  4. Fehler beim Update des Telegram-Adapters
    5.4k
23 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • D dexic
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v7+
    Installation:           Native
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     49
    Pending iob updates:    6
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/node           v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            921M        538M         41M        0.0K        341M        325M
    Swap:            99M         99M        0.0K
    Total:          1.0G        638M         41M
    Active iob-Instances:   12
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                2992
    States:                 2305
    Size of iob-Database:
    5.2M    /opt/iobroker/iobroker-data/objects.jsonl
    1.6M    /opt/iobroker/iobroker-data/states.jsonl
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:33:34 up  1:18,  3 users,  load average: 2.20, 2.06, 2.10
    CPU threads: 4
    Raspberry only:
    throttled=0x20000
    Other values than 0x0 hint to temperature/voltage problems
    temp=70.9'C
    volt=1.3438V
    *** Time and Time Zones ***
                   Local time: Wed 2023-07-05 14:33:35 CEST
               Universal time: Wed 2023-07-05 12:33:35 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            921M        507M         71M        0.0K        343M        354M
    Swap:            99M         86M         13M
    Total:          1.0G        594M         84M
              921 M total memory
              507 M used memory
              200 M active memory
              558 M inactive memory
               71 M free memory
               80 M buffer memory
              263 M swap cache
               99 M total swap
               86 M used swap
               13 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G   13G  1.7G  89% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M   60K  461M   1% /dev/shm
    tmpfs          tmpfs     185M  1.1M  184M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs      93M   24K   93M   1% /run/user/1000
    [Wed Jul  5 13:15:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Jul  5 13:15:21 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Jul  5 13:15:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Jul  5 13:15:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    5.8G    /var/
    4.3G    /var/log
    1.5G    /var/log/journal/8c8460ee931b4d829197d3853f2f4cea
    1.3G    /var/cache/apt/archives
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    496M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    801M    /opt/iobroker/iobroker-data/
    562M    /opt/iobroker/iobroker-data/history
    203M    /opt/iobroker/iobroker-data/files
    56M     /opt/iobroker/iobroker-data/files/telegram.admin
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
         18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
     *** 18.16.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.echarts@1.5.1 /opt/iobroker/node_modules/iobroker.echarts
    npm ERR!     /home/pi/.npm/_logs/2023-07-05T12_36_00_105Z-debug-0.log
    Adapters from github:   0
    Adapter State
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, compact disabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 192.168.178.30
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled, compact disabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled, compact disabled
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled, compact disabled
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              - disabled, compact disabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled, compact disabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, compact disabled, port: /dev/ttyACM0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled, compact disabled
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "onvif"        : 1.0.5    , installed 1.0.4  [Updatable]
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "telegram"     : 1.15.6   , installed 1.15.2 [Updatable]
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Adapter    "zigbee2mqtt"  : 2.7.5    , installed 2.7.5
    Objects and States
    Objects:        2992
    States:         2305
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Get:4 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5127 B]
    Fetched 5127 B in 7s (708 B/s)
    Reading package lists...
    Pending Updates: 49
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11000      576/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       43366      6724/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       43373      6724/iobroker.js-co
    tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14594      551/anydesk
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11033      538/cupsd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11032      538/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11002      576/sshd: /usr/sbin
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12160      554/xrdp-sesman
    tcp6       0      0 :::3389                 :::*                    LISTEN      115        14040      585/xrdp
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41668      6895/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44146      6743/io.admin.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40653      6839/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40654      6839/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14009      495/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11058      610/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12100      404/avahi-daemon: r
    udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          14767      551/anydesk
    udp        0      0 0.0.0.0:54737           0.0.0.0:*                           108        12102      404/avahi-daemon: r
    udp6       0      0 :::45565                :::*                                108        12103      404/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14030      495/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12101      404/avahi-daemon: r
    2023-07-05 14:36:40.301  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:36:46.278  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:36:52.295  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:36:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:04.292  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:10.289  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:16.271  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:22.589  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:28.321  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:34.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:40.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:46.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:52.290  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:37:58.312  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:04.291  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:10.288  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:16.297  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:22.296  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:28.272  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:34.275  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:40.276  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:46.283  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:52.280  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:38:58.286  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    2023-07-05 14:39:04.284  - info: smartmeter.0 (6812) Received 5 values, 2 updated
    @dexic
    Klatsch dir doch den mageren RAM nicht auch noch mit einem Desktop/X-Server zu.
