  4. Fehler beim Update des Telegram-Adapters
    5.3k
23 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • D dexic
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3B
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte 16GB
    Betriebssystem: Raspbian
    Node-Version: 10.x.x
    Nodejs-Version: 18.16.0
    NPM-Version: 9.5.1; Anzeige in der Übersicht (HTTP-Seite): --
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: ----
    Problem beim Update des Telegram-Adapters. Danach bleibt der Telegram-Adapter zunächst offline, bis ich ihn manuell wieder einschalte.
    host.raspberrypi
    	2023-07-05 13:51:12.689	info	iobroker exit 25
    host.raspberrypi
    	2023-07-05 13:51:11.642	error	iobroker host.raspberrypi Cannot install iobroker.telegram@1.15.6: 217
    host.raspberrypi
    	2023-07-05 13:51:11.595	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-07-05T11_50_37_495Z-debug-0.log
    host.raspberrypi
    	2023-07-05 13:51:11.588	info	iobroker
    host.raspberrypi
    	2023-07-05 13:51:11.586	info	iobroker npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/canvas' -> '/opt/iobroker/node_modules/.canvas-0HrdFhcM'
    host.raspberrypi
    	2023-07-05 13:51:11.574	info	iobroker npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/canvasnpm ERR! dest /opt/iobroker/node_modules/.canvas-0HrdFhcMnpm ERR! errno -39
    host.raspberrypi
    	2023-07-05 13:51:11.571	info	iobroker npm ERR! code ENOTEMPTY
    host.raspberrypi
    	2023-07-05 13:50:34.533	info	iobroker Installing iobroker.telegram@1.15.6... (System call)
    host.raspberrypi
    	2023-07-05 13:50:34.529	info	iobroker NPM version: 9.5.1
    host.raspberrypi
    	2023-07-05 13:50:32.622	info	instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-07-05 13:50:32.524	info	stopInstance system.adapter.telegram.0 killing pid 3373
    host.raspberrypi
    	2023-07-05 13:50:31.517	info	stopInstance system.adapter.telegram.0 send kill signal
    host.raspberrypi
    	2023-07-05 13:50:31.462	info	stopInstance system.adapter.telegram.0 (force=false, process=true)
    host.raspberrypi
    	2023-07-05 13:50:31.453	info	"system.adapter.telegram.0" disabled
    host.raspberrypi
    	2023-07-05 13:50:31.423	info	iobroker host.raspberrypi Adapter "system.adapter.telegram.0" is stopped.
    host.raspberrypi
    	2023-07-05 13:50:31.387	info	iobroker Update telegram from @1.15.2 to @1.15.6
    host.raspberrypi
    	2023-07-05 13:50:16.467	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-07-05 13:50:00.865	info	iobroker upgrade telegram@1.15.6 --debug
    @dexic sagte in Fehler beim Update des Telegram-Adapters:
    Lösch das Verzeichnis via iob fix
    iob stop
    iob fix
    iob start
    Ist dein nodejs richtig installiert? Schau dir
    iob diag
    an.
      iob stop
      iob fix
      iob start
      iob diag
      an.
      dexic
      @thomas-braun said in Fehler beim Update des Telegram-Adapters:
      iob stop und fix liefen ohne Fehlermeldung durch. Bei
      iob diag
      kam der unten stehende Fehler.
