  4. jarvis v3.2.x - just another remarkable vis
961 Beiträge 46 Kommentatoren 344.8k Aufrufe 43 Beobachtet
  • MeinzIsAsM MeinzIsAs
    @zefau Ja, das passiert immer. Dauerreload. Schaltet immer zwischen Englisch und Deutsch hin und her. Keine Fehlereinträge im LOG von iobroker. 😰
    War mit rc3 schon so und ist mit rc5 noch immer.
    Mit loglevel "debug" steht das hier drinn:
    jarvis.0
    2024-09-18 13:04:45.503	debug	Get List of Backups for jarvis.0.scripts.
    jarvis.0
    2024-09-18 13:04:45.503	debug	Got message: {"command":"get-backups","message":{"id":"scripts"},"from":"system.adapter.admin.0","callback":{"message":{"id":"scripts"},"id":330,"ack":false,"time":1726657485437},"_id":33540256}
    jarvis.0
    2024-09-18 13:04:45.502	debug	Get List of Backups for jarvis.0.css.
    jarvis.0
    2024-09-18 13:04:45.502	debug	Got message: {"command":"get-backups","message":{"id":"css"},"from":"system.adapter.admin.0","callback":{"message":{"id":"css"},"id":329,"ack":false,"time":1726657485435},"_id":33540255}
    jarvis.0
    2024-09-18 13:04:45.501	debug	Get List of Backups for jarvis.0.settings.
    jarvis.0
    2024-09-18 13:04:45.501	debug	Got message: {"command":"get-backups","message":{"id":"settings"},"from":"system.adapter.admin.0","callback":{"message":{"id":"settings"},"id":328,"ack":false,"time":1726657485433},"_id":33540254}
    jarvis.0
    2024-09-18 13:04:45.489	debug	Get List of Backups for jarvis.0.widgets.
    jarvis.0
    2024-09-18 13:04:45.489	debug	Got message: {"command":"get-backups","message":{"id":"widgets"},"from":"system.adapter.admin.0","callback":{"message":{"id":"widgets"},"id":327,"ack":false,"time":1726657485430},"_id":33540253}
    jarvis.0
    2024-09-18 13:04:45.488	debug	Get List of Backups for jarvis.0.layout.
    jarvis.0
    2024-09-18 13:04:45.488	debug	Got message: {"command":"get-backups","message":{"id":"layout"},"from":"system.adapter.admin.0","callback":{"message":{"id":"layout"},"id":326,"ack":false,"time":1726657485429},"_id":33540252}
    jarvis.0
    2024-09-18 13:04:45.431	debug	Get List of Backups for jarvis.0.devices.
    jarvis.0
    2024-09-18 13:04:45.431	debug	Got message: {"command":"get-backups","message":{"id":"devices"},"from":"system.adapter.admin.0","callback":{"message":{"id":"devices"},"id":325,"ack":false,"time":1726657485428},"_id":33540251}
    jarvis.0
    2024-09-18 13:04:45.429	debug	Get pro data...
    jarvis.0
    2024-09-18 13:04:45.429	debug	Got message: {"command":"get-pro-status","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":324,"ack":false,"time":1726657485426},"_id":33540250}
    jarvis.0
    2024-09-18 13:04:45.427	debug	Got message: {"command":"get-users","message":{},"from":"system.adapter.admin.0","callback":{"message":{},"id":323,"ack":false,"time":1726657485425},"_id":33540249}
    MCU
    #353
    @meinzisas Sind die jarvis DPs alle mit signature im json?
    Auch scripts und css?
    Siehe oben
    MeinzIsAsM 1 Antwort Letzte Antwort
    • M MCU
      Siehe oben
      MeinzIsAsM Offline
      MeinzIsAsM Offline
      MeinzIsAs
      #354
      @mcu Jep. Außer addnotification = leer, notifications = [] und theme = {}
        MCU
        #355
        @meinzisas upload hast du gemacht?
        • MeinzIsAsM Offline
          MeinzIsAsM Offline
          MeinzIsAs
          #356
          @mcu Ja, hab ich auch schon getestet.
