  4. Test Adapter Zendure Solarflow
2.7k Beiträge 129 Kommentatoren 1.4m Aufrufe 128 Beobachtet
  • J jan_xx
    @nograx
    Guten Morgen, ich sehe die 1.11.0 leider nicht, hab schon auf beta umgestellt und trotzdem lässt er sich nicht updates, woran kann das liegen?
    Grüße
    #781
    @jan_xx sagte in Test Adapter Zendure Solarflow:
    Repo auch aktualisiert?
    Hier kommt die Version nämlich einwandfrei rein:
    echad@chet:~ $ iob add zendure-solarflow --host chet --debug
    NPM version: 10.9.2
    Installing iobroker.zendure-solarflow@1.11.0... (System call)
    added 2 packages in 10s
    245 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter zendure-solarflow
    upload [7] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/build/index.css build/index.css text/css
    upload [6] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/build/index.css.map build/index.css.map application/json
    upload [5] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/build/index.js build/index.js application/javascript
    upload [4] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/build/index.js.map build/index.js.map application/json
    upload [3] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/donate-with-paypal.png donate-with-paypal.png image/png
    upload [2] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/index_m.html index_m.html text/html
    upload [1] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/style.css style.css text/css
    upload [0] zendure-solarflow.admin /opt/iobroker/node_modules/iobroker.zendure-solarflow/admin/zendure-solarflow.png zendure-solarflow.png image/png
    host.chet object system.adapter.zendure-solarflow created/updated
    Updating objects from io-package.json for adapter "zendure-solarflow" with version "1.11.0"
    host.chet create instance zendure-solarflow
    host.chet object system.adapter.zendure-solarflow.0.alive created
    host.chet object system.adapter.zendure-solarflow.0.connected created
    host.chet object system.adapter.zendure-solarflow.0.compactMode created
    host.chet object system.adapter.zendure-solarflow.0.cpu created
    host.chet object system.adapter.zendure-solarflow.0.cputime created
    host.chet object system.adapter.zendure-solarflow.0.memHeapUsed created
    host.chet object system.adapter.zendure-solarflow.0.memHeapTotal created
    host.chet object system.adapter.zendure-solarflow.0.memRss created
    host.chet object system.adapter.zendure-solarflow.0.uptime created
    host.chet object system.adapter.zendure-solarflow.0.inputCount created
    host.chet object system.adapter.zendure-solarflow.0.outputCount created
    host.chet object system.adapter.zendure-solarflow.0.eventLoopLag created
    host.chet object system.adapter.zendure-solarflow.0.sigKill created
    host.chet object system.adapter.zendure-solarflow.0.logLevel created
    host.chet object system.adapter.zendure-solarflow.0 created
    echad@chet:~ $
    echad@chet:~ $ iob version zendure-solarflow
    1.11.0
    echad@chet:~ $
    J 1 Antwort Letzte Antwort
      NPM version: 10.9.2
      echad@chet:~ $
      1.11.0
      echad@chet:~ $
      jan_xx
      #782
      Eine blöde Frage von mir, wie aktualisiert man Repo?
      Danke!
      • J jan_xx
        Danke!
        #783
        @jan_xx
        Schau dir
        iob repo list
        iob update
        an.
          @jan_xx
          Schau dir
          iob repo list
          iob update
          an.
          jan_xx
          schrieb am zuletzt editiert von jan_xx
          #784
          das geht bei mir nicht?🙄
          Hab jetzt den Adapter neu von githup geladen und installiert, jetzt habe ich die 1.11 drauf.
          Keine Ahnung warum es nicht anders ging...
          • nograxN nograx
            Moin,
            ich habe Version 1.11.0 bereitgestellt. Damit sollte es möglich sein über control.autoModel den Betriebsmodus (Termin, CT, Bat Prio etc.) zu setzen. Wenn man das outputLimit setzen will muss dieser auf 0 stehen. Damit sollte es nun möglich sein zwischen den einzelnen Modi hin und her zu schalten.