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
      npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
      Adapters from github:   0
      und dazu die verlinkte Datei:
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@9.5.1
      2 info using node@v18.16.0
      3 timing npm:load:whichnode Completed in 5ms
      4 timing config:load:defaults Completed in 10ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 10ms
      6 timing config:load:builtin Completed in 11ms
      7 timing config:load:cli Completed in 9ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 8ms
      10 timing config:load:project Completed in 12ms
      11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 2ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 5ms
      16 timing config:load Completed in 55ms
      17 timing npm:load:configload Completed in 55ms
      18 timing npm:load:mkdirpcache Completed in 1ms
      19 timing npm:load:mkdirplogs Completed in 0ms
      20 verbose title npm ls
      21 verbose argv "ls"
      22 timing npm:load:setTitle Completed in 6ms
      23 timing config:load:flatten Completed in 16ms
      24 timing npm:load:display Completed in 20ms
      25 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-
      26 verbose logfile /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
      27 timing npm:load:logFile Completed in 26ms
      28 timing npm:load:timers Completed in 1ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 118ms
      31 timing arborist:ctor Completed in 5ms
      32 silly logfile done cleaning log files
      33 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      34 timing command:ls Completed in 8569ms
      35 verbose stack Error: invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
      35 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:203:9)
      35 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:134:5)
      36 verbose cwd /opt/iobroker
      37 verbose Linux 6.1.21-v7+
      38 verbose node v18.16.0
      39 verbose npm  v9.5.1
      40 error code ELSPROBLEMS
      41 error invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
      42 verbose exit 1
      43 timing npm Completed in 8782ms
      44 verbose code 1
      45 error A complete log of this run can be found in:
      45 error     /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
      • D dexic
        iob diag
        42 verbose exit 1
        44 verbose code 1
        @dexic
        Und was kam sonst noch so um's Eck bei iob diag?
          @dexic
          dexic
                               v.2023-04-16
          Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
          Kernel:                 6.1.21-v7+
          Installation:           Native
          User-ID:                1000
          X-Server:               true
          Pending OS-Updates:     49
          Pending iob updates:    6
          Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                  /usr/bin/node           v18.16.0
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            921M        538M         41M        0.0K        341M        325M
          Swap:            99M         99M        0.0K
          Total:          1.0G        638M         41M
          Active iob-Instances:   12
          Active repo(s): stable
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                2992
          States:                 2305
          Size of iob-Database:
          5.2M    /opt/iobroker/iobroker-data/objects.jsonl
          1.6M    /opt/iobroker/iobroker-data/states.jsonl
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 3 Model B Rev 1.2
          Architecture    : armv7l
          Docker          : false
          Virtualization  : none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           14:33:34 up  1:18,  3 users,  load average: 2.20, 2.06, 2.10
          CPU threads: 4
          Raspberry only:
          throttled=0x20000
          Other values than 0x0 hint to temperature/voltage problems
          temp=70.9'C
          volt=1.3438V
          *** Time and Time Zones ***
                         Local time: Wed 2023-07-05 14:33:35 CEST
                     Universal time: Wed 2023-07-05 12:33:35 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            921M        507M         71M        0.0K        343M        354M
          Swap:            99M         86M         13M
          Total:          1.0G        594M         84M
                    921 M total memory
                    507 M used memory
                    200 M active memory
                    558 M inactive memory
                     71 M free memory
                     80 M buffer memory
                    263 M swap cache
                     99 M total swap
                     86 M used swap
                     13 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       15G   13G  1.7G  89% /
          devtmpfs       devtmpfs  333M     0  333M   0% /dev
          tmpfs          tmpfs     461M   60K  461M   1% /dev/shm
          tmpfs          tmpfs     185M  1.1M  184M   1% /run
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs      93M   24K   93M   1% /run/user/1000
          [Wed Jul  5 13:15:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Jul  5 13:15:21 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Jul  5 13:15:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Wed Jul  5 13:15:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          5.8G    /var/
          4.3G    /var/log
          1.5G    /var/log/journal/8c8460ee931b4d829197d3853f2f4cea
          1.3G    /var/cache/apt/archives
          Archived and active journals take up 1.4G in the file system.
