  4. ical - Webkalender lässt sich nicht einlesen
63 Beiträge 9 Kommentatoren 10.4k Aufrufe 6 Beobachtet
  • M mguenther
    @haus-automatisierung
    Hallo Matthias,
    ich hab jetzt auf 1.14.0 aktualisiert, aber der Web-Kalender lässt sich immer noch nicht auslesen.
    2024-01-17 20:43:57.073 - info: host.raspberrypi stopInstance canceled schedule system.adapter.ical.0
    2024-01-17 20:44:00.951 - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 1 3 * *
    2024-01-17 20:44:00.970 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4238
    2024-01-17 20:44:02.955 - debug: ical.0 (4238) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2024-01-17 20:44:03.090 - debug: ical.0 (4238) Objects client ready ... initialize now
    2024-01-17 20:44:03.093 - debug: ical.0 (4238) Objects create System PubSub Client
    2024-01-17 20:44:03.094 - debug: ical.0 (4238) Objects create User PubSub Client
    2024-01-17 20:44:03.572 - debug: ical.0 (4238) Objects client initialize lua scripts
    2024-01-17 20:44:03.632 - debug: ical.0 (4238) Objects connected to redis: 0.0.0.0:9001
    2024-01-17 20:44:03.816 - debug: ical.0 (4238) Redis States: Use Redis connection: 0.0.0.0:9000
    2024-01-17 20:44:04.003 - debug: ical.0 (4238) States create System PubSub Client
    2024-01-17 20:44:04.005 - debug: ical.0 (4238) States create User PubSub Client
    2024-01-17 20:44:04.319 - debug: ical.0 (4238) States connected to redis: 0.0.0.0:9000
    2024-01-17 20:44:04.567 - debug: ical.0 (4238) Plugin sentry Initialize Plugin (enabled=true)
    2024-01-17 20:44:05.355 - info: ical.0 (4238) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
    2024-01-17 20:44:06.141 - debug: ical.0 (4238) reading calendar from URL: https://www.landkreis-helmstedt.de/downloads/datei/MzdkOWQ2MmEwZTJiYTc0ZGMwRmFER3lXRGxSSHZYUzB4NjNlekdSaXZ0L1paVS9jcHJ5aU5yQWlWVGZwelBlUUxJWXJrZHl1RktQOWFiMW1YcWh0ams0cEN0bk1aYkdEamJRTDZJM2svdUl3QWM4dmtRY3FUK0k1SWlYV3pRVEJTcC9NY0IxQ2pLWlhPbjdy, color: #000000
    2024-01-17 20:44:06.864 - warn: ical.0 (4238) Error reading from URL "https://www.landkreis-helmstedt.de/downloads/datei/MzdkOWQ2MmEwZTJiYTc0ZGMwRmFER3lXRGxSSHZYUzB4NjNlekdSaXZ0L1paVS9jcHJ5aU5yQWlWVGZwelBlUUxJWXJrZHl1RktQOWFiMW1YcWh0ams0cEN0bk1aYkdEamJRTDZJM2svdUl3QWM4dmtRY3FUK0k1SWlYV3pRVEJTcC9NY0IxQ2pLWlhPbjdy": 403
    2024-01-17 20:44:06.865 - warn: ical.0 (4238) Error reading "https://www.landkreis-helmstedt.de/downloads/datei/MzdkOWQ2MmEwZTJiYTc0ZGMwRmFER3lXRGxSSHZYUzB4NjNlekdSaXZ0L1paVS9jcHJ5aU5yQWlWVGZwelBlUUxJWXJrZHl1RktQOWFiMW1YcWh0ams0cEN0bk1aYkdEamJRTDZJM2svdUl3QWM4dmtRY3FUK0k1SWlYV3pRVEJTcC9NY0IxQ2pLWlhPbjdy": Cannot read URL: "https://www.landkreis-helmstedt.de/downloads/datei/MzdkOWQ2MmEwZTJiYTc0ZGMwRmFER3lXRGxSSHZYUzB4NjNlekdSaXZ0L1paVS9jcHJ5aU5yQWlWVGZwelBlUUxJWXJrZHl1RktQOWFiMW1YcWh0ams0cEN0bk1aYkdEamJRTDZJM2svdUl3QWM4dmtRY3FUK0k1SWlYV3pRVEJTcC9NY0IxQ2pLWlhPbjdy"
    2024-01-17 20:44:06.866 - info: ical.0 (4238) All calenders could not be processed, Do not clean up events
    2024-01-17 20:44:11.879 - debug: ical.0 (4238) Plugin sentry destroyed
    2024-01-17 20:44:11.881 - info: ical.0 (4238) Terminated (NO_ERROR): Without reason
    2024-01-17 20:44:12.404 - warn: ical.0 (4238) get state error: Connection is closed.
