  4. Ring Doorbell Adapter
ringdoorbellring adapter
160 Beiträge 31 Kommentatoren 45.5k Aufrufe 26 Beobachtet
  • M ManiacKill
    Ok Danke, hab jetzt wieder auf 9.8.1 stehen 👍 Der Fehler vom Adapter bleibt !
    #41
    @maniackill
    Bei mir baut der Adapter im ersten Anlauf. Gar kein Problem mit konsistentem Setup von nodejs&Co...
    echad@chet:~ $ iobroker add ring --debug
    NPM version: 9.8.1
    Installing iobroker.ring@5.0.7... (System call)
    added 185 packages, and removed 1 package in 2m
    131 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter ring
    upload [25] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/admin.d.ts admin.d.ts video/mp2t
    upload [20] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/de.json i18n/de.json application/json
    upload [19] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/en.json i18n/en.json application/json
    upload [18] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/es.json i18n/es.json application/json
    upload [17] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/fr.json i18n/fr.json application/json
    upload [16] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/it.json i18n/it.json application/json
    upload [15] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/nl.json i18n/nl.json application/json
    upload [14] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pl.json i18n/pl.json application/json
    upload [13] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pt.json i18n/pt.json application/json
    upload [12] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/ru.json i18n/ru.json application/json
    upload [11] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/uk.json i18n/uk.json application/json
    upload [10] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
    upload [9] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/index_m.html index_m.html text/html
    upload [8] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/jsonConfig.json jsonConfig.json application/json
    upload [7] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-desktop-notification-bell-3.png preferences-desktop-notification-bell-3.png image/png
    upload [6] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-system-login.png preferences-system-login.png image/png
    upload [5] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/ring.png ring.png image/png
    upload [4] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/style.css style.css text/css
    upload [3] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.html
    tab_m.html text/html
    upload [2] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.js tab_m.js application/javascript
    upload [1] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tsconfig.json tsconfig.json application/json
    upload [0] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/words.js words.js application/javascript
    host.chet object system.adapter.ring created/updated
    host.chet create instance ring
    host.chet object system.adapter.ring.0.alive created
    host.chet object system.adapter.ring.0.connected created
    host.chet object system.adapter.ring.0.compactMode created
    host.chet object system.adapter.ring.0.cpu created
    host.chet object system.adapter.ring.0.cputime created
    host.chet object system.adapter.ring.0.memHeapUsed created
    host.chet object system.adapter.ring.0.memHeapTotal created
    host.chet object system.adapter.ring.0.memRss created
    host.chet object system.adapter.ring.0.uptime created
    host.chet object system.adapter.ring.0.inputCount created
    host.chet object system.adapter.ring.0.outputCount created
    host.chet object system.adapter.ring.0.eventLoopLag created
    host.chet object system.adapter.ring.0.sigKill created
    host.chet object system.adapter.ring.0.logLevel created
    host.chet object ring.0 created
    host.chet object system.adapter.ring.0 created
    echad@chet:~ $
      ManiacKill
      #42
      hab mal ein Backup reingespielt zurzeit geht's wieder !"
      • M ManiacKill
        #43
        @maniackill
        iob diag
        sagt? Die Langfassung.
          ManiacKill
          #44
          @thomas-braun said in Ring Doorbell Adapter:
          iob diag
          This script must not be run as root!
          Please use your standard user!
          Es wurde glaube ich bei der Einrichtung, schon länger her, der normal Benutzer gelöscht. Ist nur noch dieser Vorhanden mit root. Hab es leider nicht selber gemacht deswegen weiß ich es nicht genau !
          Können diese Fehler auch vom der neuen Ubuntu Version kommen ? Hab von 22.10 auf 23.10 ein Update gemacht ?
          • M ManiacKill
            iob diag
            #45
            @maniackill
            Dann richte dir einen User ein!
            Und bei Ubuntu verwendet man auch keine Interimsversionen sondern die LTS-Releases.
              @maniackill
              ManiacKill
              #46
              Ja leider ist das ganz hier nicht mein Täglich Brot, deswegen bin ich da nicht so fit drin. Mach mich meistes hier schlau um Update zu machen !
              • M ManiacKill
                ManiacKill
                #47
                @maniackill said in Ring Doorbell Adapter:
                Hat alles mit dem Problem hier angefangen,
                sudo apt update
                Last login: Sat Nov  4 16:54:16 2023 from 192.168.2.155
                root@raspberrypi:~# sudo apt update
                Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                Ign:2 http://archive.ubuntu.com/ubuntu kinetic InRelease
                Ign:3 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
                Ign:4 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
                Err:5 http://archive.ubuntu.com/ubuntu kinetic Release
                  404  Not Found [IP: 91.189.91.83 80]
                Err:6 http://archive.ubuntu.com/ubuntu kinetic-updates Release
                Err:7 http://archive.ubuntu.com/ubuntu kinetic-security Release
                Reading package lists... Done
                E: The repository 'http://archive.ubuntu.com/ubuntu kinetic Release' no longer has a Release file.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-updates Release' no longer has a Release file.