          /opt/iobroker/backups:
          496M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          801M    /opt/iobroker/iobroker-data/
          562M    /opt/iobroker/iobroker-data/history
          203M    /opt/iobroker/iobroker-data/files
          56M     /opt/iobroker/iobroker-data/files/telegram.admin
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
          8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
          8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
          7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
          6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.0-deb-1nodesource1
            Candidate: 18.16.1-deb-1nodesource1
            Version table:
               18.16.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
           *** 18.16.0-deb-1nodesource1 100
               12.22.12~dfsg-1~deb11u4 500
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_36_00_105Z-debug-0.log
          Adapter State
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled, compact disabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact disabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
            system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, compact disabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 192.168.178.30
            system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled, compact disabled
            system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled, compact disabled
          + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled, compact disabled
          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
            system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              - disabled, compact disabled
            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled, compact disabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, compact disabled, port: /dev/ttyACM0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled, compact disabled
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
          Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
          Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
          Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
          Adapter    "onvif"        : 1.0.5    , installed 1.0.4  [Updatable]
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "telegram"     : 1.15.6   , installed 1.15.2 [Updatable]
          Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Adapter    "zigbee2mqtt"  : 2.7.5    , installed 2.7.5
          Objects and States
          Objects:        2992
          States:         2305
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
          Get:4 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5127 B]
          Fetched 5127 B in 7s (708 B/s)
          Reading package lists...
          Pending Updates: 49
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11000      576/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       43366      6724/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       43373      6724/iobroker.js-co
          tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14594      551/anydesk
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11033      538/cupsd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11032      538/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11002      576/sshd: /usr/sbin
          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12160      554/xrdp-sesman
          tcp6       0      0 :::3389                 :::*                    LISTEN      115        14040      585/xrdp
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41668      6895/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44146      6743/io.admin.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40653      6839/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40654      6839/io.tuya.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14009      495/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11058      610/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12100      404/avahi-daemon: r
          udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          14767      551/anydesk
          udp        0      0 0.0.0.0:54737           0.0.0.0:*                           108        12102      404/avahi-daemon: r
          udp6       0      0 :::45565                :::*                                108        12103      404/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14030      495/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        12101      404/avahi-daemon: r
          2023-07-05 14:36:40.301  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:36:46.278  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:36:52.295  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:36:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:04.292  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:10.289  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:16.271  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:22.589  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:28.321  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:34.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:40.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:46.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:52.290  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:37:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:04.291  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:10.288  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:16.297  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:22.296  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:28.272  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:34.275  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:40.276  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:46.283  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:52.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:38:58.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          2023-07-05 14:39:04.284  - info: smartmeter.0 (6812) Received 5 values, 2 updated
          • D dexic
                                 v.2023-04-16
            Kernel:                 6.1.21-v7+
            User-ID:                1000
            X-Server:               true
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            MEMORY:
            Swap:            99M         99M        0.0K
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                2992
            States:                 2305
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x20000
            temp=70.9'C
            volt=1.3438V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M         86M         13M
                      921 M total memory
                      507 M used memory
                      200 M active memory
                       71 M free memory
                       80 M buffer memory
                      263 M swap cache
                       99 M total swap
                       86 M used swap
                       13 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            5.8G    /var/
            4.3G    /var/log
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2992
            States:         2305
            Pending Updates: 49
            @dexic
            Klatsch dir doch den mageren RAM nicht auch noch mit einem Desktop/X-Server zu.
            Schalt den Mumpitz auf einem Server aus.
            temp=70.9'C
            Wäre mir auch zu hoch.
            Pending Updates: 49
            Updates einspielen.
            Und den smartmeter-Adapter würde ich auf ein anderes LogLevel setzen. Der ballert ja alle 6 Sekunden in das Log.
            Installier den echarts nochmal, nachdem die anderen Dinge angegangen wurden.
              @dexic
              temp=70.9'C
              Pending Updates: 49
              Updates einspielen.
              dexic
              • Desktop beim Start in raspi-config ausgeschaltet.
              • Wie kann ich Desktop-Programme von Konsolen-Programmen unterscheiden und womöglich halbautomatisch löschen? In einem Raspberry-Forum habe ich das hier gefunden:
                sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
              • Die Temperatur ist zu hoch - meinst du, dass das am Desktop liegt? Was kann ich da noch tun?