    2024-01-17 20:44:12.841 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    Muss ich noch etwas anderes beachten?
    Gruß,
    Marcus
    haus-automatisierungH Offline
    #41
    @mguenther Was hast denn als User Agent konfiguriert?
    📚 Meine Dokumentation
    • _ Offline
      _ Offline
      _Phantom_
      schrieb am zuletzt editiert von _Phantom_
      #42
      Einen guten Morgen in die Runde.
      Ich weiß nicht, ob mein Problem schon besprochen wurden ist, aber seit kurzem bekomme ich keine Kalenderdaten ausgelesen, die eine Wiederholung haben UND Start- Endzeit besitzen.
      Wenn ich einen dieser Einträge auf "Ganzen Tag" umstelle ohne Start und Endzeit, werden sie korrekt angezeigt(ausgelesen), auch die Wiederholungen.
      Hoffe war verständlich.
      • _ _Phantom_
        liv-in-skyL Offline
        liv-in-skyL Offline
        liv-in-sky
        #43
        @_phantom_ evtl. https://github.com/iobroker-community-adapters/ioBroker.ical/issues/627#issuecomment-1896504073
        adapter downgraden half bei mir
        _ 1 Antwort Letzte Antwort
        • liv-in-skyL liv-in-sky
          _ Offline
          _ Offline
          _Phantom_
          #44
          @liv-in-sky Danke, bin auch auf 1.13.4 zurück.
          • _ _Phantom_
            MartinPM Offline
            MartinPM Offline
            MartinP
            #45
            Bei mir funktioniert auch die URL meines Entsorgers plötzlich nicht mehr ...
            https://www.edg.de/abfallkalender
            Hier kann man eine gültige Adresse im Stadtgebiet von Dortmund angeben, und kann dann eine URL über die Zwischenablage generieren, die man in seine Kalender-App kopieren soll.
            Hier die URL für die Aalbeckestraße 7 in Dortmund (nein - da wohne ich NICHT, war die schnellste Wahl im alphabetisch sortierten Straßenpicker)
            https://kundenportal.edg.de/WasteManagementDortmund/WasteManagementServiceServlet?ApplicationName=Calendar&SubmitAction=sync&StandortID=1187201001&AboID=145064&Fra=P;R;B;W
            Funktioniert ca seit dem Jahreswechsel nicht mehr ...
            Habe dann getestet. Curl generiert keine Datei im ICAL-Format, deutlich zu kurz und XML...
            Kopiert man die URL in den Browser, gibt es ein Pop-Up-Menu, Speicherdialog - wo die Datei hinkopiert werden soll.
            Habe die Datei in das Verzeichnis /opt/iobroker/iobroker-data gespeichert, und arbeite nun mit dieser lokalen Datei im ical-Adapter. Enthält Termine bis Ende des Jahres, da habe ich erstmal Ruhe ... Zur Not eben alle paar Monate aktualisieren..
            EDIT: @liv-in-sky @_Phantom_ ical 1.13.5? Seit Ihr nicht auf Stable? Über Stable wird mir 1.13.3 als aktuell angezeigt ...
            • MartinPM MartinP
              _ Offline
              _ Offline
              _Phantom_
              #46
              @martinp Guten Morgen...
              nein, ich bin auf ioBroker-Beta, da VIS-2 bei mir läuft.
              Natürlich ist sowas dann auch ein Grund für fehlerhafte iCal-Versionen.
              Aber zum Glück kann man ja zurück gehen auf eine "ältere" Version.
              J 1 Antwort Letzte Antwort
              • _ _Phantom_
                Jan1
                #47
                @_phantom_
                im Gegenteil, in der beta läuft die ical Version wie sie soll ;)
                • J Jan1
                  @_phantom_
                  _ Offline
                  _ Offline
                  _Phantom_
                  #48
                  @jan1 ... ja bei mir und Anderen halt in der Version ab 1.13.5 nicht.
                  Siehe meinen Post etwas weiter oben.
                  • _ _Phantom_
                    Jan1
                    #49
                    @_phantom_
                    die aktuelle Version von ical ist auch 1.14.0 und die läuft perfekt.
