  3. Off Topic
  4. Proxmox
  5. proxmox - iobroker startet nicht mehr
    apollon77A
  • NEWS Räume und Funktionen in einem Durchlauf: der Assistent in Admin 8 (mit Video)
Geplant Angeheftet Gesperrt Verschoben Proxmox
58 Beiträge 4 Kommentatoren 8.7k Aufrufe 4 Beobachtet
    @dos1973 sagte in proxmox - iobroker startet nicht mehr:
    *** nodejs is NOT correctly installed ***
    iob stop
    iob fix
    iob nodejs-update
    D
    D
    dos1973
    @thomas-braun sagte in proxmox - iobroker startet nicht mehr:
    iob stop
    iob fix
    iob nodejs-update
    das klappt leider nicht.
    ioBroker nodejs fixer 2023-10-13
    Recommended nodejs-version is: 18.18.2
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs 	v18.13.0
    /usr/bin/node 		v18.13.0
    /usr/bin/npm 		9.2.0
    /usr/bin/npx 		9.2.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.13.0+dfsg1-1
      Candidate: 18.18.2-1nodesource1
      Version table:
         18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
     *** 18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            100 /var/lib/dpkg/status
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2?
    Press <y> to continue or any other key to quit
    Trying to update your installation now. Please be patient.
    Virtualization: kvm
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Ign:4 https://ookla.bintray.com/debian generic InRelease
    Err:4 https://ookla.bintray.com/debian generic InRelease
      Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.214.194.113 443]
    Reading package lists... Done
    W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.214.194.113 443]
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Ign:5 https://ookla.bintray.com/debian generic InRelease
    Err:5 https://ookla.bintray.com/debian generic InRelease
      Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.232.172.199 443]
    W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.232.172.199 443]
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    E: Broken packages
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    dos1973@pve-iobroker:~$ node -v
    v18.13.0
    er fragt ob ich auf 18.18.2 update, macht er aber nicht.
    iob Diag zeigt weiterhin Fehler bei nodjs
    *** NodeJS-Installation ***
    /usr/bin/npm 		9.2.0
    /usr/bin/npx 		9.2.0
    /usr/local/bin/corepack 	0.19.0
    • D dos1973
      iob stop
      iob fix
      iob nodejs-update
      /usr/bin/npm 		9.2.0
      /usr/bin/npx 		9.2.0
      nodejs:
        Version table:
      Virtualization: kvm
      Package: nodejs
      Pin-Priority: 1001
      E: Broken packages
      v18.13.0
      /usr/bin/npm 		9.2.0
      /usr/bin/npx 		9.2.0
      Thomas BraunT
      Thomas BraunT
      @dos1973
      iob stop
      sudo apt remove nodejs libnode* node-*
      sudo apt install nodejs
      iob start
      Und dann nochmal
      iob nodejs-update
        @dos1973
        iob stop
        iob start
        Und dann nochmal
        iob nodejs-update
        D
        D
        dos1973
        schaut jetzt gut aus, Danke
        /usr/bin/nodejs 	v18.18.2
        /usr/bin/node 		v18.18.2
        /usr/bin/npm 		9.8.1
        /usr/bin/npx 		9.8.1
        /usr/bin/corepack 	0.19.0
        das Fehl:11 https://ookla.bintray.com/debian generic InRelease
        habe ich hier gefunden und
        dos1973@pve-iobroker:/etc/apt/sources.list.d$ ls
        nodesource.list  speedtest.list
          GNU nano 7.2        speedtest.list
        #deb https://ookla.bintray.com/debian generic main
        • D dos1973
          /usr/bin/npm 		9.8.1
          /usr/bin/npx 		9.8.1
          Thomas BraunT
          Thomas BraunT
          speedtest.list
          Lösch die Datei. Das wird jetzt anders angelegt. Link hatte ich oben schon gepostet.
            speedtest.list
            D
            D
            dos1973
            ok, habe da jetzt auch
            nodesource.list  ookla_speedtest-cli.list
            # this file was generated by packagecloud.io for
            # the repository at https://packagecloud.io/ookla/speedtest-cli
            deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bookworm main
            deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bookworm main
            • D dos1973
              D
              D
              dos1973
              der Server sollte jetzt doch wieder laufen, noch eine Frage habe ich
              ich habe ja die 6GB Daten gelöscht, es es üblich dass mein iobroker 12GB groß ist?
              woher kamen die backups in dem order
              /opt/iobroker/backups/
              kommt das vom Backitup Adapter, hatte den überhaupt nicht auf dem Schirm.
              wäre das die Backup Strategie den Adapter zu nutzen?
