  4. Test Adapter Weather-Warnings
    2.6k
    4.7k
    4.0k
1.1k Beiträge 35 Kommentatoren 454.6k Aufrufe 40 Beobachtet
  • T ticaki
    @sigi234
    Was muß ich tun damit der Fehler bei mir erscheint?
    sigi234S Online
    sigi234S Online
    sigi234
    #441
    @ticaki sagte in Test Adapter Weather-Warnings:
    @sigi234
    Habe via Git einen upload gemacht
    Edit:
    Dann in den Einstellungen auf EMAIL
    Immer Daten sichern!
    • sigi234S sigi234
      @sigi234
      Edit:
      ticaki
      #442
      @sigi234
      Hab ich auch gerade mit Admin 11 installiert und dann admin auf 12 weil kein Fehler kam.
      Bei mir läufts ohne Probleme. hm..
      Spenden
      sigi234S 2 Antworten Letzte Antwort
      • T ticaki
        @sigi234
        sigi234S Online
        sigi234S Online
        sigi234
        #443
        @sigi234
        Bin zurück auf 0.4.2 , Alles OK
        • T ticaki
          @sigi234
          sigi234S Online
          sigi234S Online
          sigi234
          #444
          Das auch nicht?
          admin.0
          2023-10-25 21:40:29.463	warn	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
          T 2 Antworten Letzte Antwort
          • sigi234S sigi234
            Das auch nicht?
            admin.0
            ticaki
            #445
            @sigi234
            Ich hab den Fehler reproduzieren können - vorlagen email dann da was geändert hin zurück bam
            Spenden
            • sigi234S sigi234
              Das auch nicht?
              admin.0
              ticaki
              #446
              @sigi234
              Kannst du bitte die aktuellen Version nochmal testen, hab in der jetzt 100 mal rumgeklickt und Dinge geändert ohne GUI Fehler.
              Desweiteren gibts zu der Warnmeldung, die du hast eine Issue im Admin:
              EDIT: Und ja den Fehler hatte ich, aber da weiß ich das es kein Fehler von mir ist. Daher kein Fehler. :)
        admin.0        2023-10-25 21:40:29.463	warn	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
              https://github.com/ioBroker/adapter-react-v5/issues/195
              Spenden
              rtwlR sigi234S 2 Antworten Letzte Antwort
              • T ticaki
                @sigi234
                rtwlR Online
                rtwlR Online
                rtwl
                schrieb am zuletzt editiert von rtwl
                #447
                Ich hab auch soeben aktualisiert.
                zu Email kann ich nichts sagen, aber mir ist aufgefallen, dass ich im Tab Vorlagen und Pushover nicht speichern konnte. weder "Speichern" noch "Speichern und Schließen" hat funkioniert. (Ja, ich hatte etwas verändert)
                Hab dann bei "Allgemein" die Testdaten aktiviert, dann konnte ich Speichern. - Keine Ahnung ob das an mir lag, so gewollt ist, oder ein Bug ist.
                -Peter
                • rtwlR rtwl
                  ticaki
                  #448
                  @rtwl
                  So gewollt ist es nicht, Ich hab in der Vorlagentabelle einen kopierten Vergleich drin der das Speichern verhinderen kann, aber der ist von Anfang an drin.
                  Ah es könnte auch das sein, nachdem Installieren startet der Adapter einmal/zweimal neu, wenn die Adminoberfläche dabei offen ist, könnte es zu dem Verhalten kommen. Ich korrigiere dann Daten in der Konfiguration oder erstelle Arrays mit internen Adapter Daten. Diesesmal schreibe ich die Warntypen in das Hilfstextfeld das du unter dem Icon Pfad siehst. Dann aktualisiert sich diese Hilfe, wenn ich was an den Warntypen ändere.
                  Präziser: Ich schreibe die Daten in die Konfiguration, das schreiben zwingt den Adapter zum Neustart.
                  Ich erstelle dann gleich nochmal eine neue Version 0.4.4 müsste dann morgen(2:00) im latest sein.
                  Spenden
                  rtwlR 1 Antwort Letzte Antwort
                  • T ticaki
                    @rtwl
                    rtwlR Online
                    rtwlR Online
                    rtwl
                    #449
                    @ticaki
                    kann man eigentlich mit deinen Testdaten auch testen wie die Meldung aussieht, wenn eine von den 2 Warnungen aufgehoben wird. also keine Neue Warnung und auch nicht "All clear".
