  4. Proxmox neues LXC Container, fehler im iob diag
30 Beiträge 4 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • Eduard77E Eduard77
    @dp20eic
    Guten Morgen, danke für schnelle Antwort.
    x systemd-sysusers.service - Create System Users
         Loaded: loaded (/lib/systemd/system/systemd-sysusers.service; static)
         Active: failed (Result: exit-code) since Tue 2023-10-24 21:37:41 CEST; 9h >
           Docs: man:sysusers.d(5)
                 man:systemd-sysusers.service(8)
       Main PID: 56 (code=exited, status=243/CREDENTIALS)
            CPU: 1ms
    Notice: journal has been rotated since unit was started, output may be incomple>
    lines 1-9/9 (END)
         Active: failed (Result: exit-code) since Tue 2023-10-24 21:37:41 CEST; 9h ago
            CPU: 1ms
    Notice: journal has been rotated since unit was started, output may be incomplete.
    was soll ich machen?
    @edis77 sagte in Proxmox neues LXC Container, fehler im iob diag:
    Moin,
    erst einmal richtig zitieren, es hilft beim Helfen, wenn man sieht was Du eingetippt hast
    also so
    dp20eic@iobroker:~$ sudo systemctl status systemd-sysusers.service
    [sudo] password for dp20eic:
    * systemd-sysusers.service - Create System Users
         Active: active (exited) since Tue 2023-10-17 09:21:40 CEST; 1 weeks 0 days ago
        Process: 61 ExecStart=systemd-sysusers (code=exited, status=0/SUCCESS)
       Main PID: 61 (code=exited, status=0/SUCCESS)
            CPU: 8ms
    Warning: journal has been rotated since unit was started, output may be incomplete.
    dp20eic@iobroker:~$
    Dann kann man einmal versuchen neu zu starten
    dp20eic@iobroker:~$ sudo systemctl restart systemd-sysusers.service
    Und wieder schauen ob er läuft
         Active: active (exited) since Wed 2023-10-25 07:45:08 CEST; 4s ago
        Process: 111278 ExecStart=systemd-sysusers (code=exited, status=0/SUCCESS)
       Main PID: 111278 (code=exited, status=0/SUCCESS)
            CPU: 10ms
    Oct 25 07:45:08 iobroker systemd[1]: Starting Create System Users...
    Oct 25 07:45:08 iobroker systemd[1]: Finished Create System Users.
    Bernd
    Eduard77E 1 Antwort Letzte Antwort
      @dp20eic
      Wenn ich status von AppArmor abfrage, bekomme ich folgendes:
      edi77@IOBROKER:~$ sudo apparmor_status
      apparmor module is loaded.
      Moin,
      zu AppAmor kann ich nicht viel sagen, benutze ich nicht!
      Aber was sagt denn
      # sudo systemctl status appamor.service
      Bernd
        Moin,
        diese Meldungen von Mount, Unmount, sehen für mich eher abnorm aus
        [Tue Oct 10 18:15:54 2023] EXT4-fs (dm-1): mounted filesystem dcc632b4-4524-4008-a047-ede87046e036 with ordered data mode. Quota mode: none.
        [Tue Oct 10 18:15:55 2023] EXT4-fs (dm-1): re-mounted dcc632b4-4524-4008-a047-ede87046e036. Quota mode: none.
        [Tue Oct 10 18:16:10 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
        [Mon Oct 16 19:02:53 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
        [Mon Oct 16 19:02:54 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
        [Mon Oct 23 19:10:53 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
        [Mon Oct 23 19:11:02 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
        Bernd
        Eduard77E Offline
        Eduard77E Offline
        Eduard77
        schrieb am zuletzt editiert von Eduard77
        @dp20eic sagte in Proxmox neues LXC Container, fehler im iob diag:
        Moin,
        Bernd
        Kann es daran liegen, dass ich gestern wehrend Installation mehrmals LXC Container rebootet habe.
        Debian war zuerst meine erste Wahl. Ich habe zuerst 2 Mal versucht, nach Anleitung aus Docu, Debian zu installieren. Habe aber immer im "iob diag" gleiche Time Out Fehler gehabt und History Adapter hat Backup immer mit einem Error abgebrohen.
        Deswegen habe ich dann mit Ubuntu versucht.
          Moin,
          Bernd
          Moin,
          kann ich nicht sagen, ob es daran lag, liegt.
          Nach welcher, ist eigentlich narrensicher, ein LXC unter Proxmox zu erstellen.