              • D dos1973
                Thomas BraunT
                Thomas BraunT
                Natürlich. Aber wenn du eh den ganzen 'Stadtteil' backupst brauchst du die Baupläne von der Gartenhütte 'ioBroker' ja nicht auch noch sichern.
                  D
                  D
                  dos1973
                  schrieb am zuletzt editiert von dos1973
                  ich schau mir mal den Adapter an... das mit dem Stadteil habe ich laut losgelacht :-)
                  mir machen die nur noch 6GB freien Platz etwas Sorgen, daher würde ich gerne proaktiv auf 30GB erhöhen.
                  ich habe hier eine Anleitung gefunden. Könntest du mal draufschauen ob dass passt, insbesondere mit dem Tool "Gparted"
                  https://beyond.lol/disk-einer-vm-vergroessern-in-proxmox/#:~:text=Als erstes loggen wir uns,man die Disk vergrössern möchte.
                  Nochmals ein Herzliches Danke für eure bisherige Hilfe
                  • D dos1973
                    Thomas BraunT
                    Thomas BraunT
                    Cleverer wäre es zu schauen wo die dicken Kinder wohnen und die auf Diät zu setzen statt XXXXXL-Klamotten zu beschaffen. Der Platz wird dir wieder ausgehen, wenn du die Datenvermehrung nicht stoppst.
                    • D dos1973
                      Thomas BraunT
                      Thomas BraunT
                      @dos1973
                      Zum Vergleich: Mein ganzes System inkl. 'alles' und ioBroker haust auf 5GB:
                      echad@chet:~/iob_coding/ioBroker $ df -h
                      Filesystem      Size  Used Avail Use% Mounted on
                      udev            3.6G     0  3.6G   0% /dev
                      tmpfs           782M  1.2M  780M   1% /run
                      /dev/sda2       110G  5.0G   99G   5% /
                      tmpfs           3.9G     0  3.9G   0% /dev/shm
                      tmpfs           5.0M   20K  5.0M   1% /run/lock
                      /dev/sda1       510M   61M  450M  12% /boot/firmware
                      tmpfs           782M     0  782M   0% /run/user/1000
                        @dos1973
                        D
                        D
                        dos1973
                        ich hab mal das ncdu installiert
                        .   5,1 GiB [##############################] /home
                            3,1 GiB [##################            ] /opt
                            2,7 GiB [###############               ] /usr
                        . 401,8 MiB [##                            ] /var
                           83,4 MiB [                              ] /boot
                        .   4,2 MiB [                              ] /etc
                        . 524,0 KiB [                              ] /run
                        .  28,0 KiB [                              ] /tmp
                        !  16,0 KiB [                              ] /lost+found
                        in /home
                        .   3,4 GiB [##############################] /iobroker
                            1,7 GiB [###############               ] /dos1973
                        in /dos1973
                          954,6 MiB [##############################] /node_modules
                          788,9 MiB [########################      ] /.npm
                            6,9 MiB [                              ] /.cache
                            3,3 MiB [                              ] /.nvm
                           24,0 KiB [                              ] /.config
                           12,0 KiB [                              ] /.local
                           12,0 KiB [                              ]  package-lock.json
                           12,0 KiB [                              ] /.iobroker
                            8,0 KiB [                              ] /.gnupg
                            8,0 KiB [                              ]  .bash_history
                            4,0 KiB [                              ]  .bashrc
                            4,0 KiB [                              ]  .profile
                            4,0 KiB [                              ]  .bash_logout
                            4,0 KiB [                              ]  .npmrc
                            4,0 KiB [                              ]  .lesshst
                            0,0   B [                              ]  .sudo_as_admin_successful
                        irgendwas passt nicht mit /home /opt /user
                        warum habe ich in home 3,4GB iobroker?
