  4. Twinkly Adapter bleibt gelb
    6.1k
28 Beiträge 7 Kommentatoren 5.0k Aufrufe 6 Beobachtet
    base
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Diskstation
    Arbeitsspeicher: 11 GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 14.18.3
    Nodejs-Version: 14.18.3
    NPM-Version: 6.14.15
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    ich bekommen meinen Twinkly Adapter nicht mehr zum laufen. Hab ihn schon deinstalliert und gedowngradet, den Twinkly zurückgsetzt, IP geändert, alles ohne Erfolg...
    twinkly.0
    2022-12-25 13:54:57.340	info	Startup complete
    twinkly.0
    2022-12-25 13:54:57.340	debug	[poll] Finished polling...
    twinkly.0
    2022-12-25 13:54:57.339	debug	[poll] Twinkly not connected!
    twinkly.0
    2022-12-25 13:54:57.338	debug	[checkConnection] Twinkly is not available!
    twinkly.0
    2022-12-25 13:54:57.283	debug	[poll] Start polling...
    twinkly.0
    2022-12-25 13:54:57.281	debug	[processObjectChanges] No tasks to process!
    twinkly.0
    2022-12-25 13:54:57.280	debug	[processObjectChanges] Prepare tasks of objects update
    twinkly.0
    2022-12-25 13:54:57.278	debug	[processObjectChanges] Add instance objects
    twinkly.0
    2022-12-25 13:54:57.277	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
    twinkly.0
    2022-12-25 13:54:57.115	debug	[processObjectChanges] Get existing objects
    twinkly.0
    2022-12-25 13:54:57.050	debug	[syncConfig] config network: false
    twinkly.0
    2022-12-25 13:54:57.049	debug	[syncConfig] config mqtt: true
    twinkly.0
    2022-12-25 13:54:57.049	debug	[syncConfig] config details: true
    twinkly.0
    2022-12-25 13:54:57.048	debug	[syncConfig] config interval: 60
    twinkly.0
    2022-12-25 13:54:57.047	debug	[syncConfig] config devices: [{"enabled":true,"name":"Twinkly","host":"192.168.1.125","stateOn":"color"}]
    twinkly.0
    2022-12-25 13:54:57.018	info	starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.twinkly, node: v14.18.3, js-controller: 4.0.23
    twinkly.0
    2022-12-25 13:54:56.579	debug	Plugin sentry Initialize Plugin (enabled=true)
    twinkly.0
    2022-12-25 13:54:56.291	debug	States connected to redis: 127.0.0.1:9000
    twinkly.0
    2022-12-25 13:54:56.194	debug	States create User PubSub Client
    twinkly.0
    2022-12-25 13:54:56.193	debug	States create System PubSub Client
    twinkly.0
    2022-12-25 13:54:56.153	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    twinkly.0
    2022-12-25 13:54:56.096	debug	Objects connected to redis: 127.0.0.1:9001
    twinkly.0
    2022-12-25 13:54:56.090	debug	Objects client initialize lua scripts
    twinkly.0
    2022-12-25 13:54:55.964	debug	Objects create User PubSub Client
    twinkly.0
    2022-12-25 13:54:55.962	debug	Objects create System PubSub Client
    twinkly.0
    2022-12-25 13:54:55.960	debug	Objects client ready ... initialize now
    twinkly.0
    2022-12-25 13:54:55.901	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    M HomoranH 2 Antworten Letzte Antwort
    • B base
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      MCU
      @base sagte in Twinkly Adapter bleibt gelb:
      14.18.3
      Empfohlene node-Version ist die v16.
        base
        bin jetzt auf v16. Adapter bleibt weiterhin gelb...
        • B base
          MCU
          @base Wie sind denn die Einstellungen im twinkly-Adapter?
          Per App ist die Lichterkette steuerbar?
          Sind beide Geräte im gleichen Netzwerk? WLAN 2.4 GHz!
          Twinkly App -> Geräte -> Einstellungen -> Netzwerk?
          • B base
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            twinkly.0
            Hardwaresystem:
            Diskstation
            in Verbindung mit
            Betriebssystem:
            Ubuntu/Windows/Mac
            gibt mehr Fragen als Antworten.
            was sagt iob diag?
