  4. Iobroker lässt sich nicht mehr starten.
80 Beiträge 7 Kommentatoren 8.8k Aufrufe 6 Beobachtet
  • B Borkenkäfer
    war kurz offline
    full
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-01-23 17:44:45 CET
               Universal time: Tue 2024-01-23 16:44:45 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    ulli
    /home/ulli
    ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
    Swap:            99M          0B         99M
    Total:          3.9G        807M        1.4G
             3794 M total memory
              807 M used memory
             1516 M active memory
              783 M inactive memory
             1256 M free memory
              170 M buffer memory
             1560 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   12G   45G  20% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.7G    /var/
    3.8G    /var/log
    3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
    641M    /var/cache
    Archived and active journals take up 3.1G in the file system.
    /opt/iobroker/backups:
    687M    /opt/iobroker/backups/
    343M    /opt/iobroker/backups/history
    268M    /opt/iobroker/backups/files
    88M     /opt/iobroker/backups/files/echarts.admin
    57M     /opt/iobroker/backups/files/echarts
    /opt/iobroker/iobroker-data:
    687M    /opt/iobroker/iobroker-data/
    347M    /opt/iobroker/iobroker-data/history
    294M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/echarts
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    Temp directories causing npm8 problem: 75
    Some problems detected, please run iob fix
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          "admin" not found
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Objects and States
    Objects:        2093
    States:         1702
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
    Hit:6 https://dl.yarnpkg.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Fetched 5127 B in 2s (2420 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
    tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
    tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
    udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
    udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
    udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
    2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
    2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
    2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
    2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
    2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
    2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
    2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
    2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
    2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
    2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
    2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
    2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
    2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
    2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
    2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
    2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
    2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
    2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
    #67
    @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
    das sind Meldungen bei einem Restore
      Borkenkäfer
      #68
      soll ich iobroker dann mal starten und schauen was passiert?
      • B Borkenkäfer
        #69
        iobroker logs --watch
        B 2 Antworten Letzte Antwort
          Borkenkäfer
          #70
          ein Auszug
          das sind meine Blockly sripte
          2024-01-23 18:45:15.004  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 294
          2024-01-23 18:45:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
          2024-01-23 18:45:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
           Error : Connect Failed
          2024-01-23 18:45:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 293
          2024-01-23 18:46:00.005  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 295
          2024-01-23 18:46:03.115  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
          2024-01-23 18:46:15.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 290
          2024-01-23 18:46:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
          2024-01-23 18:46:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
          2024-01-23 18:46:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 255
          2024-01-23 18:47:00.002  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 262
          2024-01-23 18:47:03.085  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
            Borkenkäfer
            #71
            hier mal der Anfang
            2024-01-23 17:47:08.532  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.net-tools@0.2.0: 155
            2024-01-23 17:47:09.586  - info: host.raspberrypi iobroker npm-install: exit 25
            2024-01-23 17:47:10.587  - warn: host.raspberrypi startInstance cannot find adapter "fritzdect@2.5.9". Try to install it... 1 attempt
            2024-01-23 17:47:10.588  - info: host.raspberrypi iobroker install fritzdect@2.5.9 using installedFrom
            2024-01-23 17:47:14.249  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
            2024-01-23 17:47:14.252  - info: host.raspberrypi iobroker npm-install: Installing iobroker.fritzdect@2.5.9... (System call)
            2024-01-23 17:50:15.627  - info: host.raspberrypi iobroker npm-install:
            2024-01-23 17:50:15.628  - info: host.raspberrypi iobroker npm-install: added 22 packages, and removed 25 packages in 3m
            2024-01-23 17:50:15.630  - info: host.raspberrypi iobroker npm-install: 73 packages are looking for funding  run `npm fund` for details
            2024-01-23 17:50:15.677  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter fritzdect@2.5.9
            2024-01-23 17:50:15.788  - info: host.raspberrypi iobroker npm-install: upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
            2024-01-23 17:50:15.815  - info: host.raspberrypi iobroker npm-install: upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
            2024-01-23 17:50:15.825  - info: host.raspberrypi iobroker npm-install: upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
            2024-01-23 17:50:15.836  - info: host.raspberrypi iobroker npm-install: upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
            2024-01-23 17:50:15.851  - info: host.raspberrypi iobroker npm-install: upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
            2024-01-23 17:50:15.862  - info: host.raspberrypi iobroker npm-install: upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
            2024-01-23 17:50:15.902  - info: host.raspberrypi "system.adapter.vis.0" disabled
            2024-01-23 17:50:15.912  - info: host.raspberrypi "system.adapter.vis.0" enabled
            2024-01-23 17:50:15.915  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
            2024-01-23 17:50:15.969  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.fritzdect created/updated
            2024-01-23 17:50:17.029  - info: host.raspberrypi iobroker npm-install: exit 0
            2024-01-23 17:50:17.077  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 210259
            2024-01-23 17:50:18.031  - warn: host.raspberrypi startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
            2024-01-23 17:50:18.032  - info: host.raspberrypi iobroker install web@6.1.10 using installedFrom
            2024-01-23 17:50:19.050  - info: fritzdect.0 (210259) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.19.0, js-controller: 5.0.17
            2024-01-23 17:50:19.083  - info: fritzdect.0 (210259) fritzdect entered ready
            2024-01-23 17:50:19.121  - info: fritzdect.0 (210259) fritzdect uses USER: admin
            2024-01-23 17:50:19.240  - error: fritzdect.0 (210259) --------------- error calling the fritzbox -----------
            2024-01-23 17:50:19.241  - error: fritzdect.0 (210259) API msg   => error calling executeCommand
            2024-01-23 17:50:19.242  - error: fritzdect.0 (210259) API funct => login_SID
            2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) no response part in returned error message
            2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
            2024-01-23 17:50:19.245  - error: fritzdect.0 (210259) login not possible, check user and permissions
            2024-01-23 17:50:20.812  - info: host.raspberrypi iobroker npm-install: host.raspberrypi Adapter "system.adapter.web.0" is stopped.
