  4. Zigbee macht immer mal wieder schlapp - findet Adapter nicht
22 Beiträge 7 Kommentatoren 2.9k Aufrufe 8 Beobachtet
    brokeling
    schrieb am zuletzt editiert von brokeling
    zigbee.0
    2024-02-07 21:37:03.669	info	cleaned everything up...
    zigbee.0
    2024-02-07 21:37:03.653	error	SRSP - SYS - version after 6000ms
    zigbee.0
    2024-02-07 21:37:03.653	error	Error: SRSP - SYS - version after 6000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:312:45 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:26) at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:300:27) at AdapterBackup.getAdapterVersion (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:403:48) at AdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:63:48) at ZStackAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:860:43) at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:330:47)
    zigbee.0
    2024-02-07 21:37:03.490	error	unhandled promise rejection: SRSP - SYS - version after 6000ms
    zigbee.0
    2024-02-07 21:37:03.489	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    und dann:
    zigbee.0
    Zeit
    info
    Nachricht
    zigbee.0
    2024-02-07 22:04:08.662	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100GB8","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100GB8","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
    zigbee.0
    2024-02-07 22:04:08.425	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    zigbee.0
    zigbee.0
    2024-02-07 21:38:15.516	error	Error herdsman start
    zigbee.0
    2024-02-07 21:38:15.515	error	Failed to start Zigbee
    zigbee.0
    2024-02-07 21:38:15.509	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2024-02-07 21:38:15.188	info	Installed Version: iobroker.zigbee@1.10.1
    zigbee.0
    2024-02-07 21:38:13.150	info	Starting Zigbee npm ...
    zigbee.0
    2024-02-07 21:38:13.149	info	Try to reconnect. 1 attempts left
    zigbee.0
    2024-02-07 21:38:03.142	error	Error herdsman start
    zigbee.0
    2024-02-07 21:38:03.142	error	Failed to start Zigbee
    zigbee.0
    2024-02-07 21:38:03.140	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2024-02-07 21:37:42.696	info	Installed Version: iobroker.zigbee@1.10.1
    zigbee
    Ich verwende den usb Adpater: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
    Zigbee will in dem Zustand auch nicht wieder starten. Dazu muss ich USB ein/ausstecken bzw. den raspberry mal wieder ganz aus/anschalten. Dann läuft es wieder - ggf. auch viele Tage wieder durch. Aber so ab und an kommt dann wieder der Fehler!
    Was kann da denn sein?
    Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
    • B brokeling
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      und dann:
      zigbee.0
      Zeit
      info
      Nachricht
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee
      @brokeling
      Zeig mal die Langfassung von
      iob diag
      B 1 Antwort Letzte Antwort
        @brokeling
        iob diag
        brokeling
        ======== Start marking the full check here =========
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         22:30:26 up 6 days, 54 min,  1 user,  load average: 2.77, 1.76, 1.26
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2024-02-07 22:30:26 CET
                   Universal time: Wed 2024-02-07 21:30:26 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        2.2G        298M        0.0K        1.2G        1.4G
        Swap:            99M         99M          0B
        Total:          3.9G        2.3G        298M
                 3786 M total memory
                 2238 M used memory
                  758 M active memory
                 2588 M inactive memory
                  297 M free memory
                  201 M buffer memory
                 1049 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FAILED SERVICES ***
          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
        1 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   20G   92G  18% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     758M  864K  757M   1% /run
        /dev/sdb1      ext4      113G   79G   29G  74% /backup
        /dev/sda1      vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     379M   16K  379M   1% /run/user/1000
        [Thu Feb  1 21:36:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Thu Feb  1 21:36:07 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Thu Feb  1 21:36:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Thu Feb  1 21:36:08 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
        [Thu Feb  1 21:36:10 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
        Show mounted filesystems \(real ones only\):
        TARGET    SOURCE    FSTYPE OPTIONS
        /         /dev/sda2 ext4   rw,noatime,stripe=8191
        |-/backup /dev/sdb1 ext4   ro,noatime
        `-/boot   /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        7.0G    /var/
        3.4G    /var/cache/apt
        3.4G    /var/cache
        3.3G    /var/cache/apt/archives
        3.0G    /var/lib
        Archived and active journals take up 528.1M in the file system.
