  4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
adapteremmahuaweiinverterluna2000modbus tcpmodbus-proxysdonglesmartloggersun2000
1.3k Beiträge 97 Kommentatoren 489.0k Aufrufe 87 Beobachtet
    dragst3r
    #241
    Nach dem Standby flutete der Adapter wieder mein Log.
    2024-03-07 18:25:17.342 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32064, Len: 2, modbusID: 2] with: Timed out
    2024-03-07 18:25:17.344 - info: sun2000.0 (3275615) Interval 30.8 sec
    2024-03-07 18:25:17.345 - info: sun2000.0 (3275615) Open Connection...
    2024-03-07 18:25:22.350 - info: sun2000.0 (3275615) Connected Modbus TCP to 192.168.2.16:502
    2024-03-07 18:25:32.852 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32080, Len: 2, modbusID: 2] with: Timed out
    2024-03-07 18:25:32.852 - info: sun2000.0 (3275615) Open Connection...
    2024-03-07 18:25:37.854 - info: sun2000.0 (3275615) Connected Modbus TCP to 192.168.2.16:502
    2024-03-07 18:25:47.859 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32064, Len: 2, modbusID: 2] with: Timed out
    2024-03-07 18:25:47.860 - info: sun2000.0 (3275615) Interval 30.516 sec
    2024-03-07 18:25:47.860 - info: sun2000.0 (3275615) Open Connection...
    2024-03-07 18:25:52.861 - info: sun2000.0 (3275615) Connected Modbus TCP to 192.168.2.16:502
    2024-03-07 18:26:03.555 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32080, Len: 2, modbusID: 2] with: Timed out
    2024-03-07 18:26:03.555 - info: sun2000.0 (3275615) Open Connection...
    2024-03-07 18:26:08.557 - info: sun2000.0 (3275615) Connected Modbus TCP to 192.168.2.16:502
    2024-03-07 18:26:18.558 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32064, Len: 2, modbusID: 2] with: Timed out
    2024-03-07 18:26:18.559 - info: sun2000.0 (3275615) Interval 30.699 sec
    2024-03-07 18:26:18.559 - info: sun2000.0 (3275615) Open Connection...
    2024-03-07 18:26:23.561 - info: sun2000.0 (3275615) Connected Modbus TCP to 192.168.2.16:502
    2024-03-07 18:26:34.814 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32080, Len: 2, modbusID: 2] with: Timed out
    2024-03-07 18:26:34.815 - info: sun2000.0 (3275615) Open Connection...
    2024-03-07 18:26:39.819 - info: sun2000.0 (3275615) Connected Modbus TCP to 192.168.2.16:502
    2024-03-07 18:26:49.821 - warn: sun2000.0 (3275615) Error while reading from 192.168.2.16 [Reg: 32064, Len: 2, modbusID: 2] with: Timed out
    VG
    Steffen
    B 1 Antwort Letzte Antwort
    • B bolliy
      @lightning sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
      Hi @bolliy,
      ich arbeite noch daran, den Fusionsolar Adapter komplett zu entfernen, da es sonst immer zu Timeouts kommt, wenn ich diesen und deinen Adapter nutze.
      Dazu muss ich einige Werte, welche ich früher aus dem fusionsolar zog, aus deinem beziehen.
      Was mir aktuell fehlt ist die bisherige Gesamtproduktion des Systems.
      Meinst du den "Gesamtenergieertrag" ?
