  4. js-controller 5.0.x jetzt in der BETA
    5.6k
580 Beiträge 71 Kommentatoren 239.5k Aufrufe 67 Beobachtet
  • mcm1957M mcm1957
    @apollon77
    Im Spoiler für Entwickler News im ersten Beitrag steht
    Support for Node.js 12 is dropped! Supported are Node.js 14.18.0+, 16.4.0+ and 18.x
    Wurde nicht node 14 enfalls gekübelt.,oder rwechsel ich das was?
    #261
    @mcm57 sagte in js-controller 5.0.x jetzt in der BETA:
    fixe ich
    • D Diamand2k22
      @diamand2k22 said in js-controller 5.0.x jetzt in der BETA:
      seit dem Update auf 5.0.5 schmiert mir immer der Zigbee Adapter ab.
      2023-06-19 10:01:37.722 - error: host.pi4b Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-06-19 10:01:37.723 - error: host.pi4b Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error')
      2023-06-19 10:01:37.723 - error: host.pi4b Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      2023-06-19 10:01:37.723 - error: host.pi4b Caught by controller[0]: at Hub.configureScope (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/hub.ts:340:1)
      2023-06-19 10:01:37.723 - error: host.pi4b Caught by controller[0]: at Object.configureScope (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/exports.ts:76:1)
      2023-06-19 10:01:37.723 - error: host.pi4b Caught by controller[0]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      2023-06-19 10:01:37.724 - error: host.pi4b Caught by controller[0]: at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
      2023-06-19 10:01:37.724 - error: host.pi4b Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
      2023-06-19 10:01:37.724 - error: host.pi4b instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      pi4b@pi4b:/opt/iobroker$ npm ls --depth=3 | grep zigbee
      └─┬ iobroker.zigbee@1.8.11 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#5add9eafb4da35eedc5655ef3c0a8a919ec873b0)
        ├─┬ zigbee-herdsman-converters@15.22.0
        │ └─┬ zigbee-herdsman@0.15.0
        └─┬ zigbee-herdsman@0.14.117
      Zigbee läuft wieder, eine Deinstallation und Reinstallation hat das Problem gelöst.
      für jemanden der das selbe Problem hat.
      cd /opt/iobroker
      npm uninstall zigbee-herdsman-converters
      danach wieder Installieren entweder über Adapter oder github.
      bin zeitgleich wieder auf due 5.0.3 zurück, da im Java Blockly die Trigger nicht mehr funktioniert haben.
      #262
      @diamand2k22 sagte in js-controller 5.0.x jetzt in der BETA:
      cd /opt/iobroker
      Falsches Verzeichnis.
      Die herdsman-Module liegen unterhalb von iobroker.zigbee
      • ste_gleiS Offline
        ste_gleiS Offline
        ste_glei
        #263
        Update auf 5.0.5 hat problemlos geklappt.
        Einzig der bosch-ebike Adapter funktioniert nicht und wirft nur Fehler aus
        host.iobroker
        2023-06-19 12:51:36.695	info	Restart adapter system.adapter.bosch-ebike.0 because enabled
        host.iobroker
        2023-06-19 12:51:36.695	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2023-06-19 12:51:36.695	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        host.iobroker
        2023-06-19 12:51:36.695	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        2023-06-19 12:51:36.695	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51)
        host.iobroker
        2023-06-19 12:51:36.695	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'replace')
        host.iobroker
        2023-06-19 12:51:36.694	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        bosch-ebike.0
        2023-06-19 12:51:35.993	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        bosch-ebike.0
        2023-06-19 12:51:35.992	info	terminating
        bosch-ebike.0
        2023-06-19 12:51:35.975	error	Cannot read properties of undefined (reading 'replace')
        bosch-ebike.0
        2023-06-19 12:51:35.974	error	TypeError: Cannot read properties of undefined (reading 'replace') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        bosch-ebike.0
        2023-06-19 12:51:35.972	error	unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
        bosch-ebike.0
        2023-06-19 12:51:35.971	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        bosch-ebike.0
        2023-06-19 12:51:34.011	info	Login to eBike flow
        • foxriver76F foxriver76
          Controller v5.0.5 wird zeitnah verfügbar sein:
          • Probleme mit falschem Loglevel bei Beenden von Adaptern behoben
          • UI Upgrade wird nur noch angeboten, wenn das Betriebssystem dies unterstützt (das heißt aktuell: nativ Linux oder offizielles ioBroker Docker Image)
          • UI Upgrade für offizielles Docker Image eingebaut
          • Probleme mit dem Aufruf von deleteState in manchen Konstellationen behoben, was zB verhindert hat Geräte in Zigbee zu löschen
          dontobiD Offline
          dontobiD Offline
          dontobi
          #264
          @foxriver76 Ich habe eben meine Installation aktualisiert. Leider klappt danach nichts mehr. Grund hierfür sind die UI Upgrade Changes. Ich nutze nämlich einen eigenen ioBroker Docker Container. Wäre es möglich da was dran zu ändern?
