  4. Twinkly Adapter bleibt gelb
28 Beiträge 7 Kommentatoren 5.0k Aufrufe 6 Beobachtet
  • B base
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Diskstation
    Arbeitsspeicher: 11 GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 14.18.3
    Nodejs-Version: 14.18.3
    NPM-Version: 6.14.15
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    ich bekommen meinen Twinkly Adapter nicht mehr zum laufen. Hab ihn schon deinstalliert und gedowngradet, den Twinkly zurückgsetzt, IP geändert, alles ohne Erfolg...
    twinkly.0
    2022-12-25 13:54:57.340	info	Startup complete
    twinkly.0
    2022-12-25 13:54:57.340	debug	[poll] Finished polling...
    twinkly.0
    2022-12-25 13:54:57.339	debug	[poll] Twinkly not connected!
    twinkly.0
    2022-12-25 13:54:57.338	debug	[checkConnection] Twinkly is not available!
    twinkly.0
    2022-12-25 13:54:57.283	debug	[poll] Start polling...
    twinkly.0
    2022-12-25 13:54:57.281	debug	[processObjectChanges] No tasks to process!
    twinkly.0
    2022-12-25 13:54:57.280	debug	[processObjectChanges] Prepare tasks of objects update
    twinkly.0
    2022-12-25 13:54:57.278	debug	[processObjectChanges] Add instance objects
    twinkly.0
    2022-12-25 13:54:57.277	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
    twinkly.0
    2022-12-25 13:54:57.115	debug	[processObjectChanges] Get existing objects
    twinkly.0
    2022-12-25 13:54:57.050	debug	[syncConfig] config network: false
    twinkly.0
    2022-12-25 13:54:57.049	debug	[syncConfig] config mqtt: true
    twinkly.0
    2022-12-25 13:54:57.049	debug	[syncConfig] config details: true
    twinkly.0
    2022-12-25 13:54:57.048	debug	[syncConfig] config interval: 60
    twinkly.0
    2022-12-25 13:54:57.047	debug	[syncConfig] config devices: [{"enabled":true,"name":"Twinkly","host":"192.168.1.125","stateOn":"color"}]
    twinkly.0
    2022-12-25 13:54:57.018	info	starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.twinkly, node: v14.18.3, js-controller: 4.0.23
    twinkly.0
    2022-12-25 13:54:56.579	debug	Plugin sentry Initialize Plugin (enabled=true)
    twinkly.0
    2022-12-25 13:54:56.291	debug	States connected to redis: 127.0.0.1:9000
    twinkly.0
    2022-12-25 13:54:56.194	debug	States create User PubSub Client
    twinkly.0
    2022-12-25 13:54:56.193	debug	States create System PubSub Client
    twinkly.0
    2022-12-25 13:54:56.153	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    twinkly.0
    2022-12-25 13:54:56.096	debug	Objects connected to redis: 127.0.0.1:9001
    twinkly.0
    2022-12-25 13:54:56.090	debug	Objects client initialize lua scripts
    twinkly.0
    2022-12-25 13:54:55.964	debug	Objects create User PubSub Client
    twinkly.0
    2022-12-25 13:54:55.962	debug	Objects create System PubSub Client
    twinkly.0
    2022-12-25 13:54:55.960	debug	Objects client ready ... initialize now
    twinkly.0
    2022-12-25 13:54:55.901	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    MCU
    @base sagte in Twinkly Adapter bleibt gelb:
    14.18.3
    Empfohlene node-Version ist die v16.
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      base
      bin jetzt auf v16. Adapter bleibt weiterhin gelb...
      • B base
        MCU
        @base Wie sind denn die Einstellungen im twinkly-Adapter?
        Per App ist die Lichterkette steuerbar?
        Sind beide Geräte im gleichen Netzwerk? WLAN 2.4 GHz!
        Twinkly App -> Geräte -> Einstellungen -> Netzwerk?
        • B base
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          twinkly.0
          Hardwaresystem:
          Diskstation
          in Verbindung mit
          Betriebssystem:
          Ubuntu/Windows/Mac
          gibt mehr Fragen als Antworten.
          was sagt iob diag?
