  4. iob diag - Skript
    6.1k
iob diag - Skript
863 Beiträge 52 Kommentatoren 285.3k Aufrufe 40 Beobachtet
  • T tobrog
    @thomas-braun Hab das skript auch mal im lxc container getestet.
    Skript v.2023-05-28-4
    *** BASE SYSTEM ***
       Static hostname: iob-test
             Icon name: computer-container
               Chassis: container
            Machine ID: d8caa5b3244e49f2ac681e0f79a122d3
               Boot ID: d94366b77fd34be8be8ae7312c47af6a
        Virtualization: lxc
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.0.19-edge
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:44:23 up 0 min,  2 users,  load average: 1.58, 0.91, 0.65
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2023-05-29 12:44:23 CEST
               Universal time: Mon 2023-05-29 10:44:23 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    rog
    /home/rog
    rog adm sudo redis iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        1.6G        6.3G        2.0M        293M        6.6G
    Swap:           2.0G          0B        2.0G
    Total:           10G        1.6G        8.3G
             8192 M total memory
             1598 M used memory
               66 M active memory
             1764 M inactive memory
             6299 M free memory
                0 M buffer memory
              293 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    *** FILESYSTEM ***
    Filesystem                           Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--200--disk--0     ext4    16G  3.9G   11G  27% /
    none                                 tmpfs  492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root                 ext4    66G   12G   51G  18% /dev/ttyACM0
    tmpfs                                tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                                tmpfs  3.1G  160K  3.1G   1% /run
    tmpfs                                tmpfs  5.0M     0  5.0M   0% /run/lock
    //10.10.10.10/Public/backup/iobroker cifs   2.7T  2.1T  627G  78% /media/iobroker
    tmpfs                                tmpfs  1.6G     0  1.6G   0% /run/user/1000
    [Sat May 27 18:18:31 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 18:18:32 2023] EXT4-fs (dm-1): re-mounted. Quota mode: none.
    [Sat May 27 18:18:51 2023] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 18:19:10 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 18:19:29 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 18:19:48 2023] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 18:19:52 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 19:01:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 19:01:47 2023] EXT4-fs (dm-9): unmounting filesystem.
    [Sat May 27 19:01:51 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat May 27 19:02:53 2023] EXT4-fs (dm-12): unmounting filesystem.
    [Sun May 28 07:01:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun May 28 07:02:15 2023] EXT4-fs (dm-9): unmounting filesystem.
    [Sun May 28 07:02:20 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun May 28 07:03:23 2023] EXT4-fs (dm-12): unmounting filesystem.
    [Sun May 28 19:01:23 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun May 28 19:01:48 2023] EXT4-fs (dm-9): unmounting filesystem.
    [Sun May 28 19:01:53 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun May 28 19:02:57 2023] EXT4-fs (dm-12): unmounting filesystem.
    [Mon May 29 07:01:21 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon May 29 07:01:46 2023] EXT4-fs (dm-9): unmounting filesystem.
    [Mon May 29 07:01:50 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon May 29 07:02:53 2023] EXT4-fs (dm-12): unmounting filesystem.
    [Mon May 29 12:38:02 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon May 29 12:43:43 2023] EXT4-fs (dm-12): unmounting filesystem.
