  4. ERROR: Process exited with code 25
56 Beiträge 6 Kommentatoren 6.7k Aufrufe 4 Beobachtet
  • M marcdo70
    @marcdo70 bizte keine schwarze Briefmarke!
    • M marcdo70
      @marcdo70
      Das ist KonsolenTEXT, den bitte auch als TEXT in CodeTAGS eingebettet posten.
        @marcdo70
        marcdo70
        Sorry, wenn ich wüsste wie das geht. werd es nachlesen
        • M marcdo70
          @marcdo70 https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
            marcdo70
            pi@raspberrypi:~ $ iob update
             Connection is closed.
            Uncaught Rejection: Error: Objects DB is not allowed to start in the current Mul                                              tihost environment
                at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/                                              lib/objects/objectsInRedisClient.js:632:23)
                at processTicksAndRejections (node:internal/process/task_queues:96:5)
             Unable to subscribe to evicted Keyspace events from Redis Server: Connection is                                               closed.
             Unable to subscribe to meta namespace "meta." changes: Connection is closed.
            pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug
            Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
            pi@raspberrypi:~ $ ^C
            pi@raspberrypi:~ $
            • M marcdo70
              pi@raspberrypi:~ $
              @marcdo70 sagte in ERROR: Process exited with code 25:
              von Mul tihost war bisher nicht die Rede
              zieh das putty Fenster mal breiter
              M 2 Antworten Letzte Antwort
                marcdo70
                login as: pi
                pi@192.168.178.74's password:
                Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                permitted by applicable law.
                Last login: Thu Oct 27 15:11:45 2022 from 192.168.178.92
                pi@raspberrypi:~ $
                pi@raspberrypi:~ $
                pi@raspberrypi:~ $
                • M marcdo70
                  login as: pi
                  pi@raspberrypi:~ $
                  pi@raspberrypi:~ $
                  pi@raspberrypi:~ $
                  marcdo70
                  @marcdo70
                  SO? Alles neu für mich gerade
                  • M marcdo70
                    @marcdo70
                    marcdo70
                    @marcdo70
                    login as: pi
                    Last login: Thu Oct 27 15:22:19 2022 from 192.168.178.92
                    Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
                    Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
                    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                    Adapter    "denon"        : 1.13.4   , installed 1.13.4
                    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                    Adapter    "iot"          : 1.11.9   , installed 1.11.9
                    Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                    Controller "js-controller": 4.0.23   , installed 4.0.23
                    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                    Adapter    "text2command" : 2.2.2    , installed 2.2.2
                    Adapter    "wled"         : 0.6.7    , installed 0.6.7
                    This upgrade of "javascript" will introduce the following changes:
                    -> 6.0.3:
                    Downgrade Typescript to prevent errors with global typescript scripts
                    -> 6.0.2:
                    -> 6.0.1:
                    Fixed the wizard schedule
                    Done small fixes on GUI
                    Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y
                    Update javascript from @6.0.0 to @6.0.3
                    NPM version: 8.19.2
                    Installing iobroker.javascript@6.0.3... (System call)
                    npm ERR! code ENOTDIR
                    npm ERR! syscall rename
                    npm ERR! path /opt/iobroker/node_modules/argparse
                    npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
                    npm ERR! errno -20
                    npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
                    npm ERR!     /home/iobroker/.npm/_logs/2022-10-27T15_11_54_736Z-debug-0.log
                    host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236
                    pi@raspberrypi:~ $
                      marcdo70
                      Ich komm nicht dahinter warum ich immer code25 Abruch bekomme und den ALexa2 und den Script Adapter nicht updaten kann, so funktioniert leider meine Spachausgabe auf meiner Alexa nicht mehr. Was kann ich tun?
                      • M marcdo70
                          marcdo70
                          schrieb am zuletzt editiert von marcdo70
                          @homoran Hab ich doch schon versucht, aber da tut sich nichts. Hab diese Zeile in mein Putty gehauen, aber Fehler bleibt
                          • M marcdo70
                            Sorry, hab kein Ergebnis gesehen
                              marcdo70
                              login as: pi
                              Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92
                              pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                              pi@raspberrypi:~ $
                              • M marcdo70
                                aber Fehler bleibt
                                und das?
                                • M marcdo70
                                  login as: pi
                                  pi@raspberrypi:~ $
                                  @marcdo70
                                  Was sagt
                                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    @marcdo70
                                    Was sagt
                                    marcdo70
                                    login as: pi
                                    pi@raspberrypi:~ $
                                    -> 6.0.3:
                                    -> 6.0.2:
                                    -> 6.0.1:
                                    NPM version: 8.19.2
                                    npm ERR! errno -20
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log
                                    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.18.0
                                    v16.18.0
                                    8.19.2
                                    4.0.23
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                    tty
                                    /home/pi
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                    Reading package lists... Done
                                    Building dependency tree
                                    11 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    nodejs:
                                      Installed: 16.18.0-deb-1nodesource1
                                      Candidate: 16.18.0-deb-1nodesource1
                                      Version table:
                                     *** 16.18.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                         10.24.0~dfsg-1~deb10u2 500
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $
                                    • M marcdo70
                                      login as: pi
                                      pi@raspberrypi:~ $
                                      -> 6.0.3:
                                      -> 6.0.2:
                                      -> 6.0.1:
                                      NPM version: 8.19.2
                                      npm ERR! errno -20
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.0
                                      v16.18.0
                                      8.19.2
                                      4.0.23
                                      pi
                                      tty
                                      /home/pi
                                      nodejs:
                                        Version table:
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $
                                      @marcdo70
                                      Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
                                        @marcdo70
                                        marcdo70
                                        Ja hab ich auch gesehen, Danke
                                          @marcdo70
                                          marcdo70
                                          @thomas-braun sagte in ERROR: Process exited with code 25:
                                          @marcdo70
                                          So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
                                          pi@raspberrypi:~ $ iobroker upgrade alexa2
                                          This upgrade of "alexa2" will introduce the following changes:
                                          -> 3.19.10:
                                          Fix issue in retry handling when rate limit exceeded is returned by Amazon
                                          Do not clean up Smart Home Device objects for now - delete manually if you remove a device
                                          Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
                                          Update alexa2 from @3.19.9 to @3.19.10
                                          NPM version: 8.19.2
                                          Installing iobroker.alexa2@3.19.10... (System call)
                                          host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
