  4. Fehler beim Update des Telegram-Adapters
    5.3k
23 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
    dexic
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3B
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte 16GB
    Betriebssystem: Raspbian
    Node-Version: 10.x.x
    Nodejs-Version: 18.16.0
    NPM-Version: 9.5.1; Anzeige in der Übersicht (HTTP-Seite): --
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: ----
    Problem beim Update des Telegram-Adapters. Danach bleibt der Telegram-Adapter zunächst offline, bis ich ihn manuell wieder einschalte.
    host.raspberrypi
    	2023-07-05 13:51:12.689	info	iobroker exit 25
    host.raspberrypi
    	2023-07-05 13:51:11.642	error	iobroker host.raspberrypi Cannot install iobroker.telegram@1.15.6: 217
    host.raspberrypi
    	2023-07-05 13:51:11.595	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-07-05T11_50_37_495Z-debug-0.log
    host.raspberrypi
    	2023-07-05 13:51:11.588	info	iobroker
    host.raspberrypi
    	2023-07-05 13:51:11.586	info	iobroker npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/canvas' -> '/opt/iobroker/node_modules/.canvas-0HrdFhcM'
    host.raspberrypi
    	2023-07-05 13:51:11.574	info	iobroker npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/canvasnpm ERR! dest /opt/iobroker/node_modules/.canvas-0HrdFhcMnpm ERR! errno -39
    host.raspberrypi
    	2023-07-05 13:51:11.571	info	iobroker npm ERR! code ENOTEMPTY
    host.raspberrypi
    	2023-07-05 13:50:34.533	info	iobroker Installing iobroker.telegram@1.15.6... (System call)
    host.raspberrypi
    	2023-07-05 13:50:34.529	info	iobroker NPM version: 9.5.1
    host.raspberrypi
    	2023-07-05 13:50:32.622	info	instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-07-05 13:50:32.524	info	stopInstance system.adapter.telegram.0 killing pid 3373
    host.raspberrypi
    	2023-07-05 13:50:31.517	info	stopInstance system.adapter.telegram.0 send kill signal
    host.raspberrypi
    	2023-07-05 13:50:31.462	info	stopInstance system.adapter.telegram.0 (force=false, process=true)
    host.raspberrypi
    	2023-07-05 13:50:31.453	info	"system.adapter.telegram.0" disabled
    host.raspberrypi
    	2023-07-05 13:50:31.423	info	iobroker host.raspberrypi Adapter "system.adapter.telegram.0" is stopped.
    host.raspberrypi
    	2023-07-05 13:50:31.387	info	iobroker Update telegram from @1.15.2 to @1.15.6
    host.raspberrypi
    	2023-07-05 13:50:16.467	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-07-05 13:50:00.865	info	iobroker upgrade telegram@1.15.6 --debug
    • D dexic
      Image genutzt: Nein
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      @dexic sagte in Fehler beim Update des Telegram-Adapters:
      Lösch das Verzeichnis via iob fix
      iob stop
      iob fix
      iob start
      Ist dein nodejs richtig installiert? Schau dir
      iob diag
      an.
        iob stop
        iob fix
        iob start
        iob diag
        an.
        dexic
        @thomas-braun said in Fehler beim Update des Telegram-Adapters:
        iob stop und fix liefen ohne Fehlermeldung durch. Bei
        iob diag
        kam der unten stehende Fehler.
