  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
    @funkytown
    Dann die Version für Erwachsene:
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
    funkytownF Offline
    funkytownF Offline
    funkytown
    #41
    kann immer noch nicht zugreifen!
    markus@rpi:~ $ iobroker fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    [sudo] Passwort für markus:
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://dl.yarnpkg.com/debian stable InRelease
    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
    Created /etc/sudoers.d/iobroker
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
    markus@rpi:~ $ iobroker start
    markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    markus@rpi:~ $ iobroker upgrade admin --debug
    Adapter "admin"          is up to date.
    markus@rpi:~ $
    Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
    • funkytownF funkytown
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      markus@rpi:~ $
      #42
      @funkytown
      iobroker update
      iobroker list instances
      GlasfaserG funkytownF 2 Antworten Letzte Antwort
        @funkytown
        iobroker update
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #43
        habe hier nur kurz reingeschaut ... sehe immer stop .. start.
        Wurde mal ein Reboot durchgeführt.
          @funkytown
          iobroker update
          funkytownF Offline
          funkytownF Offline
          funkytown
          #44
          markus@rpi:~ $ iobroker update
          #Used repository: stable
          Adapter    "admin"        : 6.2.22   , installed 6.2.22
          Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
          Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
          Adapter    "cloud"        : 4.2.2    , installed 4.2.2
          Adapter    "cul"          : 2.0.2    , installed 2.0.2
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "email"        : 1.1.3    , installed 1.1.3
          Adapter    "history"      : 2.2.0    , installed 2.2.0
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
          Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "linux-control": 1.1.3    , installed 1.1.5
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
          Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
          Adapter    "radar2"       : 2.0.3    , installed 2.0.3
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
          Adapter    "scenes"       : 2.3.9    , installed 2.3.9
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "socketio"     : 4.2.0    , installed 4.2.0
          Adapter    "synology"     : 2.1.9    , installed 2.1.9
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
          Adapter    "web"          : 4.3.0    , installed 4.3.0
          Adapter    "withings"     : 0.0.9    , installed 0.0.9
          Adapter    "ws"           : 1.3.0    , installed 1.3.0
          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
          markus@rpi:~ $ iobroker list instances
          + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
          + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
          + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
          + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
            system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
          + system.adapter.email.0                  : email                 : rpi                                      -  enabled
          + system.adapter.history.0                : history               : rpi                                      -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
          + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
          + system.adapter.info.0                   : info                  : rpi                                      -  enabled
          + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
          + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
          + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
            system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
          + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
          + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
            system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
          + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
            system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : rpi                                      - disabled
          + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
            system.adapter.vis.0                    : vis                   : rpi                                      - disabled
          + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.withings.0               : withings              : rpi                                      - disabled
            system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
          + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
          + instance is alive
          markus@rpi:~ $
            + instance is alive
            markus@rpi:~ $
            #45
            @funkytown
            Läuft.
            Zieh die updates der anderen Adapter noch nach.
              @funkytown
              Läuft.
              funkytownF Offline
              funkytownF Offline
              funkytown
              #46
              Der ioBroker ist wieder über Port 8081 erreichbar :-)
              Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
              Vielen Dank Thomas Braun!
                @funkytown
                Läuft.
                funkytownF Offline
                funkytownF Offline
                funkytown
                #47
                Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
                • Thomas BraunT Online
                  #48
                  @funkytown sagte in iobroker restore 0 funktioniert nicht:
                  Wann?
                    Wann?
                    funkytownF Offline
                    funkytownF Offline
                    funkytown
                    #49
                    nach einem reboot des System. War auf 8081 nicht erreichbar, und nach einem Start des admin.0 über die command line funktionierte wieder alles.
                      Wann?
                      funkytownF Offline
                      funkytownF Offline
                      funkytown
                      #50
                      ausserdem ist der alte admin 6.2.20 wieder installiert obwohl doch der 6.2.22 bereits installiert wurde!
                        #51
                        @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
                        sagt?
                        funkytownF 1 Antwort Letzte Antwort
                          sagt?
                          funkytownF Offline
                          funkytownF Offline
                          funkytown
                          #52
                          Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                          Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                          markus@rpi:~ $
                          + instance is alive
                          markus@rpi:~ $
                            markus@rpi:~ $
                            + instance is alive
                            markus@rpi:~ $
                            #53
                            @funkytown
                            Kann es sein, dass du da zwei Systeme parallel installiert hast und mal in das eine und mal in das andere bootest?
                              @funkytown
                              funkytownF Offline
                              funkytownF Offline
                              funkytown
                              #54
                              aber wie soll das denn passieren?
                              ABER, das war ja auch mit der cmdline.txt merkwürdig!!! Ich weiß, dass ich den Eintrag mit der UUID geändert hatte, und plötzlich stand wieder was anderes drin.
                                @funkytown
                                funkytownF Offline
                                funkytownF Offline
                                funkytown
                                #55
                                Mir ist aber auch aufgefallen, dass das system nach einem reboot mal sehr schnell und dann wiederum sehr lange braucht bis ich drauf zugreifen kann. Ich denke du hast recht mit deiner Vermutung. Verstehen tue ich es aber nicht :-)
                                  #56
                                  @funkytown
                                  Du hast doch da eine SD-Karte und noch irgendwas als Speichermedium dran. Nimm halt eins raus.
                                    @funkytown
                                    funkytownF Offline
                                    funkytownF Offline
                                    funkytown
                                    #57
                                    Ich habe eine SSD-Platte und ein USB-Stick dran hängen. Da ich mir sicher bin damals das System umgestellt habe damit es von der SSD-Platte bootet, werde ich jetzt mal den USB-Stick heraus nehmen.
                                      #58
                                      Zuerst umounten. Oder herunterfahren.
                                        funkytownF Offline
                                        funkytownF Offline
                                        funkytown
                                        #59
                                        ich fahre das System herunter.
                                          #60
                                          @funkytown
                                          Da sind drei Speichermedien drin. Eine SD-Karte steckt auch noch drin.
                                          Und die ist ebenso bootbar wie der USB_Stock auf /dev/sda1
