  4. BackItUp - InfluxDB2 - Grafana
    6.1k
62 Beiträge 7 Kommentatoren 8.4k Aufrufe 5 Beobachtet
  • FriedhofsblondF Friedhofsblond
    so meine Lieben ;)
    Ich bin doch schon wieder auf einem frischen System.
    (habe verschiedene abgespeicherte Images die ich via Acronis komlett widerherstellen kann)
    Also ganz frisches Debian 11 - minimal ohne Desktop - also alles per Console.
    Alles strikt nach Docu abgearbeitet.
    So wie es z.B. hier steht:
    influxdb2
    influxdb-cli
    Sorry ich bin ein alter Copy-Paste Arbeiter und muß mir das "Zeugs" zusammensuchen.
    Habt Mitleid ...
    Auf die Ausgaben zu:
    Linux debian 5.10.0-23-amd64 #1 SMP Debian 5.10.179-1 (2023-05-12) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Tue Jun  6 11:46:10 2023 from 192.168.115.175
    superuser@debian:~$ cat /etc/apt/sources.list
    # deb cdrom:[Debian GNU/Linux 11.7.0 _Bullseye_ - Unofficial amd64 NETINST with        firmware 20230429-11:49]/ bullseye contrib main non-free
    #deb cdrom:[Debian GNU/Linux 11.7.0 _Bullseye_ - Unofficial amd64 NETINST with f        irmware 20230429-11:49]/ bullseye contrib main non-free
    deb http://deb.debian.org/debian/ bullseye main non-free contrib
    deb-src http://deb.debian.org/debian/ bullseye main non-free contrib
    deb http://security.debian.org/debian-security bullseye-security main contrib no        n-free
    deb-src http://security.debian.org/debian-security bullseye-security main contri        b non-free
    # bullseye-updates, to get updates before a point release is made;
    # see https://www.debian.org/doc/manuals/debian-reference/ch02.en.html#_updates_        and_backports
    deb http://deb.debian.org/debian/ bullseye-updates main contrib non-free
    deb-src http://deb.debian.org/debian/ bullseye-updates main contrib non-free
    # This system was installed using small removable media
    # (e.g. netinst, live or single CD). The matching "deb cdrom"
    # entries were disabled at the end of the installation process.
    # For information about how to configure apt package sources,
    # see the sources.list(5) manual.
    superuser@debian:~$ cat /etc/apt/sources.list.d/*
    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
    @friedhofsblond
    Also doch wieder am Paketmanager vorbei?
    Die Anleitung von influx ist für ein reines Debian falsch/sehr ungünstig.
    sudo apt update
    apt policy influxdb*
    sagt?
      so meine Lieben ;)
      influxdb2
      influxdb-cli
      Habt Mitleid ...
      @friedhofsblond sagte in BackItUp - InfluxDB2 - Grafana:
      influxdb2
      influxdb-cli
      Moin,
      wie @Thomas-Braun schon schrieb ist das nicht korrekt. Wenn Du es richtig installieren möchtest, musst Du dir leider die alte Doku aus influxDB V.2.0 nehmen.
      https://docs.influxdata.com/influxdb/v2.0/install/?t=Linux
      Dann verstehe ich nicht, was Du alles aus dem Bildchen, das Du gepostet hast, gemacht hast, etwas auch den anderen Kram installiert wie mariadb-client usw.?
      VG
      Bernd
      Marc BergM FriedhofsblondF 2 Antworten Letzte Antwort
        influxdb2
        influxdb-cli
        Moin,
        VG
        Bernd
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        @dp20eic sagte in BackItUp - InfluxDB2 - Grafana:
        Unter diesem Link ist aber auch nicht die Installation per Paketmanager beschrieben, oder?
        ? 1 Antwort Letzte Antwort
          influxdb2
          influxdb-cli
          Moin,
          VG
          Bernd
          FriedhofsblondF Offline
          Friedhofsblond
          schrieb am zuletzt editiert von Friedhofsblond
          @dp20eic
          das war oben noch von der alten Installation.
          Da hatte ich OMV6 noch zusätzlich mit drauf.
          ab hier ists neu:
          https://forum.iobroker.net/topic/65972/backitup-influxdb2-grafana/20?_=1686063421690
          OK dann nochmal zurück auf "0" - ich melde mich 😐
            @dp20eic
            ab hier ists neu:
            @friedhofsblond
            Die Repos zu Grafana wie auch Influx finden sich Copy&Paste fertig hier:
            https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
            FriedhofsblondF 1 Antwort Letzte Antwort
            • Marc BergM Marc Berg
              @marc-berg sagte in BackItUp - InfluxDB2 - Grafana:
              Moin,
              yup, mein Fehler, dachte, dass das noch die alte Beschreibung ist.