          Bernd
          P.S.: wenn keine neuen Mount, Unmont Einträge dazukommen, dann scheint es der Reboot zu sein.
          P.P.S.: wieso rebootet man während einer Installation?
            Moin,
            also so
                    CPU: 8ms
            dp20eic@iobroker:~$
                    CPU: 10ms
            Bernd
            Eduard77E Offline
            Eduard77E Offline
            Eduard77
            Moin,
            also so
                    CPU: 8ms
            dp20eic@iobroker:~$
                    CPU: 10ms
            Bernd
            Entschuldige.
            edi77@IOBROKER:~$
            edi77@IOBROKER:~$ sudo systemctl status systemd-sysusers.service
            [sudo] password for edi77:
                 Active: failed (Result: exit-code) since Tue 2023-10-24 21:37:41 CEST; 10h>
                    CPU: 1ms
            lines 1-9/9 (END)
                 Active: failed (Result: exit-code) since Tue 2023-10-24 21:37:41 CEST; 10h ago
                    CPU: 1ms
            lines 1-9/9 (END)
                    CPU: 1ms
            lines 1-9/9 (END)
            edi77@IOBROKER:~$ sudo systemctl restart systemd-sysusers.service
            Job for systemd-sysusers.service failed because the control process exited with error code.
            See "systemctl status systemd-sysusers.service" and "journalctl -xeu systemd-sysusers.service" for details.
            edi77@IOBROKER:~$
              Moin,
              Bernd
              Eduard77E Offline
              Eduard77E Offline
              Eduard77
              @dp20eic
              Bernd
              Aus ioBroker Docu. https://www.iobroker.net/#de/documentation/install/proxmox.md
              deshalb habe ich mich auch gewundert, wieso es bei mir nicht klappt.
              @dp20eic
              Nicht während Installation, sondern danach. vor dem aufspielen von Backup und danach.
                Moin,
                also so
                        CPU: 8ms
                dp20eic@iobroker:~$
                        CPU: 10ms
                Bernd
                Entschuldige.
                edi77@IOBROKER:~$
                        CPU: 1ms
                lines 1-9/9 (END)
                        CPU: 1ms
                lines 1-9/9 (END)
                        CPU: 1ms
                lines 1-9/9 (END)
                edi77@IOBROKER:~$
                Moin,
                ja und dann mal das gemacht was da als Hinweis kam?
                Bernd
                  Moin,
                  Bernd
                  Eduard77E Offline
                  Eduard77E Offline
                  Eduard77
                  @dp20eic
                  Wie mache ich das?
                  Entschuldige aber mit Linux fange ich erst an.
                    @dp20eic
                    Bernd
                    @dp20eic
                    Moin,
                    gut, das ist ja die korrekte, was hat denn nicht funktioniert?
                    Bernd
                      @dp20eic
                      Wie mache ich das?
                      Moin,
                      na man nimmt die gezeigten Befehle und kopiert die auf die Konsole :)
                      # sudo systemctl status systemd-sysusers.service
                      oder
                      # sudo journalctl -xeu systemd-sysusers.service
                      Das hat auch nichts mit Linux zu tun, wenn Du in Windof weinen Dialog angezeigt bekommen würdest, dann würdest Du doch auch den Anweisungen folgen, zumal der erste Befehl genau der gleiche ist, den Du schon ausgeführt hast, ok, der zweite ist neu, aber dann probiert mal es einfach mal und schaut was passiert :)
                      Bernd
                        Moin,
                        oder
                        Bernd
                        Eduard77E Offline
                        Eduard77E Offline
                        Eduard77
                             Active: failed (Result: exit-code) since Wed 2023-10-25 08:10:40 CEST; 29m>
                            Process: 18557 ExecStart=systemd-sysusers (code=exited, status=243/CREDENTI>
                           Main PID: 18557 (code=exited, status=243/CREDENTIALS)
                                CPU: 2ms
                        Oct 25 08:10:40 IOBROKER systemd[1]: Starting Create System Users...
                        Oct 25 08:10:40 IOBROKER systemd[18557]: systemd-sysusers.service: Failed to se>
                        Oct 25 08:10:40 IOBROKER systemd[18557]: systemd-sysusers.service: Failed at st>
                        Oct 25 08:10:40 IOBROKER systemd[1]: systemd-sysusers.service: Main process exi>
                        Oct 25 08:10:40 IOBROKER systemd[1]: systemd-sysusers.service: Failed with resu>
                        Oct 25 08:10:40 IOBROKER systemd[1]: Failed to start Create System Users.
