  4. Fehler beim Update des Telegram-Adapters
    5.3k
23 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • D dexic
    @thomas-braun said in Fehler beim Update des Telegram-Adapters:
    Ist dein nodejs richtig installiert?
    iob stop und fix liefen ohne Fehlermeldung durch. Bei
    iob diag
    kam der unten stehende Fehler.
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
    npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
    Adapters from github:   0
    und dazu die verlinkte Datei:
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@9.5.1
    2 info using node@v18.16.0
    3 timing npm:load:whichnode Completed in 5ms
    4 timing config:load:defaults Completed in 10ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 10ms
    6 timing config:load:builtin Completed in 11ms
    7 timing config:load:cli Completed in 9ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 8ms
    10 timing config:load:project Completed in 12ms
    11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 2ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 5ms
    16 timing config:load Completed in 55ms
    17 timing npm:load:configload Completed in 55ms
    18 timing npm:load:mkdirpcache Completed in 1ms
    19 timing npm:load:mkdirplogs Completed in 0ms
    20 verbose title npm ls
    21 verbose argv "ls"
    22 timing npm:load:setTitle Completed in 6ms
    23 timing config:load:flatten Completed in 16ms
    24 timing npm:load:display Completed in 20ms
    25 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-
    26 verbose logfile /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
    27 timing npm:load:logFile Completed in 26ms
    28 timing npm:load:timers Completed in 1ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 118ms
    31 timing arborist:ctor Completed in 5ms
    32 silly logfile done cleaning log files
    33 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    34 timing command:ls Completed in 8569ms
    35 verbose stack Error: invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
    35 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:203:9)
    35 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:134:5)
    36 verbose cwd /opt/iobroker
    37 verbose Linux 6.1.21-v7+
    38 verbose node v18.16.0
    39 verbose npm  v9.5.1
    40 error code ELSPROBLEMS
    41 error invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
    42 verbose exit 1
    43 timing npm Completed in 8782ms
    44 verbose code 1
    45 error A complete log of this run can be found in:
    45 error     /home/pi/.npm/_logs/2023-07-05T12_16_16_434Z-debug-0.log
    @dexic
    Und was kam sonst noch so um's Eck bei iob diag?
      @dexic
      dexic
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v7+
      Installation:           Native
      User-ID:                1000
      X-Server:               true
      Pending OS-Updates:     49
      Pending iob updates:    6
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                              /usr/bin/node           v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            921M        538M         41M        0.0K        341M        325M
      Swap:            99M         99M        0.0K
      Total:          1.0G        638M         41M
      Active iob-Instances:   12
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                2992
      States:                 2305
      Size of iob-Database:
      5.2M    /opt/iobroker/iobroker-data/objects.jsonl
      1.6M    /opt/iobroker/iobroker-data/states.jsonl
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       14:33:34 up  1:18,  3 users,  load average: 2.20, 2.06, 2.10
      CPU threads: 4
      Raspberry only:
      throttled=0x20000
      Other values than 0x0 hint to temperature/voltage problems
      temp=70.9'C
      volt=1.3438V
      *** Time and Time Zones ***
                     Local time: Wed 2023-07-05 14:33:35 CEST
                 Universal time: Wed 2023-07-05 12:33:35 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            921M        507M         71M        0.0K        343M        354M
      Swap:            99M         86M         13M
      Total:          1.0G        594M         84M
                921 M total memory
                507 M used memory
                200 M active memory
                558 M inactive memory
                 71 M free memory
                 80 M buffer memory
                263 M swap cache
                 99 M total swap
                 86 M used swap
                 13 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       15G   13G  1.7G  89% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M   60K  461M   1% /dev/shm
      tmpfs          tmpfs     185M  1.1M  184M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      93M   24K   93M   1% /run/user/1000
      [Wed Jul  5 13:15:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Wed Jul  5 13:15:21 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jul  5 13:15:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Jul  5 13:15:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      5.8G    /var/
      4.3G    /var/log
      1.5G    /var/log/journal/8c8460ee931b4d829197d3853f2f4cea
      1.3G    /var/cache/apt/archives
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      496M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      801M    /opt/iobroker/iobroker-data/
      562M    /opt/iobroker/iobroker-data/history
      203M    /opt/iobroker/iobroker-data/files
      56M     /opt/iobroker/iobroker-data/files/telegram.admin
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
      8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
      8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
      7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
      6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
           18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
       *** 18.16.0-deb-1nodesource1 100
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_36_00_105Z-debug-0.log
      Adapter State
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled, compact disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, compact disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 192.168.178.30