              VG
              Bernd
                @friedhofsblond
                Friedhofsblond
                also mit diesenLinks funktioniert auch nicht alles:
                wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key /usr/share/keyrings/grafana.key: Keine Berechtigung
                dann bei Influxdb2 werden ja nur die links zu den Repositories hinzugefügt.
                Wie gehts dann weiter mit der Install??
                ? Thomas BraunT 2 Antworten Letzte Antwort
                  Moin,
                  Da ist etwas beim Kopieren/einfügen kaputt gegangen
                  1) sudo apt-get install -y apt-transport-https
                  2) sudo apt-get install -y software-properties-common wget
                  3) wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                  4) echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                  Das sind jeweils einzelne Kommandos, also erst 1, dann 2 usw.
                  VG
                  Bernd
                    Dann wie üblich bei deinem Betriebssystem.
                    sudo apt update
                    sudo apt install GEWÜNSCHTES_PAKET
                    Vermutlich also influxdb2 influxdb2-client und grafana
                      Moin,
                      VG
                      Bernd
                      @dp20eic
                      Ich hab gerade gesehen, da fehlt ein sudo in Zeile 3.
                      Muss also
                      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                      lauten.
                      • crunchipC Abwesend
                        crunchipC Abwesend
                        hier ist es via apt beschrieben
                        https://docs.influxdata.com/influxdb/v2.2/install/?t=Linux
                          @crunchip sagte in BackItUp - InfluxDB2 - Grafana:
                          Moin,
                          ah, genau das war der Link, den ich oben eigentlich meinte, also V2.2 nicht 2.0 :)
                          VG
                          Bernd
                            Moin,
                            VG
                            Bernd
                            Friedhofsblond
                            @dp20eic
                            Jo, so langsam wirds - werde dann wohl morgen die nächsten blöden Fragen stellen.
                            Danke für die Geduld - 👏
                            • FriedhofsblondF Offline
                              Friedhofsblond
                              @friedhofsblond
                              moin, so nach der Install des IOB habe ich erstmal ein image gezogen und Influxdb2 und Grafana installiert.
                              Ohne erstmal daten in die DB laufen zu lassen und an Grafana was zu basteln, will ich erstmal ein Backup anlegen können. Dann habe ich eine saubere Basis und kann weiter machen.
                              Influxdb2-CLI ist wohl jetzt im Influxdb2 paket enthalten und muß/kann nicht mehr zusätzlich installiert werden, so wie ich das deute: 🙄
                              superuser@debian:~$ sudo apt install influxdb2-client
                              Die folgenden NEUEN Pakete werden installiert:
                                influxdb2-client
                              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen noch 0 B von 11,3 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 25,0 MB Plattenplatz zusätzlich benutzt.
                              (Lese Datenbank ... 51827 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../influxdb2-client_2.7.1-1_amd64.deb ...
                              Entpacken von influxdb2-client (2.7.1-1) ...
                              dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/influxdb2-client_2.7.1-1_amd64.deb (--unpack):
                               Versuch, »/usr/bin/influx« zu überschreiben, welches auch in Paket influxdb2-cli 2.7.3-1 ist
                              dpkg-deb: Fehler: »einfügen«-Unterprozess wurde durch Signal (Datenübergabe unterbrochen (broken pipe)) getötet
                              Fehler traten auf beim Bearbeiten von:
                              E: Sub-process /usr/bin/dpkg returned an error code (1)
                              Beide Installationen laufen nach Systemstart und sind über die Web-Gui erreichbar.
                              Eh ich bei Erstellung User/Datenbank/Visu fehler mache.
                              Das mit "CREATE USER "admin" WITH PASSWORD 'iobroker' WITH ALL PRIVILEGES" usw.
                              Muß ich ja bei V2 nicht mehr machen. (oder?)
                              So Erstanmeldung bei Influx (was schreibe ich bei Bucket rein - das wird der Name der Datenbank - oder ?
                              Bei Grafana - einen sa anlegen (mit welchen privilegien)
                              Grüße
                                @friedhofsblond
                                  influxdb2-client
                                Grüße
                                Fast.
                                influxdb2-client und influxdb2-cli beißen sich da. Ich hab aber noch nicht herausgefunden, wozu die beiden Versionen dienen. Vermutlich ist influxdb2-cli das Paket, in dem die Entwicklung stattfindet und influxdb2-client ist die Version die zum Hauptrelease von influxdb2 gehört. Würde ich jedenfalls so aus den Versionsnummern interpretieren.
                                  Fast.
                                  Friedhofsblond
                                  also den cli installieren ?
                                    Den hast du schon installiert.
                                    Ich würde den influxdb2-client stattdessen nehmen.
