  4. Proxmox neues LXC Container, fehler im iob diag
30 Beiträge 4 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • Eduard77E Eduard77
    Ich habe jetzt Drittes Mal Debian und ioBroker installiert.
    Und bekomme die gleichen Fehlermeldungen.
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
    model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     10:38:55 up  1:41,  0 user,  load average: 0.12, 0.46, 0.69
    CPU threads: 4
    *** Time and Time Zones ***
    Failed to query server: Connection timed out
    *** User and Groups ***
    edi77
    /home/edi77
    edi77 sudo users iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            6.4G        4.1G        1.5G         32K        846M        2.3G
    Swap:           2.1G        196M        2.0G
    Total:          8.6G        4.3G        3.5G
             6144 M total memory
             3905 M used memory
             1311 M active memory
             3251 M inactive memory
             1431 M free memory
                0 M buffer memory
              807 M swap cache
             2048 M total swap
              187 M used swap
             1860 M free swap
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * nftables.service                   loaded failed failed nftables
    * systemd-firstboot.service          loaded failed failed First Boot Wizard
    * systemd-hostnamed.service          loaded failed failed Hostname Service
    * systemd-logind.service             loaded failed failed User Login Management
    * systemd-networkd.service           loaded failed failed Network Configuration
    * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
    * systemd-sysusers.service           loaded failed failed Create System Users
    * systemd-timedated.service          loaded failed failed Time & Date Service
    * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
    * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
    * systemd-tmpfiles-setup.service     loaded failed failed Create Volatile Files and Directories
    * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
    12 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--102--disk--0 ext4    20G  3.6G   15G  20% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  3.7G     0  3.7G   0% /dev/shm
    tmpfs                            tmpfs  1.5G   76K  1.5G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    [Tue Oct 10 18:15:55 2023] EXT4-fs (dm-1): re-mounted dcc632b4-4524-4008-a047-ede87046e036. Quota mode: none.
    [Tue Oct 10 18:16:10 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
    [Mon Oct 16 19:02:53 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
    [Mon Oct 16 19:02:54 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
    [Mon Oct 23 19:10:53 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
    [Mon Oct 23 19:11:02 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
    [Mon Oct 23 19:11:37 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
    [Mon Oct 23 19:26:39 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
    [Mon Oct 23 19:26:40 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
    [Mon Oct 23 19:28:34 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
    [Mon Oct 23 19:34:36 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
    [Mon Oct 23 19:34:47 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
    [Mon Oct 23 19:34:48 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
    [Mon Oct 23 19:36:13 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Mon Oct 23 19:36:13 2023] EXT4-fs (dm-9): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 without journal. Quota mode: none.
    [Mon Oct 23 19:36:26 2023] EXT4-fs (dm-9): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
    [Mon Oct 23 20:22:21 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
    [Mon Oct 23 20:39:38 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
    [Mon Oct 23 20:51:44 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
    [Tue Oct 24 17:16:17 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
    [Tue Oct 24 17:43:23 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
    [Tue Oct 24 18:05:03 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
    [Tue Oct 24 18:05:05 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
    [Tue Oct 24 18:36:27 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
    [Tue Oct 24 18:37:45 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
    [Tue Oct 24 18:37:52 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
    [Tue Oct 24 18:38:13 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
    [Tue Oct 24 19:01:58 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
    [Tue Oct 24 19:01:59 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
    [Tue Oct 24 19:43:32 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
    [Tue Oct 24 19:43:34 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
    [Tue Oct 24 20:14:59 2023] EXT4-fs (dm-7): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b without journal. Quota mode: none.
    [Tue Oct 24 20:16:54 2023] EXT4-fs (dm-7): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
    [Tue Oct 24 20:38:16 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
    [Tue Oct 24 20:38:24 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
    [Tue Oct 24 20:38:25 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
    [Tue Oct 24 20:46:57 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
    [Tue Oct 24 20:46:59 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
    [Tue Oct 24 20:49:37 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
    [Tue Oct 24 20:49:39 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
    [Tue Oct 24 21:35:39 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
    [Tue Oct 24 21:35:50 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
    [Tue Oct 24 21:37:31 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
    [Tue Oct 24 21:37:33 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
    [Tue Oct 24 22:16:36 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
    [Wed Oct 25 08:34:59 2023] EXT4-fs (dm-8): mounted filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f with ordered data mode. Quota mode: none.
    [Wed Oct 25 08:35:08 2023] EXT4-fs (dm-8): unmounting filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f.
    [Wed Oct 25 08:35:09 2023] EXT4-fs (dm-8): mounted filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f with ordered data mode. Quota mode: none.
    [Wed Oct 25 08:55:04 2023] EXT4-fs (dm-8): unmounting filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f.
