  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 496.9k Aufrufe 41 Beobachtet
  • sigi234S sigi234
    @ticaki sagte in Test Adapter Weather-Warnings:
    Hab ich auch gerade mit Admin 11 installiert und dann admin auf 12 weil kein Fehler kam.
    Das auch nicht?
    admin.0
    2023-10-25 21:40:29.463	warn	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    T Nicht stören
    T Nicht stören
    ticaki
    #445
    @sigi234
    Ich hab den Fehler reproduzieren können - vorlagen email dann da was geändert hin zurück bam
    Spenden
    • sigi234S sigi234
      Das auch nicht?
      admin.0
      T Nicht stören
      T Nicht stören
      ticaki
      #446
      @sigi234
      Kannst du bitte die aktuellen Version nochmal testen, hab in der jetzt 100 mal rumgeklickt und Dinge geändert ohne GUI Fehler.
      Desweiteren gibts zu der Warnmeldung, die du hast eine Issue im Admin:
      EDIT: Und ja den Fehler hatte ich, aber da weiß ich das es kein Fehler von mir ist. Daher kein Fehler. :)
        admin.0        2023-10-25 21:40:29.463	warn	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      https://github.com/ioBroker/adapter-react-v5/issues/195
      Spenden
      rtwlR sigi234S 2 Antworten Letzte Antwort
      • T ticaki
        @sigi234
        rtwlR Offline
        rtwlR Offline
        rtwl
        schrieb am zuletzt editiert von rtwl
        #447
        Ich hab auch soeben aktualisiert.
        zu Email kann ich nichts sagen, aber mir ist aufgefallen, dass ich im Tab Vorlagen und Pushover nicht speichern konnte. weder "Speichern" noch "Speichern und Schließen" hat funkioniert. (Ja, ich hatte etwas verändert)
        Hab dann bei "Allgemein" die Testdaten aktiviert, dann konnte ich Speichern. - Keine Ahnung ob das an mir lag, so gewollt ist, oder ein Bug ist.
        -Peter
        • rtwlR rtwl
          T Nicht stören
          T Nicht stören
          ticaki
          #448
          @rtwl
          So gewollt ist es nicht, Ich hab in der Vorlagentabelle einen kopierten Vergleich drin der das Speichern verhinderen kann, aber der ist von Anfang an drin.
          Ah es könnte auch das sein, nachdem Installieren startet der Adapter einmal/zweimal neu, wenn die Adminoberfläche dabei offen ist, könnte es zu dem Verhalten kommen. Ich korrigiere dann Daten in der Konfiguration oder erstelle Arrays mit internen Adapter Daten. Diesesmal schreibe ich die Warntypen in das Hilfstextfeld das du unter dem Icon Pfad siehst. Dann aktualisiert sich diese Hilfe, wenn ich was an den Warntypen ändere.
          Präziser: Ich schreibe die Daten in die Konfiguration, das schreiben zwingt den Adapter zum Neustart.
          Ich erstelle dann gleich nochmal eine neue Version 0.4.4 müsste dann morgen(2:00) im latest sein.
          Spenden
          rtwlR 1 Antwort Letzte Antwort
          • T ticaki
            @rtwl
            rtwlR Offline
            rtwlR Offline
            rtwl
            #449
            @ticaki
            kann man eigentlich mit deinen Testdaten auch testen wie die Meldung aussieht, wenn eine von den 2 Warnungen aufgehoben wird. also keine Neue Warnung und auch nicht "All clear".
            -Peter
            • rtwlR rtwl
              @ticaki
              T Nicht stören
              T Nicht stören
              ticaki
              #450
              @rtwl
              gute Idee, mach bitte eine Request danke :)
              Edit: Wobei, wenn du lange warten kannst, dann geht das auch schon jetzt. Die Warnungen stehen für eine zufällige Zeit, dann sind sie weg für eine zufällige Zeit. Aber damit kann man das nicht schnell testen.
              Die Zeiten sind 20-90 Minuten so um den dreh.
              Spenden
              • T ticaki
                @sigi234
                sigi234S Online
                sigi234S Online
                #451
                Error in GUI!
                weather-warnings.0
                2023-10-25 22:45:25.863	error	[zamg-msg] No template for Key: [object Object]!
                weather-warnings.0
                2023-10-25 22:45:25.862	error	[zamg-msg] No template for Key: [object Object]!
                weather-warnings.0
                2023-10-25 22:41:50.635	error	[zamg-msg] No template for Key: [object Object]!
                weather-warnings.0
                • sigi234S sigi234
                  Error in GUI!
                  weather-warnings.0
                  weather-warnings.0
                  weather-warnings.0
                  weather-warnings.0
                  T Nicht stören
                  T Nicht stören
                  ticaki
                  #452
                  @sigi234
                  Speichere bitte mal die Konfig nachdem du was beliebiges geändert hast, da ist was kaputt. Es kann einfach nicht sein, dass diese Fehlermeldung kommt. Außer da sind templates ausgewählt die es garnicht gibt. Die GUI Fehler helfen mir und sagen mir nichts leider nicht. Ich kenn mit mit react nicht aus.
                  Falls der Fehler bleibt, bitte mal die Config hier posten, ich füge die dann bei mir ein und schaue auf dem dev-server was da passiert.
                  Spenden
                  • T ticaki
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    #453
                    entfernt
                    Fehler bleibt, wenn ich EMails deaktiviere funktioniert alles.