            B 1 Antwort Letzte Antwort
              Hardwaresystem:
              Diskstation
              in Verbindung mit
              Betriebssystem:
              Ubuntu/Windows/Mac
              was sagt iob diag?
              base
              muss das Thema jetzt vor Weihnachten nochmal aufgreifen. Nachdem ich das System vor kurzem neu aufgesetzt habe besteht der Fehler leider weiterhin. Via App habe ich über das Netzwerk Zugriff. Auch kann ich den Controller anpingen.
              iob diag:
              ======== Start marking the full check here =========
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Hardware Vendor : Synology
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.0.1
              Virtualization  : Docker
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               15:46:13 up 19 days, 19:25,  0 user,  load average: 2.78, 3.00, 2.72
              CPU threads: 4
              *** Time and Time Zones ***
              Thu Dec  7 14:46:13 UTC 2023
              Thu Dec  7 15:46:13 CET 2023
              CET +0100
              Etc/UTC
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             12G        8.4G        993M        105M        3.4G        4.0G
              Swap:           9.6G        4.6G        5.0G
              Total:           21G         12G        6.0G
                      11822 M total memory
                       8002 M used memory
                       3724 M active memory
                       4442 M inactive memory
                        947 M free memory
                        311 M buffer memory
                       2973 M swap cache
                       9143 M total swap
                       4372 M used swap
                       4771 M free swap
              *** FILESYSTEM ***
              Filesystem             Type   Size  Used Avail Use% Mounted on
              none                   aufs   2.7T  1.9T  826G  70% /
              tmpfs                  tmpfs   64M     0   64M   0% /dev
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
              shm                    tmpfs   64M     0   64M   0% /dev/shm
              /dev/mapper/cachedev_1 ext4   2.7T  1.9T  826G  70% /opt/iobroker
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
              Show mounted filesystems \(real ones only\):
              TARGET             SOURCE  FSTYPE OPTIONS
              /                  none  aufs   rw,relatime,si=d721e7829fc3c919,dio,dirperm1
              |-/opt/iobroker    /dev/mapper/cachedev_1[/docker/iobrokerv5_data]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
              |-/etc/resolv.conf /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
              |-/etc/hostname    /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/hostname]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
              `-/etc/hosts       /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/hosts]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
              /var:
              34M     /var/
              32M     /var/lib
              19M     /var/lib/apt/lists
              19M     /var/lib/apt
              13M     /var/lib/dpkg/info
              /opt/iobroker/backups:
              81M     /opt/iobroker/backups/
              4.0K    /opt/iobroker/backups/influxDB_2020_12_12-02_00_26_backupiobroker
              4.0K    /opt/iobroker/backups/influxDB_2020_12_11-02_00_27_backupiobroker
              4.0K    /opt/iobroker/backups/influxDB_2020_12_10-02_00_25_backupiobroker
              4.0K    /opt/iobroker/backups/influxDB_2020_12_09-02_00_27_backupiobroker
              /opt/iobroker/iobroker-data:
              771M    /opt/iobroker/iobroker-data/
              604M    /opt/iobroker/iobroker-data/files
              115M    /opt/iobroker/iobroker-data/backup-objects
              90M     /opt/iobroker/iobroker-data/files/echarts.admin
              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              34M     /opt/iobroker/iobroker-data/objects.jsonl
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
              find: '/dev/serial/by-id/': No such file or directory
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.2
              /usr/bin/node           v18.18.2
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
                Installed: 18.18.2-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
                   18.19.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               *** 18.18.2-1nodesource1 500
                      100 /var/lib/dpkg/status
                   18.18.1-1nodesource1 500
                   18.18.0-1nodesource1 500
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
              No problems detected
              Errors in npm tree:
              npm ERR! code ELSPROBLEMS
              npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@7.1.6
              npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-12-07T14_46_20_632Z-debug-0.log
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   6
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker_v5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker_v5                              -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker_v5                              - disabled
              + system.adapter.backitup.0               : backitup              : iobroker_v5                              -  enabled
                system.adapter.ble.0                    : ble                   : iobroker_v5                              - disabled
              + system.adapter.bring.0                  : bring                 : iobroker_v5                              -  enabled
              + system.adapter.countdown.0              : countdown             : iobroker_v5                              -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker_v5                              -  enabled
              + system.adapter.denon.0                  : denon                 : iobroker_v5                              -  enabled
                system.adapter.devices.0                : devices               : iobroker_v5                              - disabled
              + system.adapter.discovery.0              : discovery             : iobroker_v5                              -  enabled
