  4. Iobroker lässt sich nicht mehr starten.
80 Beiträge 7 Kommentatoren 8.8k Aufrufe 6 Beobachtet
  • B Borkenkäfer
    sorry
    meldung
    sudo -H -u iobroker npm install iobroker.js-controller --debug
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 289 packages in 1m
    15 packages are looking for funding
      run `npm fund` for details
    ulli@raspberrypi:/opt/iobroker $ npm fund
    iobroker.core@1.0.0
    ├── https://github.com/sponsors/jaredhanson
    │   └── passport@0.6.0
    ├── https://github.com/sponsors/RubenVerborgh
    │   └── follow-redirects@1.15.5
    ├── https://opencollective.com/ioredis
    │   └── ioredis@4.28.5
    ├── https://github.com/sponsors/ljharb
    │   └── function-bind@1.1.2
    ├─┬ https://github.com/sindresorhus/execa?sponsor=1
    │ │ └── execa@5.1.1
    │ └── https://github.com/sponsors/sindresorhus
    │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
    ├─┬ https://paulmillr.com/funding/
    │ │ └── chokidar@3.5.3
    │ └── https://github.com/sponsors/jonschlinkert
    │     └── picomatch@2.3.1
    ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
    │ │ └── wrap-ansi@7.0.0
    │ └── https://github.com/chalk/ansi-styles?sponsor=1
    │     └── ansi-styles@4.3.0
    ├── https://github.com/sponsors/sibiraj-s
    │   └── ci-info@3.9.0
    ├── https://github.com/sponsors/feross
    │   └── safe-buffer@5.2.1
    └── https://github.com/sponsors/epoberezkin
        └── ajv@6.12.6
    ulli@raspberrypi:/opt/iobroker $ ^C
    #61
    @borkenkäfer
    sudo systemctl set-default multi-user.target
    iobroker restart
    iob diag
    B 2 Antworten Letzte Antwort
      @borkenkäfer
      iobroker restart
      iob diag
      Borkenkäfer
      #62
      war kurz offline
      full
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-01-23 17:44:45 CET
                 Universal time: Tue 2024-01-23 16:44:45 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      ulli
      /home/ulli
      ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
      Swap:            99M          0B         99M
      Total:          3.9G        807M        1.4G
               3794 M total memory
                807 M used memory
               1516 M active memory
                783 M inactive memory
               1256 M free memory
                170 M buffer memory
               1560 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      lifetime oom required: 0 Mbytes
      total time in oom handler: 0 ms
      max time spent in oom handler: 0 ms
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   12G   45G  20% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems \(real ones only\):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      4.7G    /var/
      3.8G    /var/log
      3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
      641M    /var/cache
      Archived and active journals take up 3.1G in the file system.
      /opt/iobroker/backups:
      687M    /opt/iobroker/backups/
      343M    /opt/iobroker/backups/history
      268M    /opt/iobroker/backups/files
      88M     /opt/iobroker/backups/files/echarts.admin
      57M     /opt/iobroker/backups/files/echarts
      /opt/iobroker/iobroker-data:
      687M    /opt/iobroker/iobroker-data/
      347M    /opt/iobroker/iobroker-data/history
      294M    /opt/iobroker/iobroker-data/files
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/echarts
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      Temp directories causing npm8 problem: 75
      Some problems detected, please run iob fix
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          "admin" not found
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
        system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
        system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
        system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
        system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
        system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Objects and States
      Objects:        2093
      States:         1702
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
      Hit:6 https://dl.yarnpkg.com/debian stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Fetched 5127 B in 2s (2420 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
      tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
      tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
      udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
      udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
      udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
      2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
      2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
      2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
      2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
      2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
      2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
      2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
      2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
      2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
      2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
      2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
      2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
      2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
      2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
      2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
      2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
      2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
      2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
        @borkenkäfer
        iobroker restart
        iob diag
        Borkenkäfer
        #63
        meine Internetleitung spinnt gerade
        soll ich d
        iob fix ausführen
        • B Borkenkäfer
          soll ich d
          iob fix ausführen
          #64
          @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
          soll ich d
          iob fix ausführen
          was soll der bringen?
          wird da gerade ein Backup wiederhergestellt?
          B 1 Antwort Letzte Antwort
            soll ich d
            iob fix ausführen
            Borkenkäfer
            #65
            das steht im full drin
            • B Borkenkäfer
              Borkenkäfer
              #66
              @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
              ich mach sonst nichts, nur nach Anweisung
              • B Borkenkäfer
                war kurz offline
                full
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                ulli
                /home/ulli
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3794 M total memory
                          807 M used memory
                         1256 M free memory
                          170 M buffer memory
                         1560 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                4.7G    /var/
                3.8G    /var/log
                641M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2093
                States:         1702
                Pending Updates: 0
                #67
                das sind Meldungen bei einem Restore
                  Borkenkäfer
                  #68
                  soll ich iobroker dann mal starten und schauen was passiert?