                E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-security Release' no longer has a Release file.
                Dann hab ich mich schlau gemacht wie ich das Problem wieder in den griff bekomme, deswegen hab ich dann diese Update gemacht (do-release-upgrade).
                Und mit dem Befehl (iob nodejs-update) könnte ich zumindest die Node.js und NPM updaten !
                • M ManiacKill
                  sudo apt update
                  #48
                  @maniackill sagte in Ring Doorbell Adapter:
                  kinetic
                  Das Release ist tot...
                  Und genau deswegen verwendet man den Kram nicht.
                  Installier da Debian 'Bookworm' oder die aktuelle LTS von Ubuntu.
                  Und auf einem Raspberry würde ich auch immer RaspberryOS und kein Knubbelbuntu verwenden. Das ist nämlich viel besser auf die Hardware angepasst.
                  Dann verbietet sich eine root-shell noch selbstverständlicher als ohnehin schon.
                    kinetic
                    ManiacKill
                    #49
                    Es ist kein Raspi, ich musste damals nur diesen Namen benutzen wegen dem Backup was ich hatte :).
                    Es ist eine CT auf Proxmox !
                    Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                    • M ManiacKill
                      #50
                      @maniackill
                      Dann richte den gescheit ein. Mit einem User und auf einem lebendigen Release.
                      Hier steht's:
                      https://www.iobroker.net/#de/documentation/install/proxmox.md
                      • M ManiacKill
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #51
                        @maniackill Du wurdest jetzt schon mehrmals gebeten die Langfassung von
                        iob diag
                        hier zu zeigen.
                        Warum kommt das nicht von Dir ?
                        Lehrling seit 1975 !!!
                        • DJMarc75D DJMarc75
                          iob diag
                          hier zu zeigen.
                          #52
                          @djmarc75 sagte in Ring Doorbell Adapter:
                          Weil der root das nicht ausführen darf. Der darf halt auch nicht alles.
                          Als user ausgeführt funktioniert es.
                            m4rgott
                            schrieb am zuletzt editiert von m4rgott
                            #53
                            ich habe seit gestern auch große Probleme mit dem Ring-Adapter.
                            Wegen den dauerhaften Fehlermeldungen bezüglich der Binary-States wollte ich über Git auf die 5.0.7 Version updaten.
                            Das brachte beim Starten des Adapters im Log jedoch nur Fehlermeldungen.
                            Anschließend habe ich den Iobroker auf das letzte Backup zurückgesetzt. Alle Adapter funktionierten wieder problemlos, außer Ring. Auch ein neuer Token hat nicht geholfen.
                            Ich habe nun mit Restart und neuem Token nach jeder Deinstallation und jeder Neuinstallation die Versionen 3.1.5, 3.2.2 und 5.0.7 probiert und bekomme keine zum Laufen.
                            aktueller Auszug aus dem Log wenn ich versuche den Adapter zu starten (Version 5.0.7):
                            023-11-05 12:17:15.805 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:446
                            2023-11-05 12:17:15.805 - error: host.raspberrypi Caught by controller[0]: throw err;
                            2023-11-05 12:17:15.805 - error: host.raspberrypi Caught by controller[0]: ^
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/@homebridge/camera-utils/lib/index.js'. Please verify that the package.json has a valid "main" entry
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:680:18)
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                            2023-11-05 12:17:15.806 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/ring-client-api/lib/streaming/streaming-session.js:5:24)
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: path: '/opt/iobroker/node_modules/@homebridge/camera-utils/package.json',
                            2023-11-05 12:17:15.807 - error: host.raspberrypi Caught by controller[0]: requestPath: '@homebridge/camera-utils'
                            2023-11-05 12:17:15.808 - error: host.raspberrypi Caught by controller[0]: }
                            2023-11-05 12:17:15.808 - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
                            2023-11-05 12:17:15.808 - error: host.raspberrypi instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            Auszug aus der iob diag:
                            2023-11-05 12:17:11.324  - info: host.raspberrypi "system.adapter.ring.0" enabled
                            2023-11-05 12:17:11.577  - info: host.raspberrypi instance system.adapter.ring.0 started with pid 14221
                            2023-11-05 12:17:15.531  - info: admin.0 (1538) ==> Connected system.user.admin from ::ffff:192.168.188.76
                            2023-11-05 12:17:15.805  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:446
                            2023-11-05 12:17:15.807  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/ring-client-api/lib/streaming/streaming-session.js:5:24)
                            2023-11-05 12:17:15.808  - info: host.raspberrypi Rebuild for adapter system.adapter.ring.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            /opt/iobroker/node_modules/iobroker.ring $ npm install --production
                            npm WARN config production Use `--omit=dev` instead.
                            added 353 packages, and audited 354 packages in 4m
                            56 packages are looking for funding
                            found 0 vulnerabilities
                            nodejs v18.17.1, npm 9.6.7, js-controller 5.0.12
                            Danke vorab für Eure Hilfe.