                system.adapter.dwd.0                    : dwd                   : iobroker_v5                              -  enabled
              + system.adapter.echarts.0                : echarts               : iobroker_v5                              -  enabled
              + system.adapter.enigma2.0                : enigma2               : iobroker_v5                              -  enabled
                system.adapter.flot.0                   : flot                  : iobroker_v5                              - disabled
              + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker_v5                              -  enabled
                system.adapter.fullybrowser.0           : fullybrowser          : iobroker_v5                              - disabled
              + system.adapter.harmony.0                : harmony               : iobroker_v5                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker_v5                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker_v5                              -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker_v5                              -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : iobroker_v5                              -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker_v5                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : iobroker_v5                              - disabled
                system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker_v5                              - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker_v5                              - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker_v5                              - disabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker_v5                              -  enabled
              + system.adapter.influxdb.0               : influxdb              : iobroker_v5                              -  enabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : iobroker_v5                              -  enabled, port: 8087
              + system.adapter.info.0                   : info                  : iobroker_v5                              -  enabled
              + system.adapter.iot.0                    : iot                   : iobroker_v5                              -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker_v5                              -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker_v5                              -  enabled, port: 54321
              + system.adapter.mihome.0                 : mihome                : iobroker_v5                              -  enabled, port: 9898, bind: 192.168.1.120
              + system.adapter.mytime.0                 : mytime                : iobroker_v5                              -  enabled
              + system.adapter.mytime.1                 : mytime                : iobroker_v5                              -  enabled
              + system.adapter.ping.0                   : ping                  : iobroker_v5                              -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : iobroker_v5                              -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : iobroker_v5                              -  enabled
                system.adapter.pvforecast.1             : pvforecast            : iobroker_v5                              - disabled
                system.adapter.rtspStream.0             : rtspStream            : iobroker_v5                              - disabled, port: 554
              + system.adapter.sayit.3                  : sayit                 : iobroker_v5                              -  enabled
              + system.adapter.senec.0                  : senec                 : iobroker_v5                              -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker_v5                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker_v5                              -  enabled
              + system.adapter.simple-api.0             : simple-api            : iobroker_v5                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.snmp.0                   : snmp                  : iobroker_v5                              -  enabled
              + system.adapter.sonoff.0                 : sonoff                : iobroker_v5                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker_v5                              -  enabled
                system.adapter.sql.0                    : sql                   : iobroker_v5                              - disabled, port: 0
              + system.adapter.statistics.0             : statistics            : iobroker_v5                              -  enabled
              + system.adapter.synology.0               : synology              : iobroker_v5                              -  enabled, port: 5001
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker_v5                              -  enabled
              + system.adapter.telegram.0               : telegram              : iobroker_v5                              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.terminal.0               : terminal              : iobroker_v5                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.text2command.0           : text2command          : iobroker_v5                              -  enabled
              + system.adapter.tr-064.0                 : tr-064                : iobroker_v5                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker_v5                              -  enabled
              + system.adapter.twinkly.0                : twinkly               : iobroker_v5                              -  enabled
              + system.adapter.upnp.0                   : upnp                  : iobroker_v5                              -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker_v5                              - disabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker_v5                              - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker_v5                              - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker_v5                              - disabled
