  4. oft Timeout und langsame Verbindung erkannt
    2.4k
    4.3k
71 Beiträge 10 Kommentatoren 11.0k Aufrufe 10 Beobachtet
  • Thomas123 0T Thomas123 0
    Ich habe jetzt nochmal iob diag laufen lassen
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.1.0-rpi4-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     15:24:42 up 17:10,  4 users,  load average: 1.13, 1.02, 0.83
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-11-02 15:24:42 CET
               Universal time: Thu 2023-11-02 14:24:42 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    Thomas
    /home/Thomas
    Thomas adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        2.9G        2.6G        1.2M        2.8G        5.3G
    Swap:           104M          0B        104M
    Total:          8.3G        2.9G        2.7G
             7811 M total memory
             2794 M used memory
             2768 M active memory
             2277 M inactive memory
             2458 M free memory
              132 M buffer memory
             2549 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     782M  1.2M  781M   1% /run
    /dev/mmcblk0p2 ext4       29G  4.6G   23G  17% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Wed Nov  1 22:13:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:F5:7F:DE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=dfee57ec-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Wed Nov  1 22:13:58 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  1 22:14:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    533M    /var/
    201M    /var/cache
    195M    /var/cache/apt
    159M    /var/lib
    131M    /var/lib/apt
    Archived and active journals take up 72.0M in the file system.
    /opt/iobroker/backups:
    107M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    500M    /opt/iobroker/iobroker-data/
    203M    /opt/iobroker/iobroker-data/files
    128M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    90M     /opt/iobroker/iobroker-data/states.jsonl
    77M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    No connection to databases possible ...
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
      system.adapter.botslab360.0             : botslab360            : iobroker                                 - disabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
      system.adapter.chromecast.1             : chromecast            : iobroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8087, bind: ::, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
      system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.tvprogram.0              : tvprogram             : iobroker                                 - disabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 192.168.2.176, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      system.adapter.wifilight.0              : wifilight             : iobroker                                 - disabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "botslab360"   : 0.0.2    , installed 0.0.2
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.5.5    , installed 6.5.2  [Updatable]
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
    Adapter    "web"          : 6.1.2    , installed 6.1.0  [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
    Objects and States
    Objects:        57778
    States:         51236
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:3 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.2.176:2010      0.0.0.0:*               LISTEN      1001       307455     39627/io.hm-rpc.1
    tcp        0      0 192.168.2.176:2001      0.0.0.0:*               LISTEN      1001       306324     39533/io.hm-rpc.2
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       246518     31672/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       248002     31672/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16506      683/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16508      683/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       247320     31692/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13828      531/avahi-daemon: r
    udp        0      0 0.0.0.0:34964           0.0.0.0:*                           104        13830      531/avahi-daemon: r
    udp6       0      0 fe80::8e9e:365c:6cc:546 :::*                                0          262457     595/NetworkManager
    udp6       0      0 :::33666                :::*                                104        13831      531/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        13829      531/avahi-daemon: r
    2023-11-02 15:34:20.009  - info: javascript.0 (39160) script.js.Solar-Anlage.Einspeisung_Netzbezug: -0.46
    2023-11-02 15:34:20.019  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: getState(id=0_userdata.0.Solar-Anlage.aktuelle_Sonnenleistung, timerId=undefined) => {"val":0,"ack":true,"ts":1698935650039,"q":0,"c":"script.js.Solar-Anlage.Aktuelle_Sonnenenergie","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1698423250031}
    2023-11-02 15:34:20.019  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: getState(id=0_userdata.0.Solar-Anlage.Batterieleistung_in_kW, timerId=undefined) => {"val":0,"ack":true,"ts":1698935650002,"q":0,"c":"script.js.Solar-Anlage.Skript_Batterieleistung_in_kW","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1698451060050}
