  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 499.1k Aufrufe 137 Beobachtet
  • L Offline
    lysy23
    #141
    irgendwie will nicht der Adapter bei mir funktionieren. Anmeldung und Passwort soll wie bei der Roborock-App sein?
    • L lysy23
      David G.D Online
      David G.D Online
      David G.
      #142
      @lysy23
      Jepp
      • L Offline
        lysy23
        #143
        Kann jemand helfen ?
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: node:internal/modules/cjs/loader:1189
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: ^
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: Error: \\?\C:\yyyyyyyyyyy\xxxxxxxxxx\zzzzzzzzzz\node_modules\canvas\build\Release\canvas.node ist keine zulässige Win32-Anwendung.
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: \\?\C:\yyyyyyyyyyy\xxxxxxxxxx\zzzzzzzzzz\node_modules\canvas\build\Release\canvas.node
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1189:18)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Object. (C:\yyyyyyyyyyy\xxxxxxxxxx\zzzzzzzzzz\node_modules\canvas\lib\bindings.js:3:18)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
        2023-09-09 23:08:52.879 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        2023-09-09 23:08:52.880 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
        2023-09-09 23:08:52.880 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
        2023-09-09 23:08:52.880 - error: host.xx(zzzzzzzzzz) Caught by controller[0]: }
        2023-09-09 23:08:52.880 - error: host.xx(zzzzzzzzzz) instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        copystringC 1 Antwort Letzte Antwort
        • L lysy23
          copystringC Offline
          copystringC Offline
          copystring
          #144
          @lysy23 Bei Fehlern ein Issue auf GitHub mit DEBUG-Log als .txt-Datei hochladen. Dann gucke ich mir das an.
          Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
          https://paypal.me/copystring
          • copystringC Offline
            copystringC Offline
            copystring
            #145
            Tach zusammen. Anstatt raus in die Sonne zu gehen, gammele ich vorm Rechner. :D
            In der neuen dev ist ein Check eingebaut, der prüft, ob ein Roboter offline ist und sendet dann entsprechend keine Anfragen mehr bis dieser wieder online kommt.
            Dadurch wird ein seltenes Problem behoben, welches sich hervorrufen ließ, in dem der Roboter beim Reinigen in einen Fehler läuft und dann einfach stehen gelassen wird. Dadurch schaltet sich der Roboter irgendwann ab, da er ja nicht in der Station steht und um Energie zu sparen.
            Wenn das passiert, wurden vom Adapter trotzdem fleißig weiter Anfragen an den Roboter gesendet, welche logischerweise nie beantwortet wurde. Dadurch gab es dann Timeouts im Log wie am Fließband. Dies sollte hier behoben sein.
            Lief bei mir ganz gut. Wichtig wäre jedoch zu prüfen, ob die Anfragen zuverlässig fortgesetzt werden, sobald der Roboter wieder online kommt.
            Wer mag, kann es testen: https://github.com/copystring/ioBroker.roborock/tree/dev
              tritanium
              #146
              Hallo die Damen :-D
              habe gerade von 0.2.1 auf 0.3.2 geupdatet, da ich ersoffen bin in "warnings" Logs ...
              Dummerweise, kommen die immernoch auf nach dem Update :-(
              Jemand Ideen ?
              Wie kann ich helfen ?
              lg Micha
                copystringC Offline
                copystring
                #147
                Ist der Saugroboter offline oder wird im Adapter als offline angezeigt?
                  tritanium
                  #148
                  Habe gerade geguckt :-)
                  Da steht "online" ....
                  In der App auch .... er steht gechillt im Dock und "döst" so rum ...
                  • T tritanium
                    copystringC Offline
                    copystringC Offline
                    copystring
                    #149
                    @tritanium Welche Version war vorher installiert?
                    • copystringC copystring
                      tritanium
                      #150
                      @copystring
                      Vorher war 0.2.1 aktiv....