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
        npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
        Adapters from github:   0
        und dazu die verlinkte Datei:
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@9.5.1
        2 info using node@v18.16.0
        3 timing npm:load:whichnode Completed in 5ms
        4 timing config:load:defaults Completed in 10ms
        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 10ms
        6 timing config:load:builtin Completed in 11ms
        7 timing config:load:cli Completed in 9ms
        8 timing config:load:env Completed in 1ms
        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 8ms
        10 timing config:load:project Completed in 12ms
        11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
        12 timing config:load:user Completed in 2ms
        13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
        14 timing config:load:global Completed in 1ms
        15 timing config:load:setEnvs Completed in 5ms
        16 timing config:load Completed in 55ms
        17 timing npm:load:configload Completed in 55ms
        18 timing npm:load:mkdirpcache Completed in 1ms
        19 timing npm:load:mkdirplogs Completed in 0ms
        20 verbose title npm ls
        21 verbose argv "ls"
        22 timing npm:load:setTitle Completed in 6ms
        23 timing config:load:flatten Completed in 16ms
        24 timing npm:load:display Completed in 20ms
        25 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-
        26 verbose logfile /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
        27 timing npm:load:logFile Completed in 26ms
        28 timing npm:load:timers Completed in 1ms
        29 timing npm:load:configScope Completed in 0ms
        30 timing npm:load Completed in 118ms
        31 timing arborist:ctor Completed in 5ms
        32 silly logfile done cleaning log files
        33 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
        34 timing command:ls Completed in 8569ms
        35 verbose stack Error: invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
        35 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:203:9)
        35 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:134:5)
        36 verbose cwd /opt/iobroker
        37 verbose Linux 6.1.21-v7+
        38 verbose node v18.16.0
        39 verbose npm  v9.5.1
        40 error code ELSPROBLEMS
        41 error invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
        42 verbose exit 1
        43 timing npm Completed in 8782ms
        44 verbose code 1
        45 error A complete log of this run can be found in:
        45 error     /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
        • D dexic
          iob diag
          42 verbose exit 1
          44 verbose code 1
          @dexic
          Und was kam sonst noch so um's Eck bei iob diag?
            @dexic
            dexic
                                 v.2023-04-16
            Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
            Kernel:                 6.1.21-v7+
            Installation:           Native
            Timezone:               Europe/Berlin (CEST, +0200)
            User-ID:                1000
            X-Server:               true
            Pending OS-Updates:     49
            Pending iob updates:    6
            Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                    /usr/bin/node           v18.16.0
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:            921M        538M         41M        0.0K        341M        325M
            Swap:            99M         99M        0.0K
            Total:          1.0G        638M         41M
            Active iob-Instances:   12
            Active repo(s): stable
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                2992
            States:                 2305
            Size of iob-Database:
            5.2M    /opt/iobroker/iobroker-data/objects.jsonl
            1.6M    /opt/iobroker/iobroker-data/states.jsonl
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 3 Model B Rev 1.2
            Architecture    : armv7l
            Docker          : false
            Virtualization  : none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             14:33:34 up  1:18,  3 users,  load average: 2.20, 2.06, 2.10
            CPU threads: 4
            Raspberry only:
            throttled=0x20000
            Other values than 0x0 hint to temperature/voltage problems
            temp=70.9'C
            volt=1.3438V
            *** Time and Time Zones ***
                           Local time: Wed 2023-07-05 14:33:35 CEST
                       Universal time: Wed 2023-07-05 12:33:35 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            921M        507M         71M        0.0K        343M        354M
            Swap:            99M         86M         13M
            Total:          1.0G        594M         84M
                      921 M total memory
                      507 M used memory
                      200 M active memory
                      558 M inactive memory
                       71 M free memory
                       80 M buffer memory
                      263 M swap cache
                       99 M total swap
                       86 M used swap
                       13 M free swap
            Raspberry only:
            oom events: 0
            lifetime oom required: 0 Mbytes
            total time in oom handler: 0 ms
            max time spent in oom handler: 0 ms
            *** FILESYSTEM ***
            /dev/root      ext4       15G   13G  1.7G  89% /
            devtmpfs       devtmpfs  333M     0  333M   0% /dev
            tmpfs          tmpfs     461M   60K  461M   1% /dev/shm
            tmpfs          tmpfs     185M  1.1M  184M   1% /run
            /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
            tmpfs          tmpfs      93M   24K   93M   1% /run/user/1000
            [Wed Jul  5 13:15:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Wed Jul  5 13:15:21 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Wed Jul  5 13:15:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Wed Jul  5 13:15:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems (real ones only):
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            5.8G    /var/
            4.3G    /var/log
            1.5G    /var/log/journal/8c8460ee931b4d829197d3853f2f4cea
            1.3G    /var/cache/apt/archives
            Archived and active journals take up 1.4G in the file system.
