  4. [gelöst] Canvas - compiled against a different Node.js vers,
    apollon77A
103 Beiträge 4 Kommentatoren 23.1k Aufrufe 3 Beobachtet
  • A anno171986
    @mickym said in Canvas -> compiled against a different Node.js version:
    systemctl status mysql
    pi@raspberrypi:~$ systemctl status mysql
    ● mariadb.service - MariaDB 10.5.15 database server
         Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2022-11-20 17:40:49 CET; 24min ago
           Docs: man:mariadbd(8)
                 https://mariadb.com/kb/en/library/systemd/
        Process: 545 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
        Process: 555 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
        Process: 576 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set>
        Process: 685 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
        Process: 688 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
       Main PID: 665 (mariadbd)
         Status: "Taking your SQL requests now..."
          Tasks: 8 (limit: 4915)
            CPU: 2.701s
         CGroup: /system.slice/mariadb.service
                 └─665 /usr/sbin/mariadbd
    Nov 20 17:40:49 raspberrypi systemd[1]: Started MariaDB 10.5.15 database server.
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[690]: Upgrading MySQL tables if necessary.
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[693]: /usr/bin/mysql_upgrade: the '--basedir' option is always ignored
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[693]: Looking for 'mysql' as: /usr/bin/mysql
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[693]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[693]: This installation of MariaDB is already upgraded to 10.5.15-MariaDB.
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[693]: There is no need to run mysql_upgrade again for 10.5.15-MariaDB.
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[693]: You can use --force if you still want to run mysql_upgrade
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[701]: Checking for insecure root accounts.
    Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[705]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
    Scheint zu laufen. Jetzt muss ich wirklich los
    mickymM
    mickymM
    mickym
    #41
    @anno171986 Ok - dann viel Spaß.
    • mickymM mickym
      @anno171986 Na ich sehe Du bist auch noch auf buster und altem Betriebssystem. Man könnte nochmal versuchen, dass komplette nodejs runterzuschmeissen und neu zu installieren. Im Prinzip scheitert die Installation vom dem canvas ja an irgendeinem Module der node-js.
      Wie gesagt - wenn Du eh nichts mehr zu verlieren hast, würde ich das noch versuchen.
      Also iob stoppen - nodejs deinstallieren die ganzen npm Verzeichnisse manuell löschen und nodejs neu installieren.
      also
      sudo apt remove nodejs
      dann schauen, ob
      nodejs -v
      npm -v
      keine Ausgaben mehr liefert und unter /usr/lib keine node_modules Verzeichnis mehr gibt.
      Wenn alles weg ist - dann mit
      sudo apt install nodejs
      wieder installieren
      Ich habe den echarts Adapter auf meiner Testmaschine installiert ohne Probleme - das canvas Verzeichnis taucht dann auch auf. Also wie gesagt denke ich, dass da irgendwas uralt ist, deswegen bekommst Du da auch keinen schönen Baum hin. - Ab jetzt bin ich mit meiner Weisheit denke ich auch am Ende.
      A
      A
      anno171986
      #42
      also
      dann schauen, ob
      nodejs -v
      npm -v
      wieder installieren
      Ich probiere jetzt erstmal das mit nodejs zu machen. DIe MySQl DAtenbank sehe ich erstmal als nachgelagert Problem an.
      • mickymM mickym
        also
        dann schauen, ob
        nodejs -v
        npm -v
        wieder installieren
        A
        A
        anno171986
        #43
        @mickym Es gibt noch einen node_modules Ordner in /usr/lib/.
        pi@raspberrypi:/usr/lib/node_modules$ ls
        n  node-gyp  npm
        Einfach mit
        rm node_modules
        löschen?
        • A
          A
          anno171986
          schrieb am zuletzt editiert von anno171986
          #44
          @mickym
          habe den Ordner /usr/lib/node_modules mittels
          sudo rm -r node_modules
          gelöscht.
          danach dann nodejs neuinstalliert, eCharts Adapter deinstalliert, das hate etwas länger gedauert und er hat dabei auch was installiert. Habe dann aus Neugier mal nach canvas gesucht:
          pi@raspberrypi:/opt/iobroker$ npm ls canvas
          iobroker.core@1.0.0 /opt/iobroker
          ├─┬ iobroker.iot@1.11.9
          │ ├── canvas@2.10.2
          │ └─┬ jsdom@19.0.0
          │   └── canvas@2.10.2 deduped
          └─┬ iobroker.mihome-vacuum@3.8.6
          Und er hat es wohl installiert.
          Danach dann den eCharts Adapter installiert. Canvas Abfrage sieht jetzt so aus:
          ├─┬ iobroker.echarts@1.0.12
          │ ├── canvas@2.10.2
          │ └─┬ jsdom@19.0.0
          Verglichen zu meiner Ausgangssituation hat er jetzt canvas von Version 2.9.3 auf 2.10.2 geupdated.