            MeinzIsAsM Offline
            MeinzIsAs
            #357
            @mcu Wenn ich auf der Konfigurationsseite den Adapter stoppe, hört der Dauerreload auf. Die Einstellungen werden aber nicht geladen. Es bleibt nur der Ladedonut aktiv.
            Wenn ich den Adapter dann wieder starte, kommen die Einstellwerte und der Dauerreload kommt auch nicht mehr.
            Dann kann ich auch ändern und speichern.
            Wenn ich das Fenster dann schließe und wieder öffne, kommt wieder der Dauerreload.
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #358
              @meinzisas hast du den Web Adapter installiert?
              • ZefauZ Zefau
                MeinzIsAsM Offline
                MeinzIsAsM Offline
                MeinzIsAs
                #359
                @zefau Sorry für die späte Antwort. Ja, der web-Adapter ist installiert.
                  MCU
                  #360
                  @meinzisas Was steht hier drin?
                  jarvis.0.settings.language
                  Wechselt der Inhalt auch dauernd?
                  Welche web-Instanz ist vorhanden / wird genutzt? web.0
                  Kannst du mal ein Video machen, damit es sehen kann, was genau passiert?
                  ScreenToGif
                  https://github.com/Zefau/ioBroker.jarvis/issues/2808
                  MeinzIsAsM 2 Antworten Letzte Antwort
                  • M MCU
                    ScreenToGif
                    MeinzIsAsM Offline
                    MeinzIsAsM Offline
                    MeinzIsAs
                    schrieb am zuletzt editiert von MeinzIsAs
                    #361
                    @mcu In language steht nix drinn. Den hab ich beim Probieren wegen dem Problem mal gelöscht. Der Wert vorher war de-DE.
                    Jarvis_Config.mp4
                    Hab das mal als Video hochgeladen. So läuft das in der Dauerschleife.
                    web-Instanz ist web.0
                    • M MCU
                      ScreenToGif
                      MeinzIsAsM Offline
                      MeinzIsAsM Offline
                      MeinzIsAs
                      #362
                      @mcu Das steht bei Seite untersuchen in Chrome.
                      [2024-09-24T04:20:32.603Z] Try to connect
                       "Upload Configuration": {"en": "Upload Configuration", "de": "Upload Configuration", "ru": "Upload Configuration", "pt": "Upload Configuration", "nl": "Upload Configuration", "fr": "Upload Configuration", "es": "Upload Configuration", "pl": "Upload Configuration", "it": "Upload Configuration", "zh-cn": "Upload Configuration"},
                       "Download Configuration": {"en": "Download Configuration", "de": "Download Configuration", "ru": "Download Configuration", "pt": "Download Configuration", "nl": "Download Configuration", "fr": "Download Configuration", "es": "Download Configuration", "pl": "Download Configuration", "it": "Download Configuration", "zh-cn": "Download Configuration"},
                       "Restore": {"en": "Restore", "de": "Restore", "ru": "Restore", "pt": "Restore", "nl": "Restore", "fr": "Restore", "es": "Restore", "pl": "Restore", "it": "Restore", "zh-cn": "Restore"},
                       "Cancel": {"en": "Cancel", "de": "Cancel", "ru": "Cancel", "pt": "Cancel", "nl": "Cancel", "fr": "Cancel", "es": "Cancel", "pl": "Cancel", "it": "Cancel", "zh-cn": "Cancel"},
                       "Please be aware that backups will be deleted when the adapter is updated.": {"en": "Please be aware that backups will be deleted when the adapter is updated.", "de": "Please be aware that backups will be deleted when the adapter is updated.", "ru": "Please be aware that backups will be deleted when the adapter is updated.", "pt": "Please be aware that backups will be deleted when the adapter is updated.", "nl": "Please be aware that backups will be deleted when the adapter is updated.", "fr": "Please be aware that backups will be deleted when the adapter is updated.", "es": "Please be aware that backups will be deleted when the adapter is updated.", "pl": "Please be aware that backups will be deleted when the adapter is updated.", "it": "Please be aware that backups will be deleted when the adapter is updated.", "zh-cn": "Please be aware that backups will be deleted when the adapter is updated."},
