  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • mickymM mickym
    @damrak2022
    Dann erst mal schauen, ob der Service läuft:
    systemctl status influxdb
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #161
    @mickym sagte in Influxdb2 Backitup:
    Nein noch nicht
    Andy@homebridge:~ $ systemctl status influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
         Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 18m>
           Docs: https://docs.influxdata.com/influxdb/
            CPU: 4ms
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
    Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated>
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
    Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
    lines 1-11/11 (END)
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: e>
         Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 18min ago
            CPU: 4ms
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, rest>
    Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distribut>
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too >
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-co>
    Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, d>
    lines 1-11/11 (END)
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
            CPU: 4ms
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
    Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
    Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
    Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    lines 1-11/11 (END)
            CPU: 4ms
    lines 1-11/11 (END)
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      Nein noch nicht
              CPU: 4ms
      lines 1-11/11 (END)
              CPU: 4ms
      lines 1-11/11 (END)
              CPU: 4ms
      lines 1-11/11 (END)
              CPU: 4ms
      lines 1-11/11 (END)
      mickymM Offline
      mickymM Offline
      mickym
      #162
      @damrak2022 Ok - dann lass es uns nochmal machen . aber den Service vorher stoppenn.
      Also nochmal das Ganze.
      sudo systemctl stop influxdb
      dann
      sudo systemctl disable influxdb
      dann
      Maschine neu starten
      sudo apt purge influxdb
      dann wieder die beiden Verzeichnisse löschen.
      Andy@homebridge:~ $ sudo rm -R /var/lib/influxdb
      Andy@homebridge:~ $ sudo rm -R /etc/influxdb
      Nochmal kontrollieren, dass der Service nicht mehr existiert:
      Dann Maschine nochmal neu starten.
      Dann wieder installieren und erst mal zeigen was bei
      apt install influxdb
      rauskommt.
      • mickymM mickym
        dann
        dann
        rauskommt.
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #163
        @mickym okay
        Mit besten Grüßen
        Andy
          @mickym okay
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #164
          @damrak2022 Der Service ist aktiv
          Andy@homebridge:~ $ sudo apt purge influxdb
          Paket »influxdb« ist nicht installiert, wird also auch nicht entfernt.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
          Andy@homebridge:~ $ sudo apt purge influxdb2
          Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
            influxdb2-cli
          Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
          Die folgenden Pakete werden ENTFERNT:
            influxdb2*
          0 aktualisiert, 0 neu installiert, 1 zu entfernen und 1 nicht aktualisiert.
          Nach dieser Operation werden 99,1 MB Plattenplatz freigegeben.
          Möchten Sie fortfahren? [J/n] j
          (Lese Datenbank ... 55637 Dateien und Verzeichnisse sind derzeit installiert.)
          Entfernen von influxdb2 (2.7.0-1) ...
          (Lese Datenbank ... 55627 Dateien und Verzeichnisse sind derzeit installiert.)
          Löschen der Konfigurationsdateien von influxdb2 (2.7.0-1) ...
               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
               Active: active (running) since Thu 2023-04-20 02:15:56 CEST; 4min 19s ago
              Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
             Main PID: 718 (influxd)
                Tasks: 9 (limit: 3932)
                  CPU: 1.861s
               CGroup: /system.slice/influxdb.service
                       └─718 /usr/bin/influxd
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:5>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http:>
          Apr 20 02:15:56 homebridge influxd-systemd-start.sh[715]: InfluxDB started
          Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, dist>
          lines 1-21/21 (END)
          ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
              Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http:/>
          Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distr>
          lines 1-21/21 (END)
               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
              Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gP>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforc>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" lo>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http://localhost:8086/ready unavailable after 1 attempts...
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_i>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement e>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 servi>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 serv>
          Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storag>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 se>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 servi>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indi>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interv>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener tr>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-eng>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0h>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=st>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate >
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interval=8h
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transpo>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 s>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-prec>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited).>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http add>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_n>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=rete>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation che>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrenc>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0h>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 por>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retenti>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_q>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention che>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interv>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8086
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_op>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=102>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 m>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_ope>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check_>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval=>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 ma>
          lines 1-21/21 (END)
                  CPU: 1.861s
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_open op>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check_inte>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval=10m >
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 ini>
          Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_se>
          lines 1-21/21 (END)
          Mit besten Grüßen
          Andy
              influxdb2-cli
              influxdb2*
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
                    CPU: 1.861s
            lines 1-21/21 (END)
            mickymM Offline
            mickymM Offline
            mickym
            #165
            @damrak2022 Nee das purge solltest doch doch machen, wenn der Service nicht mehr da ist.
            Also hast Du nachdem disable influx db die Maschine neu gestartet?
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #166
              @mickym Ja, so hast Du es geschrieben
              Mit besten Grüßen
              Andy
                mickymM Offline
                mickymM Offline
                mickym
                #167
                @damrak2022
                so dann
                schau mal ob es diese Datei noch gibt
                sudo ls -la /etc/systemd/system/influxd.service
                • mickymM mickym
                  @damrak2022
                  so dann
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #168
                  Nein
                  Andy@homebridge:~ $ sudo ls -la /etc/systemd/system/influxd.service
                  ls: Zugriff auf '/etc/systemd/system/influxd.service' nicht möglich: Datei oder Verzeichnis nicht gefunden
                  Andy@homebridge:~ $
                  Mit besten Grüßen
                  Andy
                    Nein
                    Andy@homebridge:~ $
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #169
                    @damrak2022 dann zeig nochmal
                    • mickymM mickym
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #170
                      @mickym
                      Andy@homebridge:~ $ systemctl disable influxdb
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                      Legitimierung ist notwendig für die Verwaltung von Systemdiensten und Einheitendateien.
                      Authenticating as: ,,, (Andy)
                      Password:
                      ==== AUTHENTICATION COMPLETE ===
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                      Legitimierung ist zum erneuten Laden des systemd-Zustands notwendig.
                      Password:
                      Andy@homebridge:~ $
                      Mit besten Grüßen
                      Andy
                        @mickym
                        Password:
                        Password:
                        Andy@homebridge:~ $
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #171
                        @damrak2022 Ja mit sudo - hatte ich vergessen
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #172
                          @mickym
                          Andy@homebridge:~ $ sudo systemctl disable influxdb
                          Andy@homebridge:~ $
                          Mit besten Grüßen
                          Andy
                            @mickym
                            Andy@homebridge:~ $
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #173
                            @damrak2022 Ok vorher ist es ja gelaufen.
                            NOchmal schauen was
                            zeigt.
                            • mickymM mickym
                              NOchmal schauen was
                              zeigt.
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #174
                                   Active: active (running) since Thu 2023-04-20 02:15:56 CEST; 17min ago
                                      CPU: 2.329s
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ0>
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enf>
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service">
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" lo>
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statemen>
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 se>
                              Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 s>
                              lines 1-20/20 (END)
                              Mit besten Grüßen
                              Andy
                                        CPU: 2.329s
                                lines 1-20/20 (END)
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #175
                                @damrak2022 Witzig ist dass der Service nun wieder aktiv gezeigt wird.
                                mach nochmal
                                und dann nochmal
                                     Active: inactive (dead) since Thu 2023-04-20 02:36:24 CEST; 3s ago
                                    Process: 563 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                                   Main PID: 572 (code=killed, signal=TERM)
                                        CPU: 29.183s
                                Bei aktiv muss dead stehen und dann Maschine neu starten - dann sollte mit dem disable nichts mehr stehen.
                                • mickymM mickym
                                  mach nochmal
                                  und dann nochmal
                                          CPU: 29.183s
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #176
                                  Andy@homebridge:~ $ sudo systemctl stop influxdb
                                       Active: inactive (dead) since Thu 2023-04-20 02:43:04 CEST; 15s ago
                                     Main PID: 718 (code=killed, signal=TERM)
                                          CPU: 2.842s
                                  Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, dis>
                                  Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Succeeded.
                                  Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
                                  Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Consumed 2.842s CPU ti>
                                  lines 1-17/17 (END)
                                       Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor prese>
                                          CPU: 2.842s
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.>
                                  Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distri>
                                  Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, distr>
                                  Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, distri>
                                  Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Consumed 2.842s CPU time.
                                  lines 1-17/17 (END)
                                          CPU: 2.842s
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_>
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ0>
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=>
                                  Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, distributed, time series database...
                                  Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                  lines 1-17/17 (END)
                                          CPU: 2.842s
                                  lines 1-17/17 (END)
                                          CPU: 2.842s
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initi>
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_sele>
                                  lines 1-17/17 (END)
                                          CPU: 2.842s
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initial_me>
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_select_po>
                                  lines 1-17/17 (END)
                                          CPU: 2.842s
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initial_mem>
                                  Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_select_poi>
                                  lines 1-17/17 (END)
                                  Mit besten Grüßen
                                  Andy
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                            CPU: 2.842s
                                    lines 1-17/17 (END)
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #177
                                    @damrak2022 Ok - dann ist das Teil nun inaktiv.
                                    Jetzt die beiden Verzeichnisse weg machen:
                                    Nochmal
                                    und Ausgabe zeigen:
                                    • mickymM mickym
                                      Nochmal
                                      und Ausgabe zeigen:
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #178
                                      Die sind garnicht da:
                                      rm: das Entfernen von '/var/lib/influxdb' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                      rm: das Entfernen von '/etc/influxdb' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                      Andy@homebridge:~ $
                                      Mit besten Grüßen
                                      Andy
                                        Andy@homebridge:~ $
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #179
                                        @damrak2022 Gut und
                                        zeigt auch nichts mehr?
                                        EDIT muss influxdb2 heißen
                                        • mickymM mickym
                                          @damrak2022 Gut und
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #180
                                            influxdb2-cli
                                          Andy@homebridge:~ $
                                          Mit besten Grüßen
                                          Andy