                    -Peter
                    • rtwlR rtwl
                      @ticaki
                      ticaki
                      #450
                      @rtwl
                      gute Idee, mach bitte eine Request danke :)
                      Edit: Wobei, wenn du lange warten kannst, dann geht das auch schon jetzt. Die Warnungen stehen für eine zufällige Zeit, dann sind sie weg für eine zufällige Zeit. Aber damit kann man das nicht schnell testen.
                      Die Zeiten sind 20-90 Minuten so um den dreh.
                      Spenden
                      • T ticaki
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        #451
                        Error in GUI!
                        weather-warnings.0
                        2023-10-25 22:45:25.863	error	[zamg-msg] No template for Key: [object Object]!
                        weather-warnings.0
                        2023-10-25 22:45:25.862	error	[zamg-msg] No template for Key: [object Object]!
                        weather-warnings.0
                        2023-10-25 22:41:50.635	error	[zamg-msg] No template for Key: [object Object]!
                        weather-warnings.0
                        • sigi234S sigi234
                          Error in GUI!
                          weather-warnings.0
                          weather-warnings.0
                          weather-warnings.0
                          weather-warnings.0
                          ticaki
                          #452
                          @sigi234
                          Speichere bitte mal die Konfig nachdem du was beliebiges geändert hast, da ist was kaputt. Es kann einfach nicht sein, dass diese Fehlermeldung kommt. Außer da sind templates ausgewählt die es garnicht gibt. Die GUI Fehler helfen mir und sagen mir nichts leider nicht. Ich kenn mit mit react nicht aus.
                          Falls der Fehler bleibt, bitte mal die Config hier posten, ich füge die dann bei mir ein und schaue auf dem dev-server was da passiert.
                          Spenden
                          • T ticaki
                            @sigi234
                            sigi234S Online
                            sigi234S Online
                            sigi234
                            #453
                            entfernt
                            Fehler bleibt, wenn ich EMails deaktiviere funktioniert alles.
                            • sigi234S sigi234
                              entfernt
                              ticaki
                              #454
                              @sigi234
                              Das ist mir eine lehre nichts mit Defaults auszuprobieren:
                              repariert:
                              Datei entfernt
                              "email_Title": "none",
                              da war ein Object drin gespeichert. So ist es richtig.
                              Spenden
                              • T ticaki
                                @sigi234
                                repariert:
                                Datei entfernt
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                #455
                                @ticaki
                                Bei mir importieren oder Update?
                                • sigi234S sigi234
                                  @ticaki
                                  ticaki
                                  #456
                                  @sigi234
                                  Importieren. Hab ausser dem Punkt nichts geändert. Sollte dann problemlos gehen. Danke fürs testen :)
                                  Spenden
                                  • T ticaki
                                    @sigi234
                                    sigi234S Online
                                    sigi234S Online
                                    sigi234
                                    #457
                                    @sigi234
                                    läuft wieder. 👍
                                      ticaki
                                      #458
                                      update github
                                      • Testwarnungen (die aller unterste Option) verändert
                                      • Bei dieser Option bleibt der Adapter gelb
                                      • Testwarnungen aktivieren!... wird von dieser Option selbstständig intern aktiviert.
                                      Ablauf jetzt je Durchlauf:
                                      1. Alle Testwarnungen sind aktiv
                                      2. Alle zufällig(gerade oder ungeraden) werden aufgehoben. Das bedeutet es gibt zur Zeit 1 aktive Warnung pro Provider und Warnzelle.
                                      3. Alle werden aufgehoben -> weiter bei 1.
                                      Intervallzeit sollte 1 Minute sein, aber kann zwischen 30 - 180 Sekunden liegen, je nachdem was ich zuletzt getestet habe und ob ich ans zurückstellen dachte. :)
                                      Spenden
                                      • T ticaki
                                        update github
                                        sigi234S Online
                                        sigi234S Online
                                        sigi234
                                        #459
                                        update github
                                        • sigi234S sigi234
                                          update github
                                          ticaki
                                          #460
                                          @sigi234
                                          ich wäre froh ich würde mal nen richtig komplizierten Fehler machen. :) 4 Zeichen vergessen, weil ich weg musste. Wenn Online editiere ich mienen letzten Beitrag.
                                          Spenden
