  4. Proxmox neues LXC Container, fehler im iob diag
30 Beiträge 4 Kommentatoren 4.3k Aufrufe 4 Beobachtet
    @edis77 sagte in Proxmox neues LXC Container, fehler im iob diag:
    was soll ich machen?
    Moin,
    erst einmal richtig zitieren, es hilft beim Helfen, wenn man sieht was Du eingetippt hast
    also so
    dp20eic@iobroker:~$ sudo systemctl status systemd-sysusers.service
    [sudo] password for dp20eic:
    * systemd-sysusers.service - Create System Users
         Loaded: loaded (/lib/systemd/system/systemd-sysusers.service; static)
         Active: active (exited) since Tue 2023-10-17 09:21:40 CEST; 1 weeks 0 days ago
           Docs: man:sysusers.d(5)
                 man:systemd-sysusers.service(8)
        Process: 61 ExecStart=systemd-sysusers (code=exited, status=0/SUCCESS)
       Main PID: 61 (code=exited, status=0/SUCCESS)
            CPU: 8ms
    Warning: journal has been rotated since unit was started, output may be incomplete.
    dp20eic@iobroker:~$
    Dann kann man einmal versuchen neu zu starten
    dp20eic@iobroker:~$ sudo systemctl restart systemd-sysusers.service
    Und wieder schauen ob er läuft
         Active: active (exited) since Wed 2023-10-25 07:45:08 CEST; 4s ago
        Process: 111278 ExecStart=systemd-sysusers (code=exited, status=0/SUCCESS)
       Main PID: 111278 (code=exited, status=0/SUCCESS)
            CPU: 10ms
    Oct 25 07:45:08 iobroker systemd[1]: Starting Create System Users...
    Oct 25 07:45:08 iobroker systemd[1]: Finished Create System Users.
    Bernd
    Eduard77E Offline
    Eduard77E Offline
    Eduard77
    @dp20eic sagte in Proxmox neues LXC Container, fehler im iob diag:
    Moin,
    also so
            CPU: 8ms
    dp20eic@iobroker:~$
            CPU: 10ms
    Bernd
    Entschuldige.
    edi77@IOBROKER:~$
    edi77@IOBROKER:~$ sudo systemctl status systemd-sysusers.service
    [sudo] password for edi77:
    x systemd-sysusers.service - Create System Users
         Active: failed (Result: exit-code) since Tue 2023-10-24 21:37:41 CEST; 10h>
       Main PID: 56 (code=exited, status=243/CREDENTIALS)
            CPU: 1ms
    Notice: journal has been rotated since unit was started, output may be incomple>
    lines 1-9/9 (END)
         Active: failed (Result: exit-code) since Tue 2023-10-24 21:37:41 CEST; 10h ago
            CPU: 1ms
    Notice: journal has been rotated since unit was started, output may be incomplete.
    lines 1-9/9 (END)
            CPU: 1ms
    lines 1-9/9 (END)
    edi77@IOBROKER:~$ sudo systemctl restart systemd-sysusers.service
    Job for systemd-sysusers.service failed because the control process exited with error code.
    See "systemctl status systemd-sysusers.service" and "journalctl -xeu systemd-sysusers.service" for details.
    edi77@IOBROKER:~$
      Kann es daran liegen, dass ich gestern wehrend Installation mehrmals LXC Container rebootet habe.
      Moin,
      kann ich nicht sagen, ob es daran lag, liegt.
      Ich habe zuerst 2 Mal versucht, nach Anleitung aus Docu, Debian zu installieren.
      Nach welcher, ist eigentlich narrensicher, ein LXC unter Proxmox zu erstellen.
      Bernd
      P.S.: wenn keine neuen Mount, Unmont Einträge dazukommen, dann scheint es der Reboot zu sein.
      P.P.S.: wieso rebootet man während einer Installation?
      Eduard77E Offline
      Eduard77E Offline
      Eduard77
      @dp20eic
      Bernd
      Aus ioBroker Docu. https://www.iobroker.net/#de/documentation/install/proxmox.md
      deshalb habe ich mich auch gewundert, wieso es bei mir nicht klappt.