            /opt/iobroker/backups:
            496M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            801M    /opt/iobroker/iobroker-data/
            562M    /opt/iobroker/iobroker-data/history
            203M    /opt/iobroker/iobroker-data/files
            56M     /opt/iobroker/iobroker-data/files/telegram.admin
            51M     /opt/iobroker/iobroker-data/files/javascript.admin
            9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
            8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
            8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
            7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
            6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.16.1-deb-1nodesource1
              Version table:
                 18.16.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
             *** 18.16.0-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            MULTIHOSTSERVICE/enabled: false
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     6.1.4
            npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_36_00_105Z-debug-0.log
            Adapter State
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
              system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled, compact disabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
            + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
            + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact disabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
              system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, compact disabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
              system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 192.168.178.30
              system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled, compact disabled
              system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled, compact disabled
            + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled, compact disabled
            + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
              system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              - disabled, compact disabled
              system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled, compact disabled
            + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
              system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, compact disabled, port: /dev/ttyACM0
              system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled, compact disabled
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "echarts"      : 1.5.1    , installed 1.5.1
            Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
            Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
            Adapter    "onvif"        : 1.0.5    , installed 1.0.4  [Updatable]
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "socketio"     : 4.2.0    , installed 4.2.0
            Adapter    "telegram"     : 1.15.6   , installed 1.15.2 [Updatable]
            Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
            Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "web"          : 4.3.0    , installed 4.3.0
            Adapter    "ws"           : 1.3.0    , installed 1.3.0
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Adapter    "zigbee2mqtt"  : 2.7.5    , installed 2.7.5
            Objects and States
            Objects:        2992
            States:         2305
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Get:4 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5127 B]
            Fetched 5127 B in 7s (708 B/s)
            Reading package lists...
            Pending Updates: 49
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11000      576/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       43366      6724/iobroker.js-co
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       43373      6724/iobroker.js-co
            tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14594      551/anydesk
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11033      538/cupsd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11032      538/cupsd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          11002      576/sshd: /usr/sbin
            tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12160      554/xrdp-sesman
            tcp6       0      0 :::3389                 :::*                    LISTEN      115        14040      585/xrdp
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41668      6895/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44146      6743/io.admin.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40653      6839/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40654      6839/io.tuya.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14009      495/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11058      610/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12100      404/avahi-daemon: r
            udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          14767      551/anydesk
            udp        0      0 0.0.0.0:54737           0.0.0.0:*                           108        12102      404/avahi-daemon: r
            udp6       0      0 :::45565                :::*                                108        12103      404/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          14030      495/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        12101      404/avahi-daemon: r
            2023-07-05 14:36:40.301  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:36:46.278  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:36:52.295  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:36:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:04.292  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:10.289  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:16.271  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:22.589  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:28.321  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:34.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:40.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:46.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:52.290  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:37:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:04.291  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:10.288  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:16.297  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:22.296  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:28.272  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:34.275  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:40.276  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:46.283  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:52.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:38:58.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            2023-07-05 14:39:04.284  - info: smartmeter.0 (6812) Received 5 values, 2 updated
            • D dexic
                                   v.2023-04-16
              Kernel:                 6.1.21-v7+
              User-ID:                1000
              X-Server:               true
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
              MEMORY:
              Swap:            99M         99M        0.0K
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                2992
              States:                 2305
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              Raspberry only:
              throttled=0x20000
              temp=70.9'C
              volt=1.3438V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M         86M         13M
                        921 M total memory
                        507 M used memory
                        200 M active memory
                         71 M free memory
                         80 M buffer memory
                        263 M swap cache
                         99 M total swap
                         86 M used swap
                         13 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              5.8G    /var/
              4.3G    /var/log
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        2992
              States:         2305
              Pending Updates: 49
              @dexic
              Klatsch dir doch den mageren RAM nicht auch noch mit einem Desktop/X-Server zu.
              Schalt den Mumpitz auf einem Server aus.
              temp=70.9'C
              Wäre mir auch zu hoch.
              Pending Updates: 49
              Updates einspielen.