    2023-11-02 15:34:20.020  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: getState(id=0_userdata.0.Solar-Anlage.Batterieleistung_in_kW, timerId=undefined) => {"val":0,"ack":true,"ts":1698935650002,"q":0,"c":"script.js.Solar-Anlage.Skript_Batterieleistung_in_kW","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1698451060050}
    2023-11-02 15:34:20.020  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: getState(id=0_userdata.0.Solar-Anlage.Einspeisung_Netzbezug, timerId=undefined) => {"val":-0.46,"ack":true,"ts":1698935650034,"q":0,"c":"script.js.Solar-Anlage.Einspeisung_Netzbezug","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1698453580039}
    2023-11-02 15:34:20.020  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Sonnenleistung: 0
    2023-11-02 15:34:20.020  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Batterie: 0
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Batterie-Aufladung: 0
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Batterie-Entladung: 0
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Netz:  -0.46
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Netz-Einspeisung:  0
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Netz-Bezug:  -0.46
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Zwischenwert 2: -0.46
    2023-11-02 15:34:20.021  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Hausverbrauch 3: 0.46
    2023-11-02 15:34:20.022  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: Hausverbrauch 7: 0.46
    2023-11-02 15:34:20.022  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: setForeignState(id=0_userdata.0.Solar-Anlage.Hausverbrauch, state={"val":0.46,"ack":true,"ts":1698935660022,"q":0,"from":"system.adapter.javascript.0","lc":1698453590030,"c":"script.js.Solar-Anlage.Hausverbrauch"})
    2023-11-02 15:34:20.022  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: getState(id=0_userdata.0.Solar-Anlage.Hausverbrauch, timerId=undefined) => {"val":0.46,"ack":true,"ts":1698935650024,"q":0,"c":"script.js.Solar-Anlage.Hausverbrauch","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1698453590030}
    2023-11-02 15:34:20.022  - info: javascript.0 (39160) script.js.Solar-Anlage.Hausverbrauch: "echter Hausverbrauch"0.46
    2023-11-02 15:34:20.035  - info: javascript.0 (39160) script.js.Solar-Anlage.PV_Leistung_Aktuell: 0
    2023-11-02 15:34:20.041  - info: javascript.0 (39160) script.js.Solar-Anlage.Skript_Batterieleistung_in_kW: getState(id=modbus.0.holdingRegisters.62836_Batterieleistung, timerId=undefined) => {"val":0,"ack":true,"ts":1698451050825,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1698451050825}
    2023-11-02 15:34:20.042  - info: javascript.0 (39160) script.js.Solar-Anlage.Skript_Batterieleistung_in_kW: setForeignState(id=0_userdata.0.Solar-Anlage.Batterieleistung_in_kW, state={"val":0,"ack":true,"ts":1698935660042,"q":0,"from":"system.adapter.javascript.0","lc":1698451060050,"c":"script.js.Solar-Anlage.Skript_Batterieleistung_in_kW"})
    2023-11-02 15:34:20.042  - info: javascript.0 (39160) script.js.Solar-Anlage.Skript_Batterieleistung_in_kW: getState(id=0_userdata.0.Wechselrichter.Batterie_leistung_in_kW, timerId=undefined) => {"val":0,"ack":true,"ts":1692188960003,"q":0,"c":"script.js.Solar-Anlage.Skript_Batterieleistung_in_kW","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1692185360002}
    2023-11-02 15:34:20.042  - warn: javascript.0 (39160) script.js.Solar-Anlage.Skript_Batterieleistung_in_kW: 0
    2023-11-02 15:34:20.272  - info: tvspielfilm.0 (40340) Terminated (NO_ERROR): Without reason
                            v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Installation:           native
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    5
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            8.2G        2.1G        3.4G        1.2M        2.8G        6.1G
    Swap:           104M          0B        104M
    Total:          8.3G        2.1G        3.5G
    Active iob-Instances:   20
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                57778
    States:                 51236
    Size of iob-Database:
    84M     /opt/iobroker/iobroker-data/objects.jsonl
    93M     /opt/iobroker/iobroker-data/states.jsonl
    Die Adapter, für die ein Update vorliegt, sind im Moment nicht aktiviert.
    ohle64O Offline
    ohle64O Offline
    ohle64
    #41
    @thomas123-0
    Ich hänge mich mal ran hier. Das Problem hatte ich auch seit Umstellung auf controller >5. Das Problem sind die vielen objects und states. Bei mir sind es nur je ca. 30000 (bei dir >50000!). Das pending beim rega-Adapter hat auch damit zu tun. Der Adapter möchte sein script ausführen - muß aber auf die objects/states warten. Das Problem mit dem Speichern von Blockly kommt auch davon. Wenn ein Wert aus den Objekten genommen wird, habe ich immer gewartet bis der Inhalt sichtbar war und habe dann erst das Auswahl-Fenster mit OK geschlossen. Beim Speichern des Blockly - geduld - warten bis die Instanz wieder da ist - dann wird auch gespeichert.