            Hardwaresystem:
            Diskstation
            in Verbindung mit
            Betriebssystem:
            Ubuntu/Windows/Mac
            was sagt iob diag?
            base
            muss das Thema jetzt vor Weihnachten nochmal aufgreifen. Nachdem ich das System vor kurzem neu aufgesetzt habe besteht der Fehler leider weiterhin. Via App habe ich über das Netzwerk Zugriff. Auch kann ich den Controller anpingen.
            iob diag:
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Hardware Vendor : Synology
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v9.0.1
            Virtualization  : Docker
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             15:46:13 up 19 days, 19:25,  0 user,  load average: 2.78, 3.00, 2.72
            CPU threads: 4
            *** Time and Time Zones ***
            Thu Dec  7 14:46:13 UTC 2023
            Thu Dec  7 15:46:13 CET 2023
            CET +0100
            Etc/UTC
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:             12G        8.4G        993M        105M        3.4G        4.0G
            Swap:           9.6G        4.6G        5.0G
            Total:           21G         12G        6.0G
                    11822 M total memory
                     8002 M used memory
                     3724 M active memory
                     4442 M inactive memory
                      947 M free memory
                      311 M buffer memory
                     2973 M swap cache
                     9143 M total swap
                     4372 M used swap
                     4771 M free swap
            *** FILESYSTEM ***
            Filesystem             Type   Size  Used Avail Use% Mounted on
            none                   aufs   2.7T  1.9T  826G  70% /
            tmpfs                  tmpfs   64M     0   64M   0% /dev
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
            shm                    tmpfs   64M     0   64M   0% /dev/shm
            /dev/mapper/cachedev_1 ext4   2.7T  1.9T  826G  70% /opt/iobroker
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
            TARGET             SOURCE  FSTYPE OPTIONS
            /                  none  aufs   rw,relatime,si=d721e7829fc3c919,dio,dirperm1
            |-/opt/iobroker    /dev/mapper/cachedev_1[/docker/iobrokerv5_data]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
            |-/etc/resolv.conf /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
            |-/etc/hostname    /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/hostname]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
            `-/etc/hosts       /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/hosts]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
            /var:
            34M     /var/
            32M     /var/lib
            19M     /var/lib/apt/lists
            19M     /var/lib/apt
            13M     /var/lib/dpkg/info
            /opt/iobroker/backups:
            81M     /opt/iobroker/backups/
            4.0K    /opt/iobroker/backups/influxDB_2020_12_12-02_00_26_backupiobroker
            4.0K    /opt/iobroker/backups/influxDB_2020_12_11-02_00_27_backupiobroker
            4.0K    /opt/iobroker/backups/influxDB_2020_12_10-02_00_25_backupiobroker
            4.0K    /opt/iobroker/backups/influxDB_2020_12_09-02_00_27_backupiobroker
            /opt/iobroker/iobroker-data:
            771M    /opt/iobroker/iobroker-data/
            604M    /opt/iobroker/iobroker-data/files
            115M    /opt/iobroker/iobroker-data/backup-objects
            90M     /opt/iobroker/iobroker-data/files/echarts.admin
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            34M     /opt/iobroker/iobroker-data/objects.jsonl
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
            USB-Devices by-id:
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.18.2
            /usr/bin/node           v18.18.2
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            /usr/bin/corepack       0.19.0
            nodejs:
              Installed: 18.18.2-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                 18.19.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             *** 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
            No problems detected
            Errors in npm tree:
            npm ERR! code ELSPROBLEMS
            npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@7.1.6
            npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-12-07T14_46_20_632Z-debug-0.log
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.16
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   6
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker_v5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker_v5                              -  enabled
              system.adapter.alias-manager.0          : alias-manager         : iobroker_v5                              - disabled
            + system.adapter.backitup.0               : backitup              : iobroker_v5                              -  enabled
              system.adapter.ble.0                    : ble                   : iobroker_v5                              - disabled
            + system.adapter.bring.0                  : bring                 : iobroker_v5                              -  enabled
            + system.adapter.countdown.0              : countdown             : iobroker_v5                              -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker_v5                              -  enabled
            + system.adapter.denon.0                  : denon                 : iobroker_v5                              -  enabled
              system.adapter.devices.0                : devices               : iobroker_v5                              - disabled
            + system.adapter.discovery.0              : discovery             : iobroker_v5                              -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker_v5                              -  enabled
            + system.adapter.echarts.0                : echarts               : iobroker_v5                              -  enabled
            + system.adapter.enigma2.0                : enigma2               : iobroker_v5                              -  enabled
