  4. ERROR: Process exited with code 25
56 Beiträge 6 Kommentatoren 6.7k Aufrufe 4 Beobachtet
    @marcdo70
    Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
    11 packages can be upgraded.
    marcdo70
    Ja hab ich auch gesehen, Danke
      @marcdo70
      marcdo70
      @thomas-braun sagte in ERROR: Process exited with code 25:
      @marcdo70
      So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
      pi@raspberrypi:~ $ iobroker upgrade alexa2
      This upgrade of "alexa2" will introduce the following changes:
      -> 3.19.10:
      Fix issue in retry handling when rate limit exceeded is returned by Amazon
      Do not clean up Smart Home Device objects for now - delete manually if you remove a device
      Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
      Update alexa2 from @3.19.9 to @3.19.10
      NPM version: 8.19.2
      Installing iobroker.alexa2@3.19.10... (System call)
      host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
      • M marcdo70
        @marcdo70
        -> 3.19.10:
        NPM version: 8.19.2
        @marcdo70
        iobroker update
        iobroker upgrade alexa2 --debug
          @marcdo70
          iobroker update
          marcdo70
          Geht nicht
          login as: pi
          pi@192.168.178.74's password:
          Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
          permitted by applicable law.
          Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92
          pi@raspberrypi:~ $ iobroker update
          Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
          Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
          Adapter    "backitup"     : 2.4.12   , installed 2.4.12
          Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
          Adapter    "denon"        : 1.13.4   , installed 1.13.4
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug
          -> 3.19.10:
          Do not clean up Smart Home Device objects for now - delete manually if you remov        e a device
          NPM version: 8.19.2
          npm ERR! code ENOTDIR
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/argparse
          npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
          npm ERR! errno -20
          npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
          npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log
          pi@raspberrypi:~ $
          • M marcdo70
            Geht nicht
            login as: pi
            -> 3.19.10:
            NPM version: 8.19.2
            npm ERR! errno -20
            pi@raspberrypi:~ $
            @marcdo70
            rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
            Loggst du dich für jeden Befehl neu ein?
              @marcdo70
              marcdo70
              Hatte Console ausversehen geschlossen, aber da passiert gar nichts
              login as: pi
              -> 3.19.10:
              NPM version: 8.19.2
              npm ERR! errno -20
              pi@raspberrypi:~ $ ^C
              pi@raspberrypi:~ $ iobroker upgrade js-controller --debug
              Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
              pi@raspberrypi:~ $ iobroker upgrade self
              Host    "raspberrypi"    is up to date.
              pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
              pi@raspberrypi:~ $
              • M marcdo70
                login as: pi
                -> 3.19.10:
                NPM version: 8.19.2
                npm ERR! errno -20
                pi@raspberrypi:~ $
                @marcdo70
                Da passiert schon was. Die Datei wurde gelöscht.
                Versuch das Upgrade jetzt nochmal.
                  @marcdo70
                  marcdo70
                  @marcdo70
                  ok
                  pi@raspberrypi:~ $
                  -> 3.19.10:
                  NPM version: 8.19.2
                  npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                  npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                  added 75 packages, removed 13 packages, and changed 95 packages in 23s
                  103 packages are looking for funding
                    run `npm fund` for details
                  Update "system.adapter.alexa2.0"
                  upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                  upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                  upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                  upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                  upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                  upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                  upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                  upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                  upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                  upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                  upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                  upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                  upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                  upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                  upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                  upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                  upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                  upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                  upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                  upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                  upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                  upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                  pi@raspberrypi:~ $
                  Thomas BraunT M 2 Antworten Letzte Antwort
                  • M marcdo70
                    @marcdo70
                    ok
                    pi@raspberrypi:~ $
                    -> 3.19.10:
                    NPM version: 8.19.2
                    pi@raspberrypi:~ $
                    @marcdo70
                    Geht wohl jetzt. Heb den Rest auch auf die aktuelle Version.
                    • M marcdo70
                      @marcdo70
                      ok
                      pi@raspberrypi:~ $
                      -> 3.19.10:
                      NPM version: 8.19.2
                      pi@raspberrypi:~ $
                      marcdo70
                      @marcdo70 sagte in ERROR: Process exited with code 25:
                      @marcdo70
                      ok
                      pi@raspberrypi:~ $
                      -> 3.19.10:
                      NPM version: 8.19.2
                      pi@raspberrypi:~ $
                      Hat bei dem Adapter funktioniert wie es aussieht
                        @marcdo70
                        marcdo70
                        @marcdo70
                        Vielen lieben Dank. Gott sei Dank. Das hat echt mein bischen Wissen überfordert.
                        GLG Marcus