                  • B Borkenkäfer
                    #69
                    iobroker logs --watch
                      Borkenkäfer
                      #70
                      ein Auszug
                      das sind meine Blockly sripte
                      2024-01-23 18:45:15.004  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 294
                      2024-01-23 18:45:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                      2024-01-23 18:45:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                       Error : Connect Failed
                      2024-01-23 18:45:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 293
                      2024-01-23 18:46:00.005  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 295
                      2024-01-23 18:46:03.115  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                      2024-01-23 18:46:15.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 290
                      2024-01-23 18:46:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                      2024-01-23 18:46:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                      2024-01-23 18:46:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 255
                      2024-01-23 18:47:00.002  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 262
                      2024-01-23 18:47:03.085  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                        Borkenkäfer
                        #71
                        hier mal der Anfang
                        2024-01-23 17:47:08.532  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.net-tools@0.2.0: 155
                        2024-01-23 17:47:09.586  - info: host.raspberrypi iobroker npm-install: exit 25
                        2024-01-23 17:47:10.587  - warn: host.raspberrypi startInstance cannot find adapter "fritzdect@2.5.9". Try to install it... 1 attempt
                        2024-01-23 17:47:10.588  - info: host.raspberrypi iobroker install fritzdect@2.5.9 using installedFrom
                        2024-01-23 17:47:14.249  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                        2024-01-23 17:47:14.252  - info: host.raspberrypi iobroker npm-install: Installing iobroker.fritzdect@2.5.9... (System call)
                        2024-01-23 17:50:15.627  - info: host.raspberrypi iobroker npm-install:
                        2024-01-23 17:50:15.628  - info: host.raspberrypi iobroker npm-install: added 22 packages, and removed 25 packages in 3m
                        2024-01-23 17:50:15.630  - info: host.raspberrypi iobroker npm-install: 73 packages are looking for funding  run `npm fund` for details
                        2024-01-23 17:50:15.677  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter fritzdect@2.5.9
                        2024-01-23 17:50:15.788  - info: host.raspberrypi iobroker npm-install: upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                        2024-01-23 17:50:15.815  - info: host.raspberrypi iobroker npm-install: upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                        2024-01-23 17:50:15.825  - info: host.raspberrypi iobroker npm-install: upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                        2024-01-23 17:50:15.836  - info: host.raspberrypi iobroker npm-install: upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                        2024-01-23 17:50:15.851  - info: host.raspberrypi iobroker npm-install: upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                        2024-01-23 17:50:15.862  - info: host.raspberrypi iobroker npm-install: upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                        2024-01-23 17:50:15.902  - info: host.raspberrypi "system.adapter.vis.0" disabled
                        2024-01-23 17:50:15.912  - info: host.raspberrypi "system.adapter.vis.0" enabled
                        2024-01-23 17:50:15.915  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
                        2024-01-23 17:50:15.969  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.fritzdect created/updated
                        2024-01-23 17:50:17.029  - info: host.raspberrypi iobroker npm-install: exit 0
                        2024-01-23 17:50:17.077  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 210259
                        2024-01-23 17:50:18.031  - warn: host.raspberrypi startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                        2024-01-23 17:50:18.032  - info: host.raspberrypi iobroker install web@6.1.10 using installedFrom
                        2024-01-23 17:50:19.050  - info: fritzdect.0 (210259) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.19.0, js-controller: 5.0.17
                        2024-01-23 17:50:19.083  - info: fritzdect.0 (210259) fritzdect entered ready
                        2024-01-23 17:50:19.121  - info: fritzdect.0 (210259) fritzdect uses USER: admin
                        2024-01-23 17:50:19.240  - error: fritzdect.0 (210259) --------------- error calling the fritzbox -----------
                        2024-01-23 17:50:19.241  - error: fritzdect.0 (210259) API msg   => error calling executeCommand
                        2024-01-23 17:50:19.242  - error: fritzdect.0 (210259) API funct => login_SID
                        2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) no response part in returned error message
                        2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
                        2024-01-23 17:50:19.245  - error: fritzdect.0 (210259) login not possible, check user and permissions
                        2024-01-23 17:50:20.812  - info: host.raspberrypi iobroker npm-install: host.raspberrypi Adapter "system.adapter.web.0" is stopped.
