  3. Einsteigerfragen
  4. Installation
  5. Installation echt nicht möglich...
Geplant Angeheftet Gesperrt Verschoben Installation
45 Beiträge 9 Kommentatoren 6.7k Aufrufe 9 Beobachtet
  • Hammer KlausH Hammer Klaus
    @da_woody
    Ich verwende ein Linux Mint. und bekomme die Fehlermeldung:
    Installing ioBroker (3/4)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh /tmp/install-0b2854f4.sh
    npm ERR! node:internal/modules/cjs/loader:959
    npm ERR! throw err;
    npm ERR! ^
    npm ERR!
    npm ERR! Error: Cannot find module 'winston'
    npm ERR! Require stack:
    npm ERR! - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    npm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
    npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19)
    npm ERR! at require (node:internal/modules/cjs/helpers:102:18)
    npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:3:15)
    npm ERR! at Module._compile (node:internal/modules/cjs/loader:1126:14)
    npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    npm ERR! at Module.load (node:internal/modules/cjs/loader:1004:32)
    npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:839:12)
    npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19) {
    npm ERR! code: 'MODULE_NOT_FOUND',
    npm ERR! requireStack: [
    npm ERR! '/opt/iobroker/node_modules/winston-daily-rotate-file/index.js',
    npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js',
    npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
    npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
    npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    npm ERR! ]
    npm ERR! }
    npm ERR! /home/iobroker/.npm/_logs/2022-09-27T07_30_51_414Z-debug-0.log
    Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
    ioBroker was installed successfully
    Open http://172.xx.xxx.xx:8081 in a browser and start configuring!
    O.K. allso mache ich das System platt und probiere es mit Debian erneut... :-/
    #41
    @hammer-klaus sagte in Installation echt nicht möglich...:
    Dann verwende das 'Original', Debian Bullseye (die Version ohne Desktop natürlich).
    Hammer KlausH 1 Antwort Letzte Antwort
      Zuerst: Ich habe iobroker schon eine Weile mit einem Raspi im Einsatz. Vor einem halben Jahre musste ein Modul aktualisiert werden, dabei ist die komplette Installation zerschossen worden. Da ich keine Lust hatte alles neu auf zu setzen, lag das ganze hier eine Weile rum.
      Genervt davon, dass meine Automation nicht läuft, habe ich iobroker neu auf dem Raspi4 installiert, alles neu gemacht.
      Prima. --- für 2 tage. iobroker bleibt einfach hängen. Nix mehr. Raspi reagiert auf nix.
      -> Netzeil getauscht, Raspi getauscht. Ergebnis: immer das selbe.
      Laut Foren habe ich zu viel Adapter für den Raspi, das kann der nicht. (Ich habe noch gar nicht richtig angefangen was zu machen. nur ein paar Daten loggen für Grafen etc.
      Also: Eigenen Rechner aufgesetzt: Linux Mint21
      Docker installiert und Docker Version drauf.
      Geht, bis man VIS versucht. Docker bzw dieser Container weigert sich, den Port 8082 frei zu geben. Trotz verschiedener Anleitungen im Web. (die Config Datei für die Porets habe ich .json korrekt bearbeitet)
      Keine Lust mehr auf Docker Dreck.
      Also: Docker runter und das tolle Install Script gestartet.
      Am Ende Fehlermeldung:
      npm ERR! code 1
      npm ERR! throw err;
      npm ERR! ^
      npm ERR!
      npm ERR! ]
      npm ERR! }
      Autostart enabled!
      Die Seite liefert natürlich kein Ergebnis, weil die Install schon kaputt ist.
      Meine farge ist jetzt: Ist das der Satus von iobroker: Sollte auf nem raspi laufen, wenn man es nicht nutzt, im Docker nur ohne VIS und das Installations Script ist nur zur Tarnung?
      Sorry, aber ich bin gerade massiv angenervt.
      haus-automatisierungH Offline
      #42
      Nein 172 ist NICHt ungewöhnlich. Ich betreibe mein privates Netz seit 25 Jahren mit 172.17.100.x
      Darauf achten, dass das Docker bridge Netzwerk nicht mit deinem Adressbereich kollidiert:
      Usually Docker uses the default 172.17. 0.0/16 subnet for container networking.
      📚 Meine Dokumentation
        Hammer KlausH Offline
        Hammer Klaus
        #43
        So, gute Nachrichten. Mit Debian Bullseye läuft es.
        Adapter installieren geht prima von der Hand. Jetzt noch die Konfig übertragen...
        @all Danke für die verschiedenen Hinweise.
        evtl. sollte man auf der Seite https://www.iobroker.net/#de/download Den Hinweis: "Am besten mit Debian" unterbringen und bei Raspi: Raspi3 zum Ausprobieren, Raspi 4 für ernsthaften Einsatz benötigt.
        Docker: Nur bei ausreichender Docker Erfahrung verwenden..
        crunchipC AlCalzoneA 2 Antworten Letzte Antwort
          crunchipC Abwesend
          crunchipC Abwesend
          #44
          @hammer-klaus steht doch in der Doku
          https://www.iobroker.net/#de/documentation/install/linux.md
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #45
            Naja... mein Produktivsystem läuft auch seit Jahren mit Raspi 3 stabil. Man darf ihn halt nicht zu voll packen.
