  4. jarvis v3.2.x - just another remarkable vis
961 Beiträge 46 Kommentatoren 335.8k Aufrufe 43 Beobachtet
  • M MCU
    @meinzisas Was steht hier drin?
    jarvis.0.settings.language
    Wechselt der Inhalt auch dauernd?
    Welche web-Instanz ist vorhanden / wird genutzt? web.0
    Kannst du mal ein Video machen, damit es sehen kann, was genau passiert?
    ScreenToGif
    https://github.com/Zefau/ioBroker.jarvis/issues/2808
    MeinzIsAsM Offline
    MeinzIsAsM Offline
    MeinzIsAs
    schrieb am zuletzt editiert von MeinzIsAs
    #361
    @mcu In language steht nix drinn. Den hab ich beim Probieren wegen dem Problem mal gelöscht. Der Wert vorher war de-DE.
    Jarvis_Config.mp4
    Hab das mal als Video hochgeladen. So läuft das in der Dauerschleife.
    web-Instanz ist web.0
    • M MCU
      ScreenToGif
      MeinzIsAsM Offline
      MeinzIsAsM Offline
      MeinzIsAs
      #362
      @mcu Das steht bei Seite untersuchen in Chrome.
      [2024-09-24T04:20:32.603Z] Try to connect
       "Upload Configuration": {"en": "Upload Configuration", "de": "Upload Configuration", "ru": "Upload Configuration", "pt": "Upload Configuration", "nl": "Upload Configuration", "fr": "Upload Configuration", "es": "Upload Configuration", "pl": "Upload Configuration", "it": "Upload Configuration", "zh-cn": "Upload Configuration"},
       "Download Configuration": {"en": "Download Configuration", "de": "Download Configuration", "ru": "Download Configuration", "pt": "Download Configuration", "nl": "Download Configuration", "fr": "Download Configuration", "es": "Download Configuration", "pl": "Download Configuration", "it": "Download Configuration", "zh-cn": "Download Configuration"},
       "Restore": {"en": "Restore", "de": "Restore", "ru": "Restore", "pt": "Restore", "nl": "Restore", "fr": "Restore", "es": "Restore", "pl": "Restore", "it": "Restore", "zh-cn": "Restore"},
       "Cancel": {"en": "Cancel", "de": "Cancel", "ru": "Cancel", "pt": "Cancel", "nl": "Cancel", "fr": "Cancel", "es": "Cancel", "pl": "Cancel", "it": "Cancel", "zh-cn": "Cancel"},
       "Please be aware that backups will be deleted when the adapter is updated.": {"en": "Please be aware that backups will be deleted when the adapter is updated.", "de": "Please be aware that backups will be deleted when the adapter is updated.", "ru": "Please be aware that backups will be deleted when the adapter is updated.", "pt": "Please be aware that backups will be deleted when the adapter is updated.", "nl": "Please be aware that backups will be deleted when the adapter is updated.", "fr": "Please be aware that backups will be deleted when the adapter is updated.", "es": "Please be aware that backups will be deleted when the adapter is updated.", "pl": "Please be aware that backups will be deleted when the adapter is updated.", "it": "Please be aware that backups will be deleted when the adapter is updated.", "zh-cn": "Please be aware that backups will be deleted when the adapter is updated."},
       "Devices": {"en": "Devices", "de": "Devices", "ru": "Devices", "pt": "Devices", "nl": "Devices", "fr": "Devices", "es": "Devices", "pl": "Devices", "it": "Devices", "zh-cn": "Devices"},
       "Layout": {"en": "Layout", "de": "Layout", "ru": "Layout", "pt": "Layout", "nl": "Layout", "fr": "Layout", "es": "Layout", "pl": "Layout", "it": "Layout", "zh-cn": "Layout"},
       "Widgets": {"en": "Widgets", "de": "Widgets", "ru": "Widgets", "pt": "Widgets", "nl": "Widgets", "fr": "Widgets", "es": "Widgets", "pl": "Widgets", "it": "Widgets", "zh-cn": "Widgets"},
       "Settings": {"en": "Settings", "de": "Settings", "ru": "Settings", "pt": "Settings", "nl": "Settings", "fr": "Settings", "es": "Settings", "pl": "Settings", "it": "Settings", "zh-cn": "Settings"},
       "Styles": {"en": "Styles", "de": "Styles", "ru": "Styles", "pt": "Styles", "nl": "Styles", "fr": "Styles", "es": "Styles", "pl": "Styles", "it": "Styles", "zh-cn": "Styles"},
       "Scripts": {"en": "Scripts", "de": "Scripts", "ru": "Scripts", "pt": "Scripts", "nl": "Scripts", "fr": "Scripts", "es": "Scripts", "pl": "Scripts", "it": "Scripts", "zh-cn": "Scripts"},
       Get backups for "devices"...
