  Objects:        11579
                  States:         9829
                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 4
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        14165      701/mosquitto
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21083      1266/io.shelly.0
                  tcp        0      0 192.168.2.210:42010     0.0.0.0:*               LISTEN      1001       17373      1102/io.hm-rpc.2
                  tcp        0      0 192.168.2.210:42001     0.0.0.0:*               LISTEN      1001       17404      1113/io.hm-rpc.3
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14264      866/iobroker.js-con
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15660      781/influxd
                  tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      106        14181      683/redis-server 0.
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13023      716/sshd: /usr/sbin
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23226      1402/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14322      919/io.admin.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25058      1413/io.simple-api.
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        15692      781/influxd
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22921      1342/io.socketio.0
                  tcp6       0      0 :::1883                 :::*                    LISTEN      107        14166      701/mosquitto
                  tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21134      1281/io.sonos.0
                  tcp6       0      0 :::3000                 :::*                    LISTEN      108        13141      865/grafana
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13034      716/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:50295           0.0.0.0:*                           104        15467      571/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15465      571/avahi-daemon: r
                  udp6       0      0 fe80::5635:5d6e:3e1:546 :::*                                0          16488      633/NetworkManager
                  udp6       0      0 :::41856                :::*                                104        15468      571/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        15466      571/avahi-daemon: r
                  2024-03-11 15:29:01.020  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1710167341011,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167341011}
                  2024-03-11 15:29:01.023  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1710167341011,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167341011}
                  2024-03-11 15:29:01.045  - warn: javascript.0 (993) script.js.EIGENE_SCRIPTE.Lautsprecher.TP_favorites_set_Setzen_v2: Test_coordinatorSetzen oder favorites_setSetzen
                  2024-03-11 15:29:20.606  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_45.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167360602,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167360602}
                  2024-03-11 15:29:20.647  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_45.state with {"val":"play","ack":false,"ts":1710167360602,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167360602}
                  2024-03-11 15:29:20.650  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_45.state_simple with {"val":true,"ack":false,"ts":1710167360602,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_WohnzimmerAn_Automatik_v5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167360602}
                  2024-03-11 15:29:25.205  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167365200,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167365200}
                  2024-03-11 15:29:25.702  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state with {"val":"play","ack":false,"ts":1710167365699,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167365699}
                  2024-03-11 15:29:25.708  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state_simple with {"val":true,"ack":false,"ts":1710167365700,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167365700}
                  2024-03-11 15:34:39.853  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167679833,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167009005}
                  2024-03-11 15:34:40.837  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"stop","ack":false,"ts":1710167680834,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167680834}
                  2024-03-11 15:34:40.839  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":false,"ack":false,"ts":1710167680834,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167680834}
                  2024-03-11 15:35:31.046  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710167731042,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167009005}
                  2024-03-11 15:35:31.087  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"play","ack":false,"ts":1710167731042,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167731042}
                  2024-03-11 15:35:31.146  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":true,"ack":false,"ts":1710167731142,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167731142}
                  2024-03-11 15:36:19.839  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.coordinator with {"val":"192_168_2_41","ack":false,"ts":1710167779836,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167779836}
                  2024-03-11 15:36:20.839  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state with {"val":"stop","ack":false,"ts":1710167780836,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167780836}
                  2024-03-11 15:36:20.843  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_41.state_simple with {"val":false,"ack":false,"ts":1710167780836,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_BadezimmerAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167780836}
                  2024-03-11 15:41:50.824  - info: admin.0 (919) <== Disconnect system.user.admin from ::ffff:192.168.2.74 javascript
                  2024-03-11 15:41:59.163  - warn: admin.0 (919) dwd has an invalid jsonConfig: [{"instancePath":"/items/land/options/1","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/22/then/properties/options/items/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"noTranslation"},"message":"must NOT have additional properties"}]
                  2024-03-11 15:44:08.937  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.coordinator with {"val":"192_168_2_27","ack":false,"ts":1710168248931,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710167009005}
                  2024-03-11 15:44:09.761  - warn: javascript.0 (993) script.js.EIGENE_SCRIPTE.Lautsprecher.TP_favorites_set_Setzen_v2: Test_coordinatorSetzen oder favorites_setSetzen
                  2024-03-11 15:44:10.105  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state with {"val":"stop","ack":false,"ts":1710168249930,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710168249701}
                  2024-03-11 15:44:10.111  - info: sonos.0 (1281) try to control id sonos.0.root.192_168_2_27.state_simple with {"val":false,"ack":false,"ts":1710168249932,"q":0,"c":"script.js.EIGENE_SCRIPTE.Lautsprecher.TP_KuecheAn_Automatik_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1710168249699}
                  2024-03-11 15:44:24.608  - warn: host.RasPi4 too delayed answer for system.host.RasPi3
                  Wilfried
                  • L Lollo_C
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                          Icon name: computer
                       Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                    RTC time: n/a
                                 NTP service: active
                             RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                            3792 M total memory
                            2518 M used memory
                             119 M free memory
                              94 M buffer memory
                            1027 M swap cache
                              99 M total swap
                               0 M used swap
                              99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    5.0G    /var/
                    4.0G    /var/log
                    538M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.4
                    /usr/bin/npx            10.2.4
                    nodejs:
                     Version table:
                        18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: redis
                    admin:          6.13.16
                    javascript:     7.8.0
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        11579
                    States:         9829
                    Pending Updates: 4
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Ja
                    Sehr gut dass du iob diag zeigst, aber wenn Du Scheduled-Adapter in Deiner Aufzählung hast dann kippt Dir Dein Skript um da diese Datenpunkte auf (null) gehen wenn der jeweilige Adapter sich wieder deaktiviert.
