  4. ERROR: Process exited with code 25
56 Beiträge 6 Kommentatoren 6.7k Aufrufe 4 Beobachtet
  • M marcdo70
    @homoran Hab ich doch schon versucht, aber da tut sich nichts. Hab diese Zeile in mein Putty gehauen, aber Fehler bleibt
    @marcdo70 sagte in ERROR: Process exited with code 25:
    aber Fehler bleibt
    und das?
    • M marcdo70
      login as: pi
      pi@192.168.178.74's password:
      Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
      permitted by applicable law.
      Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92
      pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      pi@raspberrypi:~ $
      @marcdo70
      Was sagt
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        @marcdo70
        Was sagt
        marcdo70
        login as: pi
        pi@raspberrypi:~ $ ^C
        pi@raspberrypi:~ $ iob update
        Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
        Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
        Adapter    "backitup"     : 2.4.12   , installed 2.4.12
        Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
        Adapter    "denon"        : 1.13.4   , installed 1.13.4
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.9
        Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "node-red"     : 4.0.0    , installed 4.0.0
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug
        This upgrade of "javascript" will introduce the following changes:
        -> 6.0.3:
        Downgrade Typescript to prevent errors with global typescript scripts
        -> 6.0.2:
        -> 6.0.1:
        Fixed the wizard schedule
        Done small fixes on GUI
        Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y
        Update javascript from @6.0.0 to @6.0.3
        NPM version: 8.19.2
        Installing iobroker.javascript@6.0.3... (System call)
        npm ERR! code ENOTDIR
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/argparse
        npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
        npm ERR! errno -20
        npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
        npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log
        host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236
        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.18.0
        v16.18.0
        8.19.2
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        tty
        /home/pi
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Reading package lists... Done
        Building dependency tree
        11 packages can be upgraded. Run 'apt list --upgradable' to see them.
        nodejs:
          Installed: 16.18.0-deb-1nodesource1
          Candidate: 16.18.0-deb-1nodesource1
          Version table:
         *** 16.18.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
             10.24.0~dfsg-1~deb10u2 500
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $
        • M marcdo70
          login as: pi
          pi@raspberrypi:~ $
          -> 6.0.3:
          -> 6.0.2:
          -> 6.0.1:
          NPM version: 8.19.2
          npm ERR! errno -20
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.18.0
          v16.18.0
          8.19.2
          4.0.23
          pi
          tty
          /home/pi
          nodejs:
            Version table:
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $
          @marcdo70
          Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
          M 2 Antworten Letzte Antwort
            @marcdo70
            marcdo70
            Ja hab ich auch gesehen, Danke
              @marcdo70
              marcdo70
              @thomas-braun sagte in ERROR: Process exited with code 25:
              @marcdo70
              So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
              pi@raspberrypi:~ $ iobroker upgrade alexa2
              This upgrade of "alexa2" will introduce the following changes:
              -> 3.19.10:
              Fix issue in retry handling when rate limit exceeded is returned by Amazon
              Do not clean up Smart Home Device objects for now - delete manually if you remove a device
              Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
              Update alexa2 from @3.19.9 to @3.19.10
              NPM version: 8.19.2
              Installing iobroker.alexa2@3.19.10... (System call)
              host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
              • M marcdo70
                @marcdo70
                -> 3.19.10:
                NPM version: 8.19.2
                @marcdo70
                iobroker update
                iobroker upgrade alexa2 --debug
                  @marcdo70
                  iobroker update
                  marcdo70
                  Geht nicht
                  login as: pi
                  Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92
                  pi@raspberrypi:~ $ iobroker update
                  pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug
                  -> 3.19.10:
                  Do not clean up Smart Home Device objects for now - delete manually if you remov        e a device
                  NPM version: 8.19.2
                  npm ERR! errno -20
                  npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log
                  pi@raspberrypi:~ $
                  • M marcdo70
                    Geht nicht
                    login as: pi
                    -> 3.19.10:
                    NPM version: 8.19.2
                    npm ERR! errno -20
                    pi@raspberrypi:~ $
                    @marcdo70
                    rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                    Loggst du dich für jeden Befehl neu ein?
                      @marcdo70
                      marcdo70
                      Hatte Console ausversehen geschlossen, aber da passiert gar nichts
                      login as: pi
                      -> 3.19.10:
                      NPM version: 8.19.2
                      npm ERR! errno -20
                      pi@raspberrypi:~ $ iobroker upgrade js-controller --debug
                      Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
                      pi@raspberrypi:~ $ iobroker upgrade self
                      Host    "raspberrypi"    is up to date.
                      pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                      pi@raspberrypi:~ $
                      • M marcdo70
                        login as: pi
                        -> 3.19.10:
                        NPM version: 8.19.2
                        npm ERR! errno -20
                        pi@raspberrypi:~ $
                        @marcdo70
                        Da passiert schon was. Die Datei wurde gelöscht.
                        Versuch das Upgrade jetzt nochmal.
                          @marcdo70
                          marcdo70
                          @marcdo70
                          ok
                          pi@raspberrypi:~ $
                          -> 3.19.10:
                          NPM version: 8.19.2
                          npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                          npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                          added 75 packages, removed 13 packages, and changed 95 packages in 23s
                          103 packages are looking for funding
                            run `npm fund` for details
                          Update "system.adapter.alexa2.0"
                          upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                          pi@raspberrypi:~ $
                          Thomas BraunT M 2 Antworten Letzte Antwort
                          • M marcdo70
                            @marcdo70
                            ok
                            pi@raspberrypi:~ $
                            -> 3.19.10:
                            NPM version: 8.19.2
                            pi@raspberrypi:~ $
                            @marcdo70
                            Geht wohl jetzt. Heb den Rest auch auf die aktuelle Version.
                            • M marcdo70
                              @marcdo70
                              ok
                              pi@raspberrypi:~ $
                              -> 3.19.10:
                              NPM version: 8.19.2
                              pi@raspberrypi:~ $
                              marcdo70
                              @marcdo70
                              ok
                              pi@raspberrypi:~ $
                              -> 3.19.10:
                              NPM version: 8.19.2
                              pi@raspberrypi:~ $
                              Hat bei dem Adapter funktioniert wie es aussieht
                                @marcdo70
                                marcdo70
                                @marcdo70
                                Vielen lieben Dank. Gott sei Dank. Das hat echt mein bischen Wissen überfordert.
                                GLG Marcus