       Get backups for "layout"...
       Get backups for "widgets"...
       Get backups for "settings"...
       Get backups for "styles"...
       Get backups for "scripts"...
       Got backups for "devices".
       Got backups for "layout".
       Got backups for "widgets".
       Got backups for "settings".
       Got backups for "styles".
       Got backups for "scripts".
       Message broker queried succesfully.
      3 jarvis Load setting "authentication" (radio) with value: none [object Object]
       jarvis Load setting "authenticationGroup" (select) with value: system.group.user,system.group.administrator [object Object]
      3 jarvis Load setting "authenticationConfiguration" (radio) with value: none [object Object]
       jarvis Load setting "authenticationConfigurationGroup" (select) with value: system.group.user,system.group.administrator [object Object]
       jarvis Load setting "certPublic" (select) with value:  [object Object]
       jarvis Load setting "certPrivate" (select) with value:  [object Object]
       jarvis Load setting "certChained" (select) with value:  [object Object]
       jarvis Load setting "socketPort" (number) with value: 8400 [object Object]
       jarvis Load setting "socketSecure" (checkbox) with value: false [object Object]
       jarvis Load setting "authenticationPassword" (password) with value:  [object Object]
       jarvis Load setting "authenticationConfigurationPassword" (password) with value:  [object Object]
      Instances.tsx:1090 Width: xl
       [2024-09-24T04:20:33.693Z] Try to connect
       [2024-09-24T04:20:34.972Z] Try to connect
      Wiederholen sich immer die selben Einträge. Wenn ich die Konfigseite so laufen lasse, hört das Laden dann irgendwann auf und die Werte stehen drinn.
      • MeinzIsAsM MeinzIsAs
        Meikie
        #363
        ich habe jetzt die Version v3.2.0-rc.5 installiert in Kombination mit dem neuen Admin-Panel 7.1.3.
        Leider funktioniert seit dem update mein iobroker sehr störrisch. Ich habe unter Übersicht jetzt 2 Jarvis. Einmal mit dem Port 8400, welche auch Funktioniert und einmal mit Port: undefined, welche nicht funktioniert.
        Wie bekomme ich die alte Version weg?
        Vielen Dank für die Hilfe.
        Meike
        M 2 Antworten Letzte Antwort
        • M Meikie
          Meike
          M Online
          M Online
          MCU
          #364
          @Homoran @Thomas-Braun Weiß jemand, wie man solch alte Einträge (Übersicht Anzeige Jarvis mit altem Port 8082, der aber nicht genutzt wird-> undefined) weg bekommt?
          Upload?
          Wo werden die Einträge gespeichert?
          Muss man evtl. jarvis komplett entfernen, damit auch alle Einträge einmal gelöscht werden.
          • M MCU
            Upload?
            #365
            @mcu
            Da ich keine GUI hier laufen habe kann ich dazu nichts erhellendes beitragen.
            Zwei Instanzen am Start?
            iob diag
            wäre mal wieder hilfreich.
            • M Meikie
              Meike
              M Online
              M Online
              MCU
              #366
              @meikie
              Warum? Wegen der Übersicht?
              Jarvis ist noch beta!, da sind noch einige offene Punkte.
              VORHER bitte ein Bild mit dem undefined, möchte es mit in die Doku nehmen. Danke.
              Man kann in der Übersicht den fehlerhaften Eintrag entfernen.
              rechts unten klicken und dann das Element anklicken, welches entfernt werden soll. Auf den blauen Haken klicken.
              -> Element hat einen grauen Haken
              dann unten rechts auf den grünen Haken klicken und es wird gespeichert.
              • M MCU
                @meikie
                Meikie
                schrieb am zuletzt editiert von Meikie
                #367
                @mcu Vielen Dank.