              • Updates soeben eingespielt. Zuletzt vor etwa 2 Wochen. Ich war verwundert, dass bei Raspbian schon 49 Updates dazu kamen.
              • Neustart
              • smartmeter wird jetzt bei Wertänderungen mit mindestens 30 Sekunden Verzögerung geloggt.
              • Echarts deinstallieren und installieren erledigt
              • D dexic
                • Neustart
                @dexic
                Und
                iob diag
                sagt nun?
                Für das erste reicht es, wenn der Desktop-Krempel nicht geladen wird. BootTarget: multi-user ist das Zauberwort.
                Sorg für mehr frische, kalte Luft beim Raspberry. Gehäuse zu dicht? Kein Lüfter?
                  @dexic
                  Und
                  iob diag
                  sagt nun?
                  dexic
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=raspbian
                  ID_LIKE=debian
                   18:55:44 up  3:19,  1 user,  load average: 3.97, 5.35, 4.23
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x20000
                  temp=72.0'C
                  volt=1.3438V
                                 Local time: Wed 2023-07-05 18:55:45 CEST
                             Universal time: Wed 2023-07-05 16:55:45 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            921M        674M         39M        0.0K        207M        191M
                  Swap:            99M         98M        1.0M
                  Total:          1.0G        773M         40M
                            921 M total memory
                            674 M used memory
                            293 M active memory
                            519 M inactive memory
                             39 M free memory
                             19 M buffer memory
                            188 M swap cache
                             99 M total swap
                             98 M used swap
                              1 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       15G   13G  1.5G  90% /
                  tmpfs          tmpfs     461M   76K  461M   1% /dev/shm
                  tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
                  [Wed Jul  5 15:36:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Wed Jul  5 15:36:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Wed Jul  5 15:36:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Wed Jul  5 15:36:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /var:
                  5.9G    /var/
                  4.3G    /var/log
                  1.4G    /var/cache/apt/archives
                  915M    /opt/iobroker/iobroker-data/
                  314M    /opt/iobroker/iobroker-data/files
                  88M     /opt/iobroker/iobroker-data/files/echarts.admin
                  57M     /opt/iobroker/iobroker-data/files/echarts
                  23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                  17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
                  17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
                  /usr/bin/nodejs         v18.16.1
                  /usr/bin/node           v18.16.1
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Installed: 18.16.1-deb-1nodesource1
                    Version table:
                   *** 18.16.1-deb-1nodesource1 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                  Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                  Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                  Objects and States
                  Objects:        2989
                  States:         2290
                  Fetched 5127 B in 6s (850 B/s)
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14214      548/anydesk
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13223      539/iobroker.js-con
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       12046      539/iobroker.js-con
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11882      536/cupsd
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14518      568/sshd: /usr/sbin
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16421      788/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15001      966/io.web.0
                  tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12880      554/xrdp-sesman
                  tcp6       0      0 :::3389                 :::*                    LISTEN      115        11914      574/xrdp
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14520      568/sshd: /usr/sbin
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11881      536/cupsd
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141831     11605/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141832     11605/io.tuya.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14194      502/dhcpcd
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12914      581/cups-browsed
                  udp        0      0 0.0.0.0:59522           0.0.0.0:*                           108        14101      391/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14099      391/avahi-daemon: r
                  udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          13214      548/anydesk
                  udp6       0      0 :::59326                :::*                                108        14102      391/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          14551      502/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        14100      391/avahi-daemon: r
                  2023-07-05 18:59:36.802  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 18:59:40.504  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 18:59:46.501  - info: smartmeter.0 (855) Received 5 values, 1 updated
                  2023-07-05 18:59:52.500  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 18:59:58.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:17.854  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 12374
                  2023-07-05 19:00:31.614  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:31.658  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:31.660  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:31.662  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:31.667  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:37.509  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:43.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:49.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:00:55.605  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:01.548  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:07.493  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:13.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:19.491  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:27.176  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:32.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:38.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
                  2023-07-05 19:01:39.791  - info: dwd.0 (12374) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
                  2023-07-05 19:01:42.958  - info: dwd.0 (12374) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-07-05 19:01:43.601  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                       v.2023-04-16
                  Kernel:                 6.1.21-v7+
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    3
                  Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                  MEMORY:
                  Mem:            921M        705M         46M        0.0K        169M        160M
                  Swap:            99M         99M          0B
                  Total:          1.0G        805M         46M
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                2989
                  States:                 2290
                  6.2M    /opt/iobroker/iobroker-data/objects.jsonl
                  3.3M    /opt/iobroker/iobroker-data/states.jsonl
                  Beim Zauberwort "multi-user" kann ich dir nicht folgen. :-(
                  Das Gehäuse ist ein "Original" im Set vom Raspberry gewesen. Ich habe da keinen Lüfter, das stimmt, jedoch ist da der Keller, ich dachte, es wäre gut genug.