                    Darüber ist mein Wecker und die Heizung gesteuert, würde hier auch nur ein Termin nicht passen und da sind einige neu dazu gekommen, dann würde ich das recht schnell merken.
                    liv-in-skyL _ 2 Antworten Letzte Antwort
                    • J Jan1
                      @_phantom_
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #50
                      @jan1 sind den alle serientermine im json datenpunkt sichtbar - es kann ja sein, das die serien termine in der momentanen woche angezeigt werden - aber es fehlen immer einträge, die in der zukunft noch kommen ????
                        Jan1
                        #51
                        @liv-in-sky
                        Die Termine machen Probleme, wenn man hier beim Anlegen und Löschen nicht aufpasst, sonst läuft das seit Jahren ohne Probleme ;)
                        Da wurde schon viel zu geschrieben und da kann der Adapter nix für, wenn die User hier wild an den Terminen rum fummeln. Da muss man teils Jahren in der Zukunft den eigenen Mist aufräumen, dann klappt es auch mit ical.
                        • J Jan1
                          @liv-in-sky
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #52
                          @jan1 das beantwortet nicht meine frage
                          es geht auch nicht um alten mist, sondern es werden nicht alle neu erstellten serientermine (im angegeben bereich (tage)) bei der ical abfrage in den json dp geschrieben
                          und danke, dass du mir unterstellst, ich könnte keinen termine in google anlegen
                            Jan1
                            #53
                            @liv-in-sky
                            Ich unterstelle überhaupt nicht, nur war das bis jetzt immer der Grund warum es nicht geklappt hat und da es bei mir läuft, bin ich auch schon wieder weg .
                              mguenther
                              #54
                              @haus-automatisierung sagte in ical - Webkalender lässt sich nicht einlesen:
                              ähm... - wo finde ich das?
                              • M mguenther
                                #55
                                @mguenther sagte in ical - Webkalender lässt sich nicht einlesen:
                                In den Instanz-Einstellungen. Darum ging es hier in dem Thread doch die ganze Zeit :)
                                Hier wurde schon bestätigt dass es mit dem gesetzten User-Agent funktioniert: https://github.com/iobroker-community-adapters/ioBroker.ical/issues/633
                                  mguenther
                                  #56
                                  ah - gefunden... Ich hatte gar keinen eingerichtet. Ich habe nun einfach den Haken gesetzt und siehe da, es geht mit 1.14.0
                                  Vielen Dank
                                  Marcus
                                  • J Jan1
                                    @_phantom_
                                    _ Offline
                                    _ Offline
                                    _Phantom_
                                    #57
                                    @jan1 auch wenn du weg bist, noch einen "Nachruf" von mir.
                                    Version 1.13.4 läuft bei mir perfekt, so wie bei dir scheinbar 1.14.
                                    Alle Versionen nach 1.13.4 habe ich persönlich probiert und festgestellt, dass es Probleme mit sich wiederholenden Terminen mit Start und Endzeiten gibt. Die werden einfach nicht ausgelesen und angezeigt.
                                    Wiederholende Ganztagstermine funktionieren auch mit den Versionen >1.13.4.
                                    Nachvollziehbar getestet mit "alten" und auch neu hinzugefügten Terminen (bei mir im Synology Kalender und nicht Google)...
                                    Es währe daher produktiver, wenn du uns sagen tätest, dass genau diese bei mir/uns nicht funktionierenden Einträge bei dir funktionieren, am besten mal ein kleines Beispiel ala "Volleyball - jeden Dienstag von 17:00 - 19:00Uhr" (funktioniert bei mir >1.13.4 nicht)!!
                                    • _ Offline
                                      _ Offline
                                      _Phantom_
                                      #58
                                      Jetzt mit der Version 1.14.2 funktionieren auch die wiederkehrenden Termine mit Zeitangabe...
                                      Danke an den Programmierer !
                                      • _ _Phantom_
                                        #59
                                        @_phantom_ Gern, hab direkt noch ein Integration-Test hinzugefügt, damit das demnächst direkt auffällt. Hoffentlich
                                        • H Offline
                                          hendrik87
                                          #60
                                          Bei mir werden alte, nicht ganztags Termine immer noch nicht angezeigt. Ändere ich den vergangenen Termin auf "ganztag", so wird er angezeigt. Was mache ich noch falsch?
                                          Update auf 1.14.2 durchgeführt