              system.adapter.flot.0                   : flot                  : iobroker_v5                              - disabled
            + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker_v5                              -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : iobroker_v5                              - disabled
            + system.adapter.harmony.0                : harmony               : iobroker_v5                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker_v5                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker_v5                              -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker_v5                              -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : iobroker_v5                              -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker_v5                              -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker_v5                              - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker_v5                              - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker_v5                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker_v5                              - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker_v5                              -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker_v5                              -  enabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : iobroker_v5                              -  enabled, port: 8087
            + system.adapter.info.0                   : info                  : iobroker_v5                              -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker_v5                              -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker_v5                              -  enabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker_v5                              -  enabled, port: 54321
            + system.adapter.mihome.0                 : mihome                : iobroker_v5                              -  enabled, port: 9898, bind: 192.168.1.120
            + system.adapter.mytime.0                 : mytime                : iobroker_v5                              -  enabled
            + system.adapter.mytime.1                 : mytime                : iobroker_v5                              -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker_v5                              -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : iobroker_v5                              -  enabled
            + system.adapter.pvforecast.0             : pvforecast            : iobroker_v5                              -  enabled
              system.adapter.pvforecast.1             : pvforecast            : iobroker_v5                              - disabled
              system.adapter.rtspStream.0             : rtspStream            : iobroker_v5                              - disabled, port: 554
            + system.adapter.sayit.3                  : sayit                 : iobroker_v5                              -  enabled
            + system.adapter.senec.0                  : senec                 : iobroker_v5                              -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker_v5                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker_v5                              -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker_v5                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.snmp.0                   : snmp                  : iobroker_v5                              -  enabled
            + system.adapter.sonoff.0                 : sonoff                : iobroker_v5                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker_v5                              -  enabled
              system.adapter.sql.0                    : sql                   : iobroker_v5                              - disabled, port: 0
            + system.adapter.statistics.0             : statistics            : iobroker_v5                              -  enabled
            + system.adapter.synology.0               : synology              : iobroker_v5                              -  enabled, port: 5001
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker_v5                              -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker_v5                              -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.terminal.0               : terminal              : iobroker_v5                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
            + system.adapter.text2command.0           : text2command          : iobroker_v5                              -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker_v5                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker_v5                              -  enabled
            + system.adapter.twinkly.0                : twinkly               : iobroker_v5                              -  enabled
            + system.adapter.upnp.0                   : upnp                  : iobroker_v5                              -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker_v5                              - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker_v5                              - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker_v5                              - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker_v5                              - disabled
              system.adapter.vis-history.0            : vis-history           : iobroker_v5                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker_v5                              - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker_v5                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker_v5                              - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker_v5                              - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker_v5                              -  enabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker_v5                              - disabled
