  4. Info Adapter rot nach Update
npm info
20 Beiträge 3 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    schrieb am zuletzt editiert von amg_666
    Hi, ich habe grade über die Konsole mit sudo apt update und dann sudo apt-get dist-upgrade den iob aktualisiert. Da kam dann eine Mewldung (sinngemäß) das iobroker.system neu gestartet werden muss, was ich bestätigt habe.
    System läuft auch wieder hoch, nur der info-adapter bleibt rot.
    host.iobroker
    	2023-12-28 13:32:10.279	error	Caught by controller[0]: /bin/sh: 1: npm: not found
    host.iobroker
    	2023-12-28 13:32:10.279	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    host.iobroker
    	2023-12-28 13:32:10.280	error	Caught by controller[0]: adapter.log.error("Could not check npm version: " + e);
    host.iobroker
    	2023-12-28 13:32:10.280	error	Caught by controller[0]: ^
    host.iobroker
    	2023-12-28 13:32:10.280	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
    host.iobroker
    	2023-12-28 13:32:10.280	error	Caught by controller[0]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    host.iobroker
    	2023-12-28 13:32:10.280	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
    host.iobroker
    	2023-12-28 13:32:10.281	error	Caught by controller[0]: Node.js v18.19.0
    host.iobroker
    	2023-12-28 13:32:10.282	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    	2023-12-28 13:32:10.282	info	Restart adapter system.adapter.info.0 because enabled
    ich hab dann den iob nochmal gestoppt und den fixer drüber laufen lassen, das hat aber nichts gebracht, gleiche Fehlermeldungen im Protokoll.
    iob auf proxmox container, Debian12, js-controller 5.0.17, node.js 18.19.0, bin im beta repository.
    iob diag meckert rum, dass npm nicht bekannt ist (???)
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.5.11-7-pve
        Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     13:39:04 up 7 days, 16:25,  2 users,  load average: 1.76, 2.26, 2.15
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Thu 2023-12-28 13:39:05 CET
               Universal time: Thu 2023-12-28 12:39:05 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    andreas
    /home/andreas
    andreas sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             12G        3.3G        2.3G         49K        7.3G        9.6G
    Swap:           4.3G        1.7M        4.3G
    Total:           17G        3.3G        6.6G
            12288 M total memory
             3126 M used memory
             3239 M active memory
             6428 M inactive memory
             2202 M free memory
                0 M buffer memory
             6958 M swap cache
             4096 M total swap
                1 M used swap
             4094 M free swap
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    * bluetooth.service       loaded failed failed Bluetooth service
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4      147G   49G   91G  35% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.1G   92K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems \(real ones only\):
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    1.9G    /var/
    1.3G    /var/cache/apt
    1.3G    /var/cache
    1.2G    /var/cache/apt/archives
    320M    /var/log
    Archived and active journals take up 72.4M in the file system.
    /opt/iobroker/backups:
    15G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    15G     /opt/iobroker/iobroker-data/
    14G     /opt/iobroker/iobroker-data/history
    503M    /opt/iobroker/iobroker-data/files
    159M    /opt/iobroker/iobroker-data/backup-objects
    91M     /opt/iobroker/iobroker-data/files/vis-2-beta
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    30M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /home/iobroker/.diag.sh: line 279: npm: command not found
    /home/iobroker/.diag.sh: line 280: npx: command not found
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 290: npm: command not found
    /home/iobroker/.diag.sh: line 291: npx: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
            100 /var/lib/dpkg/status
         18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    /home/iobroker/.diag.sh: line 360: npm: command not found
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.11
    javascript:     7.5.1
    /home/iobroker/.diag.sh: line 375: npm: command not found
    Adapters from github:   0
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.6                   : ical                  : iobroker                                 -  enabled
      system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.proxmox.1                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.rpi2.0                   : rpi2                  : iostrom                                  -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : iostrom                                  -  enabled
    + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      system.adapter.wifilight.0              : wifilight             : iobroker                                 - disabled
    + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 0.0.0.0
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json": timeout of 10000ms exceeded
    Adapter    "admin"        : 6.13.11  , installed 6.13.11
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 0.10.2   , installed 0.10.2
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "bmw"          : 2.7.2    , installed 2.7.2
    Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
    Adapter    "device-watcher": 2.9.11  , installed 2.9.11
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "ical"         : 1.13.6   , installed 1.13.6
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.5.1    , installed 7.5.1
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "klf200"       : 1.1.2    , installed 1.1.2
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nina"         : 0.0.26   , installed 0.0.26