                system.adapter.vis-history.0            : vis-history           : iobroker_v5                              - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker_v5                              - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker_v5                              -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker_v5                              - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : iobroker_v5                              - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker_v5                              -  enabled
                system.adapter.vis-metro.0              : vis-metro             : iobroker_v5                              - disabled
                system.adapter.vis-players.0            : vis-players           : iobroker_v5                              - disabled
                system.adapter.vis-plumb.0              : vis-plumb             : iobroker_v5                              - disabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker_v5                              - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker_v5                              - disabled
                system.adapter.vis-weather.0            : vis-weather           : iobroker_v5                              - disabled
                system.adapter.vis.0                    : vis                   : iobroker_v5                              -  enabled
              + system.adapter.web.0                    : web                   : iobroker_v5                              -  enabled, port: 8082, bind: 192.168.1.120, run as: admin
              + system.adapter.worx.0                   : worx                  : iobroker_v5                              -  enabled
              + system.adapter.ws.0                     : ws                    : iobroker_v5                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "ble"          : 0.13.4   , installed 0.13.4
              Adapter    "bring"        : 1.8.4    , installed 1.8.4
              Adapter    "countdown"    : 2.2.0    , installed 2.2.0
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "denon"        : 1.15.4   , installed 1.15.4
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
              Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
              Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
              Adapter    "harmony"      : 1.3.0    , installed 1.3.0
              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
              Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "info"         : 2.0.0    , installed 2.0.0
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
              Adapter    "snmp"         : 3.1.0    , installed 3.1.0
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "sql"          : 2.2.0    , installed 2.2.0
              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
              Adapter    "synology"     : 3.0.1    , installed 3.0.1
              Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
              Adapter    "telegram"     : 2.0.1    , installed 2.0.1
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
              Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
              Adapter    "vis-icontwo"  : 0.98.0   , installed 0.97.1 [Updatable]
              Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
              Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
              Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
              Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
              Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "worx"         : 2.3.4    , installed 2.3.4
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Objects and States
              Objects:        22170
              States:         19042
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 5
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       183619990  -
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       183627488  -
              tcp        0      0 127.0.0.11:36422        0.0.0.0:*               LISTEN      0          183606762  -
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       183612197  -
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       183612171  -
              tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       183620056  -
              tcp        0      0 192.168.1.120:8082      0.0.0.0:*               LISTEN      1000       184474196  -
              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       183643690  -
              tcp6       0      0 :::8088                 :::*                    LISTEN      1000       183649454  -
              tcp6       0      0 :::61991                :::*                    LISTEN      1000       183637426  -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       183901599  -
              tcp6       0      0 :::8084                 :::*                    LISTEN      1000       184473591  -
              udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       308708822  -
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       183654037  -
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       183654036  -
              udp        0      0 127.0.0.11:45171        0.0.0.0:*                           0          183606761  -
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       318795020  -
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       183637427  -
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       183624888  -
              udp        0      0 0.0.0.0:38624           0.0.0.0:*                           1000       183646509  -
              udp        0      0 0.0.0.0:40335           0.0.0.0:*                           1000       183646510  -
              2023-12-07 15:38:17.656  - info: host.iobroker_v5 stopInstance system.adapter.twinkly.0 send kill signal
              2023-12-07 15:38:17.902  - info: twinkly.0 (24461) terminating
              2023-12-07 15:38:17.904  - info: twinkly.0 (24461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-12-07 15:38:18.606  - info: host.iobroker_v5 instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-07 15:38:20.902  - info: host.iobroker_v5 instance system.adapter.twinkly.0 started with pid 19716