        /opt/iobroker/backups:
        3.7G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        553M    /opt/iobroker/iobroker-data/backup-objects
        354M    /opt/iobroker/iobroker-data/files
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        41M     /opt/iobroker/iobroker-data/states.json.old
        41M     /opt/iobroker/iobroker-data/states.json.bak
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.15
        javascript:     7.1.6
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.1                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : raspi                                    -  enabled
        + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
        + system.adapter.chromecast.0             : chromecast            : raspi                                    -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspi                                    -  enabled
          system.adapter.deconz.0                 : deconz                : raspi                                    - disabled, port: 80
        + system.adapter.discovery.0              : discovery             : raspi                                    -  enabled
          system.adapter.feiertage.0              : feiertage             : raspi                                    -  enabled
          system.adapter.flot.0                   : flot                  : raspi                                    -  enabled
          system.adapter.fritzdect.0              : fritzdect             : raspi                                    - disabled
          system.adapter.hue-extended.0           : hue-extended          : raspi                                    - disabled
          system.adapter.hue.0                    : hue                   : raspi                                    - disabled, port: 443
          system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspi                                    -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi                                    -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi                                    -  enabled
          system.adapter.iqontrol.0               : iqontrol              : raspi                                    - disabled
        + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
          system.adapter.luftdaten.0              : luftdaten             : raspi                                    -  enabled
          system.adapter.luftdaten.1              : luftdaten             : raspi                                    -  enabled
          system.adapter.mqtt.0                   : mqtt                  : raspi                                    - disabled, port: 1884, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : raspi                                    -  enabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    -  enabled
        + system.adapter.nuki.0                   : nuki                  : raspi                                    -  enabled
        + system.adapter.ping.0                   : ping                  : raspi                                    -  enabled
        + system.adapter.pushover.0               : pushover              : raspi                                    -  enabled
        + system.adapter.reolink.0                : reolink               : raspi                                    -  enabled
        + system.adapter.reolink.1                : reolink               : raspi                                    -  enabled
        + system.adapter.reolink.2                : reolink               : raspi                                    -  enabled
        + system.adapter.reolink.3                : reolink               : raspi                                    -  enabled
          system.adapter.reolink.4                : reolink               : raspi                                    - disabled
        + system.adapter.samsung_tizen.0          : samsung_tizen         : raspi                                    -  enabled, port: 8002
        + system.adapter.sayit.0                  : sayit                 : raspi                                    -  enabled
        + system.adapter.sayit.1                  : sayit                 : raspi                                    -  enabled
        + system.adapter.sayit.2                  : sayit                 : raspi                                    -  enabled
        + system.adapter.sayit.3                  : sayit                 : raspi                                    -  enabled
        + system.adapter.sayit.4                  : sayit                 : raspi                                    -  enabled
        + system.adapter.sayit.5                  : sayit                 : raspi                                    -  enabled
        + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1885, bind: 0.0.0.0
          system.adapter.shelly.1                 : shelly                : raspi                                    - disabled, port: 1882, bind: 0.0.0.0
        + system.adapter.signal-cmb.0             : signal-cmb            : raspi                                    -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartcontrol.0           : smartcontrol          : raspi                                    - disabled
        + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.2         : sourceanalytix        : raspi                                    -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : raspi                                    - disabled
        + system.adapter.sql.0                    : sql                   : raspi                                    -  enabled, port: 0
          system.adapter.statistics.0             : statistics            : raspi                                    - disabled
        + system.adapter.telegram.0               : telegram              : raspi                                    -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : raspi                                    - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi                                    -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspi                                    -  enabled
          system.adapter.vis-history.0            : vis-history           : raspi                                    -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi                                    -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi                                    -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspi                                    -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspi                                    -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    -  enabled
          system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
        + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    - disabled
        + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 6.13.15 [Updatable]
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
        Adapter    "hue"          : 3.10.2   , installed 3.10.1 [Updatable]
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
        Adapter    "paw"          : 0.3.2    , installed 0.3.2
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "reolink"      : 1.0.3    , installed 1.0.3
        Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
        Adapter    "sayit"        : 3.0.5    , installed 3.0.0  [Updatable]
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "vis"          : 1.5.4    , installed 1.5.4
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        10127
        States:         7782
        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 2
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11784      350/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13876      508/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          30611392   20791/cupsd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19029      2034/io.sonoff.0
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14038      350/deCONZ
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21677      2409/io.shelly.0
        tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       20456      2699/io.nuki.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14121      586/iobroker.js-con
        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        11801      588/mariadbd
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      118        13901      498/redis-server 12
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15655      1018/io.admin.1
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20060      2483/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13878      508/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          30611391   20791/cupsd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25459      3468/io.simple-api.