                                  CPU: 2ms
                          d to se>
                          Moin,
                          hast Du nur ein 10" Monitor, weil, da alles abgeschnitten ist :)
                          Mach mal das Terminalfenster ganz groß, gehst Du per putty oder Proxmox Konsole auf die LXC?
                          Was sagt der zweite Befehl?
                          Bernd
                            d to se>
                            Moin,
                            Bernd
                            Eduard77E Offline
                            Eduard77E Offline
                            Eduard77
                            @dp20eic
                            ich gehe per putty rein.
                            Ich versuche zur Zeit ein 3 Mal Debian zu installieren.
                            Ich melde mich wenn es fertig ist.
                              @dp20eic
                              Eduard77E Offline
                              Eduard77E Offline
                              Eduard77
                              Ich habe jetzt Drittes Mal Debian und ioBroker installiert.
                              Und bekomme die gleichen Fehlermeldungen.
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                              Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
                              model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
                              Docker          : false
                              Virtualization  : lxc
                              Kernel          : x86_64
                              Userland        : amd64
                              Systemuptime and Load:
                               10:38:55 up  1:41,  0 user,  load average: 0.12, 0.46, 0.69
                              CPU threads: 4
                              *** Time and Time Zones ***
                              Failed to query server: Connection timed out
                              *** User and Groups ***
                              edi77
                              /home/edi77
                              edi77 sudo users iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Mem:            6.4G        4.1G        1.5G         32K        846M        2.3G
                              Swap:           2.1G        196M        2.0G
                              Total:          8.6G        4.3G        3.5G
                                       6144 M total memory
                                       3905 M used memory
                                       1311 M active memory
                                       3251 M inactive memory
                                       1431 M free memory
                                          0 M buffer memory
                                        807 M swap cache
                                       2048 M total swap
                                        187 M used swap
                                       1860 M free swap
                              *** FAILED SERVICES ***
                                UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
                              * nftables.service                   loaded failed failed nftables
                              * systemd-firstboot.service          loaded failed failed First Boot Wizard
                              * systemd-hostnamed.service          loaded failed failed Hostname Service
                              * systemd-logind.service             loaded failed failed User Login Management
                              * systemd-networkd.service           loaded failed failed Network Configuration
                              * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
                              * systemd-sysusers.service           loaded failed failed Create System Users
                              * systemd-timedated.service          loaded failed failed Time & Date Service
                              * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
                              * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
                              * systemd-tmpfiles-setup.service     loaded failed failed Create Volatile Files and Directories
                              * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
                              12 loaded units listed.
                              *** FILESYSTEM ***
                              Filesystem                       Type   Size  Used Avail Use% Mounted on
                              /dev/mapper/pve-vm--102--disk--0 ext4    20G  3.6G   15G  20% /
                              none                             tmpfs  492K  4.0K  488K   1% /dev
                              tmpfs                            tmpfs  3.7G     0  3.7G   0% /dev/shm
                              tmpfs                            tmpfs  1.5G   76K  1.5G   1% /run
                              tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                              [Mon Oct 23 19:11:37 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
                              [Mon Oct 23 19:26:39 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
                              [Mon Oct 23 19:26:40 2023] EXT4-fs (dm-8): mounted filesystem b9504c5a-9337-4ebe-8410-ab6490771608 with ordered data mode. Quota mode: none.
                              [Mon Oct 23 19:28:34 2023] EXT4-fs (dm-8): unmounting filesystem b9504c5a-9337-4ebe-8410-ab6490771608.
                              [Mon Oct 23 19:34:36 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                              [Mon Oct 23 19:34:47 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                              [Mon Oct 23 19:34:48 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                              [Mon Oct 23 19:36:13 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
                              [Mon Oct 23 19:36:13 2023] EXT4-fs (dm-9): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 without journal. Quota mode: none.
                              [Mon Oct 23 19:36:26 2023] EXT4-fs (dm-9): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                              [Mon Oct 23 20:22:21 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                              [Mon Oct 23 20:39:38 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
                              [Mon Oct 23 20:51:44 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                              [Tue Oct 24 17:16:17 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 17:43:23 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                              [Tue Oct 24 18:05:03 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                              [Tue Oct 24 18:05:05 2023] EXT4-fs (dm-8): mounted filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 18:36:27 2023] EXT4-fs (dm-8): unmounting filesystem 9ab8010b-f1da-4a4b-bebd-7309c1284fc1.