              Und den smartmeter-Adapter würde ich auf ein anderes LogLevel setzen. Der ballert ja alle 6 Sekunden in das Log.
              Installier den echarts nochmal, nachdem die anderen Dinge angegangen wurden.
                @dexic
                temp=70.9'C
                Pending Updates: 49
                Updates einspielen.
                dexic
                • Desktop beim Start in raspi-config ausgeschaltet.
                • Wie kann ich Desktop-Programme von Konsolen-Programmen unterscheiden und womöglich halbautomatisch löschen? In einem Raspberry-Forum habe ich das hier gefunden:
                  sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
                • Die Temperatur ist zu hoch - meinst du, dass das am Desktop liegt? Was kann ich da noch tun?
                • Updates soeben eingespielt. Zuletzt vor etwa 2 Wochen. Ich war verwundert, dass bei Raspbian schon 49 Updates dazu kamen.
                • Neustart
                • smartmeter wird jetzt bei Wertänderungen mit mindestens 30 Sekunden Verzögerung geloggt.
                • Echarts deinstallieren und installieren erledigt
                • D dexic
                  • Neustart
                  @dexic
                  Und
                  iob diag
                  sagt nun?
                  Für das erste reicht es, wenn der Desktop-Krempel nicht geladen wird. BootTarget: multi-user ist das Zauberwort.
                  Sorg für mehr frische, kalte Luft beim Raspberry. Gehäuse zu dicht? Kein Lüfter?
                    @dexic
                    Und
                    iob diag
                    sagt nun?
                    dexic
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                     18:55:44 up  3:19,  1 user,  load average: 3.97, 5.35, 4.23
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x20000
                    temp=72.0'C
                    volt=1.3438V
                                   Local time: Wed 2023-07-05 18:55:45 CEST
                               Universal time: Wed 2023-07-05 16:55:45 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            921M        674M         39M        0.0K        207M        191M
                    Swap:            99M         98M        1.0M
                    Total:          1.0G        773M         40M
                              921 M total memory
                              674 M used memory
                              293 M active memory
                              519 M inactive memory
                               39 M free memory
                               19 M buffer memory
                              188 M swap cache
                               99 M total swap
                               98 M used swap
                                1 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       15G   13G  1.5G  90% /
                    tmpfs          tmpfs     461M   76K  461M   1% /dev/shm
                    tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
                    [Wed Jul  5 15:36:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Wed Jul  5 15:36:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Wed Jul  5 15:36:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Wed Jul  5 15:36:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /var:
                    5.9G    /var/
                    4.3G    /var/log
                    1.4G    /var/cache/apt/archives
                    915M    /opt/iobroker/iobroker-data/
                    314M    /opt/iobroker/iobroker-data/files
                    88M     /opt/iobroker/iobroker-data/files/echarts.admin
                    57M     /opt/iobroker/iobroker-data/files/echarts
                    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
                    17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
                    /usr/bin/nodejs         v18.16.1
                    /usr/bin/node           v18.16.1
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Installed: 18.16.1-deb-1nodesource1
                      Version table:
                     *** 18.16.1-deb-1nodesource1 500
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                    Objects and States
                    Objects:        2989
                    States:         2290
                    Fetched 5127 B in 6s (850 B/s)
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14214      548/anydesk
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13223      539/iobroker.js-con
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       12046      539/iobroker.js-con
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11882      536/cupsd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14518      568/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16421      788/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15001      966/io.web.0
                    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12880      554/xrdp-sesman
                    tcp6       0      0 :::3389                 :::*                    LISTEN      115        11914      574/xrdp
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14520      568/sshd: /usr/sbin
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11881      536/cupsd
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141831     11605/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141832     11605/io.tuya.0
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14194      502/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12914      581/cups-browsed
                    udp        0      0 0.0.0.0:59522           0.0.0.0:*                           108        14101      391/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14099      391/avahi-daemon: r
                    udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          13214      548/anydesk
                    udp6       0      0 :::59326                :::*                                108        14102      391/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          14551      502/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        14100      391/avahi-daemon: r
                    2023-07-05 18:59:36.802  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 18:59:40.504  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 18:59:46.501  - info: smartmeter.0 (855) Received 5 values, 1 updated
