  4. ERROR: Process exited with code 25
56 Beiträge 6 Kommentatoren 6.7k Aufrufe 4 Beobachtet
    @marcdo70 sagte in ERROR: Process exited with code 25:
    Hab diese Zeile in mein Putty gehauen,
    Sorry, hab kein Ergebnis gesehen
    marcdo70
    #41
    login as: pi
    pi@192.168.178.74's password:
    Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92
    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    pi@raspberrypi:~ $
    • M marcdo70
      @homoran Hab ich doch schon versucht, aber da tut sich nichts. Hab diese Zeile in mein Putty gehauen, aber Fehler bleibt
      #42
      aber Fehler bleibt
      und das?
      • M marcdo70
        login as: pi
        pi@raspberrypi:~ $
        #43
        @marcdo70
        Was sagt
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          @marcdo70
          Was sagt
          marcdo70
          #44
          login as: pi
          pi@raspberrypi:~ $ ^C
          pi@raspberrypi:~ $ iob update
          Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
          Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
          Adapter    "backitup"     : 2.4.12   , installed 2.4.12
          Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
          Adapter    "denon"        : 1.13.4   , installed 1.13.4
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "socketio"     : 4.2.0    , installed 4.2.0
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "web"          : 4.3.0    , installed 4.3.0
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          Adapter    "ws"           : 1.3.0    , installed 1.3.0
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug
          This upgrade of "javascript" will introduce the following changes:
          -> 6.0.3:
          Downgrade Typescript to prevent errors with global typescript scripts
          -> 6.0.2:
          -> 6.0.1:
          Fixed the wizard schedule
          Done small fixes on GUI
          Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y
          Update javascript from @6.0.0 to @6.0.3
          NPM version: 8.19.2
          Installing iobroker.javascript@6.0.3... (System call)
          npm ERR! code ENOTDIR
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/argparse
          npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
          npm ERR! errno -20
          npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
          npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log
          host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.18.0
          v16.18.0
          8.19.2
          4.0.23
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          tty
          /home/pi
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
          Reading package lists... Done
          Building dependency tree
          11 packages can be upgraded. Run 'apt list --upgradable' to see them.
          nodejs:
            Installed: 16.18.0-deb-1nodesource1
            Candidate: 16.18.0-deb-1nodesource1
            Version table:
           *** 16.18.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u2 500
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $
          • M marcdo70
            login as: pi
            pi@raspberrypi:~ $
            -> 6.0.3:
            -> 6.0.2:
            -> 6.0.1:
            NPM version: 8.19.2
            npm ERR! errno -20
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.18.0
            v16.18.0
            8.19.2
            4.0.23
            pi
            tty
            /home/pi
            nodejs:
              Version table:
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            #45
            @marcdo70
            Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
            M 2 Antworten Letzte Antwort
              @marcdo70
              marcdo70
              #46
              Ja hab ich auch gesehen, Danke
                @marcdo70
                marcdo70
                #47
                @thomas-braun sagte in ERROR: Process exited with code 25:
                @marcdo70
                So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
                pi@raspberrypi:~ $ iobroker upgrade alexa2
                This upgrade of "alexa2" will introduce the following changes:
                -> 3.19.10:
                Fix issue in retry handling when rate limit exceeded is returned by Amazon
                Do not clean up Smart Home Device objects for now - delete manually if you remove a device
                Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
                Update alexa2 from @3.19.9 to @3.19.10
                NPM version: 8.19.2
                Installing iobroker.alexa2@3.19.10... (System call)
                host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
                • M marcdo70
                  @marcdo70
                  -> 3.19.10:
                  NPM version: 8.19.2
                  #48
                  @marcdo70
                  iobroker update
                  iobroker upgrade alexa2 --debug
                    @marcdo70
                    iobroker update
                    marcdo70
                    #49
                    Geht nicht
                    login as: pi
                    Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92
                    pi@raspberrypi:~ $ iobroker update
                    pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug
                    -> 3.19.10:
                    Do not clean up Smart Home Device objects for now - delete manually if you remov        e a device
                    NPM version: 8.19.2
                    npm ERR! errno -20
                    npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log
                    pi@raspberrypi:~ $
                    • M marcdo70
                      Geht nicht
                      login as: pi
                      -> 3.19.10:
                      NPM version: 8.19.2
                      npm ERR! errno -20
                      pi@raspberrypi:~ $
                      #50
                      @marcdo70
                      rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                      Loggst du dich für jeden Befehl neu ein?
                        @marcdo70
                        marcdo70
                        #51
                        Hatte Console ausversehen geschlossen, aber da passiert gar nichts
                        login as: pi
                        -> 3.19.10:
                        NPM version: 8.19.2
                        npm ERR! errno -20
                        pi@raspberrypi:~ $ iobroker upgrade js-controller --debug
                        Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
                        pi@raspberrypi:~ $ iobroker upgrade self
                        Host    "raspberrypi"    is up to date.
                        pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                        pi@raspberrypi:~ $
                        • M marcdo70
                          login as: pi
                          -> 3.19.10:
                          NPM version: 8.19.2
                          npm ERR! errno -20
                          pi@raspberrypi:~ $
                          #52
                          @marcdo70
                          Da passiert schon was. Die Datei wurde gelöscht.
                          Versuch das Upgrade jetzt nochmal.
                            @marcdo70
                            marcdo70
                            #53
                            @marcdo70
                            ok
                            pi@raspberrypi:~ $
                            -> 3.19.10:
                            NPM version: 8.19.2
                            npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                            npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                            added 75 packages, removed 13 packages, and changed 95 packages in 23s
                            103 packages are looking for funding
                              run `npm fund` for details
                            Update "system.adapter.alexa2.0"
                            upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                            pi@raspberrypi:~ $
                            Thomas BraunT M 2 Antworten Letzte Antwort
                            • M marcdo70
                              @marcdo70
                              ok
                              pi@raspberrypi:~ $
                              -> 3.19.10:
                              NPM version: 8.19.2
                              pi@raspberrypi:~ $
                              #54
                              @marcdo70
                              Geht wohl jetzt. Heb den Rest auch auf die aktuelle Version.
                              • M marcdo70
                                @marcdo70
                                ok
                                pi@raspberrypi:~ $
                                -> 3.19.10:
                                NPM version: 8.19.2
                                pi@raspberrypi:~ $
                                marcdo70
                                #55
                                @marcdo70
                                ok
                                pi@raspberrypi:~ $
                                -> 3.19.10:
                                NPM version: 8.19.2
                                pi@raspberrypi:~ $
                                Hat bei dem Adapter funktioniert wie es aussieht
                                  @marcdo70
                                  marcdo70
                                  #56
                                  @marcdo70
                                  Vielen lieben Dank. Gott sei Dank. Das hat echt mein bischen Wissen überfordert.
                                  GLG Marcus