          Das Skript zum erzeugen des Diagramm Bildes gestartet: Kein Fehler. Aber: Jetzt ist SQl das Problem, da keine SQL Adapter läuft ist auch kein Diagramm da. Hast du eine Idee wie ich die SQL DAtenbank wieder ans laufen bekomme?
               Active: active (running) since Sun 2022-11-20 17:40:49 CET; 16h ago
              Process: 576 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $?>    Process: 685 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
                  CPU: 17.251s
          Nov 20 17:40:49 raspberrypi /etc/mysql/debian-start[705]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tabl>~
          • A anno171986
            @mickym
            gelöscht.
            │ ├── canvas@2.10.2
            │ └─┬ jsdom@19.0.0
            │ ├── canvas@2.10.2
            │ └─┬ jsdom@19.0.0
                    CPU: 17.251s
            mickymM
            mickymM
            mickym
            #45
            @anno171986 na erst mal Glückwunsch, das war doch das Hauptproblem. Canvas unter dem charts Adapter ist genau richtig. Der MySQL läuft ja eigentlich. Hast du schon mal versucht, die Daten aus einem MySQL Backup wieder herzustellen? (aus backitup Adapter)? Ansonsten musst mal googlen, wie man das Root Passwort des MySQL Servers zurücksetzt, da muss man ein paar Befehle auf der Kommandozeile eingeben. Meines Erachtens läuft die Datenbank ja und du hast ein Problem mit der Authentifizierung.
            A 1 Antwort Letzte Antwort
            • mickymM mickym
              A
              A
              anno171986
              #46
              @mickym Denke ich auch.
              Wenn ich mich per Konsole einlogge scheint es zu gehen:
              pi@raspberrypi:/opt/iobroker$ mariadb -u iobroker -p
              Enter password:
              Welcome to the MariaDB monitor.  Commands end with ; or \g.
              Your MariaDB connection id is 33
              Server version: 10.5.15-MariaDB-0+deb11u1 Raspbian 11
              Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
              Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
              MariaDB [(none)]>
              • A anno171986
                Enter password:
                MariaDB [(none)]>
                mickymM
                mickymM
                mickym
                #47
                @anno171986 gib mal im Adapter nochmal das Passwort ein. Das muss gehen oder auch nochmal Port 3306 etc. du musst aber auch Mel schauen, ob du auf der Kommandozeile die iobroker Datenbank Listen kannst. Wie gesagt im backitup müsstest du doch MySQL Datenbanken gesondert gesichert haben.
                • mickymM mickym
                  A
                  A
                  anno171986
                  #48
                  @mickym Geht nicht. Bin jetzt via Konsole mal in die entsprechende DB gegangen, das geht.
                  MariaDB [(none)]> \u iobroker
                  Reading table information for completion of table and column names
                  You can turn off this feature to get a quicker startup with -A
                  Database changed
                  MariaDB [iobroker]> \s
                  mariadb  Ver 15.1 Distrib 10.5.15-MariaDB, for debian-linux-gnueabihf (armv8l) using  EditLine wrapper
                  Connection id:          33
                  Current database:       iobroker
                  Current user:           iobroker@localhost
                  SSL:                    Not in use
                  Current pager:          stdout
                  Using outfile:          ''
                  Using delimiter:        ;
                  Server:                 MariaDB
                  Protocol version:       10
                  Connection:             Localhost via UNIX socket
                  Server characterset:    utf8mb4
                  Db     characterset:    utf8
                  Client characterset:    utf8
                  Conn.  characterset:    utf8
                  UNIX socket:            /run/mysqld/mysqld.sock
                  Uptime:                 16 hours 47 min 30 sec
                  Threads: 1  Questions: 71  Slow queries: 0  Opens: 38  Open tables: 31  Queries per second avg: 0.001
                  kann man sich anzeigen lassen, auf welchen port die DB hört?
                  • A anno171986
                    Database changed
                    Connection id:          33
                    SSL:                    Not in use
                    Using outfile:          ''
                    Using delimiter:        ;
                    Server:                 MariaDB
                    mickymM
                    mickymM
                    mickym
                    #49
                    @anno171986 normalerweise 3306. prüfe mit
                    sudo netstat -tulpen
                    Ansonsten erstellst mal auf der Kommandozeile einen neuen User, der sich von überall anmelden kann und alle Rechte hat.