                  DJMarc75D HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                  • D dexic
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x20000
                    temp=72.0'C
                    volt=1.3438V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M         98M        1.0M
                              921 M total memory
                              674 M used memory
                              293 M active memory
                               39 M free memory
                               19 M buffer memory
                              188 M swap cache
                               99 M total swap
                               98 M used swap
                                1 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    5.9G    /var/
                    4.3G    /var/log
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2989
                    States:         2290
                    Pending Updates: 0
                                         v.2023-04-16
                    Kernel:                 6.1.21-v7+
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                    MEMORY:
                    Swap:            99M         99M          0B
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2989
                    States:                 2290
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    temp=72.0'C
                    wird ja immer glühender
                    und Du hast 15 aktive Instanzen bei einem PRI3 am Start - definitiv zu viel
                    Lehrling seit 1975 !!!
                    • D dexic
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=raspbian
                      ID_LIKE=debian
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x20000
                      temp=72.0'C
                      volt=1.3438V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M         98M        1.0M
                                921 M total memory
                                674 M used memory
                                293 M active memory
                                 39 M free memory
                                 19 M buffer memory
                                188 M swap cache
                                 99 M total swap
                                 98 M used swap
                                  1 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      5.9G    /var/
                      4.3G    /var/log
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        2989
                      States:         2290
                      Pending Updates: 0
                                           v.2023-04-16
                      Kernel:                 6.1.21-v7+
                      User-ID:                1000
                      X-Server:               false
                                              /usr/bin/npm            9.5.1
                                              /usr/bin/npx            9.5.1
                      MEMORY:
                      Swap:            99M         99M          0B
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                2989
                      States:                 2290
                      hast du wenigstens die Kühlkörper montiert und keinen Deckel auf dem Gehäuse?
                      damit ist der arme Pi überladen:
                      weil er kein RAM mehr hat lagert er auf die SD Karte aus
                      Swap: 99M 99M 0B
                      und auch der Notfallschirm ist bereits aufgebraucht.
                      Das geht jetzt in massive Schreibaktionen, was Load und Leistung kostet. Neben zusätzlicher Hitze wird auch noch die SD Karte übermäßig belastet
                      • D dexic
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x20000
                        temp=72.0'C
                        volt=1.3438V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M         98M        1.0M
                                  921 M total memory
                                  674 M used memory
                                  293 M active memory
                                   39 M free memory
                                   19 M buffer memory
                                  188 M swap cache
                                   99 M total swap
                                   98 M used swap
                                    1 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        5.9G    /var/
                        4.3G    /var/log
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2989
                        States:         2290
                        Pending Updates: 0
                                             v.2023-04-16
                        Kernel:                 6.1.21-v7+
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.5.1
                                                /usr/bin/npx            9.5.1
                        MEMORY:
                        Swap:            99M         99M          0B
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                2989
                        States:                 2290
                        Bist du doch schon. Wenn der Desktop/X-Server ausgeknipst wurde ist das sog. BootTarget 'multi-user'. Siehe auch aktuelle Ausgabe von iob diag.
