ERROR: Process exited with code 25
@marcdo70 sagte in ERROR: Process exited with code 25:
not allowed to start in the current Mul tihost environmenvon Mul tihost war bisher nicht die Rede
zieh das putty Fenster mal breiter
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Oct 27 15:11:45 2022 from 192.168.178.92 pi@raspberrypi:~ $ pi@raspberrypi:~ $ pi@raspberrypi:~ $ iob update Connection is closed. Uncaught Rejection: Error: Objects DB is not allowed to start in the current Mul tihost environment at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/ lib/objects/objectsInRedisClient.js:632:23) at processTicksAndRejections (node:internal/process/task_queues:96:5) Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed. Unable to subscribe to meta namespace "meta." changes: Connection is closed. pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug Connection is closed. Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23) at processTicksAndRejections (node:internal/process/task_queues:96:5) pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ -
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Oct 27 15:22:19 2022 from 192.168.178.92 pi@raspberrypi:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug This upgrade of "javascript" will introduce the following changes: ========================================================================== -> 6.0.3: Downgrade Typescript to prevent errors with global typescript scripts -> 6.0.2: Downgrade Typescript to prevent errors with global typescript scripts -> 6.0.1: Fixed the wizard schedule Done small fixes on GUI ========================================================================== Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y Update javascript from @6.0.0 to @6.0.3 NPM version: 8.19.2 Installing iobroker.javascript@6.0.3... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-27T15_11_54_736Z-debug-0.log host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236 pi@raspberrypi:~ $ -
Ich komm nicht dahinter warum ich immer code25 Abruch bekomme und den ALexa2 und den Script Adapter nicht updaten kann, so funktioniert leider meine Spachausgabe auf meiner Alexa nicht mehr. Was kann ich tun? -
@homoran Hab ich doch schon versucht, aber da tut sich nichts. Hab diese Zeile in mein Putty gehauen, aber Fehler bleibt
Sorry, hab kein Ergebnis gesehen
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92 pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done pi@raspberrypi:~ $ -
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92 pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done pi@raspberrypi:~ $Was sagt
sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs -
Was sagt
sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejslogin as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92 pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug This upgrade of "javascript" will introduce the following changes: ========================================================================== -> 6.0.3: Downgrade Typescript to prevent errors with global typescript scripts -> 6.0.2: Downgrade Typescript to prevent errors with global typescript scripts -> 6.0.1: Fixed the wizard schedule Done small fixes on GUI ========================================================================== Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y Update javascript from @6.0.0 to @6.0.3 NPM version: 8.19.2 Installing iobroker.javascript@6.0.3... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236 pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs ln: failed to create symbolic link '/usr/bin/nodejs': File exists pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.18.0 v16.18.0 8.19.2 4.0.23 pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker tty /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 https://deb.nodesource.com/node_16.x buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done 11 packages can be upgraded. Run 'apt list --upgradable' to see them. nodejs: Installed: 16.18.0-deb-1nodesource1 Candidate: 16.18.0-deb-1nodesource1 Version table: *** 16.18.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u2 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages pi@raspberrypi:~ $ pi@raspberrypi:~ $ -
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92 pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug This upgrade of "javascript" will introduce the following changes: ========================================================================== -> 6.0.3: Downgrade Typescript to prevent errors with global typescript scripts -> 6.0.2: Downgrade Typescript to prevent errors with global typescript scripts -> 6.0.1: Fixed the wizard schedule Done small fixes on GUI ========================================================================== Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y Update javascript from @6.0.0 to @6.0.3 NPM version: 8.19.2 Installing iobroker.javascript@6.0.3... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236 pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs ln: failed to create symbolic link '/usr/bin/nodejs': File exists pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.18.0 v16.18.0 8.19.2 4.0.23 pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker tty /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 https://deb.nodesource.com/node_16.x buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done 11 packages can be upgraded. Run 'apt list --upgradable' to see them. nodejs: Installed: 16.18.0-deb-1nodesource1 Candidate: 16.18.0-deb-1nodesource1 Version table: *** 16.18.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u2 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages pi@raspberrypi:~ $ pi@raspberrypi:~ $Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
Ja hab ich auch gesehen, Danke -
@thomas-braun sagte in ERROR: Process exited with code 25:
So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
pi@raspberrypi:~ $ iobroker upgrade alexa2 This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remove a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236 -
pi@raspberrypi:~ $ iobroker upgrade alexa2 This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remove a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236iobroker update iobroker upgrade alexa2 --debug -
iobroker update iobroker upgrade alexa2 --debug@thomas-braun sagte in ERROR: Process exited with code 25:
Geht nicht
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92 pi@raspberrypi:~ $ iobroker update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remov e a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236 pi@raspberrypi:~ $ -
Geht nicht
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92 pi@raspberrypi:~ $ iobroker update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remov e a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236 pi@raspberrypi:~ $rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQiLoggst du dich für jeden Befehl neu ein?
Hatte Console ausversehen geschlossen, aber da passiert gar nichts
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92 pi@raspberrypi:~ $ iobroker update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remov e a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236 pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ iobroker upgrade js-controller --debug Cannot update js-controller using this command. Please use "iobroker upgrade self" instead! pi@raspberrypi:~ $ iobroker upgrade self Host "raspberrypi" is up to date. pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi pi@raspberrypi:~ $ -
login as: pi pi@192.168.178.74's password: Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92 pi@raspberrypi:~ $ iobroker update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remov e a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) npm ERR! code ENOTDIR npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/argparse npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi npm ERR! errno -20 npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236 pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ iobroker upgrade js-controller --debug Cannot update js-controller using this command. Please use "iobroker upgrade self" instead! pi@raspberrypi:~ $ iobroker upgrade self Host "raspberrypi" is up to date. pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi pi@raspberrypi:~ $Da passiert schon was. Die Datei wurde gelöscht.
Versuch das Upgrade jetzt nochmal. -
Versuch das Upgrade jetzt nochmal.@thomas-braun sagte in ERROR: Process exited with code 25:
Versuch das Upgrade jetzt nochmal.ok
pi@raspberrypi:~ $ iobroker update Used repository: Stable (default) Adapter "admin" : 6.2.23 , installed 6.2.22 [Updatable] Adapter "alexa2" : 3.19.10 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.4.12 , installed 2.4.12 Adapter "daswetter" : 3.1.3 , installed 3.1.3 Adapter "denon" : 1.13.4 , installed 1.13.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "node-red" : 4.0.0 , installed 4.0.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.14.1 , installed 1.14.1 Adapter "text2command" : 2.2.2 , installed 2.2.2 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remove a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10. npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size added 75 packages, removed 13 packages, and changed 95 packages in 23s 103 packages are looking for funding run `npm fund` for details Update "system.adapter.alexa2.0" upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript pi@raspberrypi:~ $