                              [Tue Oct 24 18:37:45 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
                              [Tue Oct 24 18:37:52 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
                              [Tue Oct 24 18:38:13 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
                              [Tue Oct 24 19:01:58 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
                              [Tue Oct 24 19:01:59 2023] EXT4-fs (dm-9): mounted filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa with ordered data mode. Quota mode: none.
                              [Tue Oct 24 19:43:32 2023] EXT4-fs (dm-6): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b with ordered data mode. Quota mode: none.
                              [Tue Oct 24 19:43:34 2023] EXT4-fs (dm-9): unmounting filesystem 36e08bb2-0047-45d8-aa82-392252aeebaa.
                              [Tue Oct 24 20:14:59 2023] EXT4-fs (dm-7): mounted filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b without journal. Quota mode: none.
                              [Tue Oct 24 20:16:54 2023] EXT4-fs (dm-7): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                              [Tue Oct 24 20:38:16 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 20:38:24 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                              [Tue Oct 24 20:38:25 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 20:46:57 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                              [Tue Oct 24 20:46:59 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 20:49:37 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                              [Tue Oct 24 20:49:39 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 21:35:39 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                              [Tue Oct 24 21:35:50 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 21:37:31 2023] EXT4-fs (dm-7): unmounting filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866.
                              [Tue Oct 24 21:37:33 2023] EXT4-fs (dm-7): mounted filesystem 4c7b1fe0-de8e-4790-af42-5a75df07a866 with ordered data mode. Quota mode: none.
                              [Tue Oct 24 22:16:36 2023] EXT4-fs (dm-6): unmounting filesystem c7ac5491-9bf7-46a2-a6f8-4a33d593592b.
                              [Wed Oct 25 08:34:59 2023] EXT4-fs (dm-8): mounted filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f with ordered data mode. Quota mode: none.
                              [Wed Oct 25 08:35:08 2023] EXT4-fs (dm-8): unmounting filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f.
                              [Wed Oct 25 08:35:09 2023] EXT4-fs (dm-8): mounted filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f with ordered data mode. Quota mode: none.
                              [Wed Oct 25 08:55:04 2023] EXT4-fs (dm-8): unmounting filesystem e4400d99-9393-482e-a0d7-6c76bde42e2f.
                              [Wed Oct 25 08:57:14 2023] EXT4-fs (dm-8): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 with ordered data mode. Quota mode: none.
                              [Wed Oct 25 08:57:23 2023] EXT4-fs (dm-8): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
                              [Wed Oct 25 08:57:25 2023] EXT4-fs (dm-8): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 with ordered data mode. Quota mode: none.
                              [Wed Oct 25 08:58:44 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
                              [Wed Oct 25 08:58:44 2023] EXT4-fs (dm-9): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 without journal. Quota mode: none.
                              [Wed Oct 25 08:58:57 2023] EXT4-fs (dm-9): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
                              [Wed Oct 25 09:34:58 2023] EXT4-fs (dm-9): write access unavailable, skipping orphan cleanup
                              [Wed Oct 25 09:34:58 2023] EXT4-fs (dm-9): mounted filesystem aa14789c-0f19-4c5f-a270-495df66c93a5 without journal. Quota mode: none.
                              [Wed Oct 25 09:35:51 2023] EXT4-fs (dm-9): unmounting filesystem aa14789c-0f19-4c5f-a270-495df66c93a5.
                              TARGET SOURCE                           FSTYPE OPTIONS
                              /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
                              /var:
                              416M    /var/
                              247M    /var/cache
                              243M    /var/cache/apt
                              168M    /var/cache/apt/archives
                              145M    /var/lib
                                    Users in the 'systemd-journal' group can see all messages. Pass -q to
                                    turn off this notice.
                              Archived and active journals take up 8.0M in the file system.