          Smart Home Zentrale: Raspberry Pi 4 4GB
          Meine Homepage: https://www.myHome.zone
          Thomas BraunT foxriver76F apollon77A 4 Antworten Letzte Antwort
          • dontobiD dontobi
            #265
            @dontobi sagte in js-controller 5.0.x jetzt in der BETA:
            Vermutlich müsstest du da was 'zu beißen' in Form von Logfiles abliefern.
            Soweit ich das hier verfolgt habe funktioniert es nämlich bei anderen im Docker.
            M dontobiD 2 Antworten Letzte Antwort
              Marty56
              schrieb am zuletzt editiert von Marty56
              #266
              Ich habe bemerkt, dass "sendToAsync" jetzt wieder Probleme macht.
              Folgende Funktion bricht mit Fehler ab.
              Die Errormeldung liefere ich nach.
              async function write_influxDB2(id,time,value,db) {
                  var timestamp = new Date(new Date(time).toISOString()).getTime();
                  try {
                      await sendToAsync(db, 'storeState', [{ id: id, state: {ts: timestamp, val: value, ack: false}}]);
                      log('Write DB:' + db + ' id:'+ id + " Value: " + value.toFixed(2) + " Time: " + time)
                  catch (error) {
                      log('InfluxDB Error trying to write ' + id ,error)
                  return;
              Update: Fehlermeldung. Ich kann damit nichts anfangen.
              Unknown severity level "[object Object]" by log of [InfluxDB Error trying to write 0_userdata.0.Energie.Auto.price_tibber]
              HW:NUC (16 GB Ram)
              OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                dontobiD Offline
                dontobiD Offline
                dontobi
                #267
                @thomas-braun Wenn ich das eben richtig gesehen habe, wir die Version des Docker Containers abgefragt. Bei mir läuft dies ins leere und somit stürzt der Controller ab.
                • dontobiD dontobi
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  schrieb am zuletzt editiert von foxriver76
                  #268
                  @dontobi ja es wird dir in Zukunft nicht mehr angeboten. UI Upgrade nur mit offiziellem iob Image und auch erst nach 5.0.5 also das kann noch keiner testen.
                  Videotutorials & mehr
                  • dontobiD dontobi
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #269
                    @dontobi und ja Log oder keiner kann dir helfen die Anfrage nach Version kann eigentlich nichts crashen soweit ich weiß
                    dontobiD 1 Antwort Letzte Antwort
                      dontobiD Offline
                      dontobiD Offline
                      dontobi
                      #270
                      @foxriver76 ich liefere das Log morgen nach.
                      • dontobiD dontobi
                        dontobiD Offline
                        dontobiD Offline
                        dontobi
                        #271
                        @dontobi Ich habe mir die UI Upgrade Sache mal genauer angesehen. In meinem Docker Container habe ich die Datei .thisisdocker nicht gesetzt. Habe nun kurz die Datei erzeugt und mit 8.0.0 beschrieben. Danach klappt alles wieder.
                        Dennoch hier das Log ohne die Datei .thisisdocker:
                        /opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/semver/classes/semver.js:38
                              throw new TypeError(`Invalid Version: ${version}`)
                        TypeError: Invalid Version:
                            at new SemVer (/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/semver/classes/semver.js:38:13)
                            at compare (/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/semver/functions/compare.js:3:3)
                            at Object.lt (/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/semver/functions/lt.js:2:29)
                            at isControllerUiUpgradeSupported (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:364:30)
                            at getSupportedFeatures (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:23:53)
                            at new AdapterClass (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:104:68)
                            at startAdapter (/opt/iobroker/node_modules/iobroker.admin/main.js:55:15)
                            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:1208:5)
                            at Module._compile (node:internal/modules/cjs/loader:1254:14)
                            at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                        Node.js v18.16.0
                        ================================== > LOG REDIRECT system.adapter.admin.0 => false
                        • dontobiD dontobi
                          Node.js v18.16.0
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          #272
                          @dontobi bitte controller issue, er erkennt fälschlicherweise wohl aktuell alle Docker Images als offiziell und macht daher nen Invaliden versionsvergleich.