                        D Thomas BraunT 2 Antworten Letzte Antwort
                        • D dos1973
                             83,4 MiB [                              ] /boot
                          .   4,2 MiB [                              ] /etc
                          .  28,0 KiB [                              ] /tmp
                          in /home
                          in /dos1973
                              6,9 MiB [                              ] /.cache
                              3,3 MiB [                              ] /.nvm
                              8,0 KiB [                              ] /.gnupg
                              4,0 KiB [                              ]  .bashrc
                              4,0 KiB [                              ]  .npmrc
                          D
                          D
                          dos1973
                          bin drauf und dran das iobroker Verzeichnis in /home mit 3,4GB zu löschen.
                          Habe ja den "Stadtteil" gesichert ...
                          • D dos1973
                               83,4 MiB [                              ] /boot
                            .   4,2 MiB [                              ] /etc
                            .  28,0 KiB [                              ] /tmp
                            in /home
                            in /dos1973
                                6,9 MiB [                              ] /.cache
                                3,3 MiB [                              ] /.nvm
                                8,0 KiB [                              ] /.gnupg
                                4,0 KiB [                              ]  .bashrc
                                4,0 KiB [                              ]  .npmrc
                            Thomas BraunT
                            Thomas BraunT
                            Weil du da mal irgendwas dickes hineininstalliert hast:
                            Ein Verzeichnis
                            /home/iobroker/node_modules
                            gibt es bei mir z. B. gar nicht.
                            • D dos1973
                              Thomas BraunT
                              Thomas BraunT
                              Nein! Das ist das home des iobrokers, das braucht es!
                              Du kannst aber node_modules da raus löschen.
                                D
                                D
                                dos1973
                                das ist der verursacher in /Home
                                --- /home/iobroker/.npm/_cacache/content-v2 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                                    3,2 GiB [##############################] /sha512
                                   39,1 MiB [                              ] /sha1
                                • D dos1973
                                     39,1 MiB [                              ] /sha1
                                  Thomas BraunT
                                  Thomas BraunT
                                  @dos1973
                                  Das ist der npm cache.
                                  sudo -H -u iobroker npm cache clear --force
                                  leert den. Lösch den nicht anders!
                                    @dos1973
                                    D
                                    D
                                    dos1973
                                    das hat schonmal geholfen /Home ist nur noch 1,8GB
                                    im Home gibt es noch den ordner /dos1973 also mein Useraccount
                                    --- /home/dos1973 --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                                        6,9 MiB [                              ] /.cache
                                        3,3 MiB [                              ] /.nvm
                                        8,0 KiB [                              ] /.gnupg
                                        4,0 KiB [                              ]  .bashrc
                                        4,0 KiB [                              ]  .npmrc
                                    /node_modules. /.npm. sind auch sehr groß
                                    • D dos1973
                                          6,9 MiB [                              ] /.cache
                                          3,3 MiB [                              ] /.nvm
                                          8,0 KiB [                              ] /.gnupg
                                          4,0 KiB [                              ]  .bashrc
                                          4,0 KiB [                              ]  .npmrc
                                      Thomas BraunT
                                      Thomas BraunT
                                      @dos1973
                                      Auch da sollte es eigentlich kein Verzeichnis /node_modules geben. Kann imho weg.
                                      Analog dann auch:
                                      cd /home/dos1973 & npm cache clear --force
                                      D 2 Antworten Letzte Antwort
                                        @dos1973
                                        Analog dann auch:
                                        D
                                        D
                                        dos1973
                                        glaube das sieht schon gut aus
                                            3,2 GiB [##############################] /opt
                                            2,7 GiB [#########################     ] /usr
                                        .   1,0 GiB [#########                     ] /home
                                        . 400,7 MiB [###                           ] /var
                                           83,4 MiB [                              ] /boot
                                        /usr ist noch groß
                                        --- /usr/lib -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                                          714,8 MiB [##############################] /modules
                                          502,4 MiB [#####################         ] /x86_64-linux-gnu
                                          237,6 MiB [#########                     ] /gcc
                                        • D dos1973
                                             83,4 MiB [                              ] /boot
                                          /usr ist noch groß
                                          Thomas BraunT
                                          Thomas BraunT
                                          @dos1973
                                          Von /usr lässt du die Finger!
                                          Das sind die UnixSystemRessources, da hast du nix verloren.
                                          Ich hab gerade mal auf meinem System geschaut. node_modules gibt es nur als:
                                          /usr/lib/node_modules
                                          /opt/iobroker/node_modules/
                                          nicht irgendwo anders.
                                          83.9k
                                          1.4m