      @dp20eic
      Nicht während Installation, sondern danach. vor dem aufspielen von Backup und danach.
      • Eduard77E Eduard77
        Moin,
        also so
                CPU: 8ms
        dp20eic@iobroker:~$
                CPU: 10ms
        Bernd
        Entschuldige.
        edi77@IOBROKER:~$
                CPU: 1ms
        lines 1-9/9 (END)
                CPU: 1ms
        lines 1-9/9 (END)
                CPU: 1ms
        lines 1-9/9 (END)
        edi77@IOBROKER:~$
        Moin,
        ja und dann mal das gemacht was da als Hinweis kam?
        Bernd
        Eduard77E 1 Antwort Letzte Antwort
          Moin,
          Bernd
          Eduard77E Offline
          Eduard77E Offline
          Eduard77
          @dp20eic
          Wie mache ich das?
          Entschuldige aber mit Linux fange ich erst an.
            @dp20eic
            Bernd
            @dp20eic
            Moin,
            gut, das ist ja die korrekte, was hat denn nicht funktioniert?
            Bernd
              @dp20eic
              Wie mache ich das?
              Moin,
              na man nimmt die gezeigten Befehle und kopiert die auf die Konsole :)
              # sudo systemctl status systemd-sysusers.service
              oder
              # sudo journalctl -xeu systemd-sysusers.service
              Das hat auch nichts mit Linux zu tun, wenn Du in Windof weinen Dialog angezeigt bekommen würdest, dann würdest Du doch auch den Anweisungen folgen, zumal der erste Befehl genau der gleiche ist, den Du schon ausgeführt hast, ok, der zweite ist neu, aber dann probiert mal es einfach mal und schaut was passiert :)
              Bernd
                Moin,
                oder
                Bernd
                Eduard77E Offline
                Eduard77E Offline
                Eduard77
                     Active: failed (Result: exit-code) since Wed 2023-10-25 08:10:40 CEST; 29m>
                    Process: 18557 ExecStart=systemd-sysusers (code=exited, status=243/CREDENTI>
                   Main PID: 18557 (code=exited, status=243/CREDENTIALS)
                        CPU: 2ms
                Oct 25 08:10:40 IOBROKER systemd[1]: Starting Create System Users...
                Oct 25 08:10:40 IOBROKER systemd[18557]: systemd-sysusers.service: Failed to se>
                Oct 25 08:10:40 IOBROKER systemd[18557]: systemd-sysusers.service: Failed at st>
                Oct 25 08:10:40 IOBROKER systemd[1]: systemd-sysusers.service: Main process exi>
                Oct 25 08:10:40 IOBROKER systemd[1]: systemd-sysusers.service: Failed with resu>
                Oct 25 08:10:40 IOBROKER systemd[1]: Failed to start Create System Users.
                          CPU: 2ms
                  d to se>
                  Moin,
                  hast Du nur ein 10" Monitor, weil, da alles abgeschnitten ist :)
                  Mach mal das Terminalfenster ganz groß, gehst Du per putty oder Proxmox Konsole auf die LXC?
                  Was sagt der zweite Befehl?
                  Bernd
                    d to se>
                    Moin,
                    Bernd
                    Eduard77E Offline
                    Eduard77E Offline
                    Eduard77
                    @dp20eic
                    ich gehe per putty rein.
                    Ich versuche zur Zeit ein 3 Mal Debian zu installieren.
                    Ich melde mich wenn es fertig ist.
                      @dp20eic
                      Eduard77E Offline
                      Eduard77E Offline
                      Eduard77
                      schrieb am zuletzt editiert von Eduard77
                      Ich habe jetzt Drittes Mal Debian und ioBroker installiert.
                      Und bekomme die gleichen Fehlermeldungen.