            2024-01-23 17:50:20.818  - info: host.raspberrypi "system.adapter.web.0" disabled
            2024-01-23 17:50:21.917  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
            2024-01-23 17:50:21.919  - info: host.raspberrypi iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
            2024-01-23 17:50:46.063  - info: host.raspberrypi iobroker npm-install:
            2024-01-23 17:50:46.064  - info: host.raspberrypi iobroker npm-install: added 62 packages in 23s
            2024-01-23 17:50:46.065  - info: host.raspberrypi iobroker npm-install: 74 packages are looking for funding  run `npm fund` for details
            2024-01-23 17:50:46.117  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter web@6.1.10
            2024-01-23 17:50:47.032  - info: host.raspberrypi iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
            2024-01-23 17:51:02.449  - info: host.raspberrypi iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
            2024-01-23 17:51:02.528  - info: host.raspberrypi iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
            2024-01-23 17:51:02.609  - info: host.raspberrypi iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
            2024-01-23 17:51:02.687  - info: host.raspberrypi iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
            2024-01-23 17:51:02.764  - info: host.raspberrypi iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
            2024-01-23 17:51:02.844  - info: host.raspberrypi iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
            2024-01-23 17:51:02.923  - info: host.raspberrypi iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
            2024-01-23 17:51:03.021  - info: host.raspberrypi iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
            2024-01-23 17:51:03.113  - info: host.raspberrypi iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
            2024-01-23 17:51:03.123  - info: host.raspberrypi iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
            2024-01-23 17:51:03.132  - info: host.raspberrypi iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
            2024-01-23 17:51:03.141  - info: host.raspberrypi iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
            2024-01-23 17:51:03.150  - info: host.raspberrypi iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
            2024-01-23 17:51:03.158  - info: host.raspberrypi iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
            2024-01-23 17:51:03.167  - info: host.raspberrypi iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
            2024-01-23 17:51:03.177  - info: host.raspberrypi iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
            2024-01-23 17:51:03.185  - info: host.raspberrypi iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
            2024-01-23 17:51:03.195  - info: host.raspberrypi iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
            2024-01-23 17:51:03.203  - info: host.raspberrypi iobroker npm-
            • B Borkenkäfer
              hier mal der Anfang
              #72
              die nächsten zwei
                die nächsten zwei
                Borkenkäfer
                #73
                einiger läuft schon mal wieder
                HomoranH B 2 Antworten Letzte Antwort
                • B Borkenkäfer
                  #74
                  @borkenkäfer so ein Neubau aller Adapter bei einem Restore kann auch mal gerne eine Stunde dauern.
                  in der Zeit darf man nicht stören.
                  • B Borkenkäfer
                    Borkenkäfer
                    #75
                    @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                    einiges läuft schon mal wieder
                    werde weiter testen
                    Melde mich
                    Danke für Eure Hilfe und eure unendliche Geduld
                    schönen Abend
                      Borkenkäfer
                      #76
                      hallo
                      iobroker scheint zu funktionieren, die Scripte laufen und vis läuft auch
                      aber ich komme nicht auf die WEB seite und es ist kein admin installiert
                      nach dem Befehl iobroker add admin --port 8081 0der 8089 kommt folgende meldung
                      ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8081
                      NPM version: 10.2.3
                      Installing iobroker.admin@6.12.0... (System call)
                      Try to solve ENOTEMPTY error automatically
                      Could not handle ENOTEMPTY, because no deletable files were found
                      npm ERR! code ENOTEMPTY
                      npm ERR! syscall rename
                      npm ERR! path /opt/iobroker/node_modules/@tootallnate/once
                      npm ERR! dest /opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@tootallnate/once' -> '/opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe'
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_04_975Z-debug-0.log
                      host.raspberrypi Cannot install iobroker.admin@6.12.0: 217
                      ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8089
                      NPM version: 10.2.3
                      npm ERR! errno -39
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_32_891Z-debug-0.log
                      • B Borkenkäfer
                        hallo
                        NPM version: 10.2.3
                        npm ERR! errno -39
                        NPM version: 10.2.3
                        npm ERR! errno -39
                        #77
                        @borkenkäfer
                        iob stop
                        iob fix
                        iob add admin
                          @borkenkäfer
                          iob stop
                          iob fix
                          iob add admin
                          Borkenkäfer
                          #78
                          funktioniert?
                          was habe ich falsche gemacht das alles abgestürzt ist
                          danke und schönen Abend
                          B Thomas BraunT 2 Antworten Letzte Antwort
                          • B Borkenkäfer
                            funktioniert?
                            Borkenkäfer
                            #79
                            funktioniert!
                            • B Borkenkäfer
                              funktioniert?
                              #80
                              @borkenkäfer
                              Ich kann mit deiner Frage nicht viel anfangen...
                              Funktioniert die Installation jetzt oder nicht?