              2023-12-07 15:38:23.638  - info: twinkly.0 (19716) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.18.2, js-controller: 5.0.16
              2023-12-07 15:38:24.129  - info: twinkly.0 (19716) Startup complete
              2023-12-07 15:40:00.108  - info: host.iobroker_v5 instance system.adapter.dwd.0 started with pid 19918
              2023-12-07 15:40:06.229  - info: host.iobroker_v5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-07 15:42:22.991  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] connection closed: closed
              2023-12-07 15:42:35.315  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] connected with secret 1701960155314_670
              2023-12-07 15:43:39.038  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] reconnected. Old secret 1701960155314_670. New secret1701960219038_8074
              2023-12-07 15:44:42.756  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] reconnected. Old secret 1701960219038_8074. New secret 1701960281472_8737
              2023-12-07 15:45:00.148  - info: host.iobroker_v5 instance system.adapter.dwd.0 started with pid 21081
              2023-12-07 15:45:04.245  - info: host.iobroker_v5 instance system.adapter.daswetter.0 started with pid 21108
              2023-12-07 15:45:06.229  - info: host.iobroker_v5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-07 15:45:15.916  - info: host.iobroker_v5 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-07 15:45:48.461  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends publish. Ignore! Actual secret is 1701960281472_8737
              2023-12-07 15:45:48.462  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends publish. Ignore! Actual secret is 1701960281472_8737
              2023-12-07 15:45:48.462  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends subscribe. Ignore! Actual secret is 1701960281472_8737
              2023-12-07 15:45:48.463  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends pingreq. Ignore! Actual secret is 1701960281472_8737
              ======================= SUMMARY =======================                        v.2023-10-10
              model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHzKernel          : x86_64
              Userland        : amd64Docker          : v9.0.1
              Installation:           Docker
              Kernel:                 x86_64Userland:               amd64
              Timezone:               Etc/UTCUser-ID:                0
              X-Server:               false
              Pending OS-Updates:     5
              Pending iob updates:    1
              Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
              Recommended versions are nodejs 18.19.0 and npm 10.2.3
              MEMORY:
              Mem:             12G        8.4G        862M        105M        3.6G        4.0G
              Total:           21G         12G        5.9G
              Active iob-Instances:   49
              ioBroker Core:          js-controller           5.0.16
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                22170
              States:                 19042
              Size of iob-Database:
              22M     /opt/iobroker/iobroker-data/states.jsonl
              • B base
                iob diag:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v9.0.1
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 4
                CET +0100
                Etc/UTC
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Total:           21G         12G        6.0G
                         8002 M used memory
                          947 M free memory
                          311 M buffer memory
                         2973 M swap cache
                         9143 M total swap
                         4372 M used swap
                         4771 M free swap
                *** FILESYSTEM ***
                /var:
                34M     /var/
                32M     /var/lib
                19M     /var/lib/apt
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        22170
                States:         19042
                Pending Updates: 5
                X-Server:               false
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                MEMORY:
                Total:           21G         12G        5.9G
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                22170
                States:                 19042
                da habe ich keinerlei Aktien drin. ist mir zu kompliziert
                • wollerosekaufeW Offline
                  wollerosekaufe
                  hab mir den adapter spaßhalber einmal angesehen.
                  wenn ich den starte, einfach mal mit 127.0.0.1 als MQTT, sieht der debug log bei mir völlig anders aus:
                  twinkly.0
                  	2023-12-08 17:57:48.747	error	[test.interview.fw] Error: connect ECONNREFUSED 127.0.0.1:80
                  twinkly.0
                  	2023-12-08 17:57:48.744	debug	[test.request.GET] Error: "connect ECONNREFUSED 127.0.0.1:80", code="ECONNREFUSED", status=null, config="{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","X-Auth-Token":"","User-Agent":"axios/1.6.2","Content-Length":"4","Accept-Encoding":"gzip, compress, deflate, br"},"baseURL":"http://127.0.0.1/xled/v1/","url":"fw/version","method":"get","data":"null"}", stack="Error: connect ECONNREFUSED 127.0.0.1:80 at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:606:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12)"
                  twinkly.0
                  	2023-12-08 17:57:48.140	debug	[test.request.GET] path="fw/version", body="null", headers="{}"
                  twinkly.0
                  	2023-12-08 17:57:48.090	debug	[test.ping] Ping result for 127.0.0.1: true in 0.130ms
                  twinkly.0
                  	2023-12-08 17:57:48.033	debug	[ping.probe] System command: /bin/ping -n -w 2 -c 1 127.0.0.1
                  twinkly.0
                  	2023-12-08 17:57:48.028	debug	[poll] Start polling...
                  twinkly.0
                  	2023-12-08 17:57:48.024	debug	[processObjectChanges] No tasks to process!