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                      Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
                      model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : amd64
                      Systemuptime and Load:
                       10:38:55 up  1:41,  0 user,  load average: 0.12, 0.46, 0.69
                      CPU threads: 4
                      *** Time and Time Zones ***
                      Failed to query server: Connection timed out
                      *** User and Groups ***
                      edi77
                      /home/edi77
                      edi77 sudo users iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:            6.4G        4.1G        1.5G         32K        846M        2.3G
                      Swap:           2.1G        196M        2.0G
                      Total:          8.6G        4.3G        3.5G
                               6144 M total memory
                               3905 M used memory
                               1311 M active memory
                               3251 M inactive memory
                               1431 M free memory
                                  0 M buffer memory
                                807 M swap cache
                               2048 M total swap
                                187 M used swap
                               1860 M free swap
                      *** FAILED SERVICES ***
                        UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
                      * nftables.service                   loaded failed failed nftables
                      * systemd-firstboot.service          loaded failed failed First Boot Wizard
                      * systemd-hostnamed.service          loaded failed failed Hostname Service
                      * systemd-logind.service             loaded failed failed User Login Management
                      * systemd-networkd.service           loaded failed failed Network Configuration
                      * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
                      * systemd-sysusers.service           loaded failed failed Create System Users
                      * systemd-timedated.service          loaded failed failed Time & Date Service
                      * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
                      * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
                      * systemd-tmpfiles-setup.service     loaded failed failed Create Volatile Files and Directories
                      * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
                      12 loaded units listed.
                      *** FILESYSTEM ***
                      Filesystem                       Type   Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--102--disk--0 ext4    20G  3.6G   15G  20% /
                      none                             tmpfs  492K  4.0K  488K   1% /dev
                      tmpfs                            tmpfs  3.7G     0  3.7G   0% /dev/shm
                      tmpfs                            tmpfs  1.5G   76K  1.5G   1% /run
                      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                      [Tue Oct 10 18:15:55 2023] EXT4-fs (dm-1): re-mounted dcc632b4-4524-4008-a047-ede87046e036. Quota mode: none.
                      [Tue Oct 10 18:16:10 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
                      [Mon Oct 16 19:02:53 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                      [Mon Oct 16 19:02:54 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
                      [Mon Oct 23 19:10:53 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
                      [Mon Oct 23 19:11:02 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
                      [Mon Oct 23 19:11:37 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
                      [Mon Oct 23 19:26:39 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
                      [Mon Oct 23 19:26:40 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
                      [Mon Oct 23 19:28:34 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
                      [Mon Oct 23 19:34:36 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                      [Mon Oct 23 19:34:47 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                      [Mon Oct 23 19:34:48 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                      [Mon Oct 23 19:36:13 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
                      [Mon Oct 23 19:36:13 2023] EXT4-fs (dm-9): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 without journal. Quota mode: none.
                      [Mon Oct 23 19:36:26 2023] EXT4-fs (dm-9): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                      [Mon Oct 23 20:22:21 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                      [Mon Oct 23 20:39:38 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
                      [Mon Oct 23 20:51:44 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                      [Tue Oct 24 17:16:17 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 17:43:23 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                      [Tue Oct 24 18:05:03 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                      [Tue Oct 24 18:05:05 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 18:36:27 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                      [Tue Oct 24 18:37:45 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
                      [Tue Oct 24 18:37:52 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
                      [Tue Oct 24 18:38:13 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
                      [Tue Oct 24 19:01:58 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
                      [Tue Oct 24 19:01:59 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
                      [Tue Oct 24 19:43:32 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
                      [Tue Oct 24 19:43:34 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
                      [Tue Oct 24 20:14:59 2023] EXT4-fs (dm-7): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b without journal. Quota mode: none.
                      [Tue Oct 24 20:16:54 2023] EXT4-fs (dm-7): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                      [Tue Oct 24 20:38:16 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 20:38:24 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                      [Tue Oct 24 20:38:25 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 20:46:57 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                      [Tue Oct 24 20:46:59 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 20:49:37 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                      [Tue Oct 24 20:49:39 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 21:35:39 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                      [Tue Oct 24 21:35:50 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 21:37:31 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                      [Tue Oct 24 21:37:33 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                      [Tue Oct 24 22:16:36 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                      [Wed Oct 25 08:34:59 2023] EXT4-fs (dm-8): mounted filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f with ordered data mode. Quota mode: none.