    Adapter    "plenticore"   : 2.3.1    , installed 2.3.1
    Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
    Adapter    "rssfeed"      : 2.8.1    , installed 2.8.1
    Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "snmp"         : 3.1.0    , installed 3.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 3.1.3    , installed 3.1.3
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2-widgets-gauges": 1.0.1, installed 1.0.1
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 1.2.1    , installed 1.2.1
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wolf"         : 1.7.0    , installed 1.7.0
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.9.3    , installed 1.9.3
    Objects and States
    Objects:        24646
    States:         21596
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       27673973   261190/io.wolf.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          26624      287/master
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       27672755   260929/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       27673587   261155/io.mqtt.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       27670583   260807/iobroker.js-
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       27668160   260807/iobroker.js-
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21210500   196637/sshd: /usr/s
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29062      1/init
    tcp        0      0 192.168.1.23:8701       0.0.0.0:*               LISTEN      1001       27672347   261027/io.hm-rpc.1
    tcp        0      0 192.168.1.23:9292       0.0.0.0:*               LISTEN      1001       27670499   261057/io.hm-rpc.3
    tcp        0      0 192.168.1.23:2001       0.0.0.0:*               LISTEN      1001       27672258   261011/io.hm-rpc.0
    tcp        0      0 192.168.1.23:2010       0.0.0.0:*               LISTEN      1001       27671368   261042/io.hm-rpc.2
    tcp6       0      0 :::20002                :::*                    LISTEN      1001       27681182   261545/io.web.1
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21210502   196637/sshd: /usr/s
    tcp6       0      0 :::111                  :::*                    LISTEN      0          29064      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          31745      287/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27668263   260825/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27676610   261389/io.web.0
    tcp6       0      0 :::4400                 :::*                    LISTEN      1001       27676259   261290/io.milight-s
    udp        0      0 0.0.0.0:34553           0.0.0.0:*                           1001       27677735   261341/io.snmp.0
    udp        0      0 0.0.0.0:35076           0.0.0.0:*                           1001       27677235   261290/io.milight-s
    udp        0      0 0.0.0.0:45815           0.0.0.0:*                           1001       27677497   261341/io.snmp.0
    udp        0      0 192.168.1.23:5353       0.0.0.0:*                           1001       27672080   260943/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       27672045   260893/io.shelly.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29063      1/init
    udp6       0      0 :::111                  :::*                                0          29065      1/init
    2023-12-28 13:39:45.909  - error: host.iobroker Caught by controller[1]: Node.js v18.19.0
    2023-12-28 13:39:45.909  - error: host.iobroker instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-12-28 13:39:45.909  - info: host.iobroker Restart adapter system.adapter.info.0 because enabled
    2023-12-28 13:40:00.085  - info: host.iobroker instance system.adapter.ical.2 started with pid 262188
    2023-12-28 13:40:08.678  - info: ical.2 (262188) starting. Version 1.13.6 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
    2023-12-28 13:40:14.581  - info: ical.2 (262188) processing URL: Geburtstag https://calendar.google.com/calendarxxxxxxx/basic.ics
    2023-12-28 13:40:16.509  - info: host.iobroker instance system.adapter.info.0 started with pid 262228
    2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]: /bin/sh: 1: npm: not found
    2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]:                adapter.log.error("Could not check npm version: " + e);
    2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]:                        ^
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
    2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
    2023-12-28 13:40:18.696  - error: host.iobroker instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-12-28 13:40:18.696  - info: host.iobroker Restart adapter system.adapter.info.0 because enabled
    2023-12-28 13:40:19.963  - info: ical.2 (262188) Terminated (NO_ERROR): Without reason
    2023-12-28 13:40:20.501  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    • amg_666A amg_666
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      Skript v.2023-10-10
      *** BASE SYSTEM ***
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      andreas
      /home/andreas
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
               3126 M used memory
               2202 M free memory
                  0 M buffer memory
               6958 M swap cache
               4096 M total swap
                  1 M used swap
               4094 M free swap
      *** FILESYSTEM ***
      /var:
      1.9G    /var/
      1.3G    /var/cache/apt
      1.3G    /var/cache
      320M    /var/log
      USB-Devices by-id:
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.11
      javascript:     7.5.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        24646
      States:         21596
      Pending Updates: 0
      @amg_666 sagte in Info Adapter rot nach Update:
      Damit wärst du der erste... Das geht nämlich nicht.