    Meine Probleme habe ich mit Installation von Redis-Server und der Umstellung von object und states auf redis gelöst.
    Das sollten sich die controller -Entwickler mal genauer anschauen.
    Meine controller CPU-Belastung ist so von manchmal mehr als 100%(im Schnitt meist mehr als 60%) auf jetzt 0,33% gesunken.
    Wer Fehler findet, darf sie behalten!
    Thomas123 0T 1 Antwort Letzte Antwort
    • ohle64O ohle64
      @thomas123-0
      Thomas123 0T Offline
      Thomas123 0
      #42
      @ohle64
      Danke erstmal für den Tip mit dem Warten, bis die Werte erscheinen. Das hat schon mal insofern geholfen, dass er nicht "abschmiert". Aber es dauert ewig, bis die Werte erscheinen, und man dann endlich ok drücken kann.
      Er schreibt auch brav die Werte in die Systemvriablen der hm-rega, aber in der CCU kommen die geänderten Werte nicht an...
      Von Redis hab ich bisher nix gehört. Hast Du einen Link zu einer "idiotensicheren" Beschreibung, wie und wo es installiert wird? Was ich bisher dazu gefunden habe, verwirrt mich sehr.
      Gruss
      Thomas
      HomoranH ohle64O 2 Antworten Letzte Antwort
        @ohle64
        #43
        @thomas123-0 sagte in oft Timeout und langsame Verbindung erkannt:
        wie? genau!
          wie? genau!
          Thomas123 0
          #44
          das Script läuft durch, und die Daten werden im ioBroker im Adapter hm-rega geschrieben. Rufe ich die CCU auf, sind da in den Systemvariablen noch die alten Daten, und nicht die vom Script geänderten
          Gruss
          Thomas
            #45
            wie schre7bt das script?
              @samson71
              Eigentlich ein ganz einfaches...
              #46
              @samson71
              ist es das???
              dann ändere mal den Block auf einen steuere Block
                @ohle64
                ohle64O Offline
                ohle64O Offline
                ohle64
                #47
                @thomas123-0
                Einen idiotensicheren Link wirst du nicht finden. Ich hab auch nur hier im Forum die Schritte gesucht und so ausgeführt. Wird ja oft genug beschrieben. Bei mir gab's auch noch ein Problem mit den objects - da stand noch der alte Host drin und wurde nicht migriert. Das beste ist ein ordentliches Backup und viel lesen. Ja das Thema ist anspruchsvoll aber machbar. Und wie schon gesagt - es bringt auch etwas an Leistung. Wichtig ist Installation des redis(der ist nicht überall dabei) - dann das der auch als Systemdienst läuft - dann die Migration und auch die Hinweise beachten zwecks Spracheinstellung hier. Das so in groben Zügen.
                • Thomas123 0T Offline
                  Thomas123 0
                  schrieb am zuletzt editiert von Thomas123 0
                  #48
                  @ohle64
                  redis habe ich jetzt installiert.
                  Aber der ioBroker ist immer noch grottenlangsam...
                  Ich verzweifele langsam
                  Herzlichen Dank schon einmal an alle, die sich mit meinem Problem beschäftigt haben.
                  Gruss
                  Thomas
                    @samson71
                    ist es das???
                    Thomas123 0
                    #49
                    @homoran said in oft Timeout und langsame Verbindung erkannt:
                    @samson71
                    ist es das???
                    Das war es. Dankeschön.
                    Ich sehe schon den Wald vor lauter Bäumen nicht mehr.
                    Gruss
                    Thomas
                      @samson71
                      ist es das???
                      Thomas123 0
                      #50
                      So, ich kann Erfolg vermelden.
                      Nachdem ich Redis-Server installiert habe, hat sich nun alles normalisiert.
                      Danke noch einmal an Alle und speziell an @ohle64 für den Tip mit Redis-Server.
                      Gruss
                      Thomas
                        Thomas123 0
                        #51
                        die Freude hat nicht lange gehalten...
                        ioBroker ist wieder extrem langsam und ich brauche (erneut) Hilfe.