                      • T tritanium
                        @copystring
                        copystringC Offline
                        copystringC Offline
                        copystring
                        #151
                        @tritanium stimmt. Hast du ja oben bereits geschrieben. Das Problem mit Timeouts ist, dass die viele Gründe haben können. Es bedeutet eben, dass entweder der Roboter nicht antwortet oder eine schlechte Internetanbindung vorliegt. Möglicherweise schlechtes WLAN. Ich bekomme ständig solche Meldungen von verschiedenen Nutzern. Das Problem liegt aber nicht am Adapter. Der Adapter fängt die Meldungen nur ab, damit dieser nicht komplett abstürzt.
                          tritanium
                          #152
                          @copystring
                          Hmm, okay, irgendwelche Ideen , wie wir vorgehen, bzw. ich dich bei der Analyse unterstützen kann ?
                          Das WLAN würde ich ausschliessen, da sämtliche anderen Geräte (die WLAN nutzen) keine Probleme machen.
                          Selbst F.R.I.D.A.Y (so heisst der Robi), lässt sich via IObroker (bzw. dem Adapter) oder auch der App ganz normal starten/triggern.
                          Ich bin etwas ratlos, das Logging einfach ganz abschalten kann ja auch nicht die Lösung sein, oder ?
                          gruß Micha
                          • T tritanium
                            @copystring
                            gruß Micha
                            copystringC Offline
                            copystringC Offline
                            copystring
                            #153
                            @tritanium Schwer von hier zu beurteilen. Ich würde es aber auch nicht an die große Glocke hängen.
                            Ich könnte mir aber trotzdem gerne von dir ein debug log angucken. Aber ich befürchte, dass ich nicht viel helfen kann.
                            Vielleicht stelle ich auch die Timeouts für die Karte auf warning anstatt error. Dann würde es ausreichen, das Logging vom Adapter auf error umzustellen.
                              tritanium
                              #154
                              @copystring
                              Also ein neustart vom Robi hat nix gebracht!
                              Ich kann ihn prima mit der App durch die Gegend schicken, ohne das Probleme auftauchen.
                              EIn Neustart des Adapters bringt dann komische Meldungen zwischendurch:
                              Vielleicht hilft dir das ?
                              Oder ich mache dir ein Debug, musst mir nur kurz schreiben wie... :-)
                              • T tritanium
                                @copystring
                                copystringC Offline
                                copystringC Offline
                                copystring
                                #155
                                Tu mir bitte einen gefallen und eröffne aber dann ein Issue auf GitHub, damit ich das sauber verfolgen kann.
                                https://github.com/copystring/ioBroker.roborock/issues
                                  tritanium
                                  schrieb am zuletzt editiert von tritanium
                                  #156
                                  @copystring
                                  So :-)
                                  Issue ist auf, mit allem was du hoffenltich benötigst.
                                  https://github.com/copystring/ioBroker.roborock/issues/371
                                  Falls was fehlt, einfach schreiben...
                                  R 1 Antwort Letzte Antwort
                                  • T tritanium
                                    @copystring
                                    So :-)
                                    RMortan
                                    #157
                                    Hallo folgendes Problen
                                    Sobald ich bei mir die Karte aktiv stelle im Adapter verliert dieser die Verbindung zum Host und das Lebenszeichen immer wieder.... Und die Karten lässt sich leider auch nicht öffnen.
                                    Verwendet wie ein roborock q revo und die adapter Version ist die V0.3.1
                                    Fehler im LOG:
                                    Ich weiß ist ein Bild vom Log aber ging grad nicht anders... 🙈
                                    Thomas BraunT copystringC 2 Antworten Letzte Antwort
                                    • R RMortan
                                      Fehler im LOG:
                                      #158
                                      @rmortan sagte in Neuer Adapter für Roborock-Staubsauger:
                                      Dann mach es später gescheit...
                                      • R RMortan
                                        Fehler im LOG:
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #159
                                        @rmortan es ist nicht möglich die Karte auf Raspberry Pi zu verwenden.
                                        R T 2 Antworten Letzte Antwort
                                          RMortan
                                          #160
                                          @copystring sagte in Neuer Adapter für Roborock-Staubsauger:
                                          Danke für die Information gibt's irgendwo einen Hardware Hinweis.. Welche da als mindestens voraus gesetzt wird das dies geht???