                        Zieh die drei Adapter noch auf Stand.
                        Soweit passt das dann; das System ist halt immer noch recht ausgelastet.
                        Zum Vergleich mal meine Kiste:
                         19:30:21 up 8 days,  1:14,  4 users,  load average: 0.12, 0.22, 0.26
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=48.2'C
                        volt=0.9560V
                        Active iob-Instances:   22
                        • DJMarc75D DJMarc75
                          temp=72.0'C
                          dexic
                          @djmarc75 said in Fehler beim Update des Telegram-Adapters:
                          temp=72.0'C
                          Ja, leider...
                          Wie komme ich da runter und was bedeutet "Instanz" in dem Zusammenhang? Sind das Anwendungen, die geladen werden?
                          • D dexic
                            temp=72.0'C
                            Ja, leider...
                            @dexic
                            Alles mit + davor ist eine laufende Instanz.
                            Adapter State
                            + instance is alive
                              Swap: 99M 99M 0B
                              dexic
                              @homoran said in Fehler beim Update des Telegram-Adapters:
                              Kein Kühlkörper, den Deckel habe ich soeben heruntergenommen und werde das beobachten.
                              Swap: 99M 99M 0B
                              Der Swap ist vollgelaufen, als ich das Update gestartet habe - von 50 MB auf die 100 MB. Ich nehme an, dass er nicht "gesäubert" wird, um Schreibvorgänge auf der SD-Karte zu minimieren.
                              Was die Temperatur angeht - die USV, auf der der Raspi liegt, hat von unten handwarm "vorgeheizt". Ich habe ihn jetzt "umgepflanzt" und den Deckel abgenommen.
                              • D dexic
                                Swap: 99M 99M 0B
                                Doch, der läuft auch wieder leer. Dauert aber und setzt voraus das nicht wieder eine neue Welle reinschwappt. Das ist das normale Verhalten vom Swap.
                                Updates und Backups brauchen viel Speicher.
                                Ich würde den Backitup-Adapter vielleicht auch nicht dauerhaft laufen lassen und den nur bei Bedarf manuell anstupsen.
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=48.2'C
                                  volt=0.9560V
                                  dexic
                                  OK, ich habe einfach nur deinen Vorschlag ausgeführt und immer noch kein richtiges Verständnis davon, was du mit "multi-user" sagen wolltest. Eine Internetsuche hat mir keine richtigen Erkenntnisse gebracht...
                                  Bin gerade dabei. Danke.
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=48.2'C
                                  volt=0.9560V
                                  Das sieht ja mal ganz anders aus ...
                                  • D dexic
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=48.2'C
                                    volt=0.9560V
                                    @dexic
                                    (alt) RunLevel = (modern) boot.targets
                                    https://de.wikipedia.org/wiki/Runlevel
                                    multi-user entspricht also dem run level 3
                                    Also System vollständig geladen, außer der Graphischen Oberfläche.
                                      @dexic
                                      dexic
                                      Sieht nach einem Neustart doch gleich viel besser aus. :-)
                                       21:15:59 up 4 min,  1 user,  load average: 1.16, 1.45, 0.71
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=57.5'C
                                      volt=1.3312V
                                      Mem:            921M        498M        144M        1.0M        278M        367M
                                      Swap:            99M          0B         99M
                                      Total:          1.0G        498M        244M
                                      • D dexic
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=57.5'C
                                        volt=1.3312V
                                        Swap:            99M          0B         99M
                                        @dexic
                                        Ja, das sieht gesünder aus.
                                          @dexic
                                          dexic
                                          Vielen lieben Dank für die heutige Unterstützung! :-) Ich habe einiges gelernt. :-)