                        hier die Zusammenfassung von iob diag:
                                                v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               arm64
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     7
                        Pending iob updates:    1
                                                /usr/bin/npm            9.8.1
                                                /usr/bin/npx            9.8.1
                        MEMORY:
                        Mem:            8.2G        2.1G        4.7G        1.2M        1.5G        6.1G
                        Swap:           104M          0B        104M
                        Total:          8.3G        2.1G        4.8G
                        Active iob-Instances:   29
                                                admin                   6.12.0
                        Objects type: redis
                        States  type: redis
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.2.176, run as: admin
                        Objects:                58977
                        States:                 54714
                        90M     /opt/iobroker/iobroker-data/objects.jsonl
                        35M     /opt/iobroker/iobroker-data/states.jsonl
                        und hier die ausführliche iob diag:
                        ======== Start marking the full check here =========
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         17:44:41 up 22:54,  3 users,  load average: 1.60, 1.72, 1.87
                        CPU threads: 4
                        Current issues:
                        ~ Under-voltage has occurred
                                       Local time: Tue 2023-11-07 17:44:41 CET
                                   Universal time: Tue 2023-11-07 16:44:41 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        Thomas
                        /home/Thomas
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.2G        2.3G        4.5G        1.2M        1.5G        5.9G
                        Swap:           104M          0B        104M
                        Total:          8.3G        2.3G        4.6G
                                 7811 M total memory
                                 2184 M used memory
                                 2112 M active memory
                                 1125 M inactive memory
                                 4311 M free memory
                                  103 M buffer memory
                                 1342 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/mmcblk0p2 ext4       29G  5.0G   23G  19% /
                        [Mon Nov  6 18:50:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:F5:7F:DE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=dfee57ec-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                        [Mon Nov  6 18:50:25 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Mon Nov  6 18:50:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        /var:
                        694M    /var/
                        311M    /var/lib
                        201M    /var/cache
                        195M    /var/cache/apt
                        152M    /var/lib/redis
                        Archived and active journals take up 80.0M in the file system.
                        135M    /opt/iobroker/backups/
                        475M    /opt/iobroker/iobroker-data/
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        No connection to objects 127.0.0.1:6379[redis]
                        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                throw e;
                        Error: Connection is closed.
                            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                            at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                            at Object.onceWrapper (node:events:632:26)
                            at Socket.emit (node:events:517:28)
                            at TCP.<anonymous> (node:net:350:12)
                        Emitted 'error' event on ScanStream instance at:
                            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                        Node.js v18.18.2
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapters from github:   4
                        Adapter State
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                          system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
                        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                          system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: ::, run as: admin
                        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                        + system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + instance is alive
                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                        Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
                        Adapter    "web"          : 6.1.4    , installed 6.1.4
                        Adapter    "ws"           : 2.5.5    , installed 2.5.7
                        Objects and States
                        Objects:        58977
                        States:         54714
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Pending Updates: 7
                        tcp        0      0 192.168.2.176:8082      0.0.0.0:*               LISTEN      1001       1247846    91393/io.web.0
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1249962    91170/io.jarvis.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15649      681/sshd: /usr/sbin
                        tcp        0      0 192.168.2.176:2010      0.0.0.0:*               LISTEN      1001       1240937    90279/io.hm-rpc.1
                        tcp        0      0 192.168.2.176:2001      0.0.0.0:*               LISTEN      1001       1243406    90338/io.hm-rpc.2
                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        14081      668/redis-server 12