    [Mon May 29 12:43:44 2023] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET            SOURCE                                                 FSTYPE OPTIONS
    /                 /dev/mapper/pve-vm--200--disk--0                       ext4   rw,relatime,stripe=16
    |-/dev/ttyACM0    /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    `-/media/iobroker //10.10.10.10/Public/backup/iobroker                   cifs   rw,relatime,vers=3.1.1,cache=strict,username=XXX,uid=1001,noforceuid,gid=1001,noforc
    /var:
    458M    /var/
    226M    /var/cache
    221M    /var/cache/apt
    161M    /var/lib
    152M    /var/cache/apt/archives
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    142M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    392M    /opt/iobroker/iobroker-data/
    305M    /opt/iobroker/iobroker-data/files
    66M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     redis on 127.0.0.1
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.admin.0                  : admin                 : iob-test                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iob-test                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : iob-test                                 - disabled
      system.adapter.apple-find-me.0          : apple-find-me         : iob-test                                 - disabled
      system.adapter.apple-find-me.1          : apple-find-me         : iob-test                                 - disabled
      system.adapter.apple-find-me.2          : apple-find-me         : iob-test                                 - disabled
      system.adapter.apple-find-me.3          : apple-find-me         : iob-test                                 - disabled
      system.adapter.apple-find-me.4          : apple-find-me         : iob-test                                 - disabled
    + system.adapter.backitup.0               : backitup              : iob-test                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iob-test                                 -  enabled
      system.adapter.devices.0                : devices               : iob-test                                 - disabled
    + system.adapter.discovery.0              : discovery             : iob-test                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iob-test                                 -  enabled
      system.adapter.flot.0                   : flot                  : iob-test                                 - disabled
      system.adapter.history.0                : history               : iob-test                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iob-test                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iob-test                                 - disabled
    + system.adapter.info.0                   : info                  : iob-test                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iob-test                                 - disabled
    + system.adapter.javascript.0             : javascript            : iob-test                                 -  enabled
      system.adapter.nina.0                   : nina                  : iob-test                                 - disabled
      system.adapter.plex.0                   : plex                  : iob-test                                 - disabled
    + system.adapter.simple-api.0             : simple-api            : iob-test                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iob-test                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.switchbot-hub.0          : switchbot-hub         : iob-test                                 - disabled
      system.adapter.telegram.0               : telegram              : iob-test                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : iob-test                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iob-test                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-test                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iob-test                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-test                                 - disabled
      system.adapter.vis-owl.0                : vis-owl               : iob-test                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-test                                 - disabled
      system.adapter.vis.0                    : vis                   : iob-test                                 -  enabled
    + system.adapter.web.0                    : web                   : iob-test                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iob-test                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : iob-test                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : iob-test                                 - disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    live-beta     : http://iobroker.live/repo/sources-dist-latest.json
    live-stable   : http://iobroker.live/repo/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "apple-find-me": 0.0.14   , installed 0.0.15
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "device-watcher": 2.9.1   , installed 2.9.1
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "plex"         : 0.9.1    , installed 0.9.1
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        5543
    States:         4580
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:5 https://packages.sury.org/php bullseye InRelease
    Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        10096841   124/mosquitto
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          10097023   318/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10094414   1/init
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          10096944   213/lighttpd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10097182   129/iobroker.js-con
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        10096812   108/systemd-resolve
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        10097759   119/redis-server 12
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        10096806   108/systemd-resolve
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          10097024   318/master
    tcp6       0      0 :::1883                 :::*                    LISTEN      110        10096842   124/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10094545   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10094418   1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          10096945   213/lighttpd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        10097760   119/redis-server 12
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       10098846   457/io.ws.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       10103907   944/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10100707   758/io.simple-api.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10098182   333/io.admin.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       10104026   987/io.web.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10098618   417/io.web.0
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        10096809   108/systemd-resolve
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        10096805   108/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        10096811   108/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10094415   1/init
    udp6       0      0 :::5355                 :::*                                104        10096808   108/systemd-resolve
    udp6       0      0 :::111                  :::*                                0          10094421   1/init
    2023-05-29 12:44:23.992  - info: host.iob-test instance system.adapter.echarts.0 started with pid 534
    2023-05-29 12:44:24.222  - info: vis.0 (474) Uploaded. 0
    2023-05-29 12:44:24.727  - info: vis.0 (474) Terminated (NO_ERROR): Without reason
    2023-05-29 12:44:25.038  - info: echarts.0 (534) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 12:44:25.305  - info: host.iob-test instance system.adapter.vis.0 terminated while should be started once
    2023-05-29 12:44:28.032  - info: host.iob-test instance system.adapter.info.0 started with pid 562
    2023-05-29 12:44:30.330  - info: info.0 (562) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 12:44:30.462  - info: info.0 (562) Reading/updating systemdata.