    [Wed Oct 25 08:57:14 2023] EXT4-fs (dm-8): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 with ordered data mode. Quota mode: none.
    [Wed Oct 25 08:57:23 2023] EXT4-fs (dm-8): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
    [Wed Oct 25 08:57:25 2023] EXT4-fs (dm-8): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 with ordered data mode. Quota mode: none.
    [Wed Oct 25 08:58:44 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed Oct 25 08:58:44 2023] EXT4-fs (dm-9): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 without journal. Quota mode: none.
    [Wed Oct 25 08:58:57 2023] EXT4-fs (dm-9): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
    [Wed Oct 25 09:34:58 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
    [Wed Oct 25 09:34:58 2023] EXT4-fs (dm-9): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 without journal. Quota mode: none.
    [Wed Oct 25 09:35:51 2023] EXT4-fs (dm-9): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
    Show mounted filesystems \(real ones only\):
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
    /var:
    416M    /var/
    247M    /var/cache
    243M    /var/cache/apt
    168M    /var/cache/apt/archives
    145M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    31M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    524M    /opt/iobroker/iobroker-data/
    346M    /opt/iobroker/iobroker-data/files
    149M    /opt/iobroker/iobroker-data/history
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/echarts
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.mihome-cloud.0           : mihome-cloud          : ioBroker                                 - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 8086
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "deyeidc"      : 0.0.11   , installed 0.0.11
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.1
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "snmp"         : 2.4.11   , installed 2.4.11
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        3254
    States:         2586
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32714961   1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       32839125   13468/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32800660   11672/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32801525   11672/iobroker.js-c
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          32586457   306/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          32587208   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          32714066   1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          32586458   306/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32802908   11699/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32841881   13599/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       32840569   13614/io.ws.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32839861   13438/io.simple-api
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32715870   1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       32839817   13419/io.mihome-vac
    udp        0      0 0.0.0.0:46499           0.0.0.0:*                           1001       32839909   13453/io.snmp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32840860   13543/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32840861   13543/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          32714963   1/init
    2023-10-25 10:38:13.066  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:14.291  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
    2023-10-25 10:38:19.911  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:24.399  - info: hmip.0 (13393) ws connection opened
    2023-10-25 10:38:26.747  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:33.560  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:34.543  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
    2023-10-25 10:38:40.367  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:44.645  - info: hmip.0 (13393) ws connection opened
    2023-10-25 10:38:47.177  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:53.997  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:38:54.794  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
    2023-10-25 10:39:00.793  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:04.917  - info: hmip.0 (13393) ws connection opened
    2023-10-25 10:39:07.617  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:14.436  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:15.062  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
    2023-10-25 10:39:21.334  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:25.164  - info: hmip.0 (13393) ws connection opened
    2023-10-25 10:39:28.145  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:34.951  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:35.309  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
    2023-10-25 10:39:41.757  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    2023-10-25 10:39:45.411  - info: hmip.0 (13393) ws connection opened
    2023-10-25 10:39:48.564  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    iob diag has finished.
    crunchipC Offline
    crunchipC Offline
    @edis77 sagte in Proxmox neues LXC Container, fehler im iob diag:
    Da stimmt doch vermutlich in deiner Grundinstallation schon etwas nicht
    Eduard77E 1 Antwort Letzte Antwort
      Eduard77E Offline
      Eduard77E Offline
      Eduard77
      @crunchip
      ich glaube ich habe mein Fehler gefunden.
      Ich wollte ein Privilegierte Container erstellen.
      Das hat bei mir immer zu dem Fehler geführt.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Failed to query system properties: Connection timed out
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
       11:50:44 up 20 min,  0 user,  load average: 0.51, 0.62, 0.50
      CPU threads: 4
      Jetzt beim 5 Mal habe ich ein Unprivilegierte Container erstellt.