                        2024-01-23 17:50:20.818  - info: host.raspberrypi "system.adapter.web.0" disabled
                        2024-01-23 17:50:21.917  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                        2024-01-23 17:50:21.919  - info: host.raspberrypi iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
                        2024-01-23 17:50:46.063  - info: host.raspberrypi iobroker npm-install:
                        2024-01-23 17:50:46.064  - info: host.raspberrypi iobroker npm-install: added 62 packages in 23s
                        2024-01-23 17:50:46.065  - info: host.raspberrypi iobroker npm-install: 74 packages are looking for funding  run `npm fund` for details
                        2024-01-23 17:50:46.117  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter web@6.1.10
                        2024-01-23 17:50:47.032  - info: host.raspberrypi iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                        2024-01-23 17:51:02.449  - info: host.raspberrypi iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                        2024-01-23 17:51:02.528  - info: host.raspberrypi iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                        2024-01-23 17:51:02.609  - info: host.raspberrypi iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                        2024-01-23 17:51:02.687  - info: host.raspberrypi iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                        2024-01-23 17:51:02.764  - info: host.raspberrypi iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                        2024-01-23 17:51:02.844  - info: host.raspberrypi iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                        2024-01-23 17:51:02.923  - info: host.raspberrypi iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                        2024-01-23 17:51:03.021  - info: host.raspberrypi iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                        2024-01-23 17:51:03.113  - info: host.raspberrypi iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                        2024-01-23 17:51:03.123  - info: host.raspberrypi iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                        2024-01-23 17:51:03.132  - info: host.raspberrypi iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                        2024-01-23 17:51:03.141  - info: host.raspberrypi iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                        2024-01-23 17:51:03.150  - info: host.raspberrypi iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                        2024-01-23 17:51:03.158  - info: host.raspberrypi iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                        2024-01-23 17:51:03.167  - info: host.raspberrypi iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                        2024-01-23 17:51:03.177  - info: host.raspberrypi iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                        2024-01-23 17:51:03.185  - info: host.raspberrypi iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                        2024-01-23 17:51:03.195  - info: host.raspberrypi iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                        2024-01-23 17:51:03.203  - info: host.raspberrypi iobroker npm-
                        • B Borkenkäfer
                          hier mal der Anfang
                          #72
                          die nächsten zwei
                            die nächsten zwei
                            Borkenkäfer
                            #73
                            einiger läuft schon mal wieder
                            HomoranH B 2 Antworten Letzte Antwort
                            • B Borkenkäfer
                              #74
                              @borkenkäfer so ein Neubau aller Adapter bei einem Restore kann auch mal gerne eine Stunde dauern.
                              in der Zeit darf man nicht stören.
                              • B Borkenkäfer
                                Borkenkäfer
                                #75
                                einiges läuft schon mal wieder
                                werde weiter testen
                                Melde mich
                                Danke für Eure Hilfe und eure unendliche Geduld
                                schönen Abend
                                  Borkenkäfer
                                  #76
                                  hallo
                                  iobroker scheint zu funktionieren, die Scripte laufen und vis läuft auch
                                  aber ich komme nicht auf die WEB seite und es ist kein admin installiert
                                  nach dem Befehl iobroker add admin --port 8081 0der 8089 kommt folgende meldung
                                  ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8081
                                  NPM version: 10.2.3
                                  Installing iobroker.admin@6.12.0... (System call)
                                  Try to solve ENOTEMPTY error automatically
                                  Could not handle ENOTEMPTY, because no deletable files were found
                                  npm ERR! code ENOTEMPTY
                                  npm ERR! syscall rename
                                  npm ERR! path /opt/iobroker/node_modules/@tootallnate/once
                                  npm ERR! dest /opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@tootallnate/once' -> '/opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe'
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_04_975Z-debug-0.log
                                  host.raspberrypi Cannot install iobroker.admin@6.12.0: 217
                                  ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8089
                                  NPM version: 10.2.3
                                  npm ERR! errno -39
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_32_891Z-debug-0.log
                                  • B Borkenkäfer
                                    hallo
                                    NPM version: 10.2.3
                                    npm ERR! errno -39
                                    NPM version: 10.2.3
                                    npm ERR! errno -39
                                    #77
                                    @borkenkäfer
                                    iob stop
                                    iob fix
                                    iob add admin
                                      @borkenkäfer
                                      iob stop
                                      iob fix
                                      iob add admin
                                      Borkenkäfer
                                      #78
                                      funktioniert?
                                      was habe ich falsche gemacht das alles abgestürzt ist
                                      danke und schönen Abend
                                      B Thomas BraunT 2 Antworten Letzte Antwort
                                      • B Borkenkäfer
                                        funktioniert?
                                        Borkenkäfer
                                        #79
                                        funktioniert!
                                        • B Borkenkäfer
                                          funktioniert?
                                          #80
                                          @borkenkäfer
                                          Ich kann mit deiner Frage nicht viel anfangen...
                                          Funktioniert die Installation jetzt oder nicht?