                            #273
                            @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
                            Diskriminierung! 😂
                              Diskriminierung! 😂
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #274
                              @homoran wollte mein iPhone wohl groß schreiben 😀
                              B 1 Antwort Letzte Antwort
                                bommel_030
                                #275
                                @foxriver76
                                Ich hab ein neues "Problem" mit den Aliasen. Kann leider nicht sagen ob es nach dem Update js-controller 5.0.5 oder Admin 6.5.9 kommt, das waren die letzten beiden Aktualisierungen, davor gab es das Problem nicht.
                                Die Aliase funktionieren an sich weiterhin, d.h. Skripte die von einem Alias getriggert werden starten, geänderte Werte werden in die influxdb gespeichert.
                                Es werden aber alle Aliase mit Werte (null) angezeigt. Hier beispielhaft ein Bewegungsmelder:
                                Sobald der Bewegungsmelder auslöst, also Datenpunkte aktualisiert/geändert werden sieht es so aus:
                                Klappe ich den Ordner Galerie zu und wieder auf habe ich wieder den Zustand vom ersten Bild.
                                "iob fix" und reboot hab ich nach den Updates schon gemacht, hat leider nichts geändert. Ebenfalls mehrere Computer/Browser getestet.
                                Die originalen Datenpunkte haben natürlich dauerhaft einen Inhalt.
                                M apollon77A 2 Antworten Letzte Antwort
                                • B bommel_030
                                  @foxriver76
                                  Marty56
                                  #276
                                  Ich habe wieder ein (altbekanntes) Darstellungsproblem im Javascript Editor
                                  admin 6.5.8, js-controller 5.05 und Safari.
                                  und auch noch
                                  HW:NUC (16 GB Ram)
                                  ? 1 Antwort Letzte Antwort
                                  • M Marty56
                                    und auch noch
                                    #277
                                    @marty56 mach mal n Update vom Admin auf 6.5.9 und den Javascript auf 7.1.1, dann gehts wieder... zumindest bei mir.. :-)
                                      solver
                                      #278
                                      Hallo zusammen!
                                      Ich habe nun auch versucht, auf den 5.0.5 das Update bei meiner Testinstallation durchzuführen. Ging doch relativ schnell. Nur 2 meiner Adapter beenden sich immer wieder der Fehlermeldung bzgl. "Probleme mit häufig abstürzenden Adapterinstanzen".
                                      Folgende Adapter betrifft das:
                                      iqontrol v2.2.0
                                      node-red v4.0.3
                                      Meine Installation:
                                      Node.js v18.16.0
                                      npm 9.5.1
                                      Admin v6.5.9
                                      Vielleicht habe ich da auch etwas falsch gemacht. Habt ihr da vielleicht eine Lösung für mich?
                                      Bzw. kennt ihr das Problem?
                                      Ich habe nun wieder auf die alte Version umgestellt und läuft alle ohne Probleme.
                                      Danke für die tolle Arbeit, die ihr da macht!
                                      lg
                                      Solver
                                      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                      • S solver
                                        Hallo zusammen!
                                        iqontrol v2.2.0
                                        node-red v4.0.3
                                        Meine Installation:
                                        Node.js v18.16.0
                                        npm 9.5.1
                                        Admin v6.5.9
                                        lg
                                        Solver
                                        #279
                                        @solver
                                        Du könntest vielleicht wertvollen Input des Ergebnisses deines Beta-Tests z. B. hier hinterlassen:
                                        https://github.com/ioBroker/ioBroker.node-red/issues/380
                                        S L 2 Antworten Letzte Antwort
                                          @solver
                                          solver
                                          #280
                                          @thomas-braun Alles klar, werde ich machen.
                                          Danke!
                                          lg
                                          Solver
