  4. ioBroker stürzt ab, startet neu
    5.4k
33 Beiträge 5 Kommentatoren 4.0k Aufrufe 6 Beobachtet
  • S Snupy
    @homoran said in ioBroker stürzt ab, startet neu:
    @snupy sagte in ioBroker stürzt ab, startet neu:
    available 1.2G
    du meinst das ist zu wenig ?
    wenn das zu wenig ist ... bleibt mir doch gar nix anderes wie den SWAP zu vergrößern ?
    available 1.2G
    nein, ich nicht.
      available 1.2G
      nein, ich nicht.
      Snupy
      @homoran 😂
      • S Snupy
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         17:57:03 up 22 days,  7:34,  1 user,  load average: 2.02, 2.51, 2.50
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=59.4'C
        volt=0.9160V
        *** Time and Time Zones ***
                       Local time: Fri 2023-05-12 17:57:03 CEST
                   Universal time: Fri 2023-05-12 15:57:03 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        2.5G        939M        0.0K        346M        1.2G
        Swap:            99M         90M        9.0M
        Total:          3.9G        2.6G        948M
                 3794 M total memory
                 2508 M used memory
                  431 M active memory
                 2248 M inactive memory
                  939 M free memory
                   40 M buffer memory
                  305 M swap cache
                   99 M total swap
                   90 M used swap
                    9 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FILESYSTEM ***
        /dev/root      ext4       59G  4.4G   52G   8% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        Show mounted filesystems (real ones only):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        632M    /var/
        289M    /var/cache
        283M    /var/cache/apt
        183M    /var/cache/apt/archives
        152M    /var/lib
        Archived and active journals take up 88.0M in the file system.
        /opt/iobroker/backups:
        48M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        603M    /opt/iobroker/iobroker-data/
        298M    /opt/iobroker/iobroker-data/history
        182M    /opt/iobroker/iobroker-data/files
        85M     /opt/iobroker/iobroker-data/backup-objects
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        30M     /opt/iobroker/iobroker-data/objects.jsonl
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        8.5M    /opt/iobroker/iobroker-data/states.jsonl
        7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
        6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.16.0
        /usr/bin/node           v18.16.0
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
         *** 18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   3
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
        + system.adapter.mytime.0                 : mytime                : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.ping.1                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.sourceanalytix.1         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.sourceanalytix.2         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.3               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.4               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.5               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
        + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.6.19   , installed 2.6.16 [Updatable]
        Adapter    "broadlink2"   : 2.1.5    , installed 2.0.3  [Updatable]
        Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "ical"         : 1.13.2   , installed 1.11.2 [Updatable]
        Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "mihome-vacuum": 3.9.5    , installed 3.8.8  [Updatable]
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "text2command" : 2.3.0    , installed 2.1.1  [Updatable]
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "worx"         : 2.1.3    , installed 2.1.3
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
        Objects and States
        Objects:        9607
        States:         12235
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 60
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25983884   2099868/iobroker.js
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25985332   2099868/iobroker.js
        tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       25986709   2100409/io.mqtt.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25988410   2100472/io.sonoff.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       25985889   2100364/io.mqtt.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       25986889   2100479/io.shelly.0
        tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          15576057   1143174/motion
        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          401684     38002/python2
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13495      536/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:4530            0.0.0.0:*               LISTEN      0          15576052   1143174/motion
        tcp        0      0 0.0.0.0:4531            0.0.0.0:*               LISTEN      0          15576053   1143174/motion
        tcp        0      0 0.0.0.0:4532            0.0.0.0:*               LISTEN      0          15576054   1143174/motion
        tcp        0      0 0.0.0.0:4533            0.0.0.0:*               LISTEN      0          15576055   1143174/motion
        tcp        0      0 0.0.0.0:4534            0.0.0.0:*               LISTEN      0          15576056   1143174/motion
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       25986233   2099981/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25988846   2100846/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13497      536/sshd: /usr/sbin
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       25985970   2100563/io.broadlin
        udp        0      0 0.0.0.0:39698           0.0.0.0:*                           1001       25986855   2100563/io.broadlin
        udp        0      0 0.0.0.0:54321           0.0.0.0:*                           1001       25985888   2100357/io.mihome-v
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11069      392/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10050      674/dhcpcd
        udp        0      0 0.0.0.0:32982           0.0.0.0:*                           108        11071      392/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11070      392/avahi-daemon: r
