  3. Einsteigerfragen
  4. Installation
  5. Installation echt nicht möglich...
Geplant Angeheftet Gesperrt Verschoben Installation
45 Beiträge 9 Kommentatoren 6.7k Aufrufe 9 Beobachtet
    @hammer-klaus
    Bitte in CodeTags. Danke.
    Hammer KlausH Offline
    Hammer Klaus
    pi@iobroker-pi:~ $ free -ht --mega
    Mem:           972M        533M        135M        6.0M        303M        447M
    Swap:           99M          0B         99M
    Total:         1.1G        533M        235M
    • Hammer KlausH Hammer Klaus
      Swap:           99M          0B         99M
      @hammer-klaus
      Das schaut erstmal gesund aus.
      Ist da der ioBroker drauf?
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      iobroker status
      iobroker update
      anschauen.
      Hammer KlausH 1 Antwort Letzte Antwort
        @hammer-klaus
        iobroker status
        iobroker update
        anschauen.
        Hammer Klaus
        pi@iobroker-pi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.20.0
        v14.20.0
        6.14.17
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        /home/pi
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
        Reading package lists... Done
        Building dependency tree
        111 packages can be upgraded. Run 'apt list --upgradable' to see them.
        nodejs:
          Installed: 14.20.0-deb-1nodesource1
          Candidate: 14.20.1-deb-1nodesource1
          Version table:
             14.20.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         *** 14.20.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
        pi@iobroker-pi:~ $ iobroker status
        Objects type: jsonl
        States  type: jsonl
        pi@iobroker-pi:~ $ iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.22
        Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.20.0
          v14.20.0
          6.14.17
          4.0.23
          pi
          /home/pi
          nodejs:
            Version table:
          Objects type: jsonl
          States  type: jsonl
          @hammer-klaus sagte in Installation echt nicht möglich...:
          Dann mach das mal zuerst.
            Hammer Klaus
            Das wird was dauern. Weil ich vorher ein Image der installation mache.
              @hammer-klaus
              Mach was du willst. Aber halte die Kiste auf Stand.
                Zuerst: Ich habe iobroker schon eine Weile mit einem Raspi im Einsatz. Vor einem halben Jahre musste ein Modul aktualisiert werden, dabei ist die komplette Installation zerschossen worden. Da ich keine Lust hatte alles neu auf zu setzen, lag das ganze hier eine Weile rum.
                Genervt davon, dass meine Automation nicht läuft, habe ich iobroker neu auf dem Raspi4 installiert, alles neu gemacht.
                Prima. --- für 2 tage. iobroker bleibt einfach hängen. Nix mehr. Raspi reagiert auf nix.
                -> Netzeil getauscht, Raspi getauscht. Ergebnis: immer das selbe.
                Laut Foren habe ich zu viel Adapter für den Raspi, das kann der nicht. (Ich habe noch gar nicht richtig angefangen was zu machen. nur ein paar Daten loggen für Grafen etc.
                Also: Eigenen Rechner aufgesetzt: Linux Mint21
                Docker installiert und Docker Version drauf.
                Geht, bis man VIS versucht. Docker bzw dieser Container weigert sich, den Port 8082 frei zu geben. Trotz verschiedener Anleitungen im Web. (die Config Datei für die Porets habe ich .json korrekt bearbeitet)
                Keine Lust mehr auf Docker Dreck.
                Also: Docker runter und das tolle Install Script gestartet.
                Am Ende Fehlermeldung:
                Installing ioBroker (3/4)
                npm ERR! code 1
                npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! command failed
                npm ERR! command sh /tmp/install-0b2854f4.sh
                npm ERR! node:internal/modules/cjs/loader:959
                npm ERR! throw err;
                npm ERR! ^
                npm ERR!
                npm ERR! Error: Cannot find module 'winston'
                npm ERR! Require stack:
                npm ERR! - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
                npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
                npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                npm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19)
                npm ERR! at require (node:internal/modules/cjs/helpers:102:18)
                npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:3:15)
                npm ERR! at Module._compile (node:internal/modules/cjs/loader:1126:14)
                npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                npm ERR! at Module.load (node:internal/modules/cjs/loader:1004:32)
                npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19) {
                npm ERR! code: 'MODULE_NOT_FOUND',
                npm ERR! requireStack: [
                npm ERR! '/opt/iobroker/node_modules/winston-daily-rotate-file/index.js',
                npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js',
                npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                npm ERR! ]
                npm ERR! }
                npm ERR! /home/iobroker/.npm/_logs/2022-09-27T07_30_51_414Z-debug-0.log
                Finalizing installation (4/4)
                Enabling autostart...
                Autostart enabled!
                ioBroker was installed successfully
                Open http://172.xx.xxx.xx:8081 in a browser and start configuring!
                Die Seite liefert natürlich kein Ergebnis, weil die Install schon kaputt ist.
                Meine farge ist jetzt: Ist das der Satus von iobroker: Sollte auf nem raspi laufen, wenn man es nicht nutzt, im Docker nur ohne VIS und das Installations Script ist nur zur Tarnung?
                Sorry, aber ich bin gerade massiv angenervt.
                crunchipC Abwesend
                crunchipC Abwesend
                und was zeigt z.b. das log, irgendwo muss es ja dann klemmen
                  @haselchen Das hat eich ja geschrieben, laut Posts zu schwach also separaten PC aufgesetzt mit Linux Mint21
                  Das Docker image installiert und konfiguriert.
