  4. Ring Doorbell Adapter
ringdoorbellring adapter
160 Beiträge 31 Kommentatoren 45.5k Aufrufe 26 Beobachtet
  • planetkeaneP Offline
    planetkeane
    Hab den 16.17.1 und funktioniert nicht
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: }
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:7:15) {
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:533:31)
    host.ioBroker2
    	2022-11-21 16:18:38.841	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:493:36)
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:748:3)
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:464:9)
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: ^
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: throw e;
    host.ioBroker2
    	2022-11-21 16:18:38.840	error	Caught by controller[0]: node:internal/modules/cjs/loader:499
    host.ioBroker2
    	2022-11-21 16:18:38.395	info	instance system.adapter.ring.0 started with pid 390107
    • Daniel ZinglerD Offline
      Daniel Zingler
      Also ich habe mein system jetzt noch mal komplett neu aufgesetzt und ein bisschen rum probiert.
      Ich bekomme bei keiner Version die älter ist als 3.1.3 eine Verbindung zum host.
      Alle versionen ab 3.1.3 (habe aktuell die 3.1.9) Verbinden sofort aber funktionieren nur ein mal.
      @denjo machst du mit eingerichtetem Adapter den downgrade auf 3.0.1 oder muss nach Versionsänderung immer ein neuer Token eingegeben werden?
      Vll kannst du auch mal gucken ob bei gedrückter Klingeltaste der Wert "If there is a Doorbell Press Event" auf True bleibt oder ob der nur einmal kurz schaltet.
      Dann könnte ich das Projekt Ring adapter eh zu den Akten legen und muss nicht länger versuchen eine Version zum laufen zu bekommen. ;)
      • Daniel ZinglerD Daniel Zingler
        denjo
        @daniel-zingler du musst beim versions Änderung am besten immer ein neuem token erstellen. Falls du schon zu viele gemacht hast am besten alle Geräte auf der Ring Internet Seite löschen und dann ein neuem token machen. Ich kann dir am we bestimmt sonst mal anbieten per Teamviewer sonst mal rauf zu gucken wenn alle stricke reißen. Bei mir läuft die 3.0.1 tadellos
          Daniel Zingler
          ja kannst du sonst gerne machen per TV.
          habe ich auch versucht mit löschen im Account.
            denjo
            @daniel-zingler also nur mal zur Info.
            Wenn ich das richtig verstanden habe auf github.com hat der Entwickler nur eine ring Kamera deswegen funktioniert nur die Version 3.0.1 und alles was drüber ist nicht für eine doorbell
              Daniel Zingler
              Dann ergibt es Sinn aber erklärt noch nicht warum erst ab 3.1.3 bei mir eine verbindung aufgebaut wird.
              Und ich scheine ja auch nicht der einzige mit dem Problem zu sein.
                denjo
                @daniel-zingler
                https://github.com/iobroker-community-adapters/ioBroker.ring/issues/373#issuecomment-1324849838
                Hier jeder der bei einer Spende mit dabei sein würde
                Daniel ZinglerD 1 Antwort Letzte Antwort
                • D denjo
                  @daniel-zingler
                  Daniel Zingler
                  @denjo ja habe ich gesehen bin dabei.
                    denjo
                    @daniel-zingler am besten auf github.com schreiben das du dabei bist falls du es nicht nicht getan hast
                    • D denjo
                      Daniel Zingler
                      @denjo habe ich schon
                        mx-driver
                        Hat jemand Info ob da noch was passiert mit dem Adapter?
                          TobiB
                          schrieb am zuletzt editiert von TobiB
                          ich bekomme den Adapter nicht zum laufen. Ich bekomme den Token und tragen diesen ein aber dennoch bleibt der Adapter Rot...
                          Das habe ich im Log:
                          Jemand eine Idee woran es liegen könnte?
                          • PischleuderP Online
                            PischleuderP Online
                            Pischleuder
                            schrieb am zuletzt editiert von Pischleuder
                            Guten Morgen,
                            verwende den Adapter aus dem git (Version 5.0.1-beta.0)
                            Damit erhalte ich jedoch keine "neuen" Videos und Bilder mehr. Der Stand ist immer noch der wie vor ein paar Tagen - bedeutet, die Datenpunkte aktualisieren sich nicht.