                              /opt/iobroker/backups:
                              31M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              524M    /opt/iobroker/iobroker-data/
                              346M    /opt/iobroker/iobroker-data/files
                              149M    /opt/iobroker/iobroker-data/history
                              88M     /opt/iobroker/iobroker-data/files/echarts.admin
                              57M     /opt/iobroker/iobroker-data/files/echarts
                              23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                              23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                              22M     /opt/iobroker/iobroker-data/objects.jsonl
                              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                              USB-Devices by-id:
                              find: '/dev/serial/by-id/': No such file or directory
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.18.2
                              /usr/bin/node           v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              /usr/bin/corepack       0.19.0
                              nodejs:
                                Installed: 18.18.2-1nodesource1
                                Candidate: 18.18.2-1nodesource1
                                Version table:
                               *** 18.18.2-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                   18.18.1-1nodesource1 500
                                   18.18.0-1nodesource1 500
                                   18.17.1-1nodesource1 500
                                   18.17.0-1nodesource1 500
                                   18.16.1-1nodesource1 500
                                   18.16.0-1nodesource1 500
                                   18.15.0-1nodesource1 500
                                   18.14.2-1nodesource1 500
                                   18.14.1-1nodesource1 500
                                   18.14.0-1nodesource1 500
                                   18.13.0+dfsg1-1 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                   18.13.0-1nodesource1 500
                                   18.12.0-1nodesource1 500
                                   18.11.0-1nodesource1 500
                                   18.10.0-1nodesource1 500
                                   18.9.1-1nodesource1 500
                                   18.9.0-1nodesource1 500
                                   18.8.0-1nodesource1 500
                                   18.7.0-1nodesource1 500
                                   18.6.0-1nodesource1 500
                                   18.5.0-1nodesource1 500
                                   18.4.0-1nodesource1 500
                                   18.3.0-1nodesource1 500
                                   18.2.0-1nodesource1 500
                                   18.1.0-1nodesource1 500
                                   18.0.0-1nodesource1 500
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  5.0.12
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapters from github:   2
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
                              + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
                              + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                              + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                              + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                              + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                              + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                              + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                system.adapter.mihome-cloud.0           : mihome-cloud          : ioBroker                                 - disabled
                              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                                system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 8086
                              + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                              + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                              + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                              + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
                              + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "admin"        : 6.10.1   , installed 6.10.1
                              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                              Adapter    "deyeidc"      : 0.0.11   , installed 0.0.11
                              Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                              Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                              Controller "js-controller": 5.0.12   , installed 5.0.12
                              Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.1
                              Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                              Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                              Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                              Adapter    "snmp"         : 2.4.11   , installed 2.4.11
                              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                              Adapter    "text2command" : 3.0.2    , installed 3.0.2
                              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                              Adapter    "web"          : 6.1.2    , installed 6.1.2
                              Adapter    "ws"           : 2.5.5    , installed 2.5.5
                              Objects and States
                              Objects:        3254
                              States:         2586
                              Hit:1 http://security.debian.org bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32714961   1/init
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       32839125   13468/io.sonoff.0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32800660   11672/iobroker.js-c
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32801525   11672/iobroker.js-c
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          32586457   306/master
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          32587208   1/init
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          32714066   1/init
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          32586458   306/master
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32802908   11699/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32841881   13599/io.web.0
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       32840569   13614/io.ws.0
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32839861   13438/io.simple-api
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32715870   1/init
                              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       32839817   13419/io.mihome-vac
                              udp        0      0 0.0.0.0:46499           0.0.0.0:*                           1001       32839909   13453/io.snmp.0
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32840860   13543/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32840861   13543/io.tuya.0
                              udp6       0      0 :::111                  :::*                                0          32714963   1/init
                              2023-10-25 10:38:13.066  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:14.291  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                              2023-10-25 10:38:19.911  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:24.399  - info: hmip.0 (13393) ws connection opened
                              2023-10-25 10:38:26.747  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:33.560  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:34.543  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                              2023-10-25 10:38:40.367  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:44.645  - info: hmip.0 (13393) ws connection opened
                              2023-10-25 10:38:47.177  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:53.997  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:38:54.794  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                              2023-10-25 10:39:00.793  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:04.917  - info: hmip.0 (13393) ws connection opened
                              2023-10-25 10:39:07.617  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:14.436  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:15.062  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                              2023-10-25 10:39:21.334  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:25.164  - info: hmip.0 (13393) ws connection opened
                              2023-10-25 10:39:28.145  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:34.951  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:35.309  - warn: hmip.0 (13393) ws connection closed (0) - code: 1000 - reason:
                              2023-10-25 10:39:41.757  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              2023-10-25 10:39:45.411  - info: hmip.0 (13393) ws connection opened
                              2023-10-25 10:39:48.564  - warn: telegram.0 (13513) polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                              iob diag has finished.