                  • Nur dass der hm-rpc Adapter die eigene Netzwerkkarte nicht sieht und der Meinung ist eine 172.18.0.2 zugewiesen zu haben. Daher läuft die Konfig dessen vor die Wand.
                  • VIS ist nicht ansprechbar, weil der Port im Docker nicht freigegeben ist. (Installation nach https://hub.docker.com/r/buanet/iobroker/) Trotz verschiedener Recherchen lässt sich die Portfreigabe für 8082 nicht realisieren (Wird nicht übernommen)
                  Und die Script Installation schlägt auch fehl.
                  da_WoodyD Offline
                  da_WoodyD Offline
                  da_Woody
                  warum? entweder direkt unter debian ioB insten, oder proxmox und dann eine VM drauf.
                  was soll das docker dingens?
                  gruß vom Woody
                  • da_WoodyD da_Woody
                    Hammer Klaus
                    @da_woody
                    Weil das Docker Ding als offizielle Version angegeben ist:
                    https://www.iobroker.net/#de/download
                    Und das Installationsscript:
                    curl -sLf https://iobroker.net/install.sh | bash -
                    Vor die Wand fährt.
                    Wenn ich eine fertige VM hätte, wäre ich froh.
                      @da_woody
                      Vor die Wand fährt.
                      da_WoodyD Offline
                      da_WoodyD Offline
                      da_Woody
                      @hammer-klaus darum frag ich ja. du hast einen rechner.
                      inste dort debian, https://www.debian.org/releases/bullseye/installmanual und dann ioB mit der zeile.
                      das hat doch nix mit docker zu tun! docker hat nichts mit linux zu tun.
                      gruß vom Woody
                        Hammer Klaus
                        @da_woody
                        Sag mal, Du hast schon gelesen, das das Script nicht läuft, oder?
                        Siehe Post von @Jey-Cee
                        https://forum.iobroker.net/topic/58380/installation-echt-nicht-möglich/11?_=1664282299559
                        Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
                          @da_woody
                          Versuch mal die 64bit-Version vom Raspberry OS.
                            Hammer Klaus
                            Wir hatten heute Morgen festgestellt, dass mein Raspi 3 zu schwach ist. Also: Warum soll ich jetzt da ein anderes RaspiOS drauf tun?
                            Das IOBroker Image läuft, hängt nur alle 48h
                            Für den Preis eines Raspi 4 kann ich aktuell jemanden einstellen, der durchs Haus läuft und Schalter drückt.
                            Auf einem echten Rechner mit Linux xyz läuft das Installscript vor die Wand.
                            Der Docker Container ist nutzlos.
                            Also warte ich, bis irgendwann der Fehler mit NPM behoben ist (siehe post von @Jey-Cee ) und dann installiere ich das auf einem Rechner.
                              @hammer-klaus
                              Ich kann dir nicht folgen, mit welchem System du da gerade zugange bist.
                              Rpi... Docker... Native Installation...
                              Den 'Fehler' mit dem Zugriff auf das /tmp-Verzeichnis kenne ich nur aus einem anderen Zusammenhang. Da lief es mit dem 64bit RPI-OS, mit der 32bit-Version klemmte es.
                                @da_woody
                                da_WoodyD Offline
                                da_WoodyD Offline
                                da_Woody
                                @hammer-klaus so, hab mir den spaß angetan. neue VM in proxmox geschnitzt, debian. danach deine, die richtige zeile eingegeben in putty.
                                was funktioniert da nicht?
                                gruß vom Woody
                                  Hammer Klaus
                                  @da_woody
                                  Ich verwende ein Linux Mint. und bekomme die Fehlermeldung:
                                  npm ERR! code 1
                                  npm ERR! throw err;
                                  npm ERR! ^
                                  npm ERR!
                                  npm ERR! ]
                                  npm ERR! }
                                  Autostart enabled!
                                  O.K. allso mache ich das System platt und probiere es mit Debian erneut... :-/
                                  da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                                    @hammer-klaus
                                    Hammer Klaus
                                    Ich habe alles drei ausprobiert.
                                    Noch bevor ich den ersten Post abgeschickt habe.
                                      @da_woody
                                      npm ERR! code 1
                                      npm ERR! throw err;
                                      npm ERR! ^
                                      npm ERR!
                                      npm ERR! ]
                                      npm ERR! }
                                      Autostart enabled!
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      da_Woody
                                      @hammer-klaus könntest du dein log in 6c8d18e7-93c5-44dc-b545-b0cfbaa752e8-grafik.png stellen, so ist das unleserlich... ;)
                                      und was sagt dein browser nach dem aufruf?
                                      nebenbei, lass das xxxen. mit deiner internen IP kann keiner was anfangen.
                                      gruß vom Woody
                                        Hammer Klaus
                                        @da_woody
                                        Der Browser sagt: Da läuft nix.
                                          @da_woody
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          da_Woody
                                          @hammer-klaus wie schon geschrieben, wenn dein rechner power hat, du noch mehr VMs haben möchtest, dann hau proxmox drauf und dann eben VMs. wenn nicht debian und dann mit dem einzeiler ioB.
                                          gruß vom Woody