                    2023-07-05 18:59:52.500  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 18:59:58.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:17.854  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 12374
                    2023-07-05 19:00:31.614  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:31.658  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:31.660  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:31.662  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:31.667  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:37.509  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:43.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:49.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:00:55.605  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:01.548  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:07.493  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:13.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:19.491  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:27.176  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:32.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:38.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
                    2023-07-05 19:01:39.791  - info: dwd.0 (12374) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
                    2023-07-05 19:01:42.958  - info: dwd.0 (12374) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-07-05 19:01:43.601  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                         v.2023-04-16
                    Kernel:                 6.1.21-v7+
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     0
                    Pending iob updates:    3
                    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                    MEMORY:
                    Mem:            921M        705M         46M        0.0K        169M        160M
                    Swap:            99M         99M          0B
                    Total:          1.0G        805M         46M
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2989
                    States:                 2290
                    6.2M    /opt/iobroker/iobroker-data/objects.jsonl
                    3.3M    /opt/iobroker/iobroker-data/states.jsonl
                    Beim Zauberwort "multi-user" kann ich dir nicht folgen. :-(
                    Das Gehäuse ist ein "Original" im Set vom Raspberry gewesen. Ich habe da keinen Lüfter, das stimmt, jedoch ist da der Keller, ich dachte, es wäre gut genug.
                    DJMarc75D HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                    • D dexic
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=raspbian
                      ID_LIKE=debian
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x20000
                      temp=72.0'C
                      volt=1.3438V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M         98M        1.0M
                                921 M total memory
                                674 M used memory
                                293 M active memory
                                 39 M free memory
                                 19 M buffer memory
                                188 M swap cache
                                 99 M total swap
                                 98 M used swap
                                  1 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      5.9G    /var/
                      4.3G    /var/log
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        2989
                      States:         2290
                      Pending Updates: 0
                                           v.2023-04-16
                      Kernel:                 6.1.21-v7+
                      User-ID:                1000
                      X-Server:               false
                                              /usr/bin/npm            9.5.1
                                              /usr/bin/npx            9.5.1
                      MEMORY:
                      Swap:            99M         99M          0B
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                2989
                      States:                 2290
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      temp=72.0'C
                      wird ja immer glühender
                      und Du hast 15 aktive Instanzen bei einem PRI3 am Start - definitiv zu viel
                      Lehrling seit 1975 !!!
                      • D dexic
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x20000
                        temp=72.0'C
                        volt=1.3438V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M         98M        1.0M
                                  921 M total memory
                                  674 M used memory
                                  293 M active memory
                                   39 M free memory
                                   19 M buffer memory
                                  188 M swap cache
                                   99 M total swap
                                   98 M used swap
                                    1 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        5.9G    /var/
                        4.3G    /var/log
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2989
                        States:         2290
                        Pending Updates: 0
                                             v.2023-04-16
                        Kernel:                 6.1.21-v7+
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.5.1
                                                /usr/bin/npx            9.5.1
                        MEMORY:
                        Swap:            99M         99M          0B
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                2989
                        States:                 2290
                        hast du wenigstens die Kühlkörper montiert und keinen Deckel auf dem Gehäuse?
                        damit ist der arme Pi überladen:
                        weil er kein RAM mehr hat lagert er auf die SD Karte aus
                        Swap: 99M 99M 0B
                        und auch der Notfallschirm ist bereits aufgebraucht.