                Aber es ist ja nicht wirklich gelöscht, sondern nur ausgeblendet. Kann man das nicht irgendwo entfernen. Es muss ja noch irgendwo ein Verweis zur alten Version sein.
                • M Meikie
                  @mcu Vielen Dank.
                  M Online
                  M Online
                  MCU
                  #368
                  @meikie Weiß ich leider nicht. Müsste man beim iobroker.admin mal ein Issue setzen.
                  Danke für das Bild, hab in die Doku mit aufgenommen.
                  hotspot_2H 1 Antwort Letzte Antwort
                  • M MCU
                    hotspot_2H Offline
                    hotspot_2H Offline
                    hotspot_2
                    #369
                    Hallo, weiß jemand wie ich in jarvis einen Wert von Watt Stunden in kilowatt Stunden umrechen kann? Mit einer Nachkommastelle? Geht das oder muss ich da ein Blockly oder sowas machen?
                    also 36500 Wh in 36,5 kWh wäre die Umrechnung z.B.
                    • hotspot_2H hotspot_2
                      M Online
                      M Online
                      MCU
                      #370
                      @hotspot_2
                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/datenpunkt-eigenschaft/berechnungen-mit-val#division
                        MiWolf
                        #371
                        Hi zusammen,
                        vielleicht könnt ihr mir helfen, ich habe heute Jarvis auf v3.2.0-rc.5 aktualisiert, das hat soweit auch alles funktioniert. Anfangs läuft auch alles schick, nach einiger Zeit (wenn der Tab sich schlafen legt?) kommt es zu folgender Fehlermeldung und Jarvis wird frecherweise deaktiviert..:
                        jarvis.0 2024-09-30 17:23:17.856	info	terminating
                        jarvis.0 2024-09-30 17:23:17.354	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        jarvis.0 2024-09-30 17:23:17.353	info	terminating
                        jarvis.0 2024-09-30 17:23:17.352	info	Adapter stopped und unloaded.
                        jarvis.0 2024-09-30 17:23:17.351	error	unhandled promise rejection: null
                        jarvis.0 2024-09-30 17:23:17.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        jarvis.0 2024-09-30 17:18:41.414	warn	Failed moving user scripts due to "ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.jarvis/../../iobroker-data/files/0_userdata.0/jarvis-scripts'"!
                        jarvis.0 2024-09-30 17:18:36.098	info	Connection: WebSocket opened on port 8400 using http...
                        jarvis.0 2024-09-30 17:18:35.933	info	starting. Version 3.2.0-rc.5 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.17.0, js-controller: 6.0.11
                        Unter Dateien / Benutzerdaten hat Jarvis den entsprechenden Ordner angelegt...
                        Beste Grüße
                        Mirko
                        • M MiWolf
                          Hi zusammen,
                          Beste Grüße
                          Mirko
                          M Online
                          M Online
                          MCU
                          #372
                          @miwolf Der Ordner ist angelegt. Wenn du jetzt jarvis wieder startest, passiert was?
                          • M MCU
                            MiWolf
                            schrieb am zuletzt editiert von MiWolf
                            #373
                            @mcu
                            Es gibt leider keine Änderung. Der Ordner war ja auch schon vorher da (im IOBroker unter Dateien)...
                            Beste Grüße Mirko
                            jarvis.0 2024-10-01 11:03:02.561	info	Adapter stopped und unloaded.
                            jarvis.0 2024-10-01 11:03:02.560	error	unhandled promise rejection: null
                            jarvis.0 2024-10-01 11:03:02.559	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            jarvis.0 2024-10-01 11:01:36.829	warn	Failed moving user scripts due to "ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.jarvis/../../iobroker-data/files/0_userdata.0/jarvis-scripts'"!
                            jarvis.0 2024-10-01 11:01:31.535	info	Connection: WebSocket opened on port 8400 using http...
                            jarvis.0 2024-10-01 11:01:31.372	info	starting. Version 3.2.0-rc.5 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.17.0, js-controller: 6.0.11
                            Nachtrag:
                            ich habe gerade gesehen, das bei mir unter /opt/iobroker/iobroker-data/files kein Ordner 0_userdata.0 existiert. Da findet sich nur admin.admin, backitup.admin und discorvery.admin. Spannenderweise sehe in im IOBroker unter "Dateien" die entsprechende Ordnerstruktur..