                    • sigi234S sigi234
                      entfernt
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      #454
                      @sigi234
                      Das ist mir eine lehre nichts mit Defaults auszuprobieren:
                      repariert:
                      Datei entfernt
                      "email_Title": "none",
                      da war ein Object drin gespeichert. So ist es richtig.
                      Spenden
                      • T ticaki
                        @sigi234
                        repariert:
                        Datei entfernt
                        sigi234S Online
                        sigi234S Online
                        #455
                        @ticaki
                        Bei mir importieren oder Update?
                        • sigi234S sigi234
                          @ticaki
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          #456
                          @sigi234
                          Importieren. Hab ausser dem Punkt nichts geändert. Sollte dann problemlos gehen. Danke fürs testen :)
                          Spenden
                          • T ticaki
                            @sigi234
                            sigi234S Online
                            sigi234S Online
                            #457
                            @sigi234
                            läuft wieder. 👍
                            • T Nicht stören
                              T Nicht stören
                              ticaki
                              #458
                              update github
                              • Testwarnungen (die aller unterste Option) verändert
                              • Bei dieser Option bleibt der Adapter gelb
                              • Testwarnungen aktivieren!... wird von dieser Option selbstständig intern aktiviert.
                              Ablauf jetzt je Durchlauf:
                              1. Alle Testwarnungen sind aktiv
                              2. Alle zufällig(gerade oder ungeraden) werden aufgehoben. Das bedeutet es gibt zur Zeit 1 aktive Warnung pro Provider und Warnzelle.
                              3. Alle werden aufgehoben -> weiter bei 1.
                              Intervallzeit sollte 1 Minute sein, aber kann zwischen 30 - 180 Sekunden liegen, je nachdem was ich zuletzt getestet habe und ob ich ans zurückstellen dachte. :)
                              Spenden
                              • T ticaki
                                update github
                                sigi234S Online
                                sigi234S Online
                                #459
                                update github
                                • sigi234S sigi234
                                  update github
                                  T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  #460
                                  @sigi234
                                  ich wäre froh ich würde mal nen richtig komplizierten Fehler machen. :) 4 Zeichen vergessen, weil ich weg musste. Wenn Online editiere ich mienen letzten Beitrag.
                                  Spenden
                                  • T ticaki
                                    @sigi234
                                    sigi234S Online
                                    sigi234S Online
                                    #461
                                    @sigi234
                                    Wie bekomme ich den Ort in die Mail Vorlage? So geht es nicht:
                                    • sigi234S sigi234
                                      @sigi234
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      #462
                                      @sigi234
                                      Zur Zeit gehen in Title, Kopfzeile und Fußzeile keine Tokens ausser ${status}. Die 3. werden immer für jede Nachricht verwendet. In Kopf und Fußzeile geht es schon von der Codeseite aktuell nicht. Title ist ein ganz normale "Nachricht" bei keiner Nachricht sind die Tokens - keine Ahnung was dann da drin steht, ansonsten steht die Daten der letzten geschriebenen Warnung im Title bei Email und in Pushover immer die gerade bearbeitete.
                                      online
                                      Kann aber mal schauen ob ich da locationcustom rein bekomme. aber dann stehen alle locationscustoms da drin.
                                      Hm... hab bei Email das RemoveAll Template vergessen.
                                      Spenden
                                      • T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        #463
                                        update
                                        • locationcustom geht jetzt in Titel
                                        • RemoveAll als Vorlage im Admin Email eingefügt.
                                        Ich hab das für Emails jetzt so gelöst:
                                        Sortierung - neu, aufgehoben, gültig (die Sortierung nach startzeitpunkt fehlt da noch)
                                        Title da steht der Datensatz der 1. Warnung zur Verfügung und wenn keine Warnung da ist die Daten vom Controller - dieser enthält dann status (All Clear) und alle locationcustom
                                        So ohne weiteres bekomme ich bei aktiven Meldungen nicht alle locationscustoms da rein.
                                        Nochwas "nebensächliches" das beim Testen aber nach einem Fehler aussehen könnte... Alle konvertierten Vorlagen werden für 1 Minute gecacht. Da könnt ihr noch soviel auf manuelle Nachricht drücken. :) Heißt auch der Status von Neu zu gültig ändert sich erst nach 1 Minute...
                                        Em und ich hab vergessen das Test ding zurück auf 1 Minute zu stelllen steht auf 15 Sekunden. :)
                                        EDIT: Und noch eine Besonderheit bei Emails:
                                        Aus der Meldung
                                        Kopfzeile
                                        Warnung vor Sturm
                                        Warnung vor Sturm
                                        Warnung vor Sturm
                                        Warnung vor Regen
                                        Fußzeile
                                        Wird vor dem Versand.
                                        Kopfzeile
                                        Warnung vor Sturm
                                        Warnung vor Regen
                                        Fußzeile
                                        Dabei zählt ob die Zeichenkette in der fertigen Meldung identisch zu andern ist.
                                        Spenden
                                        • T ticaki
                                          update
                                          Aus der Meldung
                                          Kopfzeile
                                          Warnung vor Sturm
                                          Warnung vor Sturm
                                          Warnung vor Sturm
                                          Warnung vor Regen
                                          Fußzeile
                                          Kopfzeile
                                          Warnung vor Sturm
                                          Warnung vor Regen
                                          Fußzeile
                                          sigi234S Online
                                          sigi234S Online
                                          #464
                                          @ticaki
                                          Wie schauen dann die Vorlagen für Mails aus?