                      [Wed Oct 25 08:35:08 2023] EXT4-fs (dm-8): unmounting filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f.
                      [Wed Oct 25 08:35:09 2023] EXT4-fs (dm-8): mounted filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f with ordered data mode. Quota mode: none.
                      [Wed Oct 25 08:55:04 2023] EXT4-fs (dm-8): unmounting filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f.
                      [Wed Oct 25 08:57:14 2023] EXT4-fs (dm-8): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 with ordered data mode. Quota mode: none.
                      [Wed Oct 25 08:57:23 2023] EXT4-fs (dm-8): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
                      [Wed Oct 25 08:57:25 2023] EXT4-fs (dm-8): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 with ordered data mode. Quota mode: none.
                      [Wed Oct 25 08:58:44 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
                      [Wed Oct 25 08:58:44 2023] EXT4-fs (dm-9): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 without journal. Quota mode: none.
                      [Wed Oct 25 08:58:57 2023] EXT4-fs (dm-9): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
                      [Wed Oct 25 09:34:58 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
                      [Wed Oct 25 09:34:58 2023] EXT4-fs (dm-9): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 without journal. Quota mode: none.
                      [Wed Oct 25 09:35:51 2023] EXT4-fs (dm-9): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
                      TARGET SOURCE                           FSTYPE OPTIONS
                      /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      416M    /var/
                      247M    /var/cache
                      243M    /var/cache/apt
                      168M    /var/cache/apt/archives
                      145M    /var/lib
                            Users in the 'systemd-journal' group can see all messages. Pass -q to
                            turn off this notice.
                      Archived and active journals take up 8.0M in the file system.
                      /opt/iobroker/backups:
                      31M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      524M    /opt/iobroker/iobroker-data/
                      346M    /opt/iobroker/iobroker-data/files
                      149M    /opt/iobroker/iobroker-data/history
                      88M     /opt/iobroker/iobroker-data/files/echarts.admin
                      57M     /opt/iobroker/iobroker-data/files/echarts
                      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                      22M     /opt/iobroker/iobroker-data/objects.jsonl
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                      USB-Devices by-id:
                      find: '/dev/serial/by-id/': No such file or directory
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.18.2
                      /usr/bin/node           v18.18.2
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      /usr/bin/corepack       0.19.0
                      nodejs:
                        Installed: 18.18.2-1nodesource1
                        Candidate: 18.18.2-1nodesource1
                        Version table:
                       *** 18.18.2-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           18.18.1-1nodesource1 500
                           18.18.0-1nodesource1 500
                           18.17.1-1nodesource1 500
                           18.17.0-1nodesource1 500
                           18.16.1-1nodesource1 500
                           18.16.0-1nodesource1 500
                           18.15.0-1nodesource1 500
                           18.14.2-1nodesource1 500
                           18.14.1-1nodesource1 500
                           18.14.0-1nodesource1 500
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.13.0-1nodesource1 500
                           18.12.0-1nodesource1 500
                           18.11.0-1nodesource1 500
                           18.10.0-1nodesource1 500
                           18.9.1-1nodesource1 500
                           18.9.0-1nodesource1 500
                           18.8.0-1nodesource1 500
                           18.7.0-1nodesource1 500
                           18.6.0-1nodesource1 500
                           18.5.0-1nodesource1 500
                           18.4.0-1nodesource1 500
                           18.3.0-1nodesource1 500
                           18.2.0-1nodesource1 500
                           18.1.0-1nodesource1 500
                           18.0.0-1nodesource1 500
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  5.0.12
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapters from github:   2
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
                      + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                      + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                      + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                        system.adapter.mihome-cloud.0           : mihome-cloud          : ioBroker                                 - disabled
                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                        system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 8086
                      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
                      + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "admin"        : 6.10.1   , installed 6.10.1
                      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                      Adapter    "deyeidc"      : 0.0.11   , installed 0.0.11
                      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                      Controller "js-controller": 5.0.12   , installed 5.0.12
                      Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.1
                      Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                      Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                      Adapter    "snmp"         : 2.4.11   , installed 2.4.11
                      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                      Adapter    "text2command" : 3.0.2    , installed 3.0.2
                      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                      Adapter    "web"          : 6.1.2    , installed 6.1.2
                      Adapter    "ws"           : 2.5.5    , installed 2.5.5
                      Objects and States
                      Objects:        3254
                      States:         2586