                        tcp6       0      0 ::1:6379                :::*                    LISTEN      106        14082      668/redis-server 12
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          15651      681/sshd: /usr/sbin
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1240833    90243/io.sonos.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1241242    89385/io.admin.0
                        udp        0      0 0.0.0.0:58203           0.0.0.0:*                           104        14021      533/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14019      533/avahi-daemon: r
                        udp6       0      0 fe80::8e9e:365c:6cc:546 :::*                                0          50577      604/NetworkManager
                        udp6       0      0 :::54165                :::*                                104        14022      533/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                104        14020      533/avahi-daemon: r
                        2023-11-07 17:46:20.009  - info: javascript.0 (89803) script.js.Solar-Anlage.Skript_Batterieleistung_in_kW: Batterie-Ladung: [object Object]
                        2023-11-07 17:46:20.379  - info: javascript.0 (89803) Stop script script.js.Solar-Anlage.Hausverbrauch2
                        2023-11-07 17:46:20.423  - info: javascript.0 (89803) Start javascript script.js.Solar-Anlage.Hausverbrauch2
                        2023-11-07 17:46:20.433  - info: javascript.0 (89803) script.js.Solar-Anlage.Hausverbrauch2: schedule(cron=*/10 * * * *)
                        2023-11-07 17:46:20.435  - info: javascript.0 (89803) script.js.Solar-Anlage.Hausverbrauch2: getState(id=0_userdata.0.Solar-Anlage.Hausverbrauch, timerId=undefined) => {"val":0.9304,"ack":true,"ts":1699375200322,"q":0,"c":"script.js.Solar-Anlage.Hausverbrauch2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1699375200322}
                        2023-11-07 17:46:20.436  - info: javascript.0 (89803) script.js.Solar-Anlage.Hausverbrauch2: hausverbrauch: 0.9304
                        2023-11-07 17:46:20.436  - info: javascript.0 (89803) script.js.Solar-Anlage.Hausverbrauch2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                        2023-11-07 17:46:21.002  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: getState(id=modbus.0.holdingRegisters.206_MeterPowerTotal, timerId=undefined) => {"val":-15,"ack":true,"ts":1699375579953,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1699375579953}
                        2023-11-07 17:46:21.002  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: getState(id=modbus.0.holdingRegisters.210_MeterPowerSF, timerId=undefined) => {"val":0,"ack":true,"ts":1699374698328,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1696827907914}
                        2023-11-07 17:46:21.003  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: Neuer Wert: -15
                        2023-11-07 17:46:21.003  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: setForeignState(id=0_userdata.0.Solar-Anlage.Einspeisung_Netzbezug, state={"val":-0.015,"ack":true,"ts":1699375581003,"q":0,"from":"system.adapter.javascript.0","lc":1699375581003,"c":"script.js.Solar-Anlage.Einspeisung_Netzbezug"})
                        2023-11-07 17:46:21.003  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: getState(id=0_userdata.0.Solar-Anlage.Einspeisung_Netzbezug, timerId=undefined) => {"val":0.018,"ack":true,"ts":1699375578010,"q":0,"c":"script.js.Solar-Anlage.Einspeisung_Netzbezug","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1699375578010}
                        2023-11-07 17:46:21.003  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: Einspeisung Netzbezug: -0.015
                        2023-11-07 17:46:21.008  - info: javascript.0 (89803) script.js.Energie.Licht: 46.42
                        2023-11-07 17:46:21.011  - info: javascript.0 (89803) script.js.Energie.Heizdecken: 0
                        2023-11-07 17:46:21.015  - info: javascript.0 (89803) script.js.Energie.Steckdosen: 46.42
                        2023-11-07 17:46:24.002  - info: javascript.0 (89803) script.js.Energie.Steckdosen: 46.42
                        2023-11-07 17:46:24.004  - info: javascript.0 (89803) script.js.Energie.Heizdecken: 0
                        2023-11-07 17:46:24.007  - info: javascript.0 (89803) script.js.Energie.Licht: 46.42
                        2023-11-07 17:46:24.009  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: getState(id=modbus.0.holdingRegisters.206_MeterPowerTotal, timerId=undefined) => {"val":-6,"ack":true,"ts":1699375583666,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1699375583666}
                        2023-11-07 17:46:24.009  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: getState(id=modbus.0.holdingRegisters.210_MeterPowerSF, timerId=undefined) => {"val":0,"ack":true,"ts":1699374698328,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1696827907914}
                        2023-11-07 17:46:24.010  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: Neuer Wert: -6
                        2023-11-07 17:46:24.010  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: setForeignState(id=0_userdata.0.Solar-Anlage.Einspeisung_Netzbezug, state={"val":-0.006,"ack":true,"ts":1699375584010,"q":0,"from":"system.adapter.javascript.0","lc":1699375584010,"c":"script.js.Solar-Anlage.Einspeisung_Netzbezug"})
                        2023-11-07 17:46:24.010  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: getState(id=0_userdata.0.Solar-Anlage.Einspeisung_Netzbezug, timerId=undefined) => {"val":-0.015,"ack":true,"ts":1699375581003,"q":0,"c":"script.js.Solar-Anlage.Einspeisung_Netzbezug","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1699375581003}
                        2023-11-07 17:46:24.011  - info: javascript.0 (89803) script.js.Solar-Anlage.Einspeisung_Netzbezug: Einspeisung Netzbezug: -0.006
                        Was kann ich tun??