                      Ja
                      Lollo_C
                      ... aber wenn Du Scheduled-Adapter in Deiner Aufzählung hast dann kippt Dir Dein Skript um da diese Datenpunkte auf (null) gehen wenn der jeweilige Adapter sich wieder deaktiviert.
                      So ganz verstehe ich das nicht, da die zeitgesteuerten Adapter den Datenpunkt "connection" nicht haben und deshalb von dem Script auch nicht angesprochen werden.
                      Wie dem auch sei, ich lasse das Script erst einmal deaktiviert und warte ab, was passiert.
                      Wilfried
                      DJMarc75D L 2 Antworten Letzte Antwort
                      • L Lollo_C
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        Aber klar hat jeder installierte Adapter den Datenpunkt "connected" - bis auf die VIS-Adapter, also Widgets-Adapter.
                        Ich bau da heut noch was zusammen.
                          Codierknecht
                          Als JS wäre es einfach:
                              let active = 0;
                              let inactive = 0;
                                  const instanceObject = await getObjectAsync(id.replace('.connected', ''));
                                  const scheduled = getAttr(instanceObject, 'common.schedule');
                                  if (!scheduled) {
                                          active++
                                      } else {
                                          inactive++;
                          Für Blockly fehlt mir gerade die Muße ;-)
                                let active = 0;
                                let inactive = 0;
                                    if (!scheduled) {
                                            active++
                                        } else {
                                            inactive++;
                            haus-automatisierungH Offline
                            Das Problem an diesem Script ist aber generell, dass man es regelmäßig neustarten muss damit alle Instanzen berücksichtigt werden. Und es könnte Probleme geben, wenn eine Instanz gelöscht wird (weil der State dann nicht mehr da ist, aber noch in der Liste steht).
                            @codierknecht sagte in ioBroker friert ein: "Request actual repository...".....:
                            Da würde ich eher auf den common.mode gehen und nur daemon berücksichtigen. Gibt ja neben Schedule auch noch einige andere.
                            📚 Meine Dokumentation
                              Codierknecht
                              @haus-automatisierung
                              Wie gesagt:
                              Prinzip:
                              Da führen - wie so oft - viele Wege nach Rom.
                              @haus-automatisierung sagte in ioBroker friert ein: "Request actual repository...".....:
                              Das ließe sich vermutlich auch noch irgendwie automatisieren.
                              Ein bisschen Gehirnschmalz darf der TE da natürlich noch investieren 😁
                              • L Lollo_C
                                Lollo_C
                                @lollo_c Hallo Zusammen,
                                also an dem Script lag es offensichtlich nicht,. Obwohl es deaktiviert war hat der Raspi heute wieder seinen Dienst eingestellt: Symptome wie gehabt;
                                • iobroker und Vis nicht erreichbar
                                • Raspi rote LED an, grüne blinkt,
                                • Ping antwortet sofort
                                • mit Putty nicht erreichbar.
                                Ich habe ihm eine Stunde Zeit gegeben und dann den Stecker gezogen. Nach dem Neustart ins Protokoll geschaut. Die letzten Einträge vor dem Crash waren wieder:
                                2024-03-12 15:44:10.246 - info: admin.0 (919) Request actual repository...
                                2024-03-12 15:44:12.765 - info: host.RasPi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                Jemand eine Idee, wie ich weitersuchen kann?
                                Wilfried
                                • L Lollo_C
                                  Schau dir deine Lautsprecher-Skripte an. Nicht das du mit denen das System strangulierst.
                                    Lollo_C
                                    @thomas-braun sagte in ioBroker friert ein: "Request actual repository...".....:
                                    Okay, ich habe die Scripte erst einmal alle deaktiviert. Mal sehen, was morgen passiert ;-)
                                    Wilfried
                                    • L Lollo_C
                                      Lollo_C
                                      Gestern lief der ioBroker durch. Aber heute kam es wieder zum Absturz. Im Log waren um 16:51 Uhr wieder die letzten Meldungen zu lesen:
                                      2024-03-14 16:51:44.443 - info: admin.0 (900) Adapter rating updated
                                      2024-03-14 16:52:07.331 - info: admin.0 (900) Request actual repository...