        udp6       0      0 :::44521                :::*                                108        11072      392/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          23610508   674/dhcpcd
        2023-05-12 17:38:47.587  - error: host.raspberrypi system.adapter.daswetter.0 schedule attribute missing
        2023-05-12 17:38:54.914  - info: host.raspberrypi stopInstance system.adapter.dwd.0 (force=false, process=false)
        2023-05-12 17:38:54.916  - info: host.raspberrypi stopInstance canceled schedule system.adapter.dwd.0
        2023-05-12 17:38:58.025  - error: host.raspberrypi system.adapter.dwd.0 schedule attribute missing
        2023-05-12 17:39:08.388  - info: admin.0 (2099981) <== Disconnect system.user.admin from ::ffff:192.168.0.148 admin
        2023-05-12 17:39:09.048  - info: admin.0 (2099981) ==> Connected system.user.admin from ::ffff:192.168.0.148
        2023-05-12 17:39:30.009  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
        2023-05-12 17:39:30.015  - info: host.raspberrypi stopInstance canceled schedule system.adapter.ical.0
        2023-05-12 17:39:33.130  - error: host.raspberrypi system.adapter.ical.0 schedule attribute missing
        2023-05-12 17:39:33.258  - info: admin.0 (2099981) <== Disconnect system.user.admin from ::ffff:192.168.0.148 admin
        2023-05-12 17:39:33.611  - info: admin.0 (2099981) ==> Connected system.user.admin from ::ffff:192.168.0.148
        2023-05-12 17:39:47.689  - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false)
        2023-05-12 17:39:50.785  - error: host.raspberrypi system.adapter.daswetter.0 schedule attribute missing
        2023-05-12 17:39:57.997  - info: admin.0 (2099981) <== Disconnect system.user.admin from ::ffff:192.168.0.148 admin
        2023-05-12 17:39:58.564  - info: admin.0 (2099981) ==> Connected system.user.admin from ::ffff:192.168.0.148
        2023-05-12 17:40:11.427  - info: host.raspberrypi "system.adapter.daswetter.0" disabled
        2023-05-12 17:40:11.428  - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false)
        2023-05-12 17:40:16.907  - info: host.raspberrypi "system.adapter.dwd.0" disabled
        2023-05-12 17:40:16.907  - info: host.raspberrypi stopInstance system.adapter.dwd.0 (force=false, process=false)
        2023-05-12 17:40:24.900  - info: admin.0 (2099981) <== Disconnect system.user.admin from ::ffff:192.168.0.148 admin
        2023-05-12 17:40:25.242  - info: admin.0 (2099981) ==> Connected system.user.admin from ::ffff:192.168.0.148
        2023-05-12 17:42:43.276  - info: web.0 (2100846) <== Disconnect system.user.admin from ::ffff:192.168.0.49 vis.0
        2023-05-12 17:42:57.023  - info: web.0 (2100846) ==> Connected system.user.admin from ::ffff:192.168.0.49
        2023-05-12 17:52:43.258  - info: web.0 (2100846) <== Disconnect system.user.admin from ::ffff:192.168.0.49 vis.0
        2023-05-12 17:53:01.409  - info: web.0 (2100846) ==> Connected system.user.admin from ::ffff:192.168.0.49
        crunchipC Abwesend
        crunchipC Abwesend
        0 127.0.0.1:7999 0.0.0.0:* LISTEN 0 15576057 1143174/motion tcp 0 0 0.0.0.0:8765 0.0.0.0:* LISTEN 0 401684 38002/python2
        da läuft doch noch zusätzlich motioneye auf dem Pi
        • S Snupy
          @homoran 😂
          @snupy
          Kiste aktuell halten, danach einen Reboot, da wird ein aktueller Kernel installiert werden.
          Dann in das journal zum relevanten Zeitraum schauen.
            Snupy
            schrieb am zuletzt editiert von Snupy
            @crunchip
            ja ... hatte ich schon auf einem anderem Raspy 3 ... der Fehler blieb aber
            dumme Frage, für daswetter.0 und dwd.0 muß explizit ein Zeitplan aktiviert sein ?
            • S Snupy
              @crunchip
              mickymM Online
              mickymM Online
              mickym
              @snupy Ja muss. Diese Adapter sind inaktiv und rufen nur zu bestimmten Zeiten - die Infos aus dem Netz ab.
              • mickymM mickym
                Snupy
                @mickym
                ok, danke
                welcher zyklus sollte eingestellt werden ? halbe Stunde ? Stunde ?
                • S Snupy
                  @mickym
                  ok, danke
                  mickymM Online
                  mickymM Online
                  mickym
                  @snupy Je nach Bedarf - ich würde halt das Interval unterschiedlich zum dwd Adapter nehmen, damit diese nicht immer beide gleichzeitig losstarten. Der dwd läuft standardmässig immer um viertel, halb, dreiviertel und voller Stunde los. Du könntest also den Wetter Adapter um 25 und 55 laufen lassen:
                  25,55 * * * *
                    @snupy
                    Snupy
                    @thomas-braun said in ioBroker stürzt ab, startet neu:
                    @snupy
                    du meinst damit Bullseye auf dem aktuellem Stand halten ?
                    • S Snupy
                      @snupy
                      @snupy
                      Selbstverständlich.
                      • S Snupy
                        @snupy
                        du meinst damit
                        @homoran sagte in ioBroker stürzt ab, startet neu:
                        Pending OS-Updates: 60
                        nachholen!
                        Pending iob updates: 7
                        dito
                          du meinst damit
                          nachholen!
                          dito
                          Snupy
                          so ... drei Tage sind in's Land gegangen, bisher ist kein Absturtz mehr gefolgt :)
                          was habe ich gemacht ...
                          • bullseye Update (incl. Kernel)
                          • swap vergrößert
                          • die Zeiten von dasWetter.0 dwd.0 und ical.0 unterschiedlich eingestellt
                          • Sourceanalytix, eine Instanz gelöscht, eine zweite Instanz in die erste "verschoben", somit habe ich jetzt nur noch eine Instanz
                          ich hoffe die Zeit der Abstürze ist damit vorbei ...
                          Danke euch !
                          • S Snupy
                            • swap vergrößert
                            Danke euch !
                            crunchipC Abwesend
                            crunchipC Abwesend
                            die Instanz selbst ist ja nur für die "Grundeinstellung/Preisdefinitionen" , von daher irgendwie unlogisch eine 2. zu erstellen, den Rest stellt man dann ja beim jeweiligen DP ein, welchen man mit SA erfasst.
                            wenn da sehr viele Adapter laufen + motioneye, kann das schon mal wieder passieren