            Außerdem gibts mit heatState und autoModel neue States. Gab bei einigen auch einen Fehler mit dem gridPower State, der wurde auch behoben.
            Gruß,
            Peter
            jan_xx
            #785
            @nograx
            Wenn ich im neuen Datenpunkt den Hyper umschalten will, wird nach einigen Sekunden wieder auf den SmartctModus(9) gewechselt, warum wird das nicht übernommen wenn ich den Wert unter Objekten ändere?
            Grüße
            nograxN 1 Antwort Letzte Antwort
            • J jan_xx
              #786
              @jan_xx
              Das sind ja auch zwei Kommandos.
              Was kommt bei
              iob update
              nun? Und lass den Mist, direkt von github irgendwelches Zeug zu ziehen.
              (Und BITTE keine Screenshots von TEXTEN).
                @jan_xx
                Was kommt bei
                iob update
                jan_xx
                #787
                Adapter "zendure-solarflow": 1.10.0, installed 1.11.0
                wie gesagt habe es jetzt mit dem Hintertürchen installiert.
                Funktioniert bei dir die Umschaltung wenn du den einen DP änderst?
                • J jan_xx
                  #788
                  Nur bei dem 'Hintertürchen' ist nicht gesagt, welche Version du da genau hast.
                  Und du solltest die Ausgaben ZEIGEN, nach denen du gefragt wirst.
                    jan_xx
                    #789
                    es steht jetzt 1.11 unter Eigenschaften des Adapters, darauf sollte man doch vertrauen können?🙄
                    • J jan_xx
                      #790
                      Nein, NICHT bei Github-Installationen. Da liegt es in der Natur der Sache, das das 'irgendein' Versionsstand frisch von der Werkbank des Coders gezogen wird. Weswegen das auch nur in Absprache mit dem Programmierer getan werden soll.
                      Versionsnummern sind Schall und Rauch.
                      • J jan_xx
                        #791
                        @jan_xx
                        Ausgaben (als TEXT, in CodeTags!!!) zeigen:
                        iob repo list
                        iob update
                          nograxN Online
                          nograxN Online
                          nograx
                          #792
                          @thomas-braun sagte in Test Adapter Zendure Solarflow:
                          Da wird die letzte freigebene Version unter "Releases" gezogen. Da kann auch mal eine Version drunter sein die nicht im offiziellen Stable oder Beta Repo landen. Aber eine Versionsnummer erhält sie in jedem Fall und wenn er nun die 1.11 installiert hat dann hat er auch genau den Stand der im Beta Repo ist.
                          Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                          • J jan_xx
                            @nograx
                            Grüße
                            nograxN Online
                            nograxN Online
                            nograx
                            #793
                            @nograx
                            Grüße
                            Nutzt du hier den DP im Ordner "control"?
                            • nograxN nograx
                              #794
                              @nograx sagte in Test Adapter Zendure Solarflow:
                              Das ist dann aber nur zufällig gleich. Es könnte auch mit gleicher Versionsnummer ein ganz anderer Commit-Stand geladen werden.
                              Nein, es wird der letzte Commit mit dessen Commit-Hash gezogen.
                              Frag mal @mcm1957 nach GitHub-Installationen...
                              • nograxN nograx
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #795
                                @nograx said in Test Adapter Zendure Solarflow:
                                @nograx
                                Sorry aber deine Aussage ist TOTAL FALSCH
                                Bei einer ioBroker Installation "von Github" interessiert niemand was auf Github unter Releases aufscheint. Die Anzeige von Releases auf Github ist überhaupt rein informativer Natur und wird zu keiner Zeit von irgendwelchen Installationen beachtet. Wenn du schaust gibt aus auch zig Adapter die keine oder nur veraltetet Versionen unter Releases anzeigen.
                                Bei einer Github Installation wird bei Verwendung der üblichen url die auf das Repo zeigt IMMER der letzte Commitstand installiert. Das kann identisch zur letzten auf npm veröffentlichten Release sein - ist es aber in vielen Fällen nicht da entweder der User schon etwas am Code geändert hat oder z.B. dependabot ein Update eingespielt hat.