      Der Wert "accumulatesEnergyYield" kommt direkt aus dem Reg 32106. Er beschreibt die Energie, die aus dem Wechselrichter in Richtung des Hausnetzes transportiert wurde. Der Gesamtenergieertrag aus der FusionSolar App/Portal wird anders gerechnet. Ich nenne Sie hier mal Yield total (oder besser wäre eigentlich "PortalYield total" 🤔 )
      Für den heutigen Energieartrag gilt:
      Yield today = dailyEnergyYield + currentDayChargeCapacity - currentDayDischargeCapacity - Energieverlust des Speichers
      Analog kannst du das natürlich mit den aufgelaufenen Werten machen. Überlege aber auch wie sinnvoll die Betrachtung aus dem Hause Huawei ist ;)
      Der Zusammenhang ist natürlich nicht ganz trivial. Hier habe ich versuchte es aufzuzeigen:
      https://forum.iobroker.net/topic/71768/test-adapter-sun2000-v0-1-x-huawei-wechselrichter/77
      und hier:
      https://github.com/bolliy/ioBroker.sun2000/blob/main/docs/calculation.md
      Gruß Stephan
      Für mein Verständnis wäre das "accumulatesEnergyYield", oder? Hier habe ich jedoch in meinem Fall einen Wert von fast 1.900 kWh, während mir die Fusionsolar App am Handy lediglich knapp über 1.500 kWh ausweist.
      Ich finde aber auch keinen anderen Wert, der nur ansatzweise passen würde.
      Kannst du mir da evtl. auf die Sprünge helfen?
      Jim
      Lightning
      #242
      @bolliy danke für die auführliche Erklärung und generell nochmals für den gesamten Adapter ;-)
      Der Wert aus der App, wenn ich es richtig verstehe, ist genau der Wert, den man für eine Amortisationsrechnung benötigt, oder?
      Also die Energie, dich ich durch die Anlage gewinne und auch tatsächlich nutzen kann. Daher fände ich das schon spannend.
      Aber mit deiner nleitung sollte es ja möglich sein, da einen realistischen wert zu errechen, danke :-)
      • D dragst3r
        VG
        Steffen
        bolliy
        schrieb am zuletzt editiert von bolliy
        #243
        @dragst3r ich dachte, dass ich die standby timeouts im Griff hätte.
        Jetzt brauche ich ein paar Infos:
        Bezeichnung und modelId der beider WR:
        ModbusID 2 ist der Slave WR ohne Batterie - richtig?
        Was steht in diesem State sun2000.0.inverter.1.deviceStatus nachdem der WR in standby gegangen ist?
        Welche Version vom sun2000 Adapter:
        Über gitHub oder NPM installiert:
        Gruß Stephan
        • L Lightning
          bolliy
          #244
          Auch hier gilt - es ist eine Definitionsfrage! Die Werte sollten natürlich untereinander schlüssig sein. Wenn du den Energieertrag nach Art und Weise der Huawei Entwicklern berechnist, dann sollte Amortisationswerte gleich der App/Portal sein. Sofern du einem anderen Ansatz folgst, dann natürlich nicht.
          Eigenverbrauch für heute würde ich so berechnen:
          sun2000.0.collected.dailyEnergyYield - sun2000.0.collected.gridExportToday
          Siehe https://github.com/bolliy/ioBroker.sun2000/blob/main/docs/calculation.md
          Also die Energie aus den Wechselrichtern abzüglich der ins öffentliche Netz eingespeisten Energie.
          • B bolliy
            Gruß Stephan
            dragst3r
            #245
            @bolliy
            Ich besitze noch keine Batterie.
            Inverter 0
            SUN2000-10KTL-M1EESOLAR-10
            sun2000.0.inverter.0.deviceStatus = 40960
            Inverter 1
            SUN2000-15KTL-M0
            sun2000.0.inverter.1.deviceStatus = 2
            Ich hatte fälschlicher weise Version 0.3.1 genutzt, habe dann aber noch den Adapter über github aktualisiert und die genannten Logs erhalten.
            Anschließend habe ich den Adapter gestoppt. Meine Meldungen sind daher von ca. 18:25 als die WRs in den Standby gingen.
            • D dragst3r
              @bolliy
              Inverter 0
              Inverter 1
              SUN2000-15KTL-M0
              bolliy
              #246
              @dragst3r sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
              @bolliy
              Inverter 0
              Inverter 1
              SUN2000-15KTL-M0
              Bitte auf v0.5.0 über npm aktualisieren. Von gitHub nur installieren, wenn ich dich explizit dazu auffordere!
              gitHub: Entwickler-Version, also was gerade programmiert wird. Könnte ggf. abstürzen!
              npm: Beta-Version. Also die Version, die hier getestet wird.
              ioBroker Repro: stable - wenn ihr die Beta-Version für gut befunden habt.
