  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • mickymM mickym
    @damrak2022 Wie nur drehendes Symbol - hat denn die Installation geklappt?
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #158
    @mickym Ja
    Mit besten Grüßen
    Andy
    • mickymM mickym
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #159
      @mickym Ich starte mal neu
      Mit besten Grüßen
      Andy
      • Damrak2022D Damrak2022
        @mickym Ja
        mickymM Offline
        mickymM Offline
        mickym
        #160
        @damrak2022
        Dann erst mal schauen, ob der Service läuft:
        systemctl status influxdb
        • mickymM mickym
          @damrak2022
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #161
          @mickym sagte in Influxdb2 Backitup:
          Nein noch nicht
          Andy@homebridge:~ $ systemctl status influxdb
          ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
               Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 18m>
                 Docs: https://docs.influxdata.com/influxdb/
                  CPU: 4ms
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
          Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated>
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
          Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
          lines 1-11/11 (END)
          ● influxdb.service - InfluxDB is an open-source, distributed, time series database
               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: e>
               Active: failed (Result: exit-code) since Thu 2023-04-20 01:50:08 CEST; 18min ago
                  CPU: 4ms
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, rest>
          Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distribut>
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too >
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-co>
          Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, d>
          lines 1-11/11 (END)
               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                  CPU: 4ms
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
          Apr 20 01:50:08 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
          Apr 20 01:50:08 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
          Apr 20 01:50:08 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
          lines 1-11/11 (END)
                  CPU: 4ms
          lines 1-11/11 (END)
          Mit besten Grüßen
          Andy
            Nein noch nicht
                    CPU: 4ms
            lines 1-11/11 (END)
                    CPU: 4ms
            lines 1-11/11 (END)
                    CPU: 4ms
            lines 1-11/11 (END)
                    CPU: 4ms
            lines 1-11/11 (END)
            mickymM Offline
            mickymM Offline
            mickym
            #162
            @damrak2022 Ok - dann lass es uns nochmal machen . aber den Service vorher stoppenn.
            Also nochmal das Ganze.
            sudo systemctl stop influxdb
            dann
            sudo systemctl disable influxdb
            dann
            Maschine neu starten
            sudo apt purge influxdb
            dann wieder die beiden Verzeichnisse löschen.
            Andy@homebridge:~ $ sudo rm -R /var/lib/influxdb
            Andy@homebridge:~ $ sudo rm -R /etc/influxdb
            Nochmal kontrollieren, dass der Service nicht mehr existiert:
            Dann Maschine nochmal neu starten.
            Dann wieder installieren und erst mal zeigen was bei
            apt install influxdb
            rauskommt.
            • mickymM mickym
              dann
              dann
              rauskommt.
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #163
              @mickym okay
              Mit besten Grüßen
              Andy
                @mickym okay
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #164
                @damrak2022 Der Service ist aktiv
                Andy@homebridge:~ $ sudo apt purge influxdb
                Paket »influxdb« ist nicht installiert, wird also auch nicht entfernt.
                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                Andy@homebridge:~ $ sudo apt purge influxdb2
                Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                  influxdb2-cli
                Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                Die folgenden Pakete werden ENTFERNT:
                  influxdb2*
                0 aktualisiert, 0 neu installiert, 1 zu entfernen und 1 nicht aktualisiert.
                Nach dieser Operation werden 99,1 MB Plattenplatz freigegeben.
                Möchten Sie fortfahren? [J/n] j
                (Lese Datenbank ... 55637 Dateien und Verzeichnisse sind derzeit installiert.)
                Entfernen von influxdb2 (2.7.0-1) ...
                (Lese Datenbank ... 55627 Dateien und Verzeichnisse sind derzeit installiert.)
                Löschen der Konfigurationsdateien von influxdb2 (2.7.0-1) ...
                     Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
                     Active: active (running) since Thu 2023-04-20 02:15:56 CEST; 4min 19s ago
                    Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
                   Main PID: 718 (influxd)
                      Tasks: 9 (limit: 3932)
                        CPU: 1.861s
                     CGroup: /system.slice/influxdb.service
                             └─718 /usr/bin/influxd
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:5>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http:>
                Apr 20 02:15:56 homebridge influxd-systemd-start.sh[715]: InfluxDB started
                Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, dist>
                lines 1-21/21 (END)
                ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
                     Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
                    Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http:/>
                Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distr>
                lines 1-21/21 (END)
                     Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
                    Process: 715 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gP>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforc>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" lo>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http://localhost:8086/ready unavailable after 1 attempts...
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_i>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement e>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 servi>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 serv>
                Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storag>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 se>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 servi>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indi>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interv>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener tr>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-eng>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0h>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=st>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate >
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interval=8h
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transpo>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 s>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-prec>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited).>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http add>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_n>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=rete>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation che>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrenc>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0h>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 por>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retenti>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_q>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention che>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interv>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8086
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_op>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=102>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 m>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_ope>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check_>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval=>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 ma>
                lines 1-21/21 (END)
                        CPU: 1.861s
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ07gPl000 service=storage-engine service=store op_name=tsdb_open op>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ07gPl000 service=retention check_inte>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service" log_id=0hJ07gPl000 service=shard-precreation check_interval=10m >
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 ini>
                Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_se>
                lines 1-21/21 (END)
                Mit besten Grüßen
                Andy
                    influxdb2-cli
                    influxdb2*
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                          CPU: 1.861s
                  lines 1-21/21 (END)
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #165
                  @damrak2022 Nee das purge solltest doch doch machen, wenn der Service nicht mehr da ist.