                      Hit:1 http://security.debian.org bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32714961   1/init
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       32839125   13468/io.sonoff.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32800660   11672/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32801525   11672/iobroker.js-c
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          32586457   306/master
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          32587208   1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          32714066   1/init
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          32586458   306/master
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32802908   11699/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32841881   13599/io.web.0
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       32840569   13614/io.ws.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32839861   13438/io.simple-api
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32715870   1/init
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       32839817   13419/io.mihome-vac
                      udp        0      0 0.0.0.0:46499           0.0.0.0:*                           1001       32839909   13453/io.snmp.0
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32840860   13543/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32840861   13543/io.tuya.0
                      udp6       0      0 :::111                  :::*                                0          32714963   1/init
                      2023-10-25 10:38:13.066  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:14.291  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                      2023-10-25 10:38:19.911  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:24.399  - info: hmip.0 (13393) ws connection opened
                      2023-10-25 10:38:26.747  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:33.560  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:34.543  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                      2023-10-25 10:38:40.367  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:44.645  - info: hmip.0 (13393) ws connection opened
                      2023-10-25 10:38:47.177  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:53.997  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:38:54.794  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                      2023-10-25 10:39:00.793  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:04.917  - info: hmip.0 (13393) ws connection opened
                      2023-10-25 10:39:07.617  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:14.436  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:15.062  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                      2023-10-25 10:39:21.334  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:25.164  - info: hmip.0 (13393) ws connection opened
                      2023-10-25 10:39:28.145  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:34.951  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:35.309  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                      2023-10-25 10:39:41.757  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      2023-10-25 10:39:45.411  - info: hmip.0 (13393) ws connection opened
                      2023-10-25 10:39:48.564  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                      iob diag has finished.
                      ? crunchipC 2 Antworten Letzte Antwort
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                        edi77
                        /home/edi77
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                                 6144 M total memory
                                 3905 M used memory
                                 1431 M free memory
                                    0 M buffer memory
                                  807 M swap cache
                                 2048 M total swap
                                  187 M used swap
                                 1860 M free swap
                        *** FILESYSTEM ***
                        /var:
                        416M    /var/
                        247M    /var/cache
                        243M    /var/cache/apt
                        145M    /var/lib
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        3254
                        States:         2586
                        Pending Updates: 0
                        Moin,
                        Versuch mal Deinen Weg/Installation mit ein paar Bildern zu zeigen, was hast Du wie, wo eingestellt, das mit den ganzen Mounts/Unmounts kapiere ich nicht, wie sieht Deine Proxmox Installation aus, welche Storages hast Du, was Mountest Du da alles im LX Container.
                        Ich verstehe es nicht, was Du da machst, ich muss jetzt aber erst mal mit Frauchen Einkaufen, später schaue ich mir das noch einmal an und installiere mir einen neuen LX Container, um sicherzugehen, dass da nichts in Proxmox anders ist als in der Dokumentation beschreiben.
                        Bernd
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                          edi77
                          /home/edi77
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                                   6144 M total memory
                                   3905 M used memory
                                   1431 M free memory
                                      0 M buffer memory
                                    807 M swap cache
                                   2048 M total swap
                                    187 M used swap
                                   1860 M free swap
                          *** FILESYSTEM ***
                          /var:
                          416M    /var/
                          247M    /var/cache
                          243M    /var/cache/apt
                          145M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.10.1
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        3254
                          States:         2586
                          Pending Updates: 0
                          crunchipC Offline
                          crunchipC Offline
                          Da stimmt doch vermutlich in deiner Grundinstallation schon etwas nicht
                            Eduard77E Offline
                            Eduard77E Offline
                            Eduard77
                            @crunchip
                            ich glaube ich habe mein Fehler gefunden.