              Bitte überprüfe auch ob in den Systemeinstellungen von ioBroker Längengrad und Breitengrad korrekt hinterlegt sind. Sonst funtioniert es nicht mit der standby Detektierung.
                thaistatos
                #247
                Die Einheiten beim Meter scheinen nicht zu stimmen, es wird für die Leistung der Phasen A statt W angezeigt.
                Da Huawei selber leider keine einheitliche Leistungseinheit verwendet (Meter in W, WR in kW) sollte man sich vielleicht auf eine festlegen.
                Die Stringleistungen sind aus Strom und Spannung gerechnet? Oder gibt es einen direkten Messwert?
                2.1
                Gibt es eine Übersetzungsliste, welcher Eintrag wo ausgelesen bzw. errechnet wird?
                  thaistatos
                  schrieb am zuletzt editiert von thaistatos
                  #248
                  ok, vielleicht hätte ich erst bei Github schauen sollen, das Problem wurde wohl schon gefixt.
                  Ganz dumme Frage: wie bekomme ich die neueste Version installiert, in Iobroker wird nur die 0.3.1 angeboten.
                  edit: darüber steht es ja, Expertenmodus und über NPM installieren.
                  • T thaistatos
                    2.1
                    bolliy
                    #249
                    @thaistatos sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                    Über Alias die Einheiten umrechnen:
                    https://forum.iobroker.net/post/1136611
                    Im State/Description steht die Herkunft(Register) . Die Leistung ist errechnet.
                    2.1
                    Im State/Description steht die Herkunft (Register).
                    Ansonsten wirst du sicherlich hier
                    https://github.com/bolliy/ioBroker.sun2000/blob/main/docs/README.md
                    oder hier
                    https://github.com/bolliy/ioBroker.sun2000/wiki
                    fündig. Alles noch im Aufbau aber einige Zusammenhänge werden schon gut aufgezeigt.
                    Für die TesterInnen bitte über npm installieren - aktuell die v0.5.0.
                    https://github.com/bolliy/ioBroker.sun2000/wiki/Adapter-installieren
                    LG Stephan
                    • B bolliy
                      Aktuelle Test Version NPM version
                      Veröffentlichungsdatum 12.06.2026
                      Github Link https://github.com/bolliy/ioBroker.sun2000
                      Documentation Wiki
                      Über eure Unterstützung würde ich mich sehr freuen. 😀
                      ich habe für meinen Huawei Wechselrichter SUN2000 und Speicher LUNA2000 einen Adapter entwickelt, der die Registerdaten über modbus TCP ausliest und schreibt.
                      Bitte den Adapter über das Beta Repository oder npm installieren und nicht direkt über github - damit keine unfertige Version in ioBroker eingespielt wird.
                      Nun kann im sun2000 Adapter neben dem Smart Logger auch die Emma (Energiemanagementsystem von Huawei) auf einfache Weise integriert werden.
                      Feature list:
                      • Es können max. 5 sun2000 Wechselrichter (Master/Slave) mit mehreren Batterieeinheit verarbeitet werden.
                      • Battery Control
                        Neben dem "Laden des Speichers über dynamische Stromtarife" können u.a. die Speicherladegrenzen eingestellt werden. Viele Beispielszenarien werden im Wiki beschrieben.
                      • Begrenzung Netzeinspeisung (Export Control)
                        Über die Funktion Export control kann nun die Netzeinspeisung begrenzt oder unterbunden werden.
                        Diese Funktion steht allerdings den SmartLogger Besitzern (noch) nicht zur Verfügung.
                      • Erzwungenes Laden/Entladen der Batterie (Forcible Charge/Discharge)
                        Die Batterie kann für eine bestimmte Dauer oder auf einen bestimmten SoC-Wert zwangsweise aufgeladen oder entladen werden.