                  Also hast Du nachdem disable influx db die Maschine neu gestartet?
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #166
                    @mickym Ja, so hast Du es geschrieben
                    Mit besten Grüßen
                    Andy
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #167
                      @damrak2022
                      so dann
                      schau mal ob es diese Datei noch gibt
                      sudo ls -la /etc/systemd/system/influxd.service
                      • mickymM mickym
                        @damrak2022
                        so dann
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #168
                        Nein
                        Andy@homebridge:~ $ sudo ls -la /etc/systemd/system/influxd.service
                        ls: Zugriff auf '/etc/systemd/system/influxd.service' nicht möglich: Datei oder Verzeichnis nicht gefunden
                        Andy@homebridge:~ $
                        Mit besten Grüßen
                        Andy
                          Nein
                          Andy@homebridge:~ $
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #169
                          @damrak2022 dann zeig nochmal
                          • mickymM mickym
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #170
                            @mickym
                            Andy@homebridge:~ $ systemctl disable influxdb
                            ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                            Legitimierung ist notwendig für die Verwaltung von Systemdiensten und Einheitendateien.
                            Authenticating as: ,,, (Andy)
                            Password:
                            ==== AUTHENTICATION COMPLETE ===
                            ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                            Legitimierung ist zum erneuten Laden des systemd-Zustands notwendig.
                            Password:
                            Andy@homebridge:~ $
                            Mit besten Grüßen
                            Andy
                              @mickym
                              Password:
                              Password:
                              Andy@homebridge:~ $
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #171
                              @damrak2022 Ja mit sudo - hatte ich vergessen
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #172
                                @mickym
                                Andy@homebridge:~ $ sudo systemctl disable influxdb
                                Andy@homebridge:~ $
                                Mit besten Grüßen
                                Andy
                                  @mickym
                                  Andy@homebridge:~ $
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #173
                                  @damrak2022 Ok vorher ist es ja gelaufen.
                                  NOchmal schauen was
                                  zeigt.
                                  • mickymM mickym
                                    NOchmal schauen was
                                    zeigt.
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #174
                                         Active: active (running) since Thu 2023-04-20 02:15:56 CEST; 17min ago
                                            CPU: 2.329s
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ0>
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enf>
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service">
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" lo>
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statemen>
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 se>
                                    Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 s>
                                    lines 1-20/20 (END)
                                    Mit besten Grüßen
                                    Andy
                                              CPU: 2.329s
                                      lines 1-20/20 (END)
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #175
                                      @damrak2022 Witzig ist dass der Service nun wieder aktiv gezeigt wird.
                                      mach nochmal
                                      und dann nochmal
                                           Active: inactive (dead) since Thu 2023-04-20 02:36:24 CEST; 3s ago
                                          Process: 563 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                                         Main PID: 572 (code=killed, signal=TERM)
                                              CPU: 29.183s
                                      Bei aktiv muss dead stehen und dann Maschine neu starten - dann sollte mit dem disable nichts mehr stehen.
                                      • mickymM mickym
                                        mach nochmal
                                        und dann nochmal
                                                CPU: 29.183s
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #176
                                        Andy@homebridge:~ $ sudo systemctl stop influxdb
                                             Active: inactive (dead) since Thu 2023-04-20 02:43:04 CEST; 15s ago
                                           Main PID: 718 (code=killed, signal=TERM)
                                                CPU: 2.842s
                                        Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, dis>
                                        Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Succeeded.
                                        Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
                                        Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Consumed 2.842s CPU ti>
                                        lines 1-17/17 (END)
                                             Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor prese>
                                                CPU: 2.842s
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.>
                                        Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distri>
                                        Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, distr>
                                        Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, distri>
                                        Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Consumed 2.842s CPU time.
                                        lines 1-17/17 (END)
                                                CPU: 2.842s
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_>
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ0>
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=>
                                        Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, distributed, time series database...
                                        Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                        lines 1-17/17 (END)
                                                CPU: 2.842s
                                        lines 1-17/17 (END)
                                                CPU: 2.842s
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initi>
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_sele>
                                        lines 1-17/17 (END)
                                                CPU: 2.842s
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initial_me>
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_select_po>
                                        lines 1-17/17 (END)
                                                CPU: 2.842s
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initial_mem>
                                        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_select_poi>
                                        lines 1-17/17 (END)
                                        Mit besten Grüßen
                                        Andy
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                                  CPU: 2.842s
                                          lines 1-17/17 (END)
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #177
                                          @damrak2022 Ok - dann ist das Teil nun inaktiv.
                                          Jetzt die beiden Verzeichnisse weg machen:
                                          Nochmal
                                          und Ausgabe zeigen:
