  4. Test Adapter telegram-menu v.1.6.x
    6.3k
1.9k Beiträge 65 Kommentatoren 987.1k Aufrufe 63 Beobachtet
  • W Willi-Wunder
    @michael-roling
    Bei mir gehen leider auch keine Abfragen mehr seit dem Update
    telegram.0
    	2023-12-07 22:24:24.696	error	Failed sending [chatId - xxxxxxxxx]: Error: ETELEGRAM: 400 Bad Request: message text is empty
    telegram-menu.0
    	2023-12-07 22:24:24.665	error	"TypeError: Cannot read properties of undefined (reading 'Werkstatt')\n at processData (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:337:18)\n at TelegramMenu.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:215:18)"
    telegram-menu.0
    	2023-12-07 22:24:24.665	error	Error processData: "Cannot read properties of undefined (reading 'Werkstatt')"
    telegram-menu.0
    	2023-12-07 22:24:24.664	error	"TypeError: Cannot read properties of undefined (reading 'Werkstatt')\n at processData (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:337:18)\n at TelegramMenu.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:215:18)"
    telegram-menu.0
    	2023-12-07 22:24:24.663	error	Error processData: "Cannot read properties of undefined (reading 'Werkstatt')"
    telegram-menu.0
    	2023-12-07 22:24:24.662	error	"TypeError: Cannot read properties of undefined (reading 'Werkstatt')\n at processData (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:337:18)\n at TelegramMenu.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:215:18)"
    telegram-menu.0
    	2023-12-07 22:24:24.661	error	Error processData: "Cannot read properties of undefined (reading 'Werkstatt')"
    telegram-menu.0
    	2023-12-07 22:24:24.659	error	"TypeError: Cannot read properties of undefined (reading 'Werkstatt')\n at processData (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:337:18)\n at TelegramMenu.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:215:18)"
    telegram-menu.0
    	2023-12-07 22:24:24.659	error	Error processData: "Cannot read properties of undefined (reading 'Werkstatt')"
    Zurück auf V0.8.5 geht es wieder, update hat auch keine 30 sek. gedauert, lief fix durch.
    Michael RolingM Offline
    Michael Roling
    #821
    @willi-wunder ich werde das noch mal mir anschauen
    • W Willi-Wunder
      @michael-roling
      telegram.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      telegram-menu.0
      Michael Roling
      #822
      @willi-wunder ich habe gerade das auch mal getestet ich kann innerhalb von 10 sekunden den adapter auf 1.0.1 bekommen, habe aber tatsächlich auch diese Fehler, aber solange ich das bei mir reproduzieren kann, weiss ich wonach ich schauen muss
      W 1 Antwort Letzte Antwort
      • Michael RolingM Michael Roling
        W Offline
        W Offline
        Willi-Wunder
        #823
        @michael-roling
        Okay, ansonsten sag bescheid wenn du ein Debug-Log brauchst, auch kein Problem.
        Michael RolingM 1 Antwort Letzte Antwort
        • W Willi-Wunder
          @michael-roling
          Michael Roling
          schrieb am zuletzt editiert von Michael Roling
          #824
          @willi-wunder habe gerade den fehler hoffentlich behoben und hoch geladen
          Irgendwer muss mein versuchskarnickel sein 😂
          Ich installiere in meinem Produktivsystem auch mal
          Bei mir wirft es keinen Fehler mehr
            W Offline
            W Offline
            Willi-Wunder
            #825
            @michael-roling
            Update hat zwar wieder so lange gedauert, aber es läuft jetzt wieder. Abfragen werden ausgegeben. Alles andere werde ich auch noch testen.
            Vielen Dank. 🤗
            W liv-in-skyL 2 Antworten Letzte Antwort
            • W Willi-Wunder
              @michael-roling
              Vielen Dank. 🤗
              W Offline
              W Offline
              Willi-Wunder
              #826
              Neue Zeile anfangen funktioniert mit \n schon mal super.
              Warum er mir das false mit Change nicht umwandelt, weiß ich allerdings nicht.
              • W Willi-Wunder
                Michael Roling
                #827
                @willi-wunder schau ich mal rein
                  W Offline
                  W Offline
                  Willi-Wunder
                  #828
                  @michael-roling
                  Du bist aber auch unermüdlich, mach mal eine Pause, schläfst du auch irgendwann mal? lach......
                  Michael RolingM 2 Antworten Letzte Antwort
                  • W Willi-Wunder
                    @michael-roling
                    Michael Roling
                    #829
                    @willi-wunder Ich habe meine selbstständigkeit aufgegeben und habe jetzt 4 Wochen pause und ab dem 2.1. fange ich als Programmierer Quereinsteiger an 😎
                    • W Willi-Wunder
                      @michael-roling
                      Michael Roling
                      #830
                      @willi-wunder das wird bei mir umgewandelt, steht denn bei dir ein string drin? oder ein boolean? ich habe das gerade mit einem boolean probiert
                      auch mit einem string geht es bei mir
                      W B 2 Antworten Letzte Antwort
                        W Offline
                        W Offline
                        Willi-Wunder
                        #831
                        @michael-roling
                        Steht ein boolean drin, bei beiden ID's. "True" wandelt er ja auch richtig in "EIN" um.