                              ? crunchipC 2 Antworten Letzte Antwort
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                CPU threads: 4
                                edi77
                                /home/edi77
                                X-Server:       false
                                Desktop:
                                Terminal:
                                *** MEMORY ***
                                         6144 M total memory
                                         3905 M used memory
                                         1431 M free memory
                                            0 M buffer memory
                                          807 M swap cache
                                         2048 M total swap
                                          187 M used swap
                                         1860 M free swap
                                *** FILESYSTEM ***
                                /var:
                                416M    /var/
                                247M    /var/cache
                                243M    /var/cache/apt
                                145M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.10.1
                                javascript:     7.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        3254
                                States:         2586
                                Pending Updates: 0
                                Moin,
                                Versuch mal Deinen Weg/Installation mit ein paar Bildern zu zeigen, was hast Du wie, wo eingestellt, das mit den ganzen Mounts/Unmounts kapiere ich nicht, wie sieht Deine Proxmox Installation aus, welche Storages hast Du, was Mountest Du da alles im LX Container.
                                Ich verstehe es nicht, was Du da machst, ich muss jetzt aber erst mal mit Frauchen Einkaufen, später schaue ich mir das noch einmal an und installiere mir einen neuen LX Container, um sicherzugehen, dass da nichts in Proxmox anders ist als in der Dokumentation beschreiben.
                                Bernd
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  CPU threads: 4
                                  edi77
                                  /home/edi77
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                           6144 M total memory
                                           3905 M used memory
                                           1431 M free memory
                                              0 M buffer memory
                                            807 M swap cache
                                           2048 M total swap
                                            187 M used swap
                                           1860 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  416M    /var/
                                  247M    /var/cache
                                  243M    /var/cache/apt
                                  145M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.10.1
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        3254
                                  States:         2586
                                  Pending Updates: 0
                                  crunchipC Offline
                                  crunchipC Offline
                                  Da stimmt doch vermutlich in deiner Grundinstallation schon etwas nicht
                                    Eduard77E Offline
                                    Eduard77E Offline
                                    Eduard77
                                    @crunchip
                                    ich glaube ich habe mein Fehler gefunden.
                                    Ich wollte ein Privilegierte Container erstellen.
                                    Das hat bei mir immer zu dem Fehler geführt.
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                    Failed to query system properties: Connection timed out
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                     11:50:44 up 20 min,  0 user,  load average: 0.51, 0.62, 0.50
                                    CPU threads: 4
                                    Jetzt beim 5 Mal habe ich ein Unprivilegierte Container erstellt.
                                    Jetzt habe ich Time Out Fehler nicht. (wieso auch immer)
                                    "iob diag" sagt jetzt.
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                     Static hostname: DebianIO
                                           Icon name: computer-container
                                             Chassis: container ☐
                                      Virtualization: lxc
                                              Kernel: Linux 6.2.16-15-pve
                                        Architecture: x86-64
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                     12:19:06 up 10 min,  2 users,  load average: 1.30, 1.14, 0.69
                                    CPU threads: 4
                                                   Local time: Wed 2023-10-25 12:19:07 CEST
                                               Universal time: Wed 2023-10-25 10:19:07 UTC
                                                     RTC time: n/a
                                                  NTP service: inactive
                                              RTC in local TZ: no
                                    edi77
                                    /home/edi77
                                    edi77 sudo users
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:            6.4G        309M        4.5G        118K        1.7G        6.1G
                                    Swap:           1.1G          0B        1.1G
                                    Total:          7.5G        309M        5.5G
                                             6144 M total memory
                                              295 M used memory
                                              343 M active memory
                                             1400 M inactive memory
                                             4265 M free memory
                                                0 M buffer memory
                                             1582 M swap cache
                                             1024 M total swap
                                                0 M used swap
                                             1024 M free swap
                                    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                    *** FILESYSTEM ***
                                    /dev/mapper/pve-vm--104--disk--0 ext4       16G  2.0G   13G  13% /
                                    udev                             devtmpfs  3.7G     0  3.7G   0% /dev/tty
                                    tmpfs                            tmpfs     1.5G  112K  1.5G   1% /run
                                    dmesg: read kernel buffer failed: Operation not permitted
                                    /      /dev/mapper/pve-vm--104--disk--0 ext4   rw,relatime,stripe=16
                                    /var:
                                    416M    /var/
                                    247M    /var/cache
                                    243M    /var/cache/apt
                                    167M    /var/cache/apt/archives
                                    145M    /var/lib
                                    4.0K    /opt/iobroker/backups/
                                    15M     /opt/iobroker/iobroker-data/files
                                    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                    384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                    USB-Devices by-id:
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.10.1
                                    javascript:     "javascript" not found
                                    Adapters from github:   0
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : DebianIO                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.backitup.0               : backitup              : DebianIO                                 -  enabled
                                    + system.adapter.discovery.0              : discovery             : DebianIO                                 -  enabled
                                    + instance is alive
                                    Objects and States
                                    Objects:        142
                                    States:         102
                                    Hit:2 http://security.debian.org bookworm-security InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          208394     298/master
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       267130     10597/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       268711     10597/iobroker.js-c
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          264110     1/init
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       269645     10692/io.admin.0
                                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          208395     298/master
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          209203     1/init
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          264112     1/init
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          264111     1/init
                                    udp6       0      0 :::111                  :::*                                0          264113     1/init
                                    2023-10-25 12:18:42.066  - info: host.DebianIO iobroker.js-controller version 5.0.12 js-controller starting
                                    2023-10-25 12:18:42.068  - info: host.DebianIO Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2023-10-25 12:18:42.069  - info: host.DebianIO hostname: DebianIO, node: v18.18.2
                                    2023-10-25 12:18:42.069  - info: host.DebianIO ip addresses: 192.168.178.5 2003:c0:ff08:b900:4068:1cff:fe60:9f9a fe80::4068:1cff:fe60:9f9a
                                    2023-10-25 12:18:42.361  - info: host.DebianIO connected to Objects and States
                                    2023-10-25 12:18:42.376  - info: host.DebianIO Node.js version has changed from unknown to 18.18.2
                                    2023-10-25 12:18:42.404  - info: host.DebianIO Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                    2023-10-25 12:18:42.413  - info: host.DebianIO added notifications configuration of host
                                    2023-10-25 12:18:42.647  - info: host.DebianIO 3 instances found
                                    2023-10-25 12:18:42.651  - info: host.DebianIO starting 3 instances
                                    2023-10-25 12:18:42.681  - info: host.DebianIO instance system.adapter.admin.0 started with pid 10692
                                    2023-10-25 12:18:43.631  - info: admin.0 (10692) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
                                    2023-10-25 12:18:43.662  - info: admin.0 (10692) requesting all objects
                                    2023-10-25 12:18:43.737  - info: admin.0 (10692) received all objects
                                    2023-10-25 12:18:43.782  - info: admin.0 (10692) socket.io server listening on port 8081
                                    2023-10-25 12:18:43.783  - info: admin.0 (10692) http server listening on port 8081
                                    2023-10-25 12:18:43.784  - info: admin.0 (10692) Use link "http://127.0.0.1:8081" to configure.
                                    2023-10-25 12:18:43.903  - warn: admin.0 (10692) Repository cannot be read: Active repo - stable
                                    2023-10-25 12:18:43.903  - warn: admin.0 (10692) Active repository "stable" cannot be read
                                    2023-10-25 12:18:44.071  - error: admin.0 (10692) Cannot update news: TypeError: newNews.forEach is not a function
                                    2023-10-25 12:18:46.671  - info: host.DebianIO instance system.adapter.discovery.0 started with pid 10719
                                    2023-10-25 12:18:47.413  - info: discovery.0 (10719) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.12
                                    2023-10-25 12:18:50.669  - info: host.DebianIO instance system.adapter.backitup.0 started with pid 10734
                                    2023-10-25 12:18:51.487  - info: backitup.0 (10734) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
                                    2023-10-25 12:18:51.526  - info: backitup.0 (10734) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                                            v.2023-10-10
                                      Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               amd64
                                    User-ID:                1000
                                    X-Server:               false
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                            /usr/bin/npm            9.8.1
                                                            /usr/bin/npx            9.8.1
                                    Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                    MEMORY:
                                    Mem:            6.4G        458M        4.3G        118K        1.7G        6.0G
                                    Swap:           1.1G          0B        1.1G
                                    Total:          7.5G        458M        5.4G
                                    Active iob-Instances:   4
                                    ioBroker Core:          js-controller           5.0.12
                                                            admin                   6.10.1
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                142
                                    States:                 102
                                    Size of iob-Database:
                                    3.8M    /opt/iobroker/iobroker-data/objects.jsonl
                                    32K     /opt/iobroker/iobroker-data/states.jsonl
                                    Aber 2 Probleme hat er noch. Oder?