                            Ich wollte ein Privilegierte Container erstellen.
                            Das hat bei mir immer zu dem Fehler geführt.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                            Failed to query system properties: Connection timed out
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             11:50:44 up 20 min,  0 user,  load average: 0.51, 0.62, 0.50
                            CPU threads: 4
                            Jetzt beim 5 Mal habe ich ein Unprivilegierte Container erstellt.
                            Jetzt habe ich Time Out Fehler nicht. (wieso auch immer)
                            "iob diag" sagt jetzt.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                             Static hostname: DebianIO
                                   Icon name: computer-container
                                     Chassis: container ☐
                              Virtualization: lxc
                                      Kernel: Linux 6.2.16-15-pve
                                Architecture: x86-64
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             12:19:06 up 10 min,  2 users,  load average: 1.30, 1.14, 0.69
                            CPU threads: 4
                                           Local time: Wed 2023-10-25 12:19:07 CEST
                                       Universal time: Wed 2023-10-25 10:19:07 UTC
                                             RTC time: n/a
                                          NTP service: inactive
                                      RTC in local TZ: no
                            edi77
                            /home/edi77
                            edi77 sudo users
                            X-Server:       false
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:            6.4G        309M        4.5G        118K        1.7G        6.1G
                            Swap:           1.1G          0B        1.1G
                            Total:          7.5G        309M        5.5G
                                     6144 M total memory
                                      295 M used memory
                                      343 M active memory
                                     1400 M inactive memory
                                     4265 M free memory
                                        0 M buffer memory
                                     1582 M swap cache
                                     1024 M total swap
                                        0 M used swap
                                     1024 M free swap
                            * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                            * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                            *** FILESYSTEM ***
                            /dev/mapper/pve-vm--104--disk--0 ext4       16G  2.0G   13G  13% /
                            udev                             devtmpfs  3.7G     0  3.7G   0% /dev/tty
                            tmpfs                            tmpfs     1.5G  112K  1.5G   1% /run
                            dmesg: read kernel buffer failed: Operation not permitted
                            /      /dev/mapper/pve-vm--104--disk--0 ext4   rw,relatime,stripe=16
                            /var:
                            416M    /var/
                            247M    /var/cache
                            243M    /var/cache/apt
                            167M    /var/cache/apt/archives
                            145M    /var/lib
                            4.0K    /opt/iobroker/backups/
                            15M     /opt/iobroker/iobroker-data/files
                            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                            652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                            384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                            USB-Devices by-id:
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            javascript:     "javascript" not found
                            Adapters from github:   0
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : DebianIO                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : DebianIO                                 -  enabled
                            + system.adapter.discovery.0              : discovery             : DebianIO                                 -  enabled
                            + instance is alive
                            Objects and States
                            Objects:        142
                            States:         102
                            Hit:2 http://security.debian.org bookworm-security InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          208394     298/master
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       267130     10597/iobroker.js-c