                    A 2 Antworten Letzte Antwort
                    • mickymM mickym
                      A
                      A
                      anno171986
                      #50
                      Jup, das scheint zu stimmen:
                      pi@raspberrypi:~$ sudo netstat -tulpen
                      Aktive Internetverbindungen (Nur Server)
                      Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          16392      753/python3
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1666679    18855/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1667670    18855/iobroker.js-c
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12785      567/sshd: /usr/sbin
                      tcp        0      0 192.168.178.12:8087     0.0.0.0:*               LISTEN      1001       1670571    19450/io.simple-api
                      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          15566      381/connmand
                      tcp        0      0 0.0.0.0:52050           0.0.0.0:*               LISTEN      1000       12926      393/MyMediaForAlexa
                      tcp        0      0 0.0.0.0:52051           0.0.0.0:*               LISTEN      1000       12922      393/MyMediaForAlexa
                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1668091    19115/io.mqtt.0
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          701845     15500/cupsd
                      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        11727      665/mariadbd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12795      567/sshd: /usr/sbin
                      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12740      557/xrdp-sesman
                      tcp6       0      0 :::3389                 :::*                    LISTEN      110        14899      599/xrdp
                      tcp6       0      0 :::4369                 :::*                    LISTEN      0          13938      1/init
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          701844     15500/cupsd
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1668847    19370/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1666752    18887/io.admin.0
                      tcp6       0      0 ::1:53                  :::*                    LISTEN      0          15570      381/connmand
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1668351    18984/io.mihome-vac
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14047      378/avahi-daemon: r
                      udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          15558      381/connmand
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12164      452/dhcpcd
                      udp        0      0 0.0.0.0:51299           0.0.0.0:*                           0          15890      381/connmand
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          703638     15501/cups-browsed
                      udp        0      0 0.0.0.0:49800           0.0.0.0:*                           108        14049      378/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        14048      378/avahi-daemon: r
                      udp6       0      0 :::58705                :::*                                108        14050      378/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          16390      452/dhcpcd
                      udp6       0      0 ::1:53                  :::*                                0          15562      381/connmand
                      • mickymM mickym
                        A
                        A
                        anno171986
                        #51
                        @mickym Ich ahbe im SQl Adapter mal meine RPI Adresse 192.168.178.12 durch die 127.0.0.1 ersetzt, jetzt funktioniert es.
                        • A anno171986
                          mickymM
                          mickymM
                          mickym
                          #52
                          @anno171986 ja schaut gut aus. Für mich ist das ein Berechtigungsproblem. Entweder passt das Passwort im Adapter nicht, oder der Benutzer ist limitiert.
                          • A anno171986
                            mickymM
                            mickymM
                            mickym
                            #53
                            @anno171986 sagte in Canvas -> compiled against a different Node.js version:
                            Na dann ist hat der User nur das Recht sich nur Lokal anzumelden. Dann solltest nun am wieder deine Verlaufsdaten sehen. Glückwunsch
                            • mickymM mickym
                              A
                              A
                              anno171986
                              #54
                              @mickym 📈
                              eChart funktioniert, und noch viel wichtiger: Ich habe gerade das Bild per Telegram bekommen 🍾
                              • A anno171986
                                @mickym 📈
                                mickymM
                                mickymM
                                mickym
                                #55
                                @mickym 📈
                                Na dann haben sich die Mühen doch letztlich ausgezahlt. Dann sofort das Image sichern und Dein System lieber regelmäßig aktuell halten.
                                • mickymM mickym
                                  A
                                  A
                                  anno171986
                                  #56
                                  @mickym Jetzt ist die Frage wie ich das mit den recht wieder ändere. Mit HeidiSQL kann ich nämlich immer noch nicht drauf zugreifen.
                                  • mickymM mickym
                                    @mickym 📈
                                    A
                                    A
                                    anno171986
                                    #57
                                    @mickym mit den aktuell hatte ich ja soweit, nur dass ich quasi das OS nicht geupdated hatte, hatte das nicht auf den Plan, wie man das macht und wusste auch nicht, dass es überhaupt eine neue Version gibt.
                                    • A anno171986
                                      mickymM
                                      mickymM
                                      mickym
                                      #58
                                      @anno171986 na ich würde halt mit dem Root User nun einen neuen Admin auf der Kommandozeile definieren, der sich von überall anmelden kann und den für die HeidiSql Anmeldung verwenden.
                                      • A anno171986
                                        Thomas BraunT
                                        Thomas BraunT
                                        #59
                                        @anno171986
                                        Dann kannst du ja jetzt auch den Desktop-Quatsch auf dem Server ausschalten.
                                          @anno171986
                                          A
                                          A
                                          anno171986
                                          #60
                                          @thomas-braun said in [gelöst] Canvas - compiled against a different Node.js vers,:
                                          @anno171986
                                          Was genau meinst du damit?
                                          Zur Info: Ich programmiere ab- und zu was via python auf dem RPi und dazu benutze ich die remotedesktopverbindung.
                                          84.0k
                                          1.4m