    2023-05-29 12:44:30.975  - info: info.0 (562) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2023-05-29 12:44:31.018  - info: info.0 (562) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2023-05-29 12:44:31.112  - info: info.0 (562) cpu Temp res = {"main":46,"cores":[46,46,46,45],"max":46,"socket":[45],"chipset":null}
    2023-05-29 12:44:32.051  - info: host.iob-test instance system.adapter.simple-api.0 started with pid 758
    2023-05-29 12:44:33.467  - info: simple-api.0 (758) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 12:44:33.495  - info: simple-api.0 (758) simpleAPI server listening on port 8087
    2023-05-29 12:44:33.496  - info: simple-api.0 (758) Allow states only when user is owner: false
    2023-05-29 12:44:33.505  - info: simple-api.0 (758) http server listening on port 8087
    2023-05-29 12:44:36.036  - info: host.iob-test instance system.adapter.socketio.0 started with pid 944
    2023-05-29 12:44:37.130  - info: socketio.0 (944) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 12:44:37.268  - info: socketio.0 (944) socket.io server listening on port 8084
    2023-05-29 12:44:40.035  - info: host.iob-test instance system.adapter.vis-inventwo.0 started with pid 959
    2023-05-29 12:44:41.086  - info: vis-inventwo.0 (959) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 12:44:44.044  - info: host.iob-test instance system.adapter.web.1 started with pid 987
    2023-05-29 12:44:45.611  - info: web.1 (987) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
    2023-05-29 12:44:45.770  - info: web.1 (987) socket.io server listening on port 8083
    2023-05-29 12:44:45.774  - info: web.1 (987) http server listening on port 8083
                         v.2023-05-28-4
               Chassis: container
        Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            8.2G        1.5G        6.2G        2.0M        530M        6.7G
    Swap:           2.0G          0B        2.0G
    Total:           10G        1.5G        8.2G
    Active iob-Instances:   14
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: redis
    Objects:                5543
    States:                 4580
    Size of iob-Database:
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    3.8M    /opt/iobroker/iobroker-data/states.jsonl
    rog@iob-test:~$ systemd-detect-virt
    lxc
    #441
    @tobrog
    Ja, so sollte es in einem LXC aussehen. Warum das bei @Nashra nicht funktioniert kann ich mir gerade nicht erklären. Ist aber offenbar ein individuelles phänomen in seiner Installation.
    GlasfaserG 2 Antworten Letzte Antwort
      @tobrog
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #442
      @thomas-braun sagte in iob diag - Skript:
      Da sind noch mehr ... bei Ihm :
      Failed to query server: Connection timed out
        @tobrog
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #443
        @Nashra
        Starte deine ... Kiste ... mal neu durch !
        • GlasfaserG Glasfaser
          #444
          @glasfaser
          Ja, hab ich gesehen. Sind die Stellen, die ich für non-Docker auf systemd-Kommandos umgestellt habe. Bei @tobrog funktioniert es ja auch wie vorgesehen und erwartet.
          Vielleicht eine steinalte Basis? Keine Ahnung seit wann Proxmox-LXC auf systemd laufen.
            @nashra
            Was spuckt das Terminal zu
            systemd-detect-virt
            aus?
            NashraN Offline
            NashraN Offline
            Nashra
            Most Active Forum Testing
            schrieb am zuletzt editiert von Nashra
            #445
            systemd-detect-virt
            jack@ioBroker:~$ systemd-detect-virt
            lxc
            jack@ioBroker:~$
            Starte die Kiste mal neu, ist aktuellste Version drauf
            Gruß Ralf
            Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
            • NashraN Nashra
              systemd-detect-virt
              lxc
              jack@ioBroker:~$
              #446
              @nashra
              Und
              timedatectl
              hostnamectl
              funktionieren nicht? Wundert mich.