        tcp6       0      0 ::1:6379                :::*                    LISTEN      118        13902      498/redis-server 12
        udp        0      0 0.0.0.0:50173           0.0.0.0:*                           108        14434      343/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13967      816/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30613852   20799/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21341      2223/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14432      343/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15422      350/deCONZ
        udp6       0      0 :::546                  :::*                                0          15138      816/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14433      343/avahi-daemon: r
        udp6       0      0 :::42734                :::*                                108        14435      343/avahi-daemon: r
        2024-02-07 22:30:23.183  - info: host.raspi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-02-07 22:30:32.880  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:30:32.880  - info: sql.0 (1947) No Data
        2024-02-07 22:30:33.403  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.0015bc0031015219.temperature
        2024-02-07 22:30:33.414  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.54ef4410000345bd.illuminance
        2024-02-07 22:30:42.959  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:30:42.959  - info: sql.0 (1947) No Data
        2024-02-07 22:30:52.884  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:30:52.885  - info: sql.0 (1947) No Data
        2024-02-07 22:31:02.890  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:31:02.891  - info: sql.0 (1947) No Data
        2024-02-07 22:31:12.919  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:31:12.919  - info: sql.0 (1947) No Data
        2024-02-07 22:31:22.898  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:31:22.899  - info: sql.0 (1947) No Data
        2024-02-07 22:31:32.887  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:31:32.888  - info: sql.0 (1947) No Data
        2024-02-07 22:31:33.393  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.0015bc0031015219.temperature
        2024-02-07 22:31:33.402  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.54ef4410000345bd.illuminance
        2024-02-07 22:31:42.726  - info: sql.0 (1947) Do not store value "NULL" for PM10 Outdoor because no number
        2024-02-07 22:31:42.728  - info: sql.0 (1947) Do not store value "NULL" for PM25 Outdoor because no number
        2024-02-07 22:31:42.890  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:31:42.890  - info: sql.0 (1947) No Data
        2024-02-07 22:31:52.885  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
        2024-02-07 22:31:52.885  - info: sql.0 (1947) No Data
        • B brokeling
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          und dann:
          zigbee.0
          Zeit
          info
          Nachricht
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @brokeling sagte in [Zigbee macht immer mal wieder schlapp - findet Adapter nicht]
          Da stürzt die Firmware auf dem Stick ab.
          1. Versuch: Neu Flashen
          2. Versuch: Andere Hardware benutzen
          Vorsicht - es gibt in der ZStack Firmware aktuell Probleme - (zumindest hatte @arteck das zuletzt im Forum erwähnt - find das gerade nicht)
          A.
            brokeling
            @asgothian
            Danke für deine Einschätzung.
            Wie sicher ist die Diagnose?
            Ich nehme an bei beiden Varianten (1. und 2.) muss ich alle Geräte neu anlernen???
            Was natürlich sehr schlecht wäre.
            Aber wie gesagt, es läuft z. T. auch Tage bzw. Wochen-lang unauffällig durch ...
            • B brokeling
              @asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @brokeling sagte in Zigbee macht immer mal wieder schlapp - findet Adapter nicht:
              @asgothian
              99.9%
              Variante 1; sicher nicht. Variante 2; wahrscheinlich nicht
              Es gibt noch eine Variante 3:
              • eine WLan schaltbare Steckdose
              • ein usb-hub mit eigener Stromversorgung
              • ein Skript den Stick darüber neu zu booten wenn der Zigbee-adapter nicht will.