      Jetzt habe ich Time Out Fehler nicht. (wieso auch immer)
      "iob diag" sagt jetzt.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: DebianIO
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.2.16-15-pve
          Architecture: x86-64
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
       12:19:06 up 10 min,  2 users,  load average: 1.30, 1.14, 0.69
      CPU threads: 4
                     Local time: Wed 2023-10-25 12:19:07 CEST
                 Universal time: Wed 2023-10-25 10:19:07 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      edi77
      /home/edi77
      edi77 sudo users
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            6.4G        309M        4.5G        118K        1.7G        6.1G
      Swap:           1.1G          0B        1.1G
      Total:          7.5G        309M        5.5G
               6144 M total memory
                295 M used memory
                343 M active memory
               1400 M inactive memory
               4265 M free memory
                  0 M buffer memory
               1582 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      *** FILESYSTEM ***
      /dev/mapper/pve-vm--104--disk--0 ext4       16G  2.0G   13G  13% /
      udev                             devtmpfs  3.7G     0  3.7G   0% /dev/tty
      tmpfs                            tmpfs     1.5G  112K  1.5G   1% /run
      dmesg: read kernel buffer failed: Operation not permitted
      /      /dev/mapper/pve-vm--104--disk--0 ext4   rw,relatime,stripe=16
      /var:
      416M    /var/
      247M    /var/cache
      243M    /var/cache/apt
      167M    /var/cache/apt/archives
      145M    /var/lib
      4.0K    /opt/iobroker/backups/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : DebianIO                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : DebianIO                                 -  enabled
      + system.adapter.discovery.0              : discovery             : DebianIO                                 -  enabled
      + instance is alive
      Objects and States
      Objects:        142
      States:         102
      Hit:2 http://security.debian.org bookworm-security InRelease
      Pending Updates: 0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          208394     298/master
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       267130     10597/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       268711     10597/iobroker.js-c
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          264110     1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       269645     10692/io.admin.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          208395     298/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          209203     1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          264112     1/init
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          264111     1/init
      udp6       0      0 :::111                  :::*                                0          264113     1/init
      2023-10-25 12:18:42.066  - info: host.DebianIO iobroker.js-controller version 5.0.12 js-controller starting
      2023-10-25 12:18:42.068  - info: host.DebianIO Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2023-10-25 12:18:42.069  - info: host.DebianIO hostname: DebianIO, node: v18.18.2
      2023-10-25 12:18:42.069  - info: host.DebianIO ip addresses: 192.168.178.5 2003:c0:ff08:b900:4068:1cff:fe60:9f9a fe80::4068:1cff:fe60:9f9a
      2023-10-25 12:18:42.361  - info: host.DebianIO connected to Objects and States
      2023-10-25 12:18:42.376  - info: host.DebianIO Node.js version has changed from unknown to 18.18.2
      2023-10-25 12:18:42.404  - info: host.DebianIO Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2023-10-25 12:18:42.413  - info: host.DebianIO added notifications configuration of host
      2023-10-25 12:18:42.647  - info: host.DebianIO 3 instances found
      2023-10-25 12:18:42.651  - info: host.DebianIO starting 3 instances
      2023-10-25 12:18:42.681  - info: host.DebianIO instance system.adapter.admin.0 started with pid 10692
      2023-10-25 12:18:43.631  - info: admin.0 (10692) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
      2023-10-25 12:18:43.662  - info: admin.0 (10692) requesting all objects
      2023-10-25 12:18:43.737  - info: admin.0 (10692) received all objects
      2023-10-25 12:18:43.782  - info: admin.0 (10692) socket.io server listening on port 8081
      2023-10-25 12:18:43.783  - info: admin.0 (10692) http server listening on port 8081
      2023-10-25 12:18:43.784  - info: admin.0 (10692) Use link "http://127.0.0.1:8081" to configure.
      2023-10-25 12:18:43.903  - warn: admin.0 (10692) Repository cannot be read: Active repo - stable
      2023-10-25 12:18:43.903  - warn: admin.0 (10692) Active repository "stable" cannot be read
      2023-10-25 12:18:44.071  - error: admin.0 (10692) Cannot update news: TypeError: newNews.forEach is not a function
      2023-10-25 12:18:46.671  - info: host.DebianIO instance system.adapter.discovery.0 started with pid 10719
      2023-10-25 12:18:47.413  - info: discovery.0 (10719) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.12
      2023-10-25 12:18:50.669  - info: host.DebianIO instance system.adapter.backitup.0 started with pid 10734
      2023-10-25 12:18:51.487  - info: backitup.0 (10734) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
      2023-10-25 12:18:51.526  - info: backitup.0 (10734) [iobroker] backup will be activated at 02:40 every 1 day(s)
                              v.2023-10-10
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:            6.4G        458M        4.3G        118K        1.7G        6.0G
      Swap:           1.1G          0B        1.1G
      Total:          7.5G        458M        5.4G
      Active iob-Instances:   4
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                142
      States:                 102
      Size of iob-Database:
      3.8M    /opt/iobroker/iobroker-data/objects.jsonl
      32K     /opt/iobroker/iobroker-data/states.jsonl
      Aber 2 Probleme hat er noch. Oder?