                            • M m4rgott
                              #54
                              @m4rgott sagte in Ring Doorbell Adapter:
                              Alt und aus dem verwaisten Repo.
                              iob stop
                              iob fix
                              iob nodejs-update
                              mcm1957M M 2 Antworten Letzte Antwort
                                iob stop
                                iob fix
                                iob nodejs-update
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #55
                                Yep
                                Es häufen sich aber Meldungen mit
                                Ich gab schon den verdacht dass da was an der dependency geändert hat und faul ist.
                                Kanns nur nichtcsinnvoll am handy checken
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                  iob stop
                                  iob fix
                                  iob nodejs-update
                                  m4rgott
                                  #56
                                  @thomas-braun sagte in Ring Doorbell Adapter:
                                  iob nodejs-update
                                  Danke für den Tipp.
                                  wurde durchgeführt.
                                  nodejs ist jetz v18.18.2, npm 9.8.1 und js-controller 5.0.12
                                  Anschließend Adapter neu installiert, reboot und neuer Token eingetragen.
                                  Folgendes kam beim neuen iob diag:
                                  2023-11-05 13:36:16.528  - info: host.raspberrypi instance system.adapter.ring.0 started with pid 4793
                                  2023-11-05 13:36:21.415  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:446
                                  2023-11-05 13:36:21.416  - error: host.raspberrypi Caught by controller[0]:       throw err;
                                  2023-11-05 13:36:21.416  - error: host.raspberrypi Caught by controller[0]:       ^
                                  2023-11-05 13:36:21.417  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/@homebridge/camera-utils/lib/index.js'. Please verify that the package.json has a valid "main" entry
                                  2023-11-05 13:36:21.417  - error: host.raspberrypi Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:438:19)
                                  2023-11-05 13:36:21.417  - error: host.raspberrypi Caught by controller[0]:     at Module._findPath (node:internal/modules/cjs/loader:680:18)
                                  2023-11-05 13:36:21.417  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
                                  2023-11-05 13:36:21.417  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
                                  2023-11-05 13:36:21.418  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
                                  2023-11-05 13:36:21.418  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
                                  2023-11-05 13:36:21.418  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/ring-client-api/lib/streaming/streaming-session.js:5:24)
                                  2023-11-05 13:36:21.418  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                  2023-11-05 13:36:21.418  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                  2023-11-05 13:36:21.418  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32) {
                                  2023-11-05 13:36:21.419  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2023-11-05 13:36:21.419  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_modules/@homebridge/camera-utils/package.json',
                                  2023-11-05 13:36:21.419  - error: host.raspberrypi Caught by controller[0]:   requestPath: '@homebridge/camera-utils'
                                  2023-11-05 13:36:21.419  - error: host.raspberrypi Caught by controller[0]: }
                                  2023-11-05 13:36:21.419  - error: host.raspberrypi Caught by controller[0]: Node.js v18.18.2
                                  2023-11-05 13:36:21.420  - error: host.raspberrypi instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2023-11-05 13:36:21.420  - info: host.raspberrypi Rebuild for adapter system.adapter.ring.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  • M m4rgott
                                    iob nodejs-update
                                    Danke für den Tipp.
                                    wurde durchgeführt.
                                    #57
                                    Da muss wohl einer der Developer der camera-utils mal schauen. Gibt aber schon ein Issue dazu.
                                      m4rgott
                                      #58
                                      Okay. Das heißt, dass das mit Version 5.0.7 gerade nicht funktioniert.
                                      Habt Ihr einen Tipp für mich, warum denn nun auch Version 3.2.2 vom Adapter nicht mehr will?
                                      Der hat bis gestern Morgen funktioniert. jetzt bekomme ich den auch nicht mehr installiert. Leider hat auch ein Backup vom IOB auf den letzten Stand wo es funktioniert hat nicht geholfen.
                                      • M m4rgott
                                        #59
                                        Weil in einer Abhängigkeit wohl ein Fehler ist. Und diese Abhängigkeiten werden immer frisch reingezogen, wenn der Adapter installiert oder aktualisiert wird.
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #60
                                          Es sieht do aus als wäre /homebridge/camera-utils in der Version 2.2.1 FEHLERHAFT.
                                          Eine xplizite Installation von 2.2.0 könnte helfen. Da ich aber nicht weiß wie das - ohne kurz- oder mittelfristige Störung der normalen ioBroker Installtio machbar ist - werde ich hier keien Anregungen dazu geben was konkret zu tun ist. Aber ev. kann das ja jemand mit fundierten Kenntnissen machen.
                                          Links zur Referenz:
                                          • https://github.com/homebridge/camera-utils/issues/556
                                          • https://github.com/dgreif/ring/issues/1353#issue-1977811034
                                          • https://github.com/dgreif/ring/issues/1353#issuecomment-1793767967 (ACHTUNG: Nicht ohne weitere Abklärung einfach so installieren!)
                                          • https://github.com/iobroker-community-adapters/ioBroker.ring/issues/614
                                          michiproepM 1 Antwort Letzte Antwort