              NashraN 1 Antwort Letzte Antwort
                @nashra
                Und
                timedatectl
                hostnamectl
                NashraN Offline
                NashraN Offline
                Nashra
                #447
                timedatectl
                Funktionieren beide nicht, Fehlermeldung
                und das kommt jetzt nach einem kompletten Neustart
                *** BASE SYSTEM ***
                Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
                model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                Kernel          : x86_64
                Userland        : amd64
                 13:30:51 up 5 min,  1 user,  load average: 1.34, 1.23, 0.64
                CPU threads: 4
                Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                jack
                /home/jack
                jack sudo iobroker
                Gruß Ralf
                • NashraN Nashra
                  timedatectl
                  *** BASE SYSTEM ***
                  Kernel          : x86_64
                  Userland        : amd64
                  CPU threads: 4
                  jack
                  /home/jack
                  jack sudo iobroker
                  #448
                  @nashra sagte in iob diag - Skript:
                  Keine Ahnung warum in deinem System die Services nicht laufen. Sollten sie imho eigentlich.
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    #449
                    Laut INet ein Bug in Ubuntu ...
                    Kann aber nicht erkenne was genau @Nashra hat !
                    EDIT :
                    Sollte man lieber in einem seperaten Thread klären !!
                    Thomas BraunT NashraN 2 Antworten Letzte Antwort
                      EDIT :
                      #450
                      @glasfaser sagte in iob diag - Skript:
                      Richtig, hat mit dem Skript nix zu tun, das funktioniert wie vorgesehen.
                        EDIT :
                        NashraN Offline
                        NashraN Offline
                        Nashra
                        #451
                        EDIT :
                        Debian 11
                        Habe gerade mal die anderen Container getestet, da funktionieren die Befehle.
                        Ergo, der ioB Container hat ne Macke, hat also nichts mit dem Skript zu tun.
                        Werde das die Tage mal alles neu aufsetzen, Backups sind ja genug da.
                        Gruß Ralf
                        • NashraN Nashra
                          EDIT :
                          Debian 11
                          #452
                          :-D Und ich sitz hier laut alle Virtualisierungen verfluchend über meinem Spaghetti-Code und such einen Workaround...
                            NashraN Offline
                            NashraN Offline
                            Nashra
                            #453
                            Sorry Thomas :man-bowing:
                            Gruß Ralf
                            • GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              #454
                              Vorschlag :
                              da dein
                              iob diag
                              schon zu einem Schweizer Taschenmesser geworden ist , könnte im Skript das
                              Mit Ausgabe in eine Logdatei namens iob_diag.log sähe der Aufruf so aus:
                              ./iob_diag | tee iob_diag.log
                              mit einbauen , auf Basis von :
                              iob diag  | tee log/iob_diag.log
                              Wäre dann über die Admin Oberfläche :
                              per Download bzw. besser markierbar ... ( da haben so einige Probleme damit )
                              Man könnte noch weiter denken es im Admin als Abfrage dazu mit einem Button mit einzubauen , " wenn benötigt " :)
                                Vorschlag :
                                da dein
                                iob diag
                                #455
                                @glasfaser
                                Ich hab nur keine Ahnung von Admin
                                Das Skript wird aber bereits heute in /home/iobroker/iob_diag.log abgelegt. Müsste vermutlich da nur abgeholt werden.
                                Das müsste dann im iob-Installer bzw. in iob fix angepasst werden. Magst du ein Issue aufmachen?
                                  Vorschlag :
                                  da dein
                                  iob diag
                                  #456
                                  @glasfaser
                                  Hab jetzt nochmal damit herumgespielt.
                                  Kann man natürlich auch direkt in /opt/iobroker/log rein werfen.
                                  Ist nur unschön, dass die ganze Formatierung (Leerzeilen, TabStops, Farben usw. dann weg fällt
                                    @glasfaser
                                    #457
                                    dann lass es! 😁
                                      dann lass es! 😁
                                      #458
                                      Ja, da hab ich mir sooooolche Mühe mit gegeben... :-D
                                        GlasfaserG Offline
                                        Glasfaser
                                        #459
                                        .... das alles war ja nur ein Vorschlag !
                                          #460
                                          @glasfaser
                                          Müsste eh im Installer geändert werden. Im Moment ist da ~/iobroker als Ausgabe-Pfad drin. Müsste jemand, der an den Code dran kommt nur auf /opt/iobroker/log umbauen.
