  4. Info Adapter rot nach Update
npm info
20 Beiträge 3 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • amg_666A amg_666
    @thomas-braun sagte in Info Adapter rot nach Update:
    iob nodejs-update 18
    das hats leider nicht gebracht:
    oBroker nodejs fixer 2023-10-13
    You requested to intall latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
    /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
    /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
    /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
    *** nodejs is NOT correctly installed ***
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    Your nodejs-Installation seems to be faulty. Shall we try to fix it?
    Press <y> to continue or any other key to quit
    Fixing your nodejs setup
    *** Deleting  ***
    rm: cannot remove '': No such file or directory
    *** Deleting  ***
    Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
    You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
    Trying to update your installation now. Please be patient.
    Virtualization: lxc
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Get:3 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
    Get:4 http://security.debian.org/debian-security bookworm-security/main Sources [68.7 kB]
    Get:5 http://security.debian.org/debian-security bookworm-security/main amd64 Packages [132 kB]
    Get:6 http://security.debian.org/debian-security bookworm-security/main Translation-en [78.2 kB]
    Fetched 327 kB in 5s (60.8 kB/s)
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
    Fetched 18.8 kB in 6s (3156 B/s)
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    E: Broken packages
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    ich habe danach den Container neu gestartet, info ist weiterhin rot und dieselben Fhlermeldungen im logfile
    @amg_666
    Das Repo ist nun aber richtig.
    sudo apt update
    apt policy nodejs
      @amg_666
      sudo apt update
      apt policy nodejs
      amg_666A Offline
      amg_666A Offline
      amg_666
      apt policy nodejs
      andreas@iobroker:~$ sudo apt update
      [sudo] Passwort fr andreas:
      OK:1 http://security.debian.org/debian-security bookworm-security InRelease
      OK:2 http://deb.debian.org/debian bookworm InRelease
      OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      OK:4 http://deb.debian.org/debian bookworm-updates InRelease
      Abhngigkeitsbaum wird aufgebaut... Fertig
      Statusinformationen werden eingelesen... Fertig
      Alle Pakete sind aktuell.
      andreas@iobroker:~$ apt policy nodejs
      nodejs:
        Installiert:           18.19.0+dfsg-6~deb12u1
        Installationskandidat: 18.19.0-1nodesource1
        Versionstabelle:
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      andreas@iobroker:~$
      und jetzt ?
      • amg_666A amg_666
        apt policy nodejs
        nodejs:
          Versionstabelle:
             18.13.0+dfsg1-1 500
        andreas@iobroker:~$
        und jetzt ?
        @amg_666 sagte in Info Adapter rot nach Update:
        installieren:
        sudo apt install nodejs=18.19.0-1nodesource1
          sudo apt update und dann sudo apt-get dist-upgrade den iob aktualisiert
          Damit wärst du der erste... Das geht nämlich nicht.
          Installier da nochmal per
          das nodesource-Repo drüber.
          amg_666A Offline
          amg_666A Offline
          amg_666
          Danke für die Hilfe, läuft jetzt wieder rund...
          Trotzdem ein (dumme?) Frage: Du hast im ersten Post geschrieben ich wäre da der erste. Ich hab iob wie gesagt als proxmox Container und gehe über proxmox regelmäßig auf die iob Konsole um auf updates zu prüfen. Gefühlt "schon ewig" mit diesen beiden Befehlen:
          sudo apt update
          Was ist daran falsch und wie mache ich es zukünftig richtig?
          • amg_666A amg_666
            sudo apt update
            Das ist nicht falsch, updated aber nicht den iobroker sondern nur das Betriebssystem/Container.
            Ich würde allerdings da
            sudo apt
            sudo apt full-upgrade
            empfehlen.
            Den ioBroker könnte man dann aber per
            iob update
            iob upgrade all
            aktuell halten.
              sudo apt
              empfehlen.
              iob update
              iob upgrade all
              aktuell halten.
              amg_666A Offline
              amg_666A Offline
              amg_666
              @thomas-braun Alles klar, dann habe ich mich missverständlich ausgedrückt. Über die Konsole halte ich natürlich nur den iob Container up-to-date. iobroker updates mache ich eigentlcih immer über die admin oberfläche.
              Nochmals danke für den support.
              • AgrippinenserA Offline
                Agrippinenser
                sorry das ich hier so reinplatze. Ich habe heute morgen nach Update der VM mit
                sudo apt update
                gleiches Verhalten gehabt und bin dankbar hier die Lösung gefunden habe. !
                Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
                • AgrippinenserA Agrippinenser
                  sudo apt update
                  @agrippinenser @amg_666
                  Stellt die Priority für das nodesource-Repo höher.
                  Geht so:
                  echo "Package: nodejs" | sudo tee /etc/apt/preferences.d/nodejs.pref
                  echo "Pin: origin deb.nodesource.com" | sudo tee -a /etc/apt/preferences.d/nodejs.pref
                  echo "Pin-Priority: 1001" | sudo tee -a /etc/apt/preferences.d/nodejs.pref
                  sudo apt update
                  AgrippinenserA 1 Antwort Letzte Antwort
                    Geht so:
                    sudo apt update
                    Agrippinenser
                    habe da vorher mal reingeguckt - das steht darin:
                    Package: nodejs
                    Pin-Priority: 1001
                    Pin-Priority ist demnach schon 1001. Soll ich die 4 Zeilen dennoch ausführen?
                      Package: nodejs
                      Pin-Priority: 1001
                      @agrippinenser
                      Dann dürftest du dir aber nicht die dfsg-Version eingehandelt haben.
                      sudo apt update
                      apt policy nodejs
                      sagt auf deinem System?
                        Package: nodejs
                        Pin-Priority: 1001
                        @agrippinenser
                        Ich sehe gerade, du hantierst da mit apt-get...
                        Das würde ich nicht machen, das tickt anders und berücksichtigt die gesetzten priorities nicht, soweit ich weiß.
                        Besser:
                        sudo apt update
                          @agrippinenser
                          Besser:
                          sudo apt update
                          Agrippinenser
                          Besser:
                          sudo apt update sudo apt full-upgrade
                          unter uns :-) - ich habe eine PIN-Wand vor mir. Daran klebt ein Zettel mit Inhalt:
                          sudo apt update
                          sudo full-upgrade
                          sudo reboot
                          heute Morgen habe ich folgendes im Werkzeugkasten gelesen und daraufhin "blind" sudo apt dist-upgrade ausgeführt.
                          Systemupdate
                          Seinen Debian-basierten Server (dazu gehört z. B. auch das Raspberry OS vom Raspberry Pi, Ubuntu, Armbian) aktuell und 'auf Stand' zu halten braucht es nur wenig Handwerkszeug. Die installierte Software (im Idealfall auch zusätzliche Pakete von Drittanbietern wie deconz, nodeJS von nodesource) wird sehr komfortabel und zentral über den Paketmanager gehandhabt.
                          Mit diesem 'Dreisatz' wird automatisch ein System inkl. aller über den Paketmanager installierten Software auf den aktuellen Stand gebracht:
                          sudo apt update
                          sudo reboot
                          Das sollte man regelmäßig so ein oder zweimal im Monat machen. So bleiben die Upgrades übersichtlich und Sicherheitslücken werden einigermaßen zeitnah gestopft. Generell gilt: Je häufiger ich das mache desto weniger Trouble gibt es. 'Never change a running system' ist grundfalsch.
                            sudo apt update
                            @agrippinenser sagte in Info Adapter rot nach Update:
                            sudo apt update
                            Da schreibst du was von apt-get.
                              sudo apt update
                              Agrippinenser
                              .. schreibst du was von apt-get.
                              sorry, nach Rechercheversuchen sitze ich gerade ratlos in meinem Sessel. In der Regel nutze ich bei Updates "Copy/Paste" kann aber nicht mehr richtig nachvollziehen, wie "apt-get" in den Tastaturspeicher kam.
                              Ich bin glücklich das alles wieder läuft wie es soll und möchte nur Fehler beim zukünftigen Upgrades nicht wiederholen.
                                @agrippinenser
                                Das ist ja auch kein Fehler, weil apt bzw apt-get genau das richtige gemäß deren Konfiguration getan haben: Die aktuellste Version nach Priorität eingespielt.
                                  Besser:
                                  sudo apt update
                                  sudo full-upgrade
                                  sudo reboot
                                  Systemupdate
                                  sudo apt update
                                  sudo reboot
                                  amg_666A Offline
                                  amg_666A Offline
                                  amg_666
                                  @agrippinenser ich glaube du musst deinen Pinwand-Zettel korrigieren :-)
                                  sudo full-upgrade führt bei mir zur Fehlermeldung Befehl nicht gefunden.
                                  Ich bleibe bei
                                  • amg_666A amg_666
                                    Ich bleibe bei
                                    Agrippinenser
                                    sudo full-upgrade
                                    hast recht - hier klebt laut und deutlich apt full-upgrade an der Pinwand :-)