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled, compact disabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled, compact disabled
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled, compact disabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              - disabled, compact disabled
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled, compact disabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, compact disabled, port: /dev/ttyACM0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled, compact disabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
      Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "onvif"        : 1.0.5    , installed 1.0.4  [Updatable]
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "telegram"     : 1.15.6   , installed 1.15.2 [Updatable]
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Adapter    "zigbee2mqtt"  : 2.7.5    , installed 2.7.5
      Objects and States
      Objects:        2992
      States:         2305
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Get:4 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5127 B]
      Fetched 5127 B in 7s (708 B/s)
      Reading package lists...
      Pending Updates: 49
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11000      576/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       43366      6724/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       43373      6724/iobroker.js-co
      tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14594      551/anydesk
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11033      538/cupsd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11032      538/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11002      576/sshd: /usr/sbin
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12160      554/xrdp-sesman
      tcp6       0      0 :::3389                 :::*                    LISTEN      115        14040      585/xrdp
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41668      6895/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44146      6743/io.admin.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40653      6839/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40654      6839/io.tuya.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14009      495/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11058      610/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12100      404/avahi-daemon: r
      udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          14767      551/anydesk
      udp        0      0 0.0.0.0:54737           0.0.0.0:*                           108        12102      404/avahi-daemon: r
      udp6       0      0 :::45565                :::*                                108        12103      404/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14030      495/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12101      404/avahi-daemon: r
      2023-07-05 14:36:40.301  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:36:46.278  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:36:52.295  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:36:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:04.292  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:10.289  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:16.271  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:22.589  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:28.321  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:34.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:40.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:46.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:52.290  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:37:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:04.291  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:10.288  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:16.297  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:22.296  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:28.272  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:34.275  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:40.276  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:46.283  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:52.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:38:58.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      2023-07-05 14:39:04.284  - info: smartmeter.0 (6812) Received 5 values, 2 updated
      • D dexic
                             v.2023-04-16
        Kernel:                 6.1.21-v7+
        User-ID:                1000
        X-Server:               true
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        MEMORY:
        Swap:            99M         99M        0.0K
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                2992
        States:                 2305
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x20000
        temp=70.9'C
        volt=1.3438V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         86M         13M
                  921 M total memory
                  507 M used memory
                  200 M active memory
                   71 M free memory
                   80 M buffer memory
                  263 M swap cache
                   99 M total swap
                   86 M used swap
                   13 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        5.8G    /var/
        4.3G    /var/log
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        2992
        States:         2305
        Pending Updates: 49
        @dexic
        Klatsch dir doch den mageren RAM nicht auch noch mit einem Desktop/X-Server zu.
        Schalt den Mumpitz auf einem Server aus.
        temp=70.9'C
        Wäre mir auch zu hoch.
        Pending Updates: 49
        Updates einspielen.
        Und den smartmeter-Adapter würde ich auf ein anderes LogLevel setzen. Der ballert ja alle 6 Sekunden in das Log.
        Installier den echarts nochmal, nachdem die anderen Dinge angegangen wurden.
          @dexic
          temp=70.9'C
          Pending Updates: 49
          Updates einspielen.
          dexic
          • Desktop beim Start in raspi-config ausgeschaltet.