              system.adapter.vis-players.0            : vis-players           : iobroker_v5                              - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker_v5                              - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker_v5                              - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker_v5                              - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker_v5                              - disabled
              system.adapter.vis.0                    : vis                   : iobroker_v5                              -  enabled
            + system.adapter.web.0                    : web                   : iobroker_v5                              -  enabled, port: 8082, bind: 192.168.1.120, run as: admin
            + system.adapter.worx.0                   : worx                  : iobroker_v5                              -  enabled
            + system.adapter.ws.0                     : ws                    : iobroker_v5                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "ble"          : 0.13.4   , installed 0.13.4
            Adapter    "bring"        : 1.8.4    , installed 1.8.4
            Adapter    "countdown"    : 2.2.0    , installed 2.2.0
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "denon"        : 1.15.4   , installed 1.15.4
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
            Adapter    "echarts"      : 1.5.4    , installed 1.5.4
            Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
            Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
            Adapter    "harmony"      : 1.3.0    , installed 1.3.0
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "ical"         : 1.13.3   , installed 1.13.3
            Adapter    "info"         : 2.0.0    , installed 2.0.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.16   , installed 5.0.16
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
            Adapter    "sayit"        : 3.0.5    , installed 3.0.5
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
            Adapter    "snmp"         : 3.1.0    , installed 3.1.0
            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
            Adapter    "synology"     : 3.0.1    , installed 3.0.1
            Adapter    "telegram"     : 2.0.1    , installed 2.0.1
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
            Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-icontwo"  : 0.98.0   , installed 0.97.1 [Updatable]
            Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "worx"         : 2.3.4    , installed 2.3.4
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Objects and States
            Objects:        22170
            States:         19042
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 5
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       183619990  -
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       183627488  -
            tcp        0      0 127.0.0.11:36422        0.0.0.0:*               LISTEN      0          183606762  -
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       183612197  -
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       183612171  -
            tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       183620056  -
            tcp        0      0 192.168.1.120:8082      0.0.0.0:*               LISTEN      1000       184474196  -
            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       183643690  -
            tcp6       0      0 :::8088                 :::*                    LISTEN      1000       183649454  -
            tcp6       0      0 :::61991                :::*                    LISTEN      1000       183637426  -
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       183901599  -
            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       184473591  -
            udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       308708822  -
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       183654037  -
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       183654036  -
            udp        0      0 127.0.0.11:45171        0.0.0.0:*                           0          183606761  -
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       318795020  -
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       183637427  -
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       183624888  -
            udp        0      0 0.0.0.0:38624           0.0.0.0:*                           1000       183646509  -
            udp        0      0 0.0.0.0:40335           0.0.0.0:*                           1000       183646510  -
            2023-12-07 15:38:17.656  - info: host.iobroker_v5 stopInstance system.adapter.twinkly.0 send kill signal
            2023-12-07 15:38:17.902  - info: twinkly.0 (24461) terminating
            2023-12-07 15:38:17.904  - info: twinkly.0 (24461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-12-07 15:38:18.606  - info: host.iobroker_v5 instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-07 15:38:20.902  - info: host.iobroker_v5 instance system.adapter.twinkly.0 started with pid 19716
            2023-12-07 15:38:23.638  - info: twinkly.0 (19716) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.18.2, js-controller: 5.0.16
            2023-12-07 15:38:24.129  - info: twinkly.0 (19716) Startup complete
            2023-12-07 15:40:00.108  - info: host.iobroker_v5 instance system.adapter.dwd.0 started with pid 19918
            2023-12-07 15:40:06.229  - info: host.iobroker_v5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-07 15:42:22.991  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] connection closed: closed
            2023-12-07 15:42:35.315  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] connected with secret 1701960155314_670
            2023-12-07 15:43:39.038  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] reconnected. Old secret 1701960155314_670. New secret1701960219038_8074
            2023-12-07 15:44:42.756  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] reconnected. Old secret 1701960219038_8074. New secret 1701960281472_8737
            2023-12-07 15:45:00.148  - info: host.iobroker_v5 instance system.adapter.dwd.0 started with pid 21081