                      • Über den eingebauten modbus-proxy können Geräte von Drittanbietern (Wallbox, energy manger usw.) lesend und schreibend auf die Daten der Geräte per modbus tcp zugreifen. Da der modbus-proxy multi-client-fähig ist, kann der Zugriff von mehreren Clients gleichzeigit erfolgen. Darüber hinaus ist es möglich die Daten des Adapters auf eine andere Adapter Instanz zu spiegeln.
                        Im Gegensatz zu dem SDongle ist der modbus-proxy deutlich schneller und stabiler.
                      • Wer ein SmartLogger sein Eigen nennen kann, ist sicher über die Integration des Huawei SmartLoggers erfreut.
                      • Mit der EMMA von Huawei kann der Energieverbrauch im Haus optimiert und die Energiekosten reduziert werden. Die Integration in den Adapter ist nun möglich. Die Leistungs- und Verbrauchsdaten werden im Pfad emma gespeichert.
                      • Bei der Verwendung von einem Wechselrichter werden nicht weniger als 148 Datenpunkte erzeugt.
                      • Live Daten wie Eingangsleistung (inputPower), Ausgangsleistung (activePower), Battery Lade-/Entladeleistung (charge and discharge Power) und der Netzbezug (activePower) des Smart power sensors werden in einem festen Intervall (default 20 Sekunden) ausgelesen und die entsprechenden Zustände geschrieben.
                      • Nur für geänderte Registerdaten werden Zustände (States) geschrieben. Das entlastet die ioBroker Instanz.
                      • Die States „inputPower“ oder „activePower“ im Pfad „collected“ können mit einem Trigger-Element „wurde aktualisiert“ überwacht werden. Da diese States im eingestellten Interwall immer gschrieben werden.
                      • Die Registerdaten werden über drei Intervalle gelesen und verarbeitet:
                        high: Im engestellten Intervall werden auschließlich Echtzeitdaten wie PV Leistung, Inverterleistung, Ladeleistung und Zählerstände bedient.
                        medium (30 Sek): Stringdaten, weitere Zählerdaten usw.
                        low (60 Sek): die restlichen veränderbaren Informationen
                        static: ist eigentlich kein Intervall, da dieser einmalig ausgeführt wird. Z.B. Bezeichnung und Model des Inverters
                      • Die summierten Leistungs- und Verbrauchsdaten des SDongles (sofern vorhanden) können im medium Interval gelesen und im Pfad sdongle gespeichert werden.
                      • Ein Huawei Smart Charger (Wallbox), die über eine Emma integriert ist, wird nun automaitsch erkannt und die Daten im charger Pfad gespeichert. Die Berechnung der aktuelle Ladeleistung erfolgt über die Änderung des Wertes totalEnergyCharged und wird im Unterpfad derived abgelegt.
                      • Statistik: Der Adapter erzeugt automatisch Minuten-, Stunden-, Tages-, Wochen-, Monats- und Jahreswerte für alle wichtigen Energieflüsse eurer Anlage — Solarertrag, Verbrauch, Netzbezug, Einspeisung und Batteriewerte.
                        Die Daten werden direkt als fertige interaktive Diagramme (Apache eCharts) aufbereitet. Wer den ioBroker.web und ioBroker.flexcharts Adapter installiert hat, kann die Charts einfach per URL aufrufen — zum Beispiel den Stundenchart: http://iobroker-ip:8082/flexcharts/echarts.html?source=state&id=sun2000.0.statistics.flexCharts.jsonOutput.hourly
                        Die URL lässt sich auch direkt als iFrame in VIS usw. einbinden.
                        Was der Chart zeigt: Solarertrag, Netzbezug, Einspeisung, Batterie laden/entladen, Batterie SOC und Hausverbrauch — mit Zoom-Slider, ein-/ausblendbaren Serien und bei Stundenwerten einer Tagesmarkierung wenn der Chart mehrere Tage umfasst.