                  twinkly.0
                  	2023-12-08 17:57:48.021	debug	[processObjectChanges] Prepare tasks of objects update
                  twinkly.0
                  	2023-12-08 17:57:48.018	debug	[processObjectChanges] Add instance objects
                  twinkly.0
                  	2023-12-08 17:57:48.016	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
                  twinkly.0
                  	2023-12-08 17:57:47.852	debug	[processObjectChanges] Get existing objects
                  twinkly.0
                  	2023-12-08 17:57:47.783	debug	[syncConfig] config network: false
                  twinkly.0
                  	2023-12-08 17:57:47.782	debug	[syncConfig] config mqtt: false
                  twinkly.0
                  	2023-12-08 17:57:47.781	debug	[syncConfig] config details: false
                  twinkly.0
                  	2023-12-08 17:57:47.780	debug	[syncConfig] config interval: 60
                  twinkly.0
                  	2023-12-08 17:57:47.777	debug	[syncConfig] config devices: [{"enabled":true,"name":"test","host":"127.0.0.1","stateOn":"color"}]
                  twinkly.0
                  	2023-12-08 17:57:47.728	info	starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.19.0, js-controller: 5.0.17
                  bei dir besteht der halbe log aus redis/objects, vom networking kommt wenig bis nix. wundert mich etwas...
                  wie sieht das bei dir denn aus wenn du mal eine zweite instanz aufmachst und dasselbe probierst?
                  "das mit docker" mag zwar vlt. nicht SO kompliziert sein, aber wie @homoran schon andeutet :D ohne exakte infos (networking) geht da nichts voran.
                  würde ins blaue hineinraten dass du in docker kein (host-)network definiert hast - oder der port f. twinkly fehlt (scheint über 80 zu gehen?! O_o)
                    base
                    @wollerosekaufe
                    vielen Dank, ich habe keine Ahnung was da im Docker definiert ist. Hab mich bei der Insatallation an die Anleitung von smarthome.buanet.de gehalten. Sonst funktioniert ja alles und der Adapter hat ja auch mal funktioniert. Hab jetzt das Script von @patrickbs96 https://github.com/patrickbs96/script.twinkly ausprobiert, damit kann ich die Lichterkette erstmal steuern.
                    patrickbs96P 1 Antwort Letzte Antwort
                    • B base
                      @wollerosekaufe
                      patrickbs96P Offline
                      patrickbs96
                      @base komisch das der Adapter bei dir nicht mehr funktioniert aber stattdessen das Skript. Ich hatte damals den Adapter anhand des Skripts erstellt.
                      Die Datenpunkte für eine Lichterkette werden erst erstellt, wenn eine Verbindung zu der Kette aufgebaut werden konnte. Entferne sonst mal den Haken bei "Ping für Erreichbarkeit verwenden", vielleicht klappt das ja
                      • patrickbs96P patrickbs96
                        base
                        @patrickbs96 geht leider auch nicht. Hab den Adapter nochmal deinstalliert und den Ping rausgenommen - ohne Erfolg. Es werden keine Datenpunkte angelegt.
                        Bei den Datenpunkten vom Script funktionieren alle ausser der "connected" State.
                          der-eine
                          Hallo zusammen, Hallo @patrickbs96,
                          wollte jetzt auch den Twinkly-Adapter installieren leider bleibt er bei mir auch gelb.
                          Meine Fehlermeldung ist aber eine andere und komme hier leider auch nicht weiter.
                          Hab auch ein Github Issue eröffnet.
                          Wäre super, wenn mir jemand dabei helfen könnte.
                          Danke.