            2023-12-07 15:45:04.245  - info: host.iobroker_v5 instance system.adapter.daswetter.0 started with pid 21108
            2023-12-07 15:45:06.229  - info: host.iobroker_v5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-07 15:45:15.916  - info: host.iobroker_v5 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-07 15:45:48.461  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends publish. Ignore! Actual secret is 1701960281472_8737
            2023-12-07 15:45:48.462  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends publish. Ignore! Actual secret is 1701960281472_8737
            2023-12-07 15:45:48.462  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends subscribe. Ignore! Actual secret is 1701960281472_8737
            2023-12-07 15:45:48.463  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends pingreq. Ignore! Actual secret is 1701960281472_8737
            ======================= SUMMARY =======================                        v.2023-10-10
            model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHzKernel          : x86_64
            Userland        : amd64Docker          : v9.0.1
            Installation:           Docker
            Kernel:                 x86_64Userland:               amd64
            Timezone:               Etc/UTCUser-ID:                0
            X-Server:               false
            Pending OS-Updates:     5
            Pending iob updates:    1
            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            MEMORY:
            Mem:             12G        8.4G        862M        105M        3.6G        4.0G
            Total:           21G         12G        5.9G
            Active iob-Instances:   49
            ioBroker Core:          js-controller           5.0.16
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                22170
            States:                 19042
            Size of iob-Database:
            22M     /opt/iobroker/iobroker-data/states.jsonl
            • B base
              iob diag:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.0.1
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
              CET +0100
              Etc/UTC
              root
              /root
              root
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Total:           21G         12G        6.0G
                       8002 M used memory
                        947 M free memory
                        311 M buffer memory
                       2973 M swap cache
                       9143 M total swap
                       4372 M used swap
                       4771 M free swap
              *** FILESYSTEM ***
              /var:
              34M     /var/
              32M     /var/lib
              19M     /var/lib/apt
              USB-Devices by-id:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        22170
              States:         19042
              Pending Updates: 5
              X-Server:               false
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
              MEMORY:
              Total:           21G         12G        5.9G
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                22170
              States:                 19042
              da habe ich keinerlei Aktien drin. ist mir zu kompliziert
              • wollerosekaufeW Offline
                wollerosekaufe
                hab mir den adapter spaßhalber einmal angesehen.
                wenn ich den starte, einfach mal mit 127.0.0.1 als MQTT, sieht der debug log bei mir völlig anders aus:
                twinkly.0
                	2023-12-08 17:57:48.747	error	[test.interview.fw] Error: connect ECONNREFUSED 127.0.0.1:80
                twinkly.0
                	2023-12-08 17:57:48.744	debug	[test.request.GET] Error: "connect ECONNREFUSED 127.0.0.1:80", code="ECONNREFUSED", status=null, config="{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","X-Auth-Token":"","User-Agent":"axios/1.6.2","Content-Length":"4","Accept-Encoding":"gzip, compress, deflate, br"},"baseURL":"http://127.0.0.1/xled/v1/","url":"fw/version","method":"get","data":"null"}", stack="Error: connect ECONNREFUSED 127.0.0.1:80 at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:606:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12)"
                twinkly.0
                	2023-12-08 17:57:48.140	debug	[test.request.GET] path="fw/version", body="null", headers="{}"
                twinkly.0
                	2023-12-08 17:57:48.090	debug	[test.ping] Ping result for 127.0.0.1: true in 0.130ms
                twinkly.0
                	2023-12-08 17:57:48.033	debug	[ping.probe] System command: /bin/ping -n -w 2 -c 1 127.0.0.1
                twinkly.0
                	2023-12-08 17:57:48.028	debug	[poll] Start polling...
                twinkly.0
                	2023-12-08 17:57:48.024	debug	[processObjectChanges] No tasks to process!
                twinkly.0
                	2023-12-08 17:57:48.021	debug	[processObjectChanges] Prepare tasks of objects update
                twinkly.0
                	2023-12-08 17:57:48.018	debug	[processObjectChanges] Add instance objects
                twinkly.0
                	2023-12-08 17:57:48.016	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
                twinkly.0
                	2023-12-08 17:57:47.852	debug	[processObjectChanges] Get existing objects
                twinkly.0
                	2023-12-08 17:57:47.783	debug	[syncConfig] config network: false
                twinkly.0
                	2023-12-08 17:57:47.782	debug	[syncConfig] config mqtt: false
                twinkly.0
                	2023-12-08 17:57:47.781	debug	[syncConfig] config details: false
                twinkly.0
                	2023-12-08 17:57:47.780	debug	[syncConfig] config interval: 60
                twinkly.0
                	2023-12-08 17:57:47.777	debug	[syncConfig] config devices: [{"enabled":true,"name":"test","host":"127.0.0.1","stateOn":"color"}]
                twinkly.0
                	2023-12-08 17:57:47.728	info	starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.19.0, js-controller: 5.0.17
                bei dir besteht der halbe log aus redis/objects, vom networking kommt wenig bis nix. wundert mich etwas...