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       268711     10597/iobroker.js-c
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          264110     1/init
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       269645     10692/io.admin.0
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          208395     298/master
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          209203     1/init
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          264112     1/init
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          264111     1/init
                            udp6       0      0 :::111                  :::*                                0          264113     1/init
                            2023-10-25 12:18:42.066  - info: host.DebianIO iobroker.js-controller version 5.0.12 js-controller starting
                            2023-10-25 12:18:42.068  - info: host.DebianIO Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                            2023-10-25 12:18:42.069  - info: host.DebianIO hostname: DebianIO, node: v18.18.2
                            2023-10-25 12:18:42.069  - info: host.DebianIO ip addresses: 192.168.178.5 2003:c0:ff08:b900:4068:1cff:fe60:9f9a fe80::4068:1cff:fe60:9f9a
                            2023-10-25 12:18:42.361  - info: host.DebianIO connected to Objects and States
                            2023-10-25 12:18:42.376  - info: host.DebianIO Node.js version has changed from unknown to 18.18.2
                            2023-10-25 12:18:42.404  - info: host.DebianIO Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                            2023-10-25 12:18:42.413  - info: host.DebianIO added notifications configuration of host
                            2023-10-25 12:18:42.647  - info: host.DebianIO 3 instances found
                            2023-10-25 12:18:42.651  - info: host.DebianIO starting 3 instances
                            2023-10-25 12:18:42.681  - info: host.DebianIO instance system.adapter.admin.0 started with pid 10692
                            2023-10-25 12:18:43.631  - info: admin.0 (10692) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
                            2023-10-25 12:18:43.662  - info: admin.0 (10692) requesting all objects
                            2023-10-25 12:18:43.737  - info: admin.0 (10692) received all objects
                            2023-10-25 12:18:43.782  - info: admin.0 (10692) socket.io server listening on port 8081
                            2023-10-25 12:18:43.783  - info: admin.0 (10692) http server listening on port 8081
                            2023-10-25 12:18:43.784  - info: admin.0 (10692) Use link "http://127.0.0.1:8081" to configure.
                            2023-10-25 12:18:43.903  - warn: admin.0 (10692) Repository cannot be read: Active repo - stable
                            2023-10-25 12:18:43.903  - warn: admin.0 (10692) Active repository "stable" cannot be read
                            2023-10-25 12:18:44.071  - error: admin.0 (10692) Cannot update news: TypeError: newNews.forEach is not a function
                            2023-10-25 12:18:46.671  - info: host.DebianIO instance system.adapter.discovery.0 started with pid 10719
                            2023-10-25 12:18:47.413  - info: discovery.0 (10719) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.12
                            2023-10-25 12:18:50.669  - info: host.DebianIO instance system.adapter.backitup.0 started with pid 10734
                            2023-10-25 12:18:51.487  - info: backitup.0 (10734) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
                            2023-10-25 12:18:51.526  - info: backitup.0 (10734) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                                    v.2023-10-10
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                    /usr/bin/npm            9.8.1
                                                    /usr/bin/npx            9.8.1
                            Recommended versions are nodejs 18.18.2 and npm 9.8.1
                            MEMORY:
                            Mem:            6.4G        458M        4.3G        118K        1.7G        6.0G
                            Swap:           1.1G          0B        1.1G
                            Total:          7.5G        458M        5.4G
                            Active iob-Instances:   4
                            ioBroker Core:          js-controller           5.0.12
                                                    admin                   6.10.1
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                142
                            States:                 102
                            Size of iob-Database:
                            3.8M    /opt/iobroker/iobroker-data/objects.jsonl
                            32K     /opt/iobroker/iobroker-data/states.jsonl
                            Aber 2 Probleme hat er noch. Oder?
