  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
    @funkytown
    iobroker update
    iobroker list instances
    funkytownF Offline
    funkytownF Offline
    funkytown
    markus@rpi:~ $ iobroker update
    #Used repository: stable
    Adapter    "admin"        : 6.2.22   , installed 6.2.22
    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
    Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
    Adapter    "cul"          : 2.0.2    , installed 2.0.2
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
    Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "linux-control": 1.1.3    , installed 1.1.5
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
    Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.9
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "withings"     : 0.0.9    , installed 0.0.9
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    markus@rpi:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
    + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
    + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
    + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
      system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
    + system.adapter.email.0                  : email                 : rpi                                      -  enabled
    + system.adapter.history.0                : history               : rpi                                      -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
    + system.adapter.info.0                   : info                  : rpi                                      -  enabled
    + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
    + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
    + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
      system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
    + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
    + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
      system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
      system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : rpi                                      - disabled
    + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
      system.adapter.vis.0                    : vis                   : rpi                                      - disabled
    + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.withings.0               : withings              : rpi                                      - disabled
      system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
    + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
    + instance is alive
    markus@rpi:~ $
    Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
    • funkytownF funkytown
      + instance is alive
      markus@rpi:~ $
      @funkytown
      Läuft.
      Zieh die updates der anderen Adapter noch nach.
      funkytownF 2 Antworten Letzte Antwort
        @funkytown
        Läuft.
        funkytownF Offline
        funkytownF Offline
        funkytown
        Der ioBroker ist wieder über Port 8081 erreichbar :-)
        Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
        Vielen Dank Thomas Braun!
          @funkytown
          Läuft.
          funkytownF Offline
          funkytownF Offline
          funkytown
          Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
          • Thomas BraunT Online
            @funkytown sagte in iobroker restore 0 funktioniert nicht:
            Wann?
              Wann?
              funkytownF Offline
              funkytownF Offline
              funkytown
              nach einem reboot des System. War auf 8081 nicht erreichbar, und nach einem Start des admin.0 über die command line funktionierte wieder alles.
                Wann?
                funkytownF Offline
                funkytownF Offline
                funkytown
                ausserdem ist der alte admin 6.2.20 wieder installiert obwohl doch der 6.2.22 bereits installiert wurde!
                  @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
                  sagt?
                  funkytownF 1 Antwort Letzte Antwort
                    sagt?
                    funkytownF Offline
                    funkytownF Offline
                    funkytown
                    Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                    Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                    markus@rpi:~ $
                    + instance is alive
                    markus@rpi:~ $
                      markus@rpi:~ $
                      + instance is alive
                      markus@rpi:~ $
                      @funkytown
                      Kann es sein, dass du da zwei Systeme parallel installiert hast und mal in das eine und mal in das andere bootest?
                        @funkytown
                        funkytownF Offline
                        funkytownF Offline
                        funkytown
                        aber wie soll das denn passieren?
                        ABER, das war ja auch mit der cmdline.txt merkwürdig!!! Ich weiß, dass ich den Eintrag mit der UUID geändert hatte, und plötzlich stand wieder was anderes drin.
                          @funkytown
                          funkytownF Offline
                          funkytownF Offline
                          funkytown
                          Mir ist aber auch aufgefallen, dass das system nach einem reboot mal sehr schnell und dann wiederum sehr lange braucht bis ich drauf zugreifen kann. Ich denke du hast recht mit deiner Vermutung. Verstehen tue ich es aber nicht :-)
                            @funkytown
                            Du hast doch da eine SD-Karte und noch irgendwas als Speichermedium dran. Nimm halt eins raus.
                              @funkytown
                              funkytownF Offline
                              funkytownF Offline
                              funkytown
                              Ich habe eine SSD-Platte und ein USB-Stick dran hängen. Da ich mir sicher bin damals das System umgestellt habe damit es von der SSD-Platte bootet, werde ich jetzt mal den USB-Stick heraus nehmen.
                                Zuerst umounten. Oder herunterfahren.
                                  funkytownF Offline
                                  funkytownF Offline
                                  funkytown
                                  ich fahre das System herunter.
                                    @funkytown
                                    Da sind drei Speichermedien drin. Eine SD-Karte steckt auch noch drin.
                                    Und die ist ebenso bootbar wie der USB_Stock auf /dev/sda1
                                      @funkytown
                                      funkytownF Offline
                                      funkytownF Offline
                                      funkytown
                                      soweit ich mich erinnern kann boote ich tatsächlich das System von der SD-Karte aber das Root-System liegt auf der SSD-Platte. Die root Partition ist auch nach wie vor auf der SSD-Platte. Ich habe auch nur einmal den iobroker installiert. Wo ist denn vermerkt, dass der admin.0 sofort starten soll?
                                      Komisch, in der aktuellen fstab verweist /dev/sdb1 auf root obwohl es sdb1 eigentlich nicht gibt!
                                      markus@rpi:/boot $ cat /boot/cmdline.txt
                                      dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      markus@rpi:/boot $ blkid
                                      /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                                      /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                                      /dev/sda1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                                      /dev/sda2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                                      markus@rpi:/opt/iobroker $ cat /etc/fstab
                                      proc            /proc           proc    defaults          0       0
                                      PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                                      #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                                      # a swapfile is not a swap partition, no line here
                                      #   use  dphys-swapfile swap[on|off]  for that
                                      /dev/sdb1       /               ext4    defaults,noatime  0       1
                                      /dev/sdb2       swap            swap    defaults          0       0