      Installier da nochmal per
      iob nodejs-update 18
      das nodesource-Repo drüber.
      amg_666A 2 Antworten Letzte Antwort
        amg_666A Offline
        amg_666A Offline
        amg_666
        @thomas-braun sagte in Info Adapter rot nach Update:
        das hats leider nicht gebracht:
        oBroker nodejs fixer 2023-10-13
        You requested to intall latest version from nodejs v18 tree.
        Your current setup is:
        /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
        /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
        /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
        /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
        We found these nodejs versions available for installation:
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Your nodejs-Installation seems to be faulty. Shall we try to fix it?
        Press <y> to continue or any other key to quit
        Fixing your nodejs setup
        *** Deleting  ***
        rm: cannot remove '': No such file or directory
        *** Deleting  ***
        Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
        You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
        Trying to update your installation now. Please be patient.
        Virtualization: lxc
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Get:3 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
        Get:4 http://security.debian.org/debian-security bookworm-security/main Sources [68.7 kB]
        Get:5 http://security.debian.org/debian-security bookworm-security/main amd64 Packages [132 kB]
        Get:6 http://security.debian.org/debian-security bookworm-security/main Translation-en [78.2 kB]
        Fetched 327 kB in 5s (60.8 kB/s)
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
        Fetched 18.8 kB in 6s (3156 B/s)
        Installing the recommended nodejs version now!
        Installing the recommended nodejs version!
        E: Broken packages
        *** You need to manually restart your container/virtual machine now! ***
        We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        ich habe danach den Container neu gestartet, info ist weiterhin rot und dieselben Fhlermeldungen im logfile
        • amg_666A amg_666
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          *** Deleting  ***
          *** Deleting  ***
          Virtualization: lxc
          Package: nodejs
          Pin-Priority: 1001
          E: Broken packages
          @amg_666
          Das Repo ist nun aber richtig.
          sudo apt update
          apt policy nodejs
            @amg_666
            sudo apt update
            apt policy nodejs
            amg_666A Offline
            amg_666A Offline
            amg_666
            apt policy nodejs
            andreas@iobroker:~$ sudo apt update
            [sudo] Passwort fr andreas:
            OK:1 http://security.debian.org/debian-security bookworm-security InRelease
            OK:2 http://deb.debian.org/debian bookworm InRelease
            OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            OK:4 http://deb.debian.org/debian bookworm-updates InRelease
            Abhngigkeitsbaum wird aufgebaut... Fertig
            Statusinformationen werden eingelesen... Fertig
            Alle Pakete sind aktuell.
            andreas@iobroker:~$ apt policy nodejs
            nodejs:
              Installiert:           18.19.0+dfsg-6~deb12u1
              Installationskandidat: 18.19.0-1nodesource1
              Versionstabelle:
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            andreas@iobroker:~$
            und jetzt ?
            • amg_666A amg_666
              apt policy nodejs
              nodejs:
                Versionstabelle:
                   18.13.0+dfsg1-1 500
              andreas@iobroker:~$
              und jetzt ?
              installieren:
              sudo apt install nodejs=18.19.0-1nodesource1
                amg_666A Offline
                amg_666A Offline
                amg_666
                Danke für die Hilfe, läuft jetzt wieder rund...
                Trotzdem ein (dumme?) Frage: Du hast im ersten Post geschrieben ich wäre da der erste. Ich hab iob wie gesagt als proxmox Container und gehe über proxmox regelmäßig auf die iob Konsole um auf updates zu prüfen. Gefühlt "schon ewig" mit diesen beiden Befehlen:
                sudo apt update
                Was ist daran falsch und wie mache ich es zukünftig richtig?
                • amg_666A amg_666
                  sudo apt update
                  Das ist nicht falsch, updated aber nicht den iobroker sondern nur das Betriebssystem/Container.
                  Ich würde allerdings da
                  sudo apt
                  sudo apt full-upgrade
                  empfehlen.
                  Den ioBroker könnte man dann aber per
                  iob update
                  iob upgrade all
                  aktuell halten.
                    sudo apt
                    empfehlen.
                    iob update
                    iob upgrade all
                    aktuell halten.
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    @thomas-braun Alles klar, dann habe ich mich missverständlich ausgedrückt. Über die Konsole halte ich natürlich nur den iob Container up-to-date. iobroker updates mache ich eigentlcih immer über die admin oberfläche.
                    Nochmals danke für den support.
                    • AgrippinenserA Offline
                      Agrippinenser
                      sorry das ich hier so reinplatze. Ich habe heute morgen nach Update der VM mit
                      sudo apt update
                      gleiches Verhalten gehabt und bin dankbar hier die Lösung gefunden habe. !