                                Wie Thomas schon richtig geschrieben hat (DANKE dafür) - Versionensangaben sind bei einer Github Installation Schall und Rauch. Sie sind ein Indiz was "in etwa" installiert ist - aber den genauen Stand beschreiben sie nie und nimmer. Der ist in diesem Fall nur durch die Github Commit SHA eindeutig bestimmbar.
                                FALSCH
                                Ja, nur können zig auch total unterschiedliche Versionen dann mit 1.11 aufscheinen. Wenn man genau den Stand installiert haben will, der im Repositoriy unter 1.11. gelistet ist MUSS man via Repositoriy oder von npm installieren.
                                Wenn du uns nicht glaubts versuch mach folgendes:
                                • installier einen deiner Adapter in der letzen offiziellen Version (via Repo)
                                • ändere deinen Main Code und trag z.b: "this.log('Hi i am modified');" in die onReady Routine ein
                                • installier von Github
                                Und du wirst die neue Meldung sehen - was wohl eindeutig beweist dass der Codestand nicht mehr jener Version entspricht du angezeigt wird.
                                Alternativ denk mal drüber nach wie oft es im Zuge einer Fehlersuche heißt installier nochmal von Github. Neuer Code wird installiert aber Release bleibt da gleich solange bis der Dev eine neue Release erstellt und deployed.
                                Der Vollständigkeit und als Info für alle MItleser:
                                Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                                GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                Und falls es irgendwie unklar ist:
                                ioBroker unterstützt folgende Arten von Installation:
                                • aus dem STABLE Repository
                                  Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                • aus dem LATEST Repository
                                  Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                • direkt von GITHUB
                                  Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                • direkt von npm
                                  Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • nograxN nograx
                                  @nograx
                                  Grüße
                                  jan_xx
                                  #796
                                  @nograx
                                  Ja ich habe die neuen DP beschrieben, das sollte doch eigentlich reichen?
                                  • mcm1957M mcm1957
                                    @nograx
                                    FALSCH
                                    • direkt von GITHUB
                                    • direkt von npm
                                    nograxN Online
                                    nograxN Online
                                    nograx
                                    #797
                                    @mcm1957 Danke für die Aufklärung. Da lag ich falsch. Ich bin tatsächlich davon ausgegangen das dann das bei Github hinterlegte letzte Release gezogen wird.
                                    • J jan_xx
                                      @nograx
                                      nograxN Online
                                      nograxN Online
                                      nograx
                                      #798
                                      @nograx
                                      Wichtig dabei ist das du den Punkt in "control" nutzt und nicht den direkt unter dem Device. Das sollte reichen, ich habe da aber wenig Erfahrungswerte, konnte es bisher nur mit dem HUB1200 und HUB2000 testen.
                                      • nograxN nograx
                                        @nograx
                                        jan_xx
                                        #799
                                        @nograx #Irgendwie passiert hier nix, die Kiste bleibt im Smart CT Modus...?
                                        • nograxN nograx
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #800
                                          Gern geschehen. Hoff ich habs nicht zu schulmeisternd rübergebracht.
                                          Die gebetsmühlenartige Wiederholung nicht von Github zu installieren soll ja nicht als Schikane verstanden werden sondern vor allem auf produktiven Systemen Klarheit schaffen was denn nun genau installiert ist. Es ist voll OK wenn ein Dev im Zuge einer Fehlernalyse Github Installs anregt damit z.B: Qickhacks / Juhu-Debugger etc rasch auf das Usersystem kommen. Aber bitte bei "Normalbeetrieb" vermeiden.
                                          Persönlich verwende ich bei Fixes vorzugsweise -alpha.x Versionen. Die sind via npm genauso nachvollziehbar wie normale Releases kommen aber - bei Verwendung des standardmäßigen Deplox Wrokflows - nicht ins Latest. Im Proinzip sind sie also fast Github Installs mit Versionierung :-)
                                          Grüße Mcm1957