                            crunchipC ? 3 Antworten Letzte Antwort
                              @crunchip
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 4
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              edi77
                              /home/edi77
                              edi77 sudo users
                              X-Server:       false
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Swap:           1.1G          0B        1.1G
                                       6144 M total memory
                                        295 M used memory
                                        343 M active memory
                                       4265 M free memory
                                          0 M buffer memory
                                       1582 M swap cache
                                       1024 M total swap
                                          0 M used swap
                                       1024 M free swap
                              *** FILESYSTEM ***
                              /var:
                              416M    /var/
                              247M    /var/cache
                              243M    /var/cache/apt
                              145M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        142
                              States:         102
                              Pending Updates: 0
                                                      v.2023-10-10
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            9.8.1
                                                      /usr/bin/npx            9.8.1
                              MEMORY:
                              Swap:           1.1G          0B        1.1G
                                                      admin                   6.10.1
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                142
                              States:                 102
                              crunchipC Offline
                              crunchipC Offline
                              Bin mir nicht sicher, hängt glaub ich mit ipv6 zusammen
                                @crunchip
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                CPU threads: 4
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                  Virtualization: lxc
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                CPU threads: 4
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                edi77
                                /home/edi77
                                edi77 sudo users
                                X-Server:       false
                                Desktop:
                                Terminal:
                                *** MEMORY ***
                                Swap:           1.1G          0B        1.1G
                                         6144 M total memory
                                          295 M used memory
                                          343 M active memory
                                         4265 M free memory
                                            0 M buffer memory
                                         1582 M swap cache
                                         1024 M total swap
                                            0 M used swap
                                         1024 M free swap
                                *** FILESYSTEM ***
                                /var:
                                416M    /var/
                                247M    /var/cache
                                243M    /var/cache/apt
                                145M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.10.1
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        142
                                States:         102
                                Pending Updates: 0
                                                        v.2023-10-10
                                  Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               amd64
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                MEMORY:
                                Swap:           1.1G          0B        1.1G
                                                        admin                   6.10.1
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                142
                                States:                 102
                                crunchipC Offline
                                crunchipC Offline
                                Stimmt immer noch etwas nicht
                                  @crunchip
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  CPU threads: 4
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                    Virtualization: lxc
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  CPU threads: 4
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  edi77
                                  /home/edi77
                                  edi77 sudo users
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Swap:           1.1G          0B        1.1G
                                           6144 M total memory
                                            295 M used memory
                                            343 M active memory
                                           4265 M free memory
                                              0 M buffer memory
                                           1582 M swap cache
                                           1024 M total swap
                                              0 M used swap
                                           1024 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  416M    /var/
                                  247M    /var/cache
                                  243M    /var/cache/apt
                                  145M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.10.1
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        142
                                  States:         102
                                  Pending Updates: 0
                                                          v.2023-10-10
                                    Virtualization: lxc
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               amd64
                                  User-ID:                1000
                                  X-Server:               false
                                                          /usr/bin/npm            9.8.1
                                                          /usr/bin/npx            9.8.1
                                  MEMORY:
                                  Swap:           1.1G          0B        1.1G
                                                          admin                   6.10.1
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                142
                                  States:                 102
                                  Moin,
                                  hatte ich dazu nicht schon einmal was geschrieben, find den Beitrag gerade nicht, der eine Dienst rpc... ist für NFS kann man wohl vernachlässigen, der andere sys-kern... sollte man in einem LXC auch nicht machen, denn dann würden
                                  /sys
                                  /proc
                                  Vom Hostsystem, schreibend in den LXC gemountet, was dann echt blöd ist, wenn man da an der Kernel Konfiguration aus einem LX Container, am Kernel des Hostsystems (PVE) Änderungen vornimmt, dann kracht irgendwann die ganze Maschine.
                                  Anders sieht es aus, wenn das eine VM ist, dann muss das laufen, da dort ein eigener Kernel und ein eigenes Subsystem vorhanden ist.
                                  Ich würde diese Information als Warnung ansehen, sollte man sich anschauen, sich aber nicht verrückt machen lassen.
                                  Bernd
                                    Moin,
                                    /sys
                                    /proc
                                    Bernd
                                    Eduard77E Offline
                                    Eduard77E Offline
                                    Eduard77
                                    @dp20eic
                                    Danke für die Info.
                                    Soll ich noch wegen dmesg was machen?
                                      @dp20eic
                                      Danke für die Info.
                                      Nein, auch das ist ein Zugriff auf den Kernel (der aber bei LXC nicht lokal läuft).
                                      Notiz an mich selbst: Code im 'iob diag' bei LXC-Umgebung kalt stellen...
                                        @thomas-braun sagte in Proxmox neues LXC Container, fehler im iob diag:
                                        Moin,
                                        ich wollte gerade, nach dem Mittagessen, Dir ein issue erstellen, hast Du ja gerade selber gemacht :)
                                        Bernd
                                        Thomas BraunT Eduard77E 2 Antworten Letzte Antwort
                                          Moin,
                                          Bernd
                                          Erledigt.