                            Ich erzeuge mal die Ordner händisch und melde mich wieder.
                            Btw: Das was bei mir "nicht" normal ist... Ich hab eine Redis-Installation, wo der Redis-Server auf einem anderen System als den Raspi läuft.. ansonsten ist es eine frische Installation die via BackitUp wieder hergestellt wurde...
                            Nachtrag 2:
                            lege ich die Ordnerstruktur im Filesystem händisch an, startet Jarvis problemlos..
                            Nachtrag 3:
                            leider scheint das aber nicht die Ursache für die Exception gewesen zu sein, die besteht leider weiterhin:
                            • M MiWolf
                              @mcu
                              Beste Grüße Mirko
                              Nachtrag:
                              Nachtrag 2:
                              Nachtrag 3:
                              M Online
                              M Online
                              MCU
                              #374
                              @miwolf Nutzt du denn scripts?
                              Was sagt denn der Browser-LOG (F12)?
                              Admin Version 7?
                              • M MCU
                                Admin Version 7?
                                MiWolf
                                #375
                                @mcu
                                In der Console bekomme ich die folgende Fehlermeldung:
                                Ich bin mal durch den Code debugged und bin hier gelandet :)
                                Ich hab keine Scripts und kein CustomCSS
                                Admin ist Version 7.1.5.
                                  Steph 0
                                  #376
                                  ich habe seit meinem Umstieg auf auf einen nginx Reverse-Proxy einen seltsamen Effekt, desen Ursache ich nicht verstehe:
                                  Grundsätzlich funktioniert der Zugriff auf die Jarvis (rc5) Instanz via Reverse-Proxy (https://jarvis.xx.xx) einwandfrei.
                                  Jetzt habe ich die Config so ergänzt, dass der Zugriff aus meinem LAN ohne Autentifizierung möglich ist (IP Whitelist), von außerhalb meines LANs habe ich eine Basic Auth davor gesetzt.
                                  Die Basic Auth funktioniert auch einwandfrei, solange ich von einem Desktop-Browser komme (getestet: Chrome & Edge unter Windows).
                                  Nutze ich jedoch Safari oder Chrome vom iPhone (IOS 18) aus, dann kann ich mich zwar auch via Basic Auth anmelden, danach laufe ich aber in einen Websocket-Timeout und das war es dann. Auch ein Reload hilft nicht, Browser-Cache habe ich (mehrfach) gelöscht.
                                  Ich sehe eigentlich keinen Unteschied, ob ich die Seite via Mobiltelefon oder via Desktop aufrufe, oder übersehe ich etwas?
                                  Danke für jeden Hinweis!
                                  R 1 Antwort Letzte Antwort
                                  • S Steph 0
                                    Robbi12
                                    #377
                                    Hi. Wie bekomme ich es im Datenpunkt hin, dass das Icon in der jeweiligen Farbe blinkt.
                                    • R Robbi12
                                      M Online
                                      M Online
                                      MCU
                                      #378
                                      @robbi12 Welche Abhängigkeit hat denn die Farbe zum Icon? Sollen unterschiedliche Icons abhängig vom Wert angezeigt werden?
                                      Zeig mal den jetzigen Stand vom Geräte-DP.
                                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/icon-stil
                                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/eingabewerte-fur-die-gerate-dp-state-felder#icon
                                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/eingabewerte-fur-die-gerate-dp-state-felder#icon-stil
                                      • M MCU
                                        Robbi12
                                        #379
                                        @mcu So habe ich es jetzt.
                                        {"Gelb blinkt":{"color":"#fefe00"},"Gelb":{"color":"#fefe00"},"Violett dunkel":{"color":"#6b14b8"},"Gruen blinkt":{"color":"#00ff00"},"Gruen":{"color":"#00ff00"}}
                                        Ich würde gerne bei Gelb blinkt auch gerne blinken lassen
                                        • R Robbi12
                                          M Online
                                          M Online
                                          MCU
                                          #380
                                          @robbi12 Wo steht das denn?
                                          Im DP-State steht Gelb blinkt?
                                          Im Icon
                                          {"Gelb blinkt":"Icon blink","default":"Icon"}
                                          R 2 Antworten Letzte Antwort