                      Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
                      • AgrippinenserA Agrippinenser
                        sudo apt update
                        @agrippinenser @amg_666
                        Stellt die Priority für das nodesource-Repo höher.
                        Geht so:
                        echo "Package: nodejs" | sudo tee /etc/apt/preferences.d/nodejs.pref
                        echo "Pin: origin deb.nodesource.com" | sudo tee -a /etc/apt/preferences.d/nodejs.pref
                        echo "Pin-Priority: 1001" | sudo tee -a /etc/apt/preferences.d/nodejs.pref
                        sudo apt update
                        AgrippinenserA 1 Antwort Letzte Antwort
                          Geht so:
                          sudo apt update
                          Agrippinenser
                          habe da vorher mal reingeguckt - das steht darin:
                          Package: nodejs
                          Pin-Priority: 1001
                          Pin-Priority ist demnach schon 1001. Soll ich die 4 Zeilen dennoch ausführen?
                            Package: nodejs
                            Pin-Priority: 1001
                            @agrippinenser
                            Dann dürftest du dir aber nicht die dfsg-Version eingehandelt haben.
                            sudo apt update
                            apt policy nodejs
                            sagt auf deinem System?
                              Package: nodejs
                              Pin-Priority: 1001
                              @agrippinenser
                              Ich sehe gerade, du hantierst da mit apt-get...
                              Das würde ich nicht machen, das tickt anders und berücksichtigt die gesetzten priorities nicht, soweit ich weiß.
                              Besser:
                              sudo apt update
                                @agrippinenser
                                Besser:
                                sudo apt update
                                Agrippinenser
                                Besser:
                                sudo apt update sudo apt full-upgrade
                                unter uns :-) - ich habe eine PIN-Wand vor mir. Daran klebt ein Zettel mit Inhalt:
                                sudo apt update
                                sudo full-upgrade
                                sudo reboot
                                heute Morgen habe ich folgendes im Werkzeugkasten gelesen und daraufhin "blind" sudo apt dist-upgrade ausgeführt.
                                Systemupdate
                                Seinen Debian-basierten Server (dazu gehört z. B. auch das Raspberry OS vom Raspberry Pi, Ubuntu, Armbian) aktuell und 'auf Stand' zu halten braucht es nur wenig Handwerkszeug. Die installierte Software (im Idealfall auch zusätzliche Pakete von Drittanbietern wie deconz, nodeJS von nodesource) wird sehr komfortabel und zentral über den Paketmanager gehandhabt.
                                Mit diesem 'Dreisatz' wird automatisch ein System inkl. aller über den Paketmanager installierten Software auf den aktuellen Stand gebracht:
                                sudo apt update
                                sudo reboot
                                Das sollte man regelmäßig so ein oder zweimal im Monat machen. So bleiben die Upgrades übersichtlich und Sicherheitslücken werden einigermaßen zeitnah gestopft. Generell gilt: Je häufiger ich das mache desto weniger Trouble gibt es. 'Never change a running system' ist grundfalsch.
                                  sudo apt update
                                  @agrippinenser sagte in Info Adapter rot nach Update:
                                  sudo apt update
                                  Da schreibst du was von apt-get.
                                    sudo apt update
                                    Agrippinenser
                                    .. schreibst du was von apt-get.
                                    sorry, nach Rechercheversuchen sitze ich gerade ratlos in meinem Sessel. In der Regel nutze ich bei Updates "Copy/Paste" kann aber nicht mehr richtig nachvollziehen, wie "apt-get" in den Tastaturspeicher kam.
                                    Ich bin glücklich das alles wieder läuft wie es soll und möchte nur Fehler beim zukünftigen Upgrades nicht wiederholen.
                                      @agrippinenser
                                      Das ist ja auch kein Fehler, weil apt bzw apt-get genau das richtige gemäß deren Konfiguration getan haben: Die aktuellste Version nach Priorität eingespielt.
                                        Besser:
                                        sudo apt update
                                        sudo full-upgrade
                                        sudo reboot
                                        Systemupdate
                                        sudo apt update
                                        sudo reboot
                                        amg_666A Offline
                                        amg_666A Offline
                                        amg_666
                                        @agrippinenser ich glaube du musst deinen Pinwand-Zettel korrigieren :-)
                                        sudo full-upgrade führt bei mir zur Fehlermeldung Befehl nicht gefunden.
                                        Ich bleibe bei
                                        • amg_666A amg_666
                                          Ich bleibe bei
                                          Agrippinenser
                                          sudo full-upgrade
                                          hast recht - hier klebt laut und deutlich apt full-upgrade an der Pinwand :-)