                                    sudo apt update
                                    sudo apt remove influxdb2-cli
                                    apt policy influxdb2*
                                      sudo apt update
                                      Friedhofsblond
                                      superuser@debian:~$ sudo apt update
                                      [sudo] Passwort für superuser:
                                      OK:1 http://deb.debian.org/debian bullseye InRelease
                                      Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                      OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                                      OK:4 https://repos.influxdata.com/debian stable InRelease
                                      OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                      OK:6 https://apt.grafana.com stable InRelease
                                      Es wurden 44,1 kB in 1 s geholt (54,0 kB/s).
                                      Alle Pakete sind aktuell.
                                      superuser@debian:~$ sudo apt remove influxdb2-cli
                                      Die folgenden Pakete werden ENTFERNT:
                                        influxdb2-cli
                                      0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
                                      Nach dieser Operation werden 25,2 MB Plattenplatz freigegeben.
                                      Möchten Sie fortfahren? [J/n] j
                                      (Lese Datenbank ... 60118 Dateien und Verzeichnisse sind derzeit installiert.)
                                      Entfernen von influxdb2-cli (2.7.3-1) ...
                                        influxdb2-client
                                      (Lese Datenbank ... 60115 Dateien und Verzeichnisse sind derzeit installiert.)
                                      influxdb2-client (2.7.1-1) wird eingerichtet ...
                                      superuser@debian:~$ apt policy influxdb2*
                                      influxdb2-cli:
                                        Installiert:           (keine)
                                        Installationskandidat: 2.7.3-1
                                        Versionstabelle:
                                           2.7.3-1 500
                                              500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                           2.7.1-2 500
                                           2.6.1 500
                                           2.6.0 500
                                           2.5.0 500
                                           2.4.0 500
                                           2.3.0 500
                                      influxdb2-client:
                                        Installiert:           2.7.1-1
                                        Installationskandidat: 2.7.1-1
                                        Versionstabelle:
                                       *** 2.7.1-1 500
                                              100 /var/lib/dpkg/status
                                      influxdb2:
                                        Versionstabelle:
                                       *** 2.7.1-1 500
                                           2.7.0-1 500
                                           2.6.1-1 500
                                           2.6.0-1 500
                                           2.5.1-1 500
                                           2.4.0-1 500
                                           2.3.0-1 500
                                           2.2.0 500
                                      superuser@debian:~$
                                      OK hat geklappt
                                      Obwohl es manchmal von cli und manchmal von client die Rede ist.
                                      Hier geht es um cli:
                                      und der Link geht auf CLI
                                      Ich denke fast der Client muß raus der CLI rein ?
                                          influxdb2-cli
                                          influxdb2-client
                                        influxdb2-cli:
                                          Versionstabelle:
                                             2.7.3-1 500
                                             2.7.1-2 500
                                             2.6.1 500
                                             2.6.0 500
                                             2.5.0 500
                                             2.4.0 500
                                             2.3.0 500
                                        influxdb2-client:
                                          Versionstabelle:
                                         *** 2.7.1-1 500
                                        influxdb2:
                                          Versionstabelle:
                                         *** 2.7.1-1 500
                                             2.7.0-1 500
                                             2.6.1-1 500
                                             2.6.0-1 500
                                             2.5.1-1 500
                                             2.4.0-1 500
                                             2.3.0-1 500
                                             2.2.0 500
                                        superuser@debian:~$
                                        OK hat geklappt
                                        Nein, beide Pakete stellen die benötigten Programme bereit. Das Paket influxdb2-client gibt es glaube ich auch noch nicht so lange.
                                        Von den Versionsnummern her bilden aber influxdb2 und influxdb2-client das bessere Pärchen, würde ich mal behaupten.
                                          Friedhofsblond
                                          OK sieht erstmal gut aus. Adapter influx und backup für influx - läuft.
                                          Nach dem Mittag grafana.
                                          Started iobroker ...
                                          [DEBUG] [iobroker] - host.debian 2119 states saved
                                          [DEBUG] [iobroker] - host.debian 2900 objects saved
                                          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_07-11_49_07_backupiobroker.tar.gz
                                          [DEBUG] [iobroker] - done
                                          [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                          [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_06_07-11_49_10_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_06_07-11_49_10_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_06_07-11_49_10_backupiobroker" successfully deleted
                                          [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                                          [DEBUG] [influxDB] - done
                                          [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                                          [DEBUG] [clean] - done
                                          [DEBUG] [historyHTML] - new history html values created
                                          [DEBUG] [historyHTML] - done
                                          [DEBUG] [historyJSON] - new history json values created
                                          [DEBUG] [historyJSON] - done
                                          [EXIT] 0