                        Gruss
                        Thomas
                        DJMarc75D Thomas BraunT ? 3 Antworten Letzte Antwort
                                                  v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               arm64
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.8.1
                                                  /usr/bin/npx            9.8.1
                          MEMORY:
                          Swap:           104M          0B        104M
                                                  admin                   6.12.0
                          Objects type: redis
                          States  type: redis
                          Objects:                58977
                          States:                 54714
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          Thomas
                          /home/Thomas
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           104M          0B        104M
                                   7811 M total memory
                                   2184 M used memory
                                   4311 M free memory
                                    103 M buffer memory
                                   1342 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          694M    /var/
                          311M    /var/lib
                          201M    /var/cache
                          195M    /var/cache/apt
                          152M    /var/lib/redis
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                                  throw e;
                          Node.js v18.18.2
                          admin:          6.12.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        58977
                          States:         54714
                          Pending Updates: 7
                          Was kann ich tun??
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #52
                          Zu schwaches Netzteil
                          Pending Updates: 7
                          Updates einspielen
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            Pending Updates: 7
                            Updates einspielen
                            Thomas123 0
                            #53
                            @djmarc75
                            Dankeschön.
                            Updates habe ich eingespielt.
                            Thema Netzteil. Das ist das Netzteil, das bei dem Raspi-Set damals dabei war, und sollte also (eigentlich) passen.
                            Kann das Netzteil "kaputt" sein?
                            Gruss
                            Thomas
                              @djmarc75
                              Dankeschön.
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #54
                              Keine Ahnung. Aber Netzteile können, wie alle elektronischen Artikel, irgendwann in die Knie gehen ;)
                                Thomas123 0
                                #55
                                @djmarc75 said in oft Timeout und langsame Verbindung erkannt:
                                Dann bestelle ich mal ein neues :-)
                                Gruss
                                Thomas
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #56
                                  @thomas123-0 Hast Du denn eine SSD an Deinem RPI hängen ?
                                    Thomas123 0
                                    #57
                                    @djmarc75 nein
                                    Gruss
                                    Thomas
                                                              v.2023-10-10
                                             Icon name: computer
                                          Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               arm64
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Swap:           104M          0B        104M
                                                              admin                   6.12.0
                                      Objects type: redis
                                      States  type: redis
                                      Objects:                58977
                                      States:                 54714
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      Thomas
                                      /home/Thomas
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           104M          0B        104M
                                               7811 M total memory
                                               2184 M used memory
                                               4311 M free memory
                                                103 M buffer memory
                                               1342 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      694M    /var/
                                      311M    /var/lib
                                      201M    /var/cache
                                      195M    /var/cache/apt
                                      152M    /var/lib/redis
                                      USB-Devices by-id:
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      ioBroker Status
                                              throw e;
                                      Node.js v18.18.2
                                      admin:          6.12.0
                                      javascript:     7.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        58977
                                      States:         54714
                                      Pending Updates: 7
                                      Was kann ich tun??
                                      #58
                                      Da klemmt es noch irgendwo beim redis:
                                              throw e;
                                      systemctl status redis
                                      sagt?
                                                throw e;
                                        sagt?
                                        Thomas123 0
                                        #59
                                        @thomas-braun said in oft Timeout und langsame Verbindung erkannt:
                                        Thomas@iobroker:~ $ systemctl status redis
                                        * redis-server.service - Advanced key-value store
                                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset: enabled)
                                             Active: active (running) since Mon 2023-11-06 18:46:04 CET; 1 day 19h ago
                                               Docs: http://redis.io/documentation,
                                                     man:redis-server(1)
                                           Main PID: 668 (redis-server)
                                             Status: "Ready to accept connections"
                                              Tasks: 5 (limit: 8741)
                                                CPU: 9h 25min 32.206s
                                             CGroup: /system.slice/redis-server.service
                                                     `-668 "/usr/bin/redis-server 127.0.0.1:6379"
                                        Nov 06 18:46:00 iobroker systemd[1]: Starting redis-server.service - Advanced key-value store...
                                        Nov 06 18:46:04 iobroker systemd[1]: Started redis-server.service - Advanced key-value store.
                                        Thomas@iobroker:~ $
                                        Gruss
                                        Thomas
                                                       man:redis-server(1)
                                          Thomas@iobroker:~ $
                                          #60
                                          @thomas123-0
                                          .kay...
                                          Hatte eigentlich erwartet, dass da mehr zu sehen ist.
                                          Starten den vielleicht mal durch.
                                          sudo systemctl restart redis-server
                                          ? 1 Antwort Letzte Antwort