                                      2024-03-14 16:52:10.859 - info: host.RasPi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                      Danach wieder wie gehabt: ping i.O. ; mit Putty kein Zugriff. Um 17:41 habe ich dann den Stecker gezogen und der RasPi lief neu hoch. Beim betrachten der Logs fiel mir danach auf, dass der RasPi in der Zwischenzeit wohl doch was ins log geschrieben hat. Folgende Einträge sind von 17:31 Uhr:
                                      2024-03-14 17:31:25.715 - info: host.RasPi4 iobroker.js-controller version 5.0.19 js-controller starting
                                      2024-03-14 17:31:25.722 - info: host.RasPi4 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                      2024-03-14 17:31:25.723 - info: host.RasPi4 hostname: RasPi4, node: v18.19.1
                                      2024-03-14 17:31:25.724 - info: host.RasPi4 ip addresses: 192.168.2.210 2003:e0:9712:9a00:a47e:4086:36a5:a208 fe80::5635:5d6e:3e15:cb7e
                                      2024-03-14 17:31:27.258 - info: host.RasPi4 connected to Objects and States
                                      2024-03-14 17:31:27.288 - info: host.RasPi4 added notifications configuration of host
                                      2024-03-14 17:31:28.283 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.nodeCurrent"
                                      2024-03-14 17:31:28.287 - info: host.RasPi4 55 instances found
                                      2024-03-14 17:31:28.368 - info: host.RasPi4 starting 28 instances
                                      2024-03-14 17:31:28.381 - warn: host.RasPi4 startInstance cannot find adapter "vis-material-webfont@0.0.3". Try to install it... 1 attempt
                                      2024-03-14 17:31:28.383 - info: host.RasPi4 iobroker install vis-material-webfont@0.0.3 using installedFrom
                                      2024-03-14 17:31:28.572 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.nodeNewest"
                                      2024-03-14 17:31:28.591 - info: host.RasPi4 instance system.adapter.admin.0 started with pid 898
                                      2024-03-14 17:31:28.623 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.nodeNewestNext"
                                      2024-03-14 17:31:28.633 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.npmCurrent"
                                      2024-03-14 17:31:28.641 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.npmNewest"
                                      2024-03-14 17:31:28.650 - info: host.RasPi4 Delete state "system.host.RasPi4.versions.npmNewestNext"
                                      2024-03-14 17:31:28.658 - info: host.RasPi4 Some obsolete host states deleted.
                                      2024-03-14 17:31:31.746 - error: host.RasPi4 iobroker npm-install: host.RasPi4 Unknown packetName vis-material-webfont. Please install packages from outside the repository using npm!
                                      2024-03-14 17:31:32.513 - info: host.RasPi4 instance system.adapter.influxdb.0 started with pid 909
                                      2024-03-14 17:31:32.803 - info: host.RasPi4 iobroker npm-install: exit 12
                                      2024-03-14 17:31:32.957 - info: admin.0 (898) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
                                      2024-03-14 17:31:33.009 - info: admin.0 (898) requesting all objects
                                      2024-03-14 17:31:36.174 - info: admin.0 (898) received all objects
                                      2024-03-14 17:31:36.561 - info: host.RasPi4 instance system.adapter.influxdb.1 started with pid 932
                                      2024-03-14 17:31:36.754 - info: admin.0 (898) Request actual repository...
                                      2024-03-14 17:31:36.826 - info: admin.0 (898) socket.io server listening on port 8081
                                      2024-03-14 17:31:36.843 - info: admin.0 (898) http server listening on port 8081
                                      2024-03-14 17:31:36.844 - info: admin.0 (898) Use link "http://127.0.0.1:8081" to configure.
                                      2024-03-14 17:31:39.474 - info: influxdb.0 (909) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v18.19.1, js-controller: 5.0.19
                                      2024-03-14 17:31:39.518 - info: influxdb.0 (909) No stored data from last exit found
                                      2024-03-14 17:31:39.522 - info: influxdb.0 (909) Connecting http://localhost:8086/ ...
                                      2024-03-14 17:31:39.523 - info: influxdb.0 (909) Influx DB Version used: 1.x
                                      Dann folgt eine ganze Auflistung bei der alle geloggten Datenpunkte der influxdb aufgelistet sind. Gefolgt von eine Auflistung aller Scripte im javascript-Adapter und dann den Homematic usw. Adapter.
                                      Würde mich über den nächsten Tipp zur Fehlersuche sehr freuen.
                                      Wilfried
                                      • L Lollo_C
                                        nicht unbedingt!
                                        der Raspi hat keine Batteriegepufferte Echtzeituhr.
                                        es kann also eine falsche Uhrzeit sein, bevorcder Pi sich per ntp wieder die richtige Zeit verschaffen konnte.
                                          nicht unbedingt!
                                          Lollo_C
                                          nicht unbedingt!
                                          Schade. Ich hatte schon die Hoffnung, dass ich nur nicht lange genug gewartet hätte. Kann ich denn sonst noch irgendwo sehen, waren der ioBroker eingefroren ist?
                                          Wilfried