    Schalt den Mumpitz auf einem Server aus.
    temp=70.9'C
    Wäre mir auch zu hoch.
    Pending Updates: 49
    Updates einspielen.
    Und den smartmeter-Adapter würde ich auf ein anderes LogLevel setzen. Der ballert ja alle 6 Sekunden in das Log.
    Installier den echarts nochmal, nachdem die anderen Dinge angegangen wurden.
      @dexic
      temp=70.9'C
      Pending Updates: 49
      Updates einspielen.
      dexic
      • Desktop beim Start in raspi-config ausgeschaltet.
      • Wie kann ich Desktop-Programme von Konsolen-Programmen unterscheiden und womöglich halbautomatisch löschen? In einem Raspberry-Forum habe ich das hier gefunden:
        sudo apt purge xserver* lightdm* raspberrypi-ui-mods vlc* lxde* chromium* desktop* gnome* gstreamer* gtk* hicolor-icon-theme* lx* mesa*
      • Die Temperatur ist zu hoch - meinst du, dass das am Desktop liegt? Was kann ich da noch tun?
      • Updates soeben eingespielt. Zuletzt vor etwa 2 Wochen. Ich war verwundert, dass bei Raspbian schon 49 Updates dazu kamen.
      • Neustart
      • smartmeter wird jetzt bei Wertänderungen mit mindestens 30 Sekunden Verzögerung geloggt.
      • Echarts deinstallieren und installieren erledigt
      • D dexic
        • Neustart
        @dexic
        Und
        iob diag
        sagt nun?
        Für das erste reicht es, wenn der Desktop-Krempel nicht geladen wird. BootTarget: multi-user ist das Zauberwort.
        Sorg für mehr frische, kalte Luft beim Raspberry. Gehäuse zu dicht? Kein Lüfter?
          @dexic
          Und
          iob diag
          sagt nun?
          dexic
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
           18:55:44 up  3:19,  1 user,  load average: 3.97, 5.35, 4.23
          CPU threads: 4
          Raspberry only:
          throttled=0x20000
          temp=72.0'C
          volt=1.3438V
                         Local time: Wed 2023-07-05 18:55:45 CEST
                     Universal time: Wed 2023-07-05 16:55:45 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            921M        674M         39M        0.0K        207M        191M
          Swap:            99M         98M        1.0M
          Total:          1.0G        773M         40M
                    921 M total memory
                    674 M used memory
                    293 M active memory
                    519 M inactive memory
                     39 M free memory
                     19 M buffer memory
                    188 M swap cache
                     99 M total swap
                     98 M used swap
                      1 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       15G   13G  1.5G  90% /
          tmpfs          tmpfs     461M   76K  461M   1% /dev/shm
          tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
          [Wed Jul  5 15:36:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ad18b115-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Jul  5 15:36:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Jul  5 15:36:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Wed Jul  5 15:36:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          /var:
          5.9G    /var/
          4.3G    /var/log
          1.4G    /var/cache/apt/archives
          915M    /opt/iobroker/iobroker-data/
          314M    /opt/iobroker/iobroker-data/files
          88M     /opt/iobroker/iobroker-data/files/echarts.admin
          57M     /opt/iobroker/iobroker-data/files/echarts
          23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
          17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
          17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
          /usr/bin/nodejs         v18.16.1
          /usr/bin/node           v18.16.1
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Version table:
           *** 18.16.1-deb-1nodesource1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "telegram"     : 1.15.6   , installed 1.15.6
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Objects and States
          Objects:        2989
          States:         2290
          Fetched 5127 B in 6s (850 B/s)
          Pending Updates: 0
          tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14214      548/anydesk
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13223      539/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       12046      539/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11882      536/cupsd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14518      568/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16421      788/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15001      966/io.web.0
          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12880      554/xrdp-sesman
          tcp6       0      0 :::3389                 :::*                    LISTEN      115        11914      574/xrdp
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14520      568/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11881      536/cupsd
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141831     11605/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141832     11605/io.tuya.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14194      502/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12914      581/cups-browsed
          udp        0      0 0.0.0.0:59522           0.0.0.0:*                           108        14101      391/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14099      391/avahi-daemon: r
          udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          13214      548/anydesk
          udp6       0      0 :::59326                :::*                                108        14102      391/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14551      502/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14100      391/avahi-daemon: r
          2023-07-05 18:59:36.802  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 18:59:40.504  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 18:59:46.501  - info: smartmeter.0 (855) Received 5 values, 1 updated
          2023-07-05 18:59:52.500  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 18:59:58.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:17.854  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 12374