          • Wie kann ich Desktop-Programme von Konsolen-Programmen unterscheiden und womöglich halbautomatisch löschen? In einem Raspberry-Forum habe ich das hier gefunden:
            sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
          • Die Temperatur ist zu hoch - meinst du, dass das am Desktop liegt? Was kann ich da noch tun?
          • Updates soeben eingespielt. Zuletzt vor etwa 2 Wochen. Ich war verwundert, dass bei Raspbian schon 49 Updates dazu kamen.
          • Neustart
          • smartmeter wird jetzt bei Wertänderungen mit mindestens 30 Sekunden Verzögerung geloggt.
          • Echarts deinstallieren und installieren erledigt
          • D dexic
            • Neustart
            @dexic
            Und
            iob diag
            sagt nun?
            Für das erste reicht es, wenn der Desktop-Krempel nicht geladen wird. BootTarget: multi-user ist das Zauberwort.
            Sorg für mehr frische, kalte Luft beim Raspberry. Gehäuse zu dicht? Kein Lüfter?
              @dexic
              Und
              iob diag
              sagt nun?
              dexic
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
               18:55:44 up  3:19,  1 user,  load average: 3.97, 5.35, 4.23
              CPU threads: 4
              Raspberry only:
              throttled=0x20000
              temp=72.0'C
              volt=1.3438V
                             Local time: Wed 2023-07-05 18:55:45 CEST
                         Universal time: Wed 2023-07-05 16:55:45 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            921M        674M         39M        0.0K        207M        191M
              Swap:            99M         98M        1.0M
              Total:          1.0G        773M         40M
                        921 M total memory
                        674 M used memory
                        293 M active memory
                        519 M inactive memory
                         39 M free memory
                         19 M buffer memory
                        188 M swap cache
                         99 M total swap
                         98 M used swap
                          1 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       15G   13G  1.5G  90% /
              tmpfs          tmpfs     461M   76K  461M   1% /dev/shm
              tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
              [Wed Jul  5 15:36:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Wed Jul  5 15:36:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Wed Jul  5 15:36:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Wed Jul  5 15:36:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              /var:
              5.9G    /var/
              4.3G    /var/log
              1.4G    /var/cache/apt/archives
              915M    /opt/iobroker/iobroker-data/
              314M    /opt/iobroker/iobroker-data/files
              88M     /opt/iobroker/iobroker-data/files/echarts.admin
              57M     /opt/iobroker/iobroker-data/files/echarts
              23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
              23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
              17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
              17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
              /usr/bin/nodejs         v18.16.1
              /usr/bin/node           v18.16.1
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Installed: 18.16.1-deb-1nodesource1
                Version table:
               *** 18.16.1-deb-1nodesource1 500
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Objects and States
              Objects:        2989
              States:         2290
              Fetched 5127 B in 6s (850 B/s)
              Pending Updates: 0
              tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14214      548/anydesk
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13223      539/iobroker.js-con
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       12046      539/iobroker.js-con
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11882      536/cupsd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14518      568/sshd: /usr/sbin
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16421      788/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15001      966/io.web.0
              tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12880      554/xrdp-sesman
              tcp6       0      0 :::3389                 :::*                    LISTEN      115        11914      574/xrdp
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14520      568/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11881      536/cupsd
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141831     11605/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141832     11605/io.tuya.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14194      502/dhcpcd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12914      581/cups-browsed
              udp        0      0 0.0.0.0:59522           0.0.0.0:*                           108        14101      391/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14099      391/avahi-daemon: r
              udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          13214      548/anydesk
              udp6       0      0 :::59326                :::*                                108        14102      391/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          14551      502/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        14100      391/avahi-daemon: r
              2023-07-05 18:59:36.802  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 18:59:40.504  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 18:59:46.501  - info: smartmeter.0 (855) Received 5 values, 1 updated
              2023-07-05 18:59:52.500  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 18:59:58.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:17.854  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 12374
              2023-07-05 19:00:31.614  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:31.658  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:31.660  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:31.662  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:31.667  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:37.509  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:43.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:49.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:00:55.605  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:01.548  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:07.493  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:13.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:19.491  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:27.176  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:32.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:38.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
              2023-07-05 19:01:39.791  - info: dwd.0 (12374) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
              2023-07-05 19:01:42.958  - info: dwd.0 (12374) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-07-05 19:01:43.601  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                   v.2023-04-16
              Kernel:                 6.1.21-v7+
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    3
              Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
              MEMORY:
              Mem:            921M        705M         46M        0.0K        169M        160M
              Swap:            99M         99M          0B
              Total:          1.0G        805M         46M
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                2989
              States:                 2290
              6.2M    /opt/iobroker/iobroker-data/objects.jsonl
              3.3M    /opt/iobroker/iobroker-data/states.jsonl
              Beim Zauberwort "multi-user" kann ich dir nicht folgen. :-(
              Das Gehäuse ist ein "Original" im Set vom Raspberry gewesen. Ich habe da keinen Lüfter, das stimmt, jedoch ist da der Keller, ich dachte, es wäre gut genug.