                       "Devices": {"en": "Devices", "de": "Devices", "ru": "Devices", "pt": "Devices", "nl": "Devices", "fr": "Devices", "es": "Devices", "pl": "Devices", "it": "Devices", "zh-cn": "Devices"},
                       "Layout": {"en": "Layout", "de": "Layout", "ru": "Layout", "pt": "Layout", "nl": "Layout", "fr": "Layout", "es": "Layout", "pl": "Layout", "it": "Layout", "zh-cn": "Layout"},
                       "Widgets": {"en": "Widgets", "de": "Widgets", "ru": "Widgets", "pt": "Widgets", "nl": "Widgets", "fr": "Widgets", "es": "Widgets", "pl": "Widgets", "it": "Widgets", "zh-cn": "Widgets"},
                       "Settings": {"en": "Settings", "de": "Settings", "ru": "Settings", "pt": "Settings", "nl": "Settings", "fr": "Settings", "es": "Settings", "pl": "Settings", "it": "Settings", "zh-cn": "Settings"},
                       "Styles": {"en": "Styles", "de": "Styles", "ru": "Styles", "pt": "Styles", "nl": "Styles", "fr": "Styles", "es": "Styles", "pl": "Styles", "it": "Styles", "zh-cn": "Styles"},
                       "Scripts": {"en": "Scripts", "de": "Scripts", "ru": "Scripts", "pt": "Scripts", "nl": "Scripts", "fr": "Scripts", "es": "Scripts", "pl": "Scripts", "it": "Scripts", "zh-cn": "Scripts"},
                       Get backups for "devices"...
                       Get backups for "layout"...
                       Get backups for "widgets"...
                       Get backups for "settings"...
                       Get backups for "styles"...
                       Get backups for "scripts"...
                       Got backups for "devices".
                       Got backups for "layout".
                       Got backups for "widgets".
                       Got backups for "settings".
                       Got backups for "styles".
                       Got backups for "scripts".
                       Message broker queried succesfully.
                      3 jarvis Load setting "authentication" (radio) with value: none [object Object]
                       jarvis Load setting "authenticationGroup" (select) with value: system.group.user,system.group.administrator [object Object]
                      3 jarvis Load setting "authenticationConfiguration" (radio) with value: none [object Object]
                       jarvis Load setting "authenticationConfigurationGroup" (select) with value: system.group.user,system.group.administrator [object Object]
                       jarvis Load setting "certPublic" (select) with value:  [object Object]
                       jarvis Load setting "certPrivate" (select) with value:  [object Object]
                       jarvis Load setting "certChained" (select) with value:  [object Object]
                       jarvis Load setting "socketPort" (number) with value: 8400 [object Object]
                       jarvis Load setting "socketSecure" (checkbox) with value: false [object Object]
                       jarvis Load setting "authenticationPassword" (password) with value:  [object Object]
                       jarvis Load setting "authenticationConfigurationPassword" (password) with value:  [object Object]
                      Instances.tsx:1090 Width: xl
                       [2024-09-24T04:20:33.693Z] Try to connect
                       [2024-09-24T04:20:34.972Z] Try to connect
                      Wiederholen sich immer die selben Einträge. Wenn ich die Konfigseite so laufen lasse, hört das Laden dann irgendwann auf und die Werte stehen drinn.
                        Meikie
                        #363
                        ich habe jetzt die Version v3.2.0-rc.5 installiert in Kombination mit dem neuen Admin-Panel 7.1.3.
                        Leider funktioniert seit dem update mein iobroker sehr störrisch. Ich habe unter Übersicht jetzt 2 Jarvis. Einmal mit dem Port 8400, welche auch Funktioniert und einmal mit Port: undefined, welche nicht funktioniert.
                        Wie bekomme ich die alte Version weg?
                        Vielen Dank für die Hilfe.
                        Meike
                        • M Meikie
                          Meike
                          MCU
                          #364
                          @Homoran @Thomas-Braun Weiß jemand, wie man solch alte Einträge (Übersicht Anzeige Jarvis mit altem Port 8082, der aber nicht genutzt wird-> undefined) weg bekommt?
                          Upload?
                          Wo werden die Einträge gespeichert?