              Auch ein um positionieren vom Koordinator relativ zu anderen 2.4gHz Quellen kann helfen (wlan, dect, aber auch 2.4gHz Tastaturen, Kopfhörern und so weiter sowie USB3 Festplatten am Pi.)
              A.
              • B brokeling
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M         99M          0B
                         3786 M total memory
                         2238 M used memory
                          758 M active memory
                          297 M free memory
                          201 M buffer memory
                         1049 M swap cache
                           99 M total swap
                           99 M used swap
                            0 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                7.0G    /var/
                3.4G    /var/cache/apt
                3.4G    /var/cache
                3.0G    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                admin:          6.13.15
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        10127
                States:         7782
                Pending Updates: 2
                CodierknechtC Offline
                Codierknecht
                @brokeling
                Ganz schön viel installiert auf der kleinen Kiste.
                Könnte auch einfach sein, dass ihr der Speicher ausgeht.
                Die teils mehrfachen Instanzen (luftdaten, reolink, sayit) sind notwendig?
                Discovery-Adapter kann man in der Regel schon mal rauswerfen. Braucht man nach der Ersteinrichtung eigentlich nicht.
                Telegram und Signal parallel?
                Iqontrol und vis parallel?
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • AsgothianA Asgothian
                  @asgothian
                  99.9%
                  A.
                  brokeling
                  @asgothian
                  Dann könnte ich auf alle Fälle Variante 1 mal probieren.
                  Die ZSTack Firmware muss ich dann noch schauen, welche Probleme da gerade bestehen.
                  Und für Variante 2 - welche Hardware ist empfehlenswert(er)?
                  Variante 3 könnte ich natürlich auch noch probieren, ist als Dauerlösung halt nicht so befriedigend.
                  Abstand zu potenziellen Störgeräten hab ich schon über 1m. Ich könnte das auch mal drehen oder anders kippen, wenn du meinst das könnte auch was bringen.
                  • CodierknechtC Codierknecht
                    @brokeling
                    brokeling
                    @codierknecht
                    Alle Adapter laufen nicht drauf.
                    Aber da miste ich jetzt auch etwas aus...
                    Die mehrfachen Adapter sind leider in Benutzung. Da muss man für jedes Gerät leider einen eigenen Adapter installieren!
                    Aber danke für den Hinweis.
                    • B brokeling
                      @codierknecht
                      Codierknecht
                      Ja - wenn man richtig hinguckt, sieht man's auch
                      Ist meistens 'ne gute Idee.
                      MariaDB läuft da ja auch noch still und heimlich auf der Kiste.
                      Und Redis auch.
                      Mit nur noch < 300 MB freiem Speicher könnte es schon ganz schön eng werden, wenn nachts das Backup läuft.
                      SchmakusS B 2 Antworten Letzte Antwort
                        Und Redis auch.
                        SchmakusS Offline
                        SchmakusS Offline
                        Schmakus
                        schrieb am zuletzt editiert von Schmakus
                        Ich habe das auch sporadisch mit meinem TI-Board und TCP Anbindung.
                        Hier hilft ein kurzer PowerCycle des POE-Ports, an welchem das TI-Board hängt.
                        Ich vermute, es liegt an einer buggy ZStack Firmware. Dazu gibt es auch eine Diskussion: https://github.com/Koenkk/Z-Stack-firmware/discussions/483.
                        Ich muss es jetzt auch mal die Version 20231112 testen.
                        Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
                          Und Redis auch.
                          brokeling
                          @codierknecht said in Zigbee macht immer mal wieder schlapp - findet Adapter nicht:
                          Und Redis auch.
                          Der Speicher ist aber nicht immer so belegt, jetzt z. B.
                          *** MEMORY ***
                          Mem:            3.8G        1.8G        1.0G        0.0K        924M        1.8G
                          Swap:            99M          0B         99M
                          Total:          3.9G        1.8G        1.1G
                                   3786 M total memory
                                   1813 M used memory
                                    217 M active memory
                                   2415 M inactive memory
                                   1048 M free memory
                                    104 M buffer memory
                                    819 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Und am Handy kann ich die Daten auch kontrollieren, auch die CPU ist immer relativ gering belastet, meistens im 1-stelligen Bereich, und springt manchmal auf max. 60-70% hoch um dann wieder gleich runter zu gehen:
                          • SchmakusS Schmakus
                            brokeling
                            @schmakus said in Zigbee macht immer mal wieder schlapp - findet Adapter nicht:
                            Bei mir zickt zigbee (bzw. das TI-Board) allerdings länger rum.