                wie sieht das bei dir denn aus wenn du mal eine zweite instanz aufmachst und dasselbe probierst?
                "das mit docker" mag zwar vlt. nicht SO kompliziert sein, aber wie @homoran schon andeutet :D ohne exakte infos (networking) geht da nichts voran.
                würde ins blaue hineinraten dass du in docker kein (host-)network definiert hast - oder der port f. twinkly fehlt (scheint über 80 zu gehen?! O_o)
                  base
                  @wollerosekaufe
                  vielen Dank, ich habe keine Ahnung was da im Docker definiert ist. Hab mich bei der Insatallation an die Anleitung von smarthome.buanet.de gehalten. Sonst funktioniert ja alles und der Adapter hat ja auch mal funktioniert. Hab jetzt das Script von @patrickbs96 https://github.com/patrickbs96/script.twinkly ausprobiert, damit kann ich die Lichterkette erstmal steuern.
                  patrickbs96P 1 Antwort Letzte Antwort
                  • B base
                    @wollerosekaufe
                    patrickbs96P Offline
                    patrickbs96
                    @base komisch das der Adapter bei dir nicht mehr funktioniert aber stattdessen das Skript. Ich hatte damals den Adapter anhand des Skripts erstellt.
                    Die Datenpunkte für eine Lichterkette werden erst erstellt, wenn eine Verbindung zu der Kette aufgebaut werden konnte. Entferne sonst mal den Haken bei "Ping für Erreichbarkeit verwenden", vielleicht klappt das ja
                    • patrickbs96P patrickbs96
                      base
                      @patrickbs96 geht leider auch nicht. Hab den Adapter nochmal deinstalliert und den Ping rausgenommen - ohne Erfolg. Es werden keine Datenpunkte angelegt.
                      Bei den Datenpunkten vom Script funktionieren alle ausser der "connected" State.
                        der-eine
                        Hallo zusammen, Hallo @patrickbs96,
                        wollte jetzt auch den Twinkly-Adapter installieren leider bleibt er bei mir auch gelb.
                        Meine Fehlermeldung ist aber eine andere und komme hier leider auch nicht weiter.
                        Hab auch ein Github Issue eröffnet.
                        Wäre super, wenn mir jemand dabei helfen könnte.
                        Danke.
