  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
  • funkytownF funkytown
    kann immer noch nicht zugreifen!
    markus@rpi:~ $ iobroker fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    [sudo] Passwort für markus:
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://dl.yarnpkg.com/debian stable InRelease
    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    markus@rpi:~ $ iobroker start
    markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    markus@rpi:~ $ iobroker upgrade admin --debug
    Adapter "admin"          is up to date.
    markus@rpi:~ $
    @funkytown
    iobroker update
    iobroker list instances
    GlasfaserG funkytownF 2 Antworten Letzte Antwort
      @funkytown
      iobroker update
      GlasfaserG Offline
      GlasfaserG Offline
      habe hier nur kurz reingeschaut ... sehe immer stop .. start.
      Wurde mal ein Reboot durchgeführt.
        @funkytown
        iobroker update
        funkytownF Offline
        funkytownF Offline
        funkytown
        markus@rpi:~ $ iobroker update
        #Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.22
        Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
        Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
        Adapter    "cloud"        : 4.2.2    , installed 4.2.2
        Adapter    "cul"          : 2.0.2    , installed 2.0.2
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
        Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "linux-control": 1.1.3    , installed 1.1.5
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
        Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "synology"     : 2.1.9    , installed 2.1.9
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "withings"     : 0.0.9    , installed 0.0.9
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        markus@rpi:~ $ iobroker list instances
        + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
        + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
        + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
        + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
          system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
        + system.adapter.email.0                  : email                 : rpi                                      -  enabled
        + system.adapter.history.0                : history               : rpi                                      -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
        + system.adapter.info.0                   : info                  : rpi                                      -  enabled
        + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
        + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
        + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
          system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
        + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
        + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
          system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
          system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : rpi                                      - disabled
        + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
          system.adapter.vis.0                    : vis                   : rpi                                      - disabled
        + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.withings.0               : withings              : rpi                                      - disabled
          system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
        + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
        + instance is alive
        markus@rpi:~ $
        Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
          + instance is alive
          markus@rpi:~ $
          @funkytown
          Läuft.
          Zieh die updates der anderen Adapter noch nach.
            @funkytown
            Läuft.
            funkytownF Offline
            funkytownF Offline
            funkytown
            Der ioBroker ist wieder über Port 8081 erreichbar :-)
            Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
            Vielen Dank Thomas Braun!
              @funkytown
              Läuft.
              funkytownF Offline
              funkytownF Offline
              funkytown
              Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
              • Thomas BraunT Online
                @funkytown sagte in iobroker restore 0 funktioniert nicht:
                Wann?
                  Wann?
                  funkytownF Offline
                  funkytownF Offline
                  funkytown
                  nach einem reboot des System. War auf 8081 nicht erreichbar, und nach einem Start des admin.0 über die command line funktionierte wieder alles.
                    Wann?
                    funkytownF Offline
                    funkytownF Offline
                    funkytown
                    ausserdem ist der alte admin 6.2.20 wieder installiert obwohl doch der 6.2.22 bereits installiert wurde!
                      @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
                      sagt?
                      funkytownF 1 Antwort Letzte Antwort
                        sagt?
                        funkytownF Offline
                        funkytownF Offline
                        funkytown
                        Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                        Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                        markus@rpi:~ $
                        + instance is alive
                        markus@rpi:~ $
                          markus@rpi:~ $
                          + instance is alive
                          markus@rpi:~ $
                          @funkytown
                          Kann es sein, dass du da zwei Systeme parallel installiert hast und mal in das eine und mal in das andere bootest?
                            @funkytown
                            funkytownF Offline
                            funkytownF Offline
                            funkytown
                            aber wie soll das denn passieren?
                            ABER, das war ja auch mit der cmdline.txt merkwürdig!!! Ich weiß, dass ich den Eintrag mit der UUID geändert hatte, und plötzlich stand wieder was anderes drin.
                              @funkytown
                              funkytownF Offline
                              funkytownF Offline
                              funkytown
                              Mir ist aber auch aufgefallen, dass das system nach einem reboot mal sehr schnell und dann wiederum sehr lange braucht bis ich drauf zugreifen kann. Ich denke du hast recht mit deiner Vermutung. Verstehen tue ich es aber nicht :-)
                                @funkytown
                                Du hast doch da eine SD-Karte und noch irgendwas als Speichermedium dran. Nimm halt eins raus.
                                  @funkytown
                                  funkytownF Offline
                                  funkytownF Offline
                                  funkytown
                                  Ich habe eine SSD-Platte und ein USB-Stick dran hängen. Da ich mir sicher bin damals das System umgestellt habe damit es von der SSD-Platte bootet, werde ich jetzt mal den USB-Stick heraus nehmen.
                                    Zuerst umounten. Oder herunterfahren.
                                      funkytownF Offline
                                      funkytownF Offline
                                      funkytown
                                      ich fahre das System herunter.
                                        @funkytown
                                        Da sind drei Speichermedien drin. Eine SD-Karte steckt auch noch drin.
                                        Und die ist ebenso bootbar wie der USB_Stock auf /dev/sda1
                                          @funkytown
                                          funkytownF Offline
                                          funkytownF Offline
                                          funkytown
                                          soweit ich mich erinnern kann boote ich tatsächlich das System von der SD-Karte aber das Root-System liegt auf der SSD-Platte. Die root Partition ist auch nach wie vor auf der SSD-Platte. Ich habe auch nur einmal den iobroker installiert. Wo ist denn vermerkt, dass der admin.0 sofort starten soll?
                                          Komisch, in der aktuellen fstab verweist /dev/sdb1 auf root obwohl es sdb1 eigentlich nicht gibt!
                                          markus@rpi:/boot $ cat /boot/cmdline.txt
                                          dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          markus@rpi:/boot $ blkid
                                          /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                                          /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                                          /dev/sda1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                                          /dev/sda2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                                          markus@rpi:/opt/iobroker $ cat /etc/fstab
                                          proc            /proc           proc    defaults          0       0
                                          PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                                          #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                                          # a swapfile is not a swap partition, no line here
                                          #   use  dphys-swapfile swap[on|off]  for that
                                          /dev/sdb1       /               ext4    defaults,noatime  0       1
                                          /dev/sdb2       swap            swap    defaults          0       0