                        Wer das Layout anpassen möchte, kann ein eigenes Template als JSON in den State statistics.flexCharts.template.hourly (bzw. .live., .daily, .weekly usw.) schreiben. Wer nichts einträgt, bekommt das eingebaute (build-in) Layout.
                        Verfügbare Charts: live (1-15min) · hourly · daily · weekly · monthly · annual
                      Über Tests und euer Feedback freue mich sehr.
                      Installation:
                      Den Adapter über das Beta Repository oder npm installieren installieren, damit keine unfertige Version in ioBroker eingespielt wird.
                      Durch Änderungen am js-controller werden vom sun2000 Adapter nur noch node 18.x und höher unterstützt!
                      Ich freue mich auf eure Mitwirkung!
                      Bolli
                      #250
                      @bolliy ist es möglich „nachträglich“ den modbus proxy aufzuspielen? Ich frage alle werte von drei wechselrichter und lunas bereits ab. Aber ich bekomme es absolut nicht hin die werte weiter an einen Heizstab ACthor zu senden, weil sobald acthor aktiv ist, kann ich keine werte muer vom sdongle anholen. Hast du / evtl ein ansatz ?
                      • B Bolli
                        bolliy
                        #251
                        @bolli könntest du etwas weiter ausholen? Ich verstehe nicht recht das Problem
                        • B bolliy
                          2.1
                          oder hier
                          LG Stephan
                          thaistatos
                          #252
                          @bolliy sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                          Danke.
                          Gibt es noch eine andere Möglichkeit, den auszulesen also mit der Maus drüber zu hovern?
                          • B bolliy
                            Bolli
                            #253
                            @bolliy ich hole die einzelnen register per nodered , aber: wenn acthor aktiviert wird , sperrt es mir diesen Modbus kanal. Weil der sdongle nur eine Abfrage kann ? Wenn aber das über ein modbus sever geht dann könnte der acthor von dort die werte holen? Ich hoffe es einigermaßen erklärt zu haben ?
                            B 2 Antworten Letzte Antwort
                            • B Bolli
                              bolliy
                              #254
                              @bolli ok, nutze den modbus-proxy. Der ist Bestandteil des sun2000 Adapters. Er ist multi-client fähig. Installiere die Version v0.5.0 über npm.
                              Siehe: https://github.com/bolliy/ioBroker.sun2000/wiki/Adapter-installieren
                              • B Bolli
                                bolliy
                                #255
                                @bolli Jetzt verstehe ich. Du suchst nur einen modbus-proxy um mit nodered und deinem Heizstab gleichzeitig auf den WR zuzugreifen. Ok - selbst das würde funktionieren. Nur ob das Sinn macht - steht sicher auf einem anderen Blatt ;)
                                LG Stephan
                                • B bolliy
                                  LG Stephan
                                  Bolli
                                  #256
                                  @bolliy naja sinn. Ich möchte natürlich im iobroker die werte visualisieren und mein überschuss an acthor senden .
                                  Oder hab ich gerade ein denkfehler?
                                  • B Bolli
                                    bolliy
                                    #257
                                    @bolli der sun2000 Adapter liest die Daten von den WR und speichert diese in Datenpunkten. Die VIS musst du selber bauen. Der modbus-proxy ist genau richtig für deinen Heizstab. Der Heizstab holt die Daten über den proxy ab. So gibt keine Zugriffskonflikte.
                                    • B bolliy
                                      Bolli
                                      #258
                                      @bolliy eine Frage habe ich doch nich. Welche ip trägt man im Proxy ein?
                                      • B Bolli
                                        bolliy
                                        #259
                                        @bolli Die Adresse an dem der proxy lauschen soll - also 0.0.0.0
                                        • T thaistatos
                                          Danke.
                                          bolliy
                                          #260
                                          @thaistatos ich glaube ab admin adapter v6 wird die Beschreibung unter dem Namen angezeigt.
                                          Dominic ReberD 1 Antwort Letzte Antwort