                            Der refresh Token wurde bereits aktualisiert und ich hatte den iobroker auch über die Weboberfläche von ring herausgeworfen und neu hinzugefügt.
                            Im log erscheint folgendes:
                            host.raspberrypi2
                            2023-10-18 06:02:24.723	error	instance system.adapter.ring.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            ring.0 2023-10-18 06:02:23.884	error	(0 , rxjs_1.firstValueFrom) is not a function
                            ring.0 2023-10-18 06:02:23.884	error	TypeError: (0 , rxjs_1.firstValueFrom) is not a function at OwnRingCamera.takeHDSnapshot (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:519:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async OwnRingCamera.conditionalRecording (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:773:53)
                            ring.0 2023-10-18 06:02:23.883	error	unhandled promise rejection: (0 , rxjs_1.firstValueFrom) is not a function
                            ring.0 2023-10-18 06:02:23.882	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              ManiacKill
                              Moien zusammen, brauch mal Hilfe bei der Installation vom Adapter. Er ist eigentlich bis jetzt immer gelaufen. Hab ein Update auf 5.07 gemacht und jetzt bekomme ich ihn nicht mehr zum laufen. Egal welche Version !
                              Node.js: v18.18.2
                              NPM: 10.2.3
                              Installiert js-controller:5.0.12
                              ost.raspberrypi
                              2023-11-04 11:28:38.101	info	Rebuild for adapter system.adapter.ring.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: Node.js v18.18.2
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: }
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: requestPath: '@homebridge/camera-utils'
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/@homebridge/camera-utils/package.json',
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
                              host.raspberrypi
                              2023-11-04 11:28:38.101	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/ring-client-api/lib/streaming/streaming-session.js:5:24)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:680:18)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/@homebridge/camera-utils/lib/index.js'. Please verify that the package.json has a valid "main" entry
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: ^
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: throw err;
                              host.raspberrypi
                              2023-11-04 11:28:38.100	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
                              Danke euch
                              DJMarc75D mcm1957M 2 Antworten Letzte Antwort
                              • M ManiacKill
                                Node.js: v18.18.2
                                NPM: 10.2.3
                                ost.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                Danke euch
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                @maniackill sagte in Ring Doorbell Adapter:
                                NPM: 10.2.3
                                da stimmt was nicht
                                Lehrling seit 1975 !!!
                                • DJMarc75D DJMarc75
                                  NPM: 10.2.3
                                  da stimmt was nicht
                                  ManiacKill
                                  @djmarc75 Ok sollte ich ein andren nehmen ?
                                  • M ManiacKill
                                    Node.js: v18.18.2
                                    NPM: 10.2.3
                                    ost.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    Danke euch
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @maniackill said in Ring Doorbell Adapter:
                                    Querverweis zu deinem Issue auf Github
                                    https://github.com/iobroker-community-adapters/ioBroker.ring/issues/613
                                    Und ja, was DJMarc75 schon gesagt hat
                                    npm ist immer nur gemeinsam mit node zu installieren - niemals extra oder extra zu aktualisieren. Node 18.x.x ist npm 9.x.x - bring das mal in Ordnung.
                                    @Thomas-Braun
                                    Korrigiert der nodejs fixer auch falsche npms ?
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                      ManiacKill
                                      Ok Danke, hab jetzt wieder auf 9.8.1 stehen 👍 Der Fehler vom Adapter bleibt !
                                      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                                      • M ManiacKill
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @maniackill dann zeig mal die Langfassung von
                                        iob diag
                                        bitte
                                        • mcm1957M mcm1957
                                          @Thomas-Braun
                                          @mcm57 sagte in Ring Doorbell Adapter:
                                          Jein. Kommt darauf an, ob das binairy im falschen Pfad liegt. Ansonsten wird das nur im Zusammenhang mit dem Paket 'nodejs' angepackt.
                                          Das kann man aber direkt anpacken.
                                          sudo apt update
                                          iob stop
                                          sudo apt install --reinstall nodejs