          2023-07-05 19:00:31.614  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:31.658  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:31.660  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:31.662  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:31.667  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:37.509  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:43.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:49.503  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:00:55.605  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:01.548  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:07.493  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:13.496  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:19.491  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:27.176  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:32.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:38.495  - info: smartmeter.0 (855) Received 5 values, 2 updated
          2023-07-05 19:01:39.791  - info: dwd.0 (12374) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
          2023-07-05 19:01:42.958  - info: dwd.0 (12374) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-07-05 19:01:43.601  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                               v.2023-04-16
          Kernel:                 6.1.21-v7+
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    3
          Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          MEMORY:
          Mem:            921M        705M         46M        0.0K        169M        160M
          Swap:            99M         99M          0B
          Total:          1.0G        805M         46M
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                2989
          States:                 2290
          6.2M    /opt/iobroker/iobroker-data/objects.jsonl
          3.3M    /opt/iobroker/iobroker-data/states.jsonl
          Beim Zauberwort "multi-user" kann ich dir nicht folgen. :-(
          Das Gehäuse ist ein "Original" im Set vom Raspberry gewesen. Ich habe da keinen Lüfter, das stimmt, jedoch ist da der Keller, ich dachte, es wäre gut genug.
          DJMarc75D HomoranH Thomas BraunT 3 Antworten Letzte Antwort
          • D dexic
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x20000
            temp=72.0'C
            volt=1.3438V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M         98M        1.0M
                      921 M total memory
                      674 M used memory
                      293 M active memory
                       39 M free memory
                       19 M buffer memory
                      188 M swap cache
                       99 M total swap
                       98 M used swap
                        1 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            5.9G    /var/
            4.3G    /var/log
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2989
            States:         2290
            Pending Updates: 0
                                 v.2023-04-16
            Kernel:                 6.1.21-v7+
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
            MEMORY:
            Swap:            99M         99M          0B
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                2989
            States:                 2290
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @dexic sagte in Fehler beim Update des Telegram-Adapters:
            temp=72.0'C
            wird ja immer glühender
            und Du hast 15 aktive Instanzen bei einem PRI3 am Start - definitiv zu viel
            Lehrling seit 1975 !!!
            • D dexic
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              Raspberry only:
              throttled=0x20000
              temp=72.0'C
              volt=1.3438V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M         98M        1.0M
                        921 M total memory
                        674 M used memory
                        293 M active memory
                         39 M free memory
                         19 M buffer memory
                        188 M swap cache
                         99 M total swap
                         98 M used swap
                          1 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              5.9G    /var/
              4.3G    /var/log
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        2989
              States:         2290
              Pending Updates: 0
                                   v.2023-04-16
              Kernel:                 6.1.21-v7+
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
              MEMORY:
              Swap:            99M         99M          0B
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                2989
              States:                 2290
              hast du wenigstens die Kühlkörper montiert und keinen Deckel auf dem Gehäuse?
              damit ist der arme Pi überladen:
              weil er kein RAM mehr hat lagert er auf die SD Karte aus
              Swap: 99M 99M 0B
              und auch der Notfallschirm ist bereits aufgebraucht.
              Das geht jetzt in massive Schreibaktionen, was Load und Leistung kostet. Neben zusätzlicher Hitze wird auch noch die SD Karte übermäßig belastet
              • D dexic
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                Raspberry only:
                throttled=0x20000
                temp=72.0'C
                volt=1.3438V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M         98M        1.0M
                          921 M total memory
                          674 M used memory
                          293 M active memory
                           39 M free memory
                           19 M buffer memory
                          188 M swap cache
                           99 M total swap
                           98 M used swap
                            1 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                5.9G    /var/
                4.3G    /var/log
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2989
                States:         2290
                Pending Updates: 0
                                     v.2023-04-16
                Kernel:                 6.1.21-v7+
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                MEMORY:
                Swap:            99M         99M          0B
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                2989
                States:                 2290
                Bist du doch schon. Wenn der Desktop/X-Server ausgeknipst wurde ist das sog. BootTarget 'multi-user'. Siehe auch aktuelle Ausgabe von iob diag.