              DJMarc75D HomoranH Thomas BraunT 3 Antworten Letzte Antwort
              • D dexic
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                Raspberry only:
                throttled=0x20000
                temp=72.0'C
                volt=1.3438V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M         98M        1.0M
                          921 M total memory
                          674 M used memory
                          293 M active memory
                           39 M free memory
                           19 M buffer memory
                          188 M swap cache
                           99 M total swap
                           98 M used swap
                            1 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                5.9G    /var/
                4.3G    /var/log
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2989
                States:         2290
                Pending Updates: 0
                                     v.2023-04-16
                Kernel:                 6.1.21-v7+
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                MEMORY:
                Swap:            99M         99M          0B
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                2989
                States:                 2290
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @dexic sagte in Fehler beim Update des Telegram-Adapters:
                temp=72.0'C
                wird ja immer glühender
                und Du hast 15 aktive Instanzen bei einem PRI3 am Start - definitiv zu viel
                Lehrling seit 1975 !!!
                • D dexic
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=raspbian
                  ID_LIKE=debian
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x20000
                  temp=72.0'C
                  volt=1.3438V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M         98M        1.0M
                            921 M total memory
                            674 M used memory
                            293 M active memory
                             39 M free memory
                             19 M buffer memory
                            188 M swap cache
                             99 M total swap
                             98 M used swap
                              1 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  5.9G    /var/
                  4.3G    /var/log
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        2989
                  States:         2290
                  Pending Updates: 0
                                       v.2023-04-16
                  Kernel:                 6.1.21-v7+
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                  MEMORY:
                  Swap:            99M         99M          0B
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                2989
                  States:                 2290
                  hast du wenigstens die Kühlkörper montiert und keinen Deckel auf dem Gehäuse?
                  damit ist der arme Pi überladen:
                  weil er kein RAM mehr hat lagert er auf die SD Karte aus
                  Swap: 99M 99M 0B
                  und auch der Notfallschirm ist bereits aufgebraucht.
                  Das geht jetzt in massive Schreibaktionen, was Load und Leistung kostet. Neben zusätzlicher Hitze wird auch noch die SD Karte übermäßig belastet
                  • D dexic
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x20000
                    temp=72.0'C
                    volt=1.3438V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M         98M        1.0M
                              921 M total memory
                              674 M used memory
                              293 M active memory
                               39 M free memory
                               19 M buffer memory
                              188 M swap cache
                               99 M total swap
                               98 M used swap
                                1 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    5.9G    /var/
                    4.3G    /var/log
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2989
                    States:         2290
                    Pending Updates: 0
                                         v.2023-04-16
                    Kernel:                 6.1.21-v7+
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                    MEMORY:
                    Swap:            99M         99M          0B
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2989
                    States:                 2290
                    Bist du doch schon. Wenn der Desktop/X-Server ausgeknipst wurde ist das sog. BootTarget 'multi-user'. Siehe auch aktuelle Ausgabe von iob diag.