                            Zunächst, wenn das problem auftritt USB ein/ausstecken, Adapter neu starten.
                            Dann geht er auf grün, funktioniert aber nicht richtig.
                            Bei mir muss ich wie ich das sehe tatsächlich den ganzen raspi rebooten, dass ich da richtig Erfolg kriege. Und jetzt hält er derzeit nicht so lange durch...er stieg schon wieder aus!?!
                            Vielleicht doch den Adapter wechseln. Wenn das nicht mit Neu-Anlernen verbunden wäre, dann hätte ich kein Problem damit.
                            Welcher Adapter ist der beste?
                            • B brokeling
                              brokeling
                              Habe das device jetzt von
                              CC2652R_coordinator_20230507
                              auf
                              CC2652R_coordinator_20231112
                              upgedated.
                              Es läuft jetzt. Mal sehen wie lange!
                              • B brokeling
                                auf
                                upgedated.
                                brokeling
                                ...nicht sehr lange!
                                Leider stürzte er immer wieder ab.
                                Gestern hab ich dann einen nagelneuen USB Adapter installiert:
                                es ist der Sonoff ZIGBEE 3.0 USB-STICK CC2652P.
                                Doch nach fast 24 Stunden perfektem Lauf - ich habe mich schon gefreut - habe ich jetzt wieder diese Aussetzer.
                                Oh nein!
                                Also wahrscheinlich lag es jetzt doch nicht an einer abgestürzten Firmware.
                                Kann mir da jemand helfen und der Sache endgültig auf den Grund gehen?
                                Es ist wirklich sehr übel dass Zigbee bei mir immer wieder ausfällt :(
                                Eigentlich sind es meine wichtigsten Geräte.
                                CluniC AsgothianA 2 Antworten Letzte Antwort
                                • B brokeling
                                  Oh nein!
                                  CluniC Offline
                                  CluniC Offline
                                  Cluni
                                  @brokeling Hast du den Stick denn auch über eine USB-Verlängerung eingesteckt? Die Dinger sind sehr empfindlich. Ich hatte anfangs nur eine sehr kurze Verlängerung und auch damit hatte ich dann schon Probleme. Du solltest den Stick mindestens so 50-100cm vom Raspi weg positionieren und auch schauen, dass nicht unmittelbar daneben ein Router oder sonstige Störquellen sind.
                                  Ich bin kein Experte, ob dies zu genau deinen Problemen führen könnte. Soll nur ein Hinweis am Rande sein.
                                  • B brokeling
                                    Oh nein!
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @brokeling
                                    Du musst nach störquellen im 2.4 GHz Band schauen
                                    • wifi
                                    • dect
                                    • proprietäre funkstrecken für Tastaturen, Mäuse und Kopfhörer
                                    • usb3 Störungen durch Festplatten / ssd / Hubs
                                    Auch: USB Verlängerungskabel auf Qualität prüfen
                                    Koordinator an USB 2 anschließen, nicht USB3
                                    A.
                                      @brokeling
                                      • wifi
                                      • dect
                                      A.
                                      brokeling
                                      @asgothian
                                      Danke für die Hinweise!
                                      Ich habe die Verlängerung gleich im Bundle mitbestellt, müsste also passen.
                                      Mit den Abständen zu Wlan usw. hab ich jetzt weiter optimiert.
                                      Und von USB 3.0 in USB 2.0 umgesteckt.
                                      Mal sehen wie es weitergeht.
                                      • B brokeling
                                        @asgothian
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        @asgothian
                                        Es geht nicht nur um passen, sondern um Qualität - USb3 streut gerne in 2.4 ghz band - da kann eine schlechte Abschirmung schon zu Problemen führen.
                                          @asgothian
                                          brokeling
                                          @asgothian
                                          Ich gehe davon aus, dass das mitgelieferte Kabel den optimalen Betrieb gewährleistet.
                                          Aber wie kann man das Kabel prüfen?