                Zieh die drei Adapter noch auf Stand.
                Soweit passt das dann; das System ist halt immer noch recht ausgelastet.
                Zum Vergleich mal meine Kiste:
                 19:30:21 up 8 days,  1:14,  4 users,  load average: 0.12, 0.22, 0.26
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=48.2'C
                volt=0.9560V
                Active iob-Instances:   22
                • DJMarc75D DJMarc75
                  temp=72.0'C
                  dexic
                  @djmarc75 said in Fehler beim Update des Telegram-Adapters:
                  temp=72.0'C
                  Ja, leider...
                  Wie komme ich da runter und was bedeutet "Instanz" in dem Zusammenhang? Sind das Anwendungen, die geladen werden?
                  • D dexic
                    temp=72.0'C
                    Ja, leider...
                    @dexic
                    Alles mit + davor ist eine laufende Instanz.
                    Adapter State
                    + instance is alive
                      Swap: 99M 99M 0B
                      dexic
                      @homoran said in Fehler beim Update des Telegram-Adapters:
                      Kein Kühlkörper, den Deckel habe ich soeben heruntergenommen und werde das beobachten.
                      Swap: 99M 99M 0B
                      Der Swap ist vollgelaufen, als ich das Update gestartet habe - von 50 MB auf die 100 MB. Ich nehme an, dass er nicht "gesäubert" wird, um Schreibvorgänge auf der SD-Karte zu minimieren.
                      Was die Temperatur angeht - die USV, auf der der Raspi liegt, hat von unten handwarm "vorgeheizt". Ich habe ihn jetzt "umgepflanzt" und den Deckel abgenommen.
                      • D dexic
                        Swap: 99M 99M 0B
                        Doch, der läuft auch wieder leer. Dauert aber und setzt voraus das nicht wieder eine neue Welle reinschwappt. Das ist das normale Verhalten vom Swap.
                        Updates und Backups brauchen viel Speicher.
                        Ich würde den Backitup-Adapter vielleicht auch nicht dauerhaft laufen lassen und den nur bei Bedarf manuell anstupsen.
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=48.2'C
                          volt=0.9560V
                          dexic
                          @thomas-braun said in Fehler beim Update des Telegram-Adapters:
                          OK, ich habe einfach nur deinen Vorschlag ausgeführt und immer noch kein richtiges Verständnis davon, was du mit "multi-user" sagen wolltest. Eine Internetsuche hat mir keine richtigen Erkenntnisse gebracht...
                          Bin gerade dabei. Danke.
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=48.2'C
                          volt=0.9560V
                          Das sieht ja mal ganz anders aus ...
                          • D dexic
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=48.2'C
                            volt=0.9560V
                            @dexic
                            (alt) RunLevel = (modern) boot.targets
                            https://de.wikipedia.org/wiki/Runlevel
                            multi-user entspricht also dem run level 3
                            Also System vollständig geladen, außer der Graphischen Oberfläche.
                              @dexic
                              dexic
                              Sieht nach einem Neustart doch gleich viel besser aus. :-)
                               21:15:59 up 4 min,  1 user,  load average: 1.16, 1.45, 0.71
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=57.5'C
                              volt=1.3312V
                              Mem:            921M        498M        144M        1.0M        278M        367M
                              Swap:            99M          0B         99M
                              Total:          1.0G        498M        244M
                              • D dexic
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=57.5'C
                                volt=1.3312V
                                Swap:            99M          0B         99M
                                @dexic
                                Ja, das sieht gesünder aus.
                                  @dexic
                                  dexic
                                  Vielen lieben Dank für die heutige Unterstützung! :-) Ich habe einiges gelernt. :-)
                                    dexic
                                    schrieb am zuletzt editiert von dexic
                                    Und noch ein kleiner Nachschlag:
                                    So schlimm schaut es jetzt auch nicht mehr aus. :-)
                                    Vielen Dank nochmals an alle Unterstützer! :-)
                                    • D dexic
                                      der Swap ist aber schon wieder angekratzt