                    Zieh die drei Adapter noch auf Stand.
                    Soweit passt das dann; das System ist halt immer noch recht ausgelastet.
                    Zum Vergleich mal meine Kiste:
                     19:30:21 up 8 days,  1:14,  4 users,  load average: 0.12, 0.22, 0.26
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=48.2'C
                    volt=0.9560V
                    Active iob-Instances:   22
                    • DJMarc75D DJMarc75
                      temp=72.0'C
                      dexic
                      @djmarc75 said in Fehler beim Update des Telegram-Adapters:
                      temp=72.0'C
                      Ja, leider...
                      Wie komme ich da runter und was bedeutet "Instanz" in dem Zusammenhang? Sind das Anwendungen, die geladen werden?
                      • D dexic
                        temp=72.0'C
                        Ja, leider...
                        @dexic
                        Alles mit + davor ist eine laufende Instanz.
                        Adapter State
                        + instance is alive
                          Swap: 99M 99M 0B
                          dexic
                          @homoran said in Fehler beim Update des Telegram-Adapters:
                          Kein Kühlkörper, den Deckel habe ich soeben heruntergenommen und werde das beobachten.
                          Swap: 99M 99M 0B
                          Der Swap ist vollgelaufen, als ich das Update gestartet habe - von 50 MB auf die 100 MB. Ich nehme an, dass er nicht "gesäubert" wird, um Schreibvorgänge auf der SD-Karte zu minimieren.
                          Was die Temperatur angeht - die USV, auf der der Raspi liegt, hat von unten handwarm "vorgeheizt". Ich habe ihn jetzt "umgepflanzt" und den Deckel abgenommen.
                          • D dexic
                            Swap: 99M 99M 0B
                            Doch, der läuft auch wieder leer. Dauert aber und setzt voraus das nicht wieder eine neue Welle reinschwappt. Das ist das normale Verhalten vom Swap.
                            Updates und Backups brauchen viel Speicher.
                            Ich würde den Backitup-Adapter vielleicht auch nicht dauerhaft laufen lassen und den nur bei Bedarf manuell anstupsen.
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=48.2'C
                              volt=0.9560V
                              dexic
                              OK, ich habe einfach nur deinen Vorschlag ausgeführt und immer noch kein richtiges Verständnis davon, was du mit "multi-user" sagen wolltest. Eine Internetsuche hat mir keine richtigen Erkenntnisse gebracht...
                              Bin gerade dabei. Danke.
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=48.2'C
                              volt=0.9560V
                              Das sieht ja mal ganz anders aus ...
                              • D dexic
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=48.2'C
                                volt=0.9560V
                                @dexic
                                (alt) RunLevel = (modern) boot.targets
                                https://de.wikipedia.org/wiki/Runlevel
                                multi-user entspricht also dem run level 3
                                Also System vollständig geladen, außer der Graphischen Oberfläche.
                                  @dexic
                                  dexic
                                  Sieht nach einem Neustart doch gleich viel besser aus. :-)
                                   21:15:59 up 4 min,  1 user,  load average: 1.16, 1.45, 0.71
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=57.5'C
                                  volt=1.3312V
                                  Mem:            921M        498M        144M        1.0M        278M        367M
                                  Swap:            99M          0B         99M
                                  Total:          1.0G        498M        244M
                                  • D dexic
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=57.5'C
                                    volt=1.3312V
                                    Swap:            99M          0B         99M
                                    @dexic
                                    Ja, das sieht gesünder aus.
                                      @dexic
                                      dexic
                                      Vielen lieben Dank für die heutige Unterstützung! :-) Ich habe einiges gelernt. :-)
                                        dexic
                                        schrieb am zuletzt editiert von dexic
                                        Und noch ein kleiner Nachschlag:
                                        So schlimm schaut es jetzt auch nicht mehr aus. :-)
                                        Vielen Dank nochmals an alle Unterstützer! :-)
                                        • D dexic
                                          der Swap ist aber schon wieder angekratzt