      crunchipC ? 3 Antworten Letzte Antwort
        @crunchip
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
        Skript v.2023-10-10
        *** BASE SYSTEM ***
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        edi77
        /home/edi77
        edi77 sudo users
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           1.1G          0B        1.1G
                 6144 M total memory
                  295 M used memory
                  343 M active memory
                 4265 M free memory
                    0 M buffer memory
                 1582 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        *** FILESYSTEM ***
        /var:
        416M    /var/
        247M    /var/cache
        243M    /var/cache/apt
        145M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        142
        States:         102
        Pending Updates: 0
                                v.2023-10-10
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
        MEMORY:
        Swap:           1.1G          0B        1.1G
                                admin                   6.10.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                142
        States:                 102
        crunchipC Offline
        crunchipC Offline
        Bin mir nicht sicher, hängt glaub ich mit ipv6 zusammen
          @crunchip
          Skript v.2023-10-10
          *** BASE SYSTEM ***
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
          Skript v.2023-10-10
          *** BASE SYSTEM ***
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          edi77
          /home/edi77
          edi77 sudo users
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           1.1G          0B        1.1G
                   6144 M total memory
                    295 M used memory
                    343 M active memory
                   4265 M free memory
                      0 M buffer memory
                   1582 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          *** FILESYSTEM ***
          /var:
          416M    /var/
          247M    /var/cache
          243M    /var/cache/apt
          145M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.10.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        142
          States:         102
          Pending Updates: 0
                                  v.2023-10-10
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
          MEMORY:
          Swap:           1.1G          0B        1.1G
                                  admin                   6.10.1
          Objects type: jsonl
          States  type: jsonl
          Objects:                142
          States:                 102
          crunchipC Offline
          crunchipC Offline
          Stimmt immer noch etwas nicht
            @crunchip
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
            Skript v.2023-10-10
            *** BASE SYSTEM ***
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                             RTC time: n/a
                      RTC in local TZ: no
            edi77
            /home/edi77
            edi77 sudo users
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Swap:           1.1G          0B        1.1G
                     6144 M total memory
                      295 M used memory
                      343 M active memory
                     4265 M free memory
                        0 M buffer memory
                     1582 M swap cache
                     1024 M total swap
                        0 M used swap
                     1024 M free swap
            *** FILESYSTEM ***
            /var:
            416M    /var/
            247M    /var/cache
            243M    /var/cache/apt
            145M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            Adapter State
            + instance is alive
            Objects and States
            Objects:        142
            States:         102
            Pending Updates: 0
                                    v.2023-10-10
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               amd64
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
            MEMORY:
            Swap:           1.1G          0B        1.1G
                                    admin                   6.10.1
            Objects type: jsonl
            States  type: jsonl
            Objects:                142
            States:                 102
            Moin,
            hatte ich dazu nicht schon einmal was geschrieben, find den Beitrag gerade nicht, der eine Dienst rpc... ist für NFS kann man wohl vernachlässigen, der andere sys-kern... sollte man in einem LXC auch nicht machen, denn dann würden
            /sys
            /proc
            Vom Hostsystem, schreibend in den LXC gemountet, was dann echt blöd ist, wenn man da an der Kernel Konfiguration aus einem LX Container, am Kernel des Hostsystems (PVE) Änderungen vornimmt, dann kracht irgendwann die ganze Maschine.
            Anders sieht es aus, wenn das eine VM ist, dann muss das laufen, da dort ein eigener Kernel und ein eigenes Subsystem vorhanden ist.
            Ich würde diese Information als Warnung ansehen, sollte man sich anschauen, sich aber nicht verrückt machen lassen.
            VG
            Bernd
              Moin,
              /sys
              /proc
              VG
              Bernd
              Eduard77E Offline
              Eduard77E Offline
              Eduard77
              @dp20eic
              Danke für die Info.
              Soll ich noch wegen dmesg was machen?
                @dp20eic
                Danke für die Info.
                Nein, auch das ist ein Zugriff auf den Kernel (der aber bei LXC nicht lokal läuft).
                Notiz an mich selbst: Code im 'iob diag' bei LXC-Umgebung kalt stellen...
                ? 1 Antwort Letzte Antwort
                  @thomas-braun sagte in Proxmox neues LXC Container, fehler im iob diag:
                  Moin,
                  ich wollte gerade, nach dem Mittagessen, Dir ein issue erstellen, hast Du ja gerade selber gemacht :)
                  VG
                  Bernd
                  Thomas BraunT Eduard77E 2 Antworten Letzte Antwort
                    Moin,
                    VG
                    Bernd
                    @dp20eic sagte in Proxmox neues LXC Container, fehler im iob diag:
                    Erledigt.
                      Moin,
                      VG
                      Bernd
                      Eduard77E Offline
                      Eduard77E Offline
                      Eduard77
                      @dp20eic,
                      Vielen Dank nochmals für die Hilfe.
                      Backups sind jetzt geladen und es läuft alles.
                      Ich werde jetzt versuchen Backup Adapter mit meinem NAS zu verknüpfen.
                      Dazu hast du schon mal @homoran geholfen.
                      Ich werde mir die Seite durchlesen und versuchen es zu kapieren.
                      Link Text
                      Darf ich mich nochmals melden, wenn es nicht klappt.