                        Das geht jetzt in massive Schreibaktionen, was Load und Leistung kostet. Neben zusätzlicher Hitze wird auch noch die SD Karte übermäßig belastet
                        • D dexic
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=raspbian
                          ID_LIKE=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x20000
                          temp=72.0'C
                          volt=1.3438V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M         98M        1.0M
                                    921 M total memory
                                    674 M used memory
                                    293 M active memory
                                     39 M free memory
                                     19 M buffer memory
                                    188 M swap cache
                                     99 M total swap
                                     98 M used swap
                                      1 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          5.9G    /var/
                          4.3G    /var/log
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        2989
                          States:         2290
                          Pending Updates: 0
                                               v.2023-04-16
                          Kernel:                 6.1.21-v7+
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.5.1
                                                  /usr/bin/npx            9.5.1
                          MEMORY:
                          Swap:            99M         99M          0B
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                2989
                          States:                 2290
                          Bist du doch schon. Wenn der Desktop/X-Server ausgeknipst wurde ist das sog. BootTarget 'multi-user'. Siehe auch aktuelle Ausgabe von iob diag.
                          Zieh die drei Adapter noch auf Stand.
                          Soweit passt das dann; das System ist halt immer noch recht ausgelastet.
                          Zum Vergleich mal meine Kiste:
                           19:30:21 up 8 days,  1:14,  4 users,  load average: 0.12, 0.22, 0.26
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=48.2'C
                          volt=0.9560V
                          Active iob-Instances:   22
                          • DJMarc75D DJMarc75
                            temp=72.0'C
                            dexic
                            @djmarc75 said in Fehler beim Update des Telegram-Adapters:
                            temp=72.0'C
                            Ja, leider...
                            Wie komme ich da runter und was bedeutet "Instanz" in dem Zusammenhang? Sind das Anwendungen, die geladen werden?
                            • D dexic
                              temp=72.0'C
                              Ja, leider...
                              @dexic
                              Alles mit + davor ist eine laufende Instanz.
                              Adapter State
                              + instance is alive
                                Swap: 99M 99M 0B
                                dexic
                                @homoran said in Fehler beim Update des Telegram-Adapters:
                                Kein Kühlkörper, den Deckel habe ich soeben heruntergenommen und werde das beobachten.
                                Swap: 99M 99M 0B
                                Der Swap ist vollgelaufen, als ich das Update gestartet habe - von 50 MB auf die 100 MB. Ich nehme an, dass er nicht "gesäubert" wird, um Schreibvorgänge auf der SD-Karte zu minimieren.
                                Was die Temperatur angeht - die USV, auf der der Raspi liegt, hat von unten handwarm "vorgeheizt". Ich habe ihn jetzt "umgepflanzt" und den Deckel abgenommen.
                                • D dexic
                                  Swap: 99M 99M 0B
                                  Doch, der läuft auch wieder leer. Dauert aber und setzt voraus das nicht wieder eine neue Welle reinschwappt. Das ist das normale Verhalten vom Swap.
                                  Updates und Backups brauchen viel Speicher.
                                  Ich würde den Backitup-Adapter vielleicht auch nicht dauerhaft laufen lassen und den nur bei Bedarf manuell anstupsen.
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=48.2'C
                                    volt=0.9560V
                                    dexic
                                    OK, ich habe einfach nur deinen Vorschlag ausgeführt und immer noch kein richtiges Verständnis davon, was du mit "multi-user" sagen wolltest. Eine Internetsuche hat mir keine richtigen Erkenntnisse gebracht...
                                    Bin gerade dabei. Danke.
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=48.2'C
                                    volt=0.9560V
                                    Das sieht ja mal ganz anders aus ...
                                    • D dexic
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=48.2'C
                                      volt=0.9560V
                                      @dexic
                                      (alt) RunLevel = (modern) boot.targets
                                      https://de.wikipedia.org/wiki/Runlevel
                                      multi-user entspricht also dem run level 3
                                      Also System vollständig geladen, außer der Graphischen Oberfläche.
                                        @dexic
                                        dexic
                                        Sieht nach einem Neustart doch gleich viel besser aus. :-)
                                         21:15:59 up 4 min,  1 user,  load average: 1.16, 1.45, 0.71
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=57.5'C
                                        volt=1.3312V
                                        Mem:            921M        498M        144M        1.0M        278M        367M
                                        Swap:            99M          0B         99M
                                        Total:          1.0G        498M        244M
                                        • D dexic
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=57.5'C
                                          volt=1.3312V
                                          Swap:            99M          0B         99M
                                          @dexic
                                          Ja, das sieht gesünder aus.