                          Versions:
                          iobroker-Admin: 6.12.0
                          Adapter version: 1.0.14
                          JS-Controller version: 5.0.16
                          Node version: 16.17.0
                          Operating system: Debian 11 bullseye
                          Twinkly Version: 2.8.18
                          2023-12-14 12:11:51.101 - info: host.ioBroker "system.adapter.twinkly.0" enabled
                          2023-12-14 12:11:51.400 - info: host.ioBroker instance system.adapter.twinkly.0 started with pid 1474
                          2023-12-14 12:11:52.152 - debug: twinkly.0 (1474) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2023-12-14 12:11:52.212 - debug: twinkly.0 (1474) Objects client ready ... initialize now
                          2023-12-14 12:11:52.213 - debug: twinkly.0 (1474) Objects create System PubSub Client
                          2023-12-14 12:11:52.214 - debug: twinkly.0 (1474) Objects create User PubSub Client
                          2023-12-14 12:11:52.366 - debug: twinkly.0 (1474) Objects client initialize lua scripts
                          2023-12-14 12:11:52.370 - debug: twinkly.0 (1474) Objects connected to redis: 127.0.0.1:9001
                          2023-12-14 12:11:52.450 - debug: twinkly.0 (1474) Redis States: Use Redis connection: 127.0.0.1:9000
                          2023-12-14 12:11:52.483 - debug: twinkly.0 (1474) States create System PubSub Client
                          2023-12-14 12:11:52.484 - debug: twinkly.0 (1474) States create User PubSub Client
                          2023-12-14 12:11:52.546 - debug: twinkly.0 (1474) States connected to redis: 127.0.0.1:9000
                          2023-12-14 12:11:52.600 - debug: twinkly.0 (1474) Plugin sentry Initialize Plugin (enabled=true)
                          2023-12-14 12:11:52.831 - info: twinkly.0 (1474) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v16.17.0, js-controller: 5.0.16
                          2023-12-14 12:11:52.860 - debug: twinkly.0 (1474) [syncConfig] config devices: [{"enabled":true,"name":"Girlande","host":"192.168.20.100","stateOn":"color"}]
                          2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config interval: 60
                          2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config details: true
                          2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config mqtt: false
                          2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config network: true
                          2023-12-14 12:11:52.890 - debug: twinkly.0 (1474) [processObjectChanges] Get existing objects
                          2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
                          2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Add instance objects
                          2023-12-14 12:11:53.168 - debug: twinkly.0 (1474) [processObjectChanges] Prepare tasks of objects update
                          2023-12-14 12:11:53.169 - debug: twinkly.0 (1474) [processObjectChanges] No tasks to process!
                          2023-12-14 12:11:53.170 - debug: twinkly.0 (1474) [poll] Start polling...
                          2023-12-14 12:11:53.171 - debug: twinkly.0 (1474) [ping.probe] System command: /bin/ping -n -w 2 -c 1 192.168.20.100
                          2023-12-14 12:11:53.183 - error: twinkly.0 (1474) [Girlande.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
                          2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [checkConnection] Girlande is not available!
                          2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Girlande not connected!
                          2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Finished polling...
                          2023-12-14 12:11:53.229 - info: twinkly.0 (1474) Startup complete
                          • D der-eine
                            Danke.
                            Versions:
                            @der-eine
                            node: v16.17.0
                            Veraltet, abgekündigt.
                            Bring das auf nodejs@18.
                            Per
                            iob nodejs-update
                            • D der-eine
                              Danke.
                              Versions:
                              @der-eine
                              type -p ping
                              sudo -u iobroker ping iobroker.net
                              sagt?
                                @der-eine
                                type -p ping
                                sagt?
                                der-eine
                                @thomas-braun sagte in Twinkly Adapter bleibt gelb:
                                Update mach ich dann. Danke.
                                Hier die Ausgabe
                                daniel@ioBroker:~$ type -p ping
                                /usr/bin/ping
                                daniel@ioBroker:~$ sudo -u iobroker ping iobroker.net
                                [sudo] password for daniel:
                                daniel@ioBroker:~$
                                • D der-eine
                                  Hier die Ausgabe
                                  /usr/bin/ping
                                  daniel@ioBroker:~$
                                  @der-eine sagte in Twinkly Adapter bleibt gelb:
                                  Mach es jetzt. Ist überfällig.
                                  • D der-eine
                                    Hier die Ausgabe
                                    /usr/bin/ping
                                    daniel@ioBroker:~$
                                    @der-eine
                                    ping iobroker.net
                                      @der-eine
                                      ping iobroker.net
                                      der-eine
                                      ping iobroker.net
                                        der-eine
                                        schrieb am zuletzt editiert von der-eine
                                        Last login: Thu Dec 14 19:03:34 CET 2023 on tty1
                                        daniel@ioBroker:~$ node -v
                                        v18.19.0
                                        daniel@ioBroker:~$
                                        • D der-eine
                                          v18.19.0
                                          daniel@ioBroker:~$
                                          @der-eine
                                          Also dürfen user nicht pingen.
                                          Was ist das da genau für eine Umgebung?
                                          iob diag
                                          in der Langfassung.