                        • W Willi-Wunder
                          @michael-roling
                          Vielen Dank. 🤗
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #832
                          @willi-wunder sagte in Test Adapter telegram-menu v.0.9.x:
                          @michael-roling
                          das selbe gilt für mich - vielen dank
                            BobBruni
                            schrieb am zuletzt editiert von BobBruni
                            #833
                            @michael-roling
                            Hallo Michael, habe noch ein Verständisproblem... Was ist der Unterschied zwischen dem Ack-Hacken und ack:true im Rückgabetext?
                            Wenn ich den Ack-Haken setze, und ich stelle den Tempwert z.B. von 20°C auf 24°C, wird der Wert des Datenpunkts im iO-Broker entsprechend geändert und ich erhalte sofort den Rückgabetext. Problem: Der Datenpunkt wechselt nach dem er bestätigt wurde wieder auf den urspr. Wert (20°C) zurück.
                            Sobald ich den Ack-Haken rausnehme, funkitioniert es wie es soll - der Datenpunkt wird dauerhaft auf den neu eingestellten Wert gestellt. Wenn ich dann noch im Rückgabetext ack:true eintrage, erhalte ich den Rückgabetext, sobald der Wert bestätigt wurde.
                            Gibt es eine Möglichkeit, eine Rückmeldung zu erhalten sobald ich den Befehl abgesetzt habe und zustäzlich nochmal eine, wenn der Wert wirklich übnommen wurde?
                            Besten Dank!
                            • B BobBruni
                              @michael-roling
                              Besten Dank!
                              Michael Roling
                              #834
                              @bobbruni eigentlich sollte die checkbox das ack:true nur ersetzen. Genau um den datenpunkt eines adapters zu setzen darf man nicht mit ack:true setzen, also darf die checkbox nicht gechecked sein. da ack.true im text wird nicht mehr benötigt. aber anscheinend ist da dann noch ein kleiner bug drin.
                              • B BobBruni
                                @michael-roling
                                Besten Dank!
                                Michael Roling
                                #835
                                @bobbruni hast du denn die checkbox bei confirm message gesetzt? ich habe es gerade selbst mal mit hmip probiert und eine heizung gesetzt, dageht es wie gewünscht nach ca. 5 sek kommt die bestätigung
                                B 1 Antwort Letzte Antwort
                                  BobBruni
                                  #836
                                  @michael-roling
                                  ich muss mich nochmal korrigieren, ob ich das ack:true in den Rückgabetext eintrage oder weglasse, hat keinen Einfluss.
                                  Die Checkbox bei confirm habe ich gesetzt. Der Rückmeldetext kommt bei mir, sobald der Wert bestätigt wurde. Nachdem in dem Adapter, den ich verwende, ein Abfrageintervall von 5min eingestellt ist, kann das schon mal dauern.
                                  Das man Datenpunkte eines Adapters nicht mit ack:true setzen darf, ist für mich eine neue und wichtige Erkenntnis, danke!
                                  Zu meiner Anwendung:
                                  Ich möchte damit meine Standheizung von meinem Auto steuern. Für die Temperatur habe ich ein Submenü erstellt. Wenn ich nun eine Temperatur auswähle, bekomme ich "erstmal" keine Rückmeldung - spätestens eben nach 5min. Wenn ich nun eine Rückmeldung unmittelbar nach der Eingabe haben möchte, müsste ich mir selbst was mit einem Script / Blockly basteln, korrekt?
                                  • B BobBruni
                                    @michael-roling
                                    Michael Roling
                                    #837
                                    @bobbruni ja genau. Denn erst wenn der Adapter den Wert verarbeitet hat setzt er diesen mit ack true. Er reagiert auch nur auf werte die mit ack false gesetzt wurden, damit er weiß das er was zu tun hat. Wenn du eine Rückmeldung bekommst wenn du den Wert gesetzt hast bringt das ja nichts, denn du bekommst nicht mit ob dieser eben verarbeitet wurde.
                                      BobBruni
                                      #838
                                      @michael-roling
                                      Eine Meldung wie "Wert wurde gesendet." unmittelbar nach dem die Temperatur gedrückt wurde, würde dem User vermitteln das es passiert. Man könnte sonst meinen, dass das System nicht reagiert und ein "wildes rumdrücken" auf sämtlichen Temperaturen beginnt 😀
                                      • B BobBruni
                                        @michael-roling
                                        Michael Roling
                                        #839
                                        @bobbruni müsste ich mir anschauen ob ich das einfach eingebaut bekomme. Kannst du dazu ein Issue anlegen?
                                          BobBruni
                                          #840
                                          @michael-roling vielen dank, aber das mach ich dann einfach mit Blockly