                                    crunchipC ? 3 Antworten Letzte Antwort
                                      @crunchip
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      CPU threads: 4
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      CPU threads: 4
                                                       RTC time: n/a
                                                RTC in local TZ: no
                                      edi77
                                      /home/edi77
                                      edi77 sudo users
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Swap:           1.1G          0B        1.1G
                                               6144 M total memory
                                                295 M used memory
                                                343 M active memory
                                               4265 M free memory
                                                  0 M buffer memory
                                               1582 M swap cache
                                               1024 M total swap
                                                  0 M used swap
                                               1024 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      416M    /var/
                                      247M    /var/cache
                                      243M    /var/cache/apt
                                      145M    /var/lib
                                      USB-Devices by-id:
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.10.1
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        142
                                      States:         102
                                      Pending Updates: 0
                                                              v.2023-10-10
                                        Virtualization: lxc
                                      Installation:           lxc
                                      Kernel:                 x86_64
                                      Userland:               amd64
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Swap:           1.1G          0B        1.1G
                                                              admin                   6.10.1
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                142
                                      States:                 102
                                      crunchipC Offline
                                      crunchipC Offline
                                      Bin mir nicht sicher, hängt glaub ich mit ipv6 zusammen
                                        @crunchip
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        CPU threads: 4
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                          Virtualization: lxc
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        CPU threads: 4
                                                         RTC time: n/a
                                                  RTC in local TZ: no
                                        edi77
                                        /home/edi77
                                        edi77 sudo users
                                        X-Server:       false
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Swap:           1.1G          0B        1.1G
                                                 6144 M total memory
                                                  295 M used memory
                                                  343 M active memory
                                                 4265 M free memory
                                                    0 M buffer memory
                                                 1582 M swap cache
                                                 1024 M total swap
                                                    0 M used swap
                                                 1024 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        416M    /var/
                                        247M    /var/cache
                                        243M    /var/cache/apt
                                        145M    /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.10.1
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        142
                                        States:         102
                                        Pending Updates: 0
        v.2023-10-10
                                          Virtualization: lxc
                                        Installation:           lxc
                                        Kernel:                 x86_64
                                        Userland:               amd64
                                        User-ID:                1000
                                        X-Server:               false
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
                                        MEMORY:
                                        Swap:           1.1G          0B        1.1G
        admin                   6.10.1
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                142
                                        States:                 102
                                        crunchipC Offline
                                        crunchipC Offline
                                        Stimmt immer noch etwas nicht
                                          @crunchip
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          CPU threads: 4
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          CPU threads: 4
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          edi77
                                          /home/edi77
                                          edi77 sudo users
                                          X-Server:       false
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Swap:           1.1G          0B        1.1G
                                                   6144 M total memory
                                                    295 M used memory
                                                    343 M active memory
                                                   4265 M free memory
                                                      0 M buffer memory
                                                   1582 M swap cache
                                                   1024 M total swap
                                                      0 M used swap
                                                   1024 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          416M    /var/
                                          247M    /var/cache
                                          243M    /var/cache/apt
                                          145M    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.10.1
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        142
                                          States:         102
                                          Pending Updates: 0
        v.2023-10-10
                                            Virtualization: lxc
                                          Installation:           lxc
                                          Kernel:                 x86_64
                                          Userland:               amd64
                                          User-ID:                1000
                                          X-Server:               false
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
                                          MEMORY:
                                          Swap:           1.1G          0B        1.1G
        admin                   6.10.1
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                142
                                          States:                 102
                                          Moin,
                                          hatte ich dazu nicht schon einmal was geschrieben, find den Beitrag gerade nicht, der eine Dienst rpc... ist für NFS kann man wohl vernachlässigen, der andere sys-kern... sollte man in einem LXC auch nicht machen, denn dann würden
                                          /sys
                                          /proc
                                          Vom Hostsystem, schreibend in den LXC gemountet, was dann echt blöd ist, wenn man da an der Kernel Konfiguration aus einem LX Container, am Kernel des Hostsystems (PVE) Änderungen vornimmt, dann kracht irgendwann die ganze Maschine.
                                          Anders sieht es aus, wenn das eine VM ist, dann muss das laufen, da dort ein eigener Kernel und ein eigenes Subsystem vorhanden ist.
                                          Ich würde diese Information als Warnung ansehen, sollte man sich anschauen, sich aber nicht verrückt machen lassen.
                                          Bernd