                        Versions:
                        iobroker-Admin: 6.12.0
                        Adapter version: 1.0.14
                        JS-Controller version: 5.0.16
                        Node version: 16.17.0
                        Operating system: Debian 11 bullseye
                        Twinkly Version: 2.8.18
                        2023-12-14 12:11:51.101 - info: host.ioBroker "system.adapter.twinkly.0" enabled
                        2023-12-14 12:11:51.400 - info: host.ioBroker instance system.adapter.twinkly.0 started with pid 1474
                        2023-12-14 12:11:52.152 - debug: twinkly.0 (1474) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-12-14 12:11:52.212 - debug: twinkly.0 (1474) Objects client ready ... initialize now
                        2023-12-14 12:11:52.213 - debug: twinkly.0 (1474) Objects create System PubSub Client
                        2023-12-14 12:11:52.214 - debug: twinkly.0 (1474) Objects create User PubSub Client
                        2023-12-14 12:11:52.366 - debug: twinkly.0 (1474) Objects client initialize lua scripts
                        2023-12-14 12:11:52.370 - debug: twinkly.0 (1474) Objects connected to redis: 127.0.0.1:9001
                        2023-12-14 12:11:52.450 - debug: twinkly.0 (1474) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-12-14 12:11:52.483 - debug: twinkly.0 (1474) States create System PubSub Client
                        2023-12-14 12:11:52.484 - debug: twinkly.0 (1474) States create User PubSub Client
                        2023-12-14 12:11:52.546 - debug: twinkly.0 (1474) States connected to redis: 127.0.0.1:9000
                        2023-12-14 12:11:52.600 - debug: twinkly.0 (1474) Plugin sentry Initialize Plugin (enabled=true)
                        2023-12-14 12:11:52.831 - info: twinkly.0 (1474) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v16.17.0, js-controller: 5.0.16
                        2023-12-14 12:11:52.860 - debug: twinkly.0 (1474) [syncConfig] config devices: [{"enabled":true,"name":"Girlande","host":"192.168.20.100","stateOn":"color"}]
                        2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config interval: 60
                        2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config details: true
                        2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config mqtt: false
                        2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config network: true
                        2023-12-14 12:11:52.890 - debug: twinkly.0 (1474) [processObjectChanges] Get existing objects
                        2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
                        2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Add instance objects
                        2023-12-14 12:11:53.168 - debug: twinkly.0 (1474) [processObjectChanges] Prepare tasks of objects update
                        2023-12-14 12:11:53.169 - debug: twinkly.0 (1474) [processObjectChanges] No tasks to process!
                        2023-12-14 12:11:53.170 - debug: twinkly.0 (1474) [poll] Start polling...
                        2023-12-14 12:11:53.171 - debug: twinkly.0 (1474) [ping.probe] System command: /bin/ping -n -w 2 -c 1 192.168.20.100
                        2023-12-14 12:11:53.183 - error: twinkly.0 (1474) [Girlande.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
                        2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [checkConnection] Girlande is not available!
                        2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Girlande not connected!
                        2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Finished polling...
                        2023-12-14 12:11:53.229 - info: twinkly.0 (1474) Startup complete
                        • D der-eine
                          Danke.
                          Versions:
                          @der-eine
                          node: v16.17.0
                          Veraltet, abgekündigt.
                          Bring das auf nodejs@18.
                          Per
                          iob nodejs-update
                          • D der-eine
                            Danke.
                            Versions:
                            @der-eine
                            type -p ping
                            sudo -u iobroker ping iobroker.net
                            sagt?
                              @der-eine
                              type -p ping
                              sagt?
                              der-eine
                              @thomas-braun sagte in Twinkly Adapter bleibt gelb:
                              Update mach ich dann. Danke.
                              Hier die Ausgabe
                              daniel@ioBroker:~$ type -p ping
                              /usr/bin/ping
                              daniel@ioBroker:~$ sudo -u iobroker ping iobroker.net
                              [sudo] password for daniel:
                              daniel@ioBroker:~$
                              • D der-eine
                                Hier die Ausgabe
                                /usr/bin/ping
                                daniel@ioBroker:~$
                                @der-eine sagte in Twinkly Adapter bleibt gelb:
                                Mach es jetzt. Ist überfällig.
                                • D der-eine
                                  Hier die Ausgabe
                                  /usr/bin/ping
                                  daniel@ioBroker:~$
                                  @der-eine
                                  ping iobroker.net
                                    @der-eine
                                    ping iobroker.net
                                    der-eine
                                    ping iobroker.net
                                      der-eine
                                      schrieb am zuletzt editiert von der-eine
                                      Last login: Thu Dec 14 19:03:34 CET 2023 on tty1
                                      daniel@ioBroker:~$ node -v
                                      v18.19.0
                                      daniel@ioBroker:~$
                                      • D der-eine
                                        v18.19.0
                                        daniel@ioBroker:~$
                                        @der-eine
                                        Also dürfen user nicht pingen.
                                        Was ist das da genau für eine Umgebung?
                                        iob diag
                                        in der Langfassung.
                                          @der-eine
                                          iob diag
                                          in der Langfassung.
                                          der-eine
                                          iob diag
                                          was brauchst Du davon alles?