                          Muss man evtl. jarvis komplett entfernen, damit auch alle Einträge einmal gelöscht werden.
                          • M MCU
                            Upload?
                            #365
                            @mcu
                            Da ich keine GUI hier laufen habe kann ich dazu nichts erhellendes beitragen.
                            Zwei Instanzen am Start?
                            iob diag
                            wäre mal wieder hilfreich.
                            • M Meikie
                              Meike
                              MCU
                              #366
                              @meikie
                              Warum? Wegen der Übersicht?
                              Jarvis ist noch beta!, da sind noch einige offene Punkte.
                              VORHER bitte ein Bild mit dem undefined, möchte es mit in die Doku nehmen. Danke.
                              Man kann in der Übersicht den fehlerhaften Eintrag entfernen.
                              rechts unten klicken und dann das Element anklicken, welches entfernt werden soll. Auf den blauen Haken klicken.
                              -> Element hat einen grauen Haken
                              dann unten rechts auf den grünen Haken klicken und es wird gespeichert.
                              • M MCU
                                @meikie
                                Meikie
                                schrieb am zuletzt editiert von Meikie
                                #367
                                @mcu Vielen Dank.
                                Aber es ist ja nicht wirklich gelöscht, sondern nur ausgeblendet. Kann man das nicht irgendwo entfernen. Es muss ja noch irgendwo ein Verweis zur alten Version sein.
                                • M Meikie
                                  @mcu Vielen Dank.
                                  MCU
                                  #368
                                  @meikie Weiß ich leider nicht. Müsste man beim iobroker.admin mal ein Issue setzen.
                                  Danke für das Bild, hab in die Doku mit aufgenommen.
                                  hotspot_2H 1 Antwort Letzte Antwort
                                  • M MCU
                                    hotspot_2H Offline
                                    hotspot_2H Offline
                                    hotspot_2
                                    #369
                                    Hallo, weiß jemand wie ich in jarvis einen Wert von Watt Stunden in kilowatt Stunden umrechen kann? Mit einer Nachkommastelle? Geht das oder muss ich da ein Blockly oder sowas machen?
                                    also 36500 Wh in 36,5 kWh wäre die Umrechnung z.B.
                                    • hotspot_2H hotspot_2
                                      MCU
                                      #370
                                      @hotspot_2
                                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/datenpunkt-eigenschaft/berechnungen-mit-val#division
                                        MiWolf
                                        #371
                                        Hi zusammen,
                                        vielleicht könnt ihr mir helfen, ich habe heute Jarvis auf v3.2.0-rc.5 aktualisiert, das hat soweit auch alles funktioniert. Anfangs läuft auch alles schick, nach einiger Zeit (wenn der Tab sich schlafen legt?) kommt es zu folgender Fehlermeldung und Jarvis wird frecherweise deaktiviert..:
                                        jarvis.0 2024-09-30 17:23:17.856	info	terminating
                                        jarvis.0 2024-09-30 17:23:17.354	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        jarvis.0 2024-09-30 17:23:17.353	info	terminating
                                        jarvis.0 2024-09-30 17:23:17.352	info	Adapter stopped und unloaded.
                                        jarvis.0 2024-09-30 17:23:17.351	error	unhandled promise rejection: null
                                        jarvis.0 2024-09-30 17:23:17.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        jarvis.0 2024-09-30 17:18:41.414	warn	Failed moving user scripts due to "ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.jarvis/../../iobroker-data/files/0_userdata.0/jarvis-scripts'"!
                                        jarvis.0 2024-09-30 17:18:36.098	info	Connection: WebSocket opened on port 8400 using http...
                                        jarvis.0 2024-09-30 17:18:35.933	info	starting. Version 3.2.0-rc.5 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.17.0, js-controller: 6.0.11
                                        Unter Dateien / Benutzerdaten hat Jarvis den entsprechenden Ordner angelegt...
                                        Beste Grüße
                                        Mirko
                                        • M MiWolf
                                          Hi zusammen,
                                          Beste Grüße
                                          Mirko
                                          MCU
                                          #372
                                          @miwolf Der Ordner ist angelegt. Wenn du jetzt jarvis wieder startest, passiert was?
